root/radiance/ray/src/hd/rholo3.c
Revision: 3.1
Committed: Fri Oct 31 10:23:29 1997 UTC (26 years, 7 months ago) by gregl
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for tracking beam compuatations
9 */
10
11 #include "rholo.h"
12
13
14 #define abs(x) ((x) > 0 ? (x) : -(x))
15 #define sgn(x) ((x) > 0 ? 1 : (x) < 0 ? -1 : 0)
16
17
18 static PACKHEAD *complist; /* list of beams to compute */
19 static int complen; /* length of complist */
20 static int listpos; /* current list position for next_pack */
21 static int lastin; /* last ordered position in list */
22
23
24 int
25 weightf(hp, x0, x1, x2) /* voxel weighting function */
26 register HOLO *hp;
27 register int x0, x1, x2;
28 {
29 switch (vlet(OCCUPANCY)) {
30 case 'U': /* uniform weighting */
31 return(1);
32 case 'C': /* center weighting (crude) */
33 x0 += x0 - hp->grid[0] + 1;
34 x0 = abs(x0)*hp->grid[1]*hp->grid[2];
35 x1 += x1 - hp->grid[1] + 1;
36 x1 = abs(x1)*hp->grid[0]*hp->grid[2];
37 x2 += x2 - hp->grid[2] + 1;
38 x2 = abs(x2)*hp->grid[0]*hp->grid[1];
39 return(hp->grid[0]*hp->grid[1]*hp->grid[2] -
40 (x0+x1+x2)/3);
41 default:
42 badvalue(OCCUPANCY);
43 }
44 }
45
46
47 /* The following is by Daniel Cohen, taken from Graphics Gems IV, p. 368 */
48 long
49 lineweight(hp, x, y, z, dx, dy, dz) /* compute weights along a line */
50 HOLO *hp;
51 int x, y, z, dx, dy, dz;
52 {
53 long wres = 0;
54 int n, sx, sy, sz, exy, exz, ezy, ax, ay, az, bx, by, bz;
55
56 sx = sgn(dx); sy = sgn(dy); sz = sgn(dz);
57 ax = abs(dx); ay = abs(dy); az = abs(dz);
58 bx = 2*ax; by = 2*ay; bz = 2*az;
59 exy = ay-ax; exz = az-ax; ezy = ay-az;
60 n = ax+ay+az + 1; /* added increment to visit last */
61 while (n--) {
62 wres += weightf(hp, x, y, z);
63 if (exy < 0) {
64 if (exz < 0) {
65 x += sx;
66 exy += by; exz += bz;
67 } else {
68 z += sz;
69 exz -= bx; ezy += by;
70 }
71 } else {
72 if (ezy < 0) {
73 z += sz;
74 exz -= bx; ezy += by;
75 } else {
76 y += sy;
77 exy -= bx; ezy -= bz;
78 }
79 }
80 }
81 return(wres);
82 }
83
84
85 int
86 beamcmp(b0, b1) /* comparison for descending compute order */
87 register PACKHEAD *b0, *b1;
88 {
89 return( b1->nr*(bnrays(hdlist[b0->hd],b0->bi)+1) -
90 b0->nr*(bnrays(hdlist[b1->hd],b1->bi)+1) );
91 }
92
93
94 init_global() /* initialize global ray computation */
95 {
96 long wtotal = 0;
97 int i, j;
98 int lseg[2][3];
99 double frac;
100 register int k;
101 /* allocate beam list */
102 complen = 0;
103 for (j = 0; hdlist[j] != NULL; j++)
104 complen += nbeams(hdlist[j]);
105 complist = (PACKHEAD *)malloc(complen*sizeof(PACKHEAD));
106 if (complist == NULL)
107 error(SYSTEM, "out of memory in init_global");
108 /* compute beam weights */
109 k = 0;
110 for (j = 0; hdlist[j] != NULL; j++)
111 for (i = nbeams(hdlist[j]); i > 0; i--) {
112 hdlseg(lseg, hdlist[j], i);
113 complist[k].hd = j;
114 complist[k].bi = i;
115 complist[k].nr = lineweight( hdlist[j],
116 lseg[0][0], lseg[0][1], lseg[0][2],
117 lseg[1][0] - lseg[0][0],
118 lseg[1][1] - lseg[0][1],
119 lseg[1][2] - lseg[0][2] );
120 wtotal += complist[k++].nr;
121 }
122 /* adjust weights */
123 if (vdef(DISKSPACE)) {
124 frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL));
125 if (frac < 0.95 | frac > 1.05)
126 while (k--)
127 complist[k].nr = frac * complist[k].nr;
128 }
129 listpos = 0; lastin = -1;
130 }
131
132
133 mergeclists(cdest, cl1, n1, cl2, n2) /* merge two sorted lists */
134 PACKHEAD *cdest;
135 PACKHEAD *cl1, *cl2;
136 int n1, n2;
137 {
138 int cmp;
139
140 while (n1 | n2) {
141 if (!n1) cmp = 1;
142 else if (!n2) cmp = -1;
143 else cmp = beamcmp(cl1, cl2);
144 if (cmp > 0) {
145 copystruct(cdest, cl2);
146 cl2++; n2--;
147 } else {
148 copystruct(cdest, cl1);
149 cl1++; n1--;
150 }
151 cdest++;
152 }
153 }
154
155
156 sortcomplist() /* fix our list order */
157 {
158 PACKHEAD *list2;
159 /* empty queue */
160 done_packets(flush_queue());
161 if (lastin < 0) /* flag to sort entire list */
162 qsort((char *)complist, complen, sizeof(PACKHEAD), beamcmp);
163 else if (listpos) { /* else sort and merge sublist */
164 list2 = (PACKHEAD *)malloc(listpos*sizeof(PACKHEAD));
165 if (list2 == NULL)
166 error(SYSTEM, "out of memory in sortcomplist");
167 bcopy((char *)complist,(char *)list2,listpos*sizeof(PACKHEAD));
168 qsort((char *)list2, listpos, sizeof(PACKHEAD), beamcmp);
169 mergeclists(complist, list2, listpos,
170 complist+listpos, complen-listpos);
171 free((char *)list2);
172 }
173 listpos = 0; lastin = complen-1;
174 }
175
176
177 /*
178 * The following routine works on the assumption that the bundle weights are
179 * more or less evenly distributed, such that computing a packet causes
180 * a given bundle to move way down in the computation order. We keep
181 * track of where the computed bundle with the highest priority would end
182 * up, and if we get further in our compute list than this, we resort the
183 * list and start again from the beginning. We have to flush the queue
184 * each time we sort, to ensure that we are not disturbing the order.
185 * If our major assumption is violated, and we have a very steep
186 * descent in our weights, then we will end up resorting much more often
187 * than necessary, resulting in frequent flushing of the queue. Since
188 * a merge sort is used, the sorting costs will be minimal.
189 */
190 next_packet(p) /* prepare packet for computation */
191 register PACKET *p;
192 {
193 int ncomp;
194 register int i;
195
196 if (complen <= 0)
197 return(0);
198 if (listpos > lastin) /* time to sort the list */
199 sortcomplist();
200 p->hd = complist[listpos].hd;
201 p->bi = complist[listpos].bi;
202 ncomp = bnrays(hdlist[p->hd],p->bi);
203 p->nr = complist[listpos].nr - ncomp;
204 if (p->nr <= 0)
205 return(0);
206 if (p->nr > RPACKSIZ)
207 p->nr = RPACKSIZ;
208 ncomp += p->nr; /* find where this one would go */
209 while (lastin > listpos && complist[listpos].nr *
210 (bnrays(hdlist[complist[lastin].hd],complist[lastin].bi)+1)
211 > complist[lastin].nr * (ncomp+1))
212 lastin--;
213 listpos++;
214 return(1);
215 }
