root/radiance/ray/src/hd/rholo2l.c
Revision: 3.8
Committed: Thu Dec 11 11:51:20 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.7: +3 -2 lines
increased MAXPROC from 16 to 64 and made nprocs variable global
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for local rtrace execution
9 */
10
11 #include "rholo.h"
12 #include "random.h"
13 #include "paths.h"
14 #include "selcall.h"
15 #include <signal.h>
16 #include <sys/time.h>
17
18 #ifndef MAXPROC
19 #define MAXPROC 64
20 #endif
21
22 int nprocs = 0; /* running process count */
23
24 static char pfile[] = TEMPLATE; /* persist file name */
25
26 static int rtpd[MAXPROC][3]; /* process descriptors */
27 static float *rtbuf = NULL; /* allocated i/o buffer */
28 static int maxqlen = 0; /* maximum packets per queue */
29
30 static PACKET *pqueue[MAXPROC]; /* packet queues */
31 static int pqlen[MAXPROC]; /* packet queue lengths */
32
33
34 int
35 start_rtrace() /* start rtrace process */
36 {
37 static char buf1[8];
38 int rmaxpack = 0;
39 int psiz, npt, n;
40 /* get number of processes */
41 if ((npt = ncprocs) <= 0)
42 return(0);
43 if (npt > MAXPROC) {
44 sprintf(errmsg,
45 "number of rtrace processes reduced from %d to %d",
46 npt, MAXPROC);
47 error(WARNING, errmsg);
48 npt = MAXPROC;
49 }
50 /* add compulsory options */
51 rtargv[rtargc++] = "-i-";
52 rtargv[rtargc++] = "-I-";
53 rtargv[rtargc++] = "-h-";
54 rtargv[rtargc++] = "-ld-";
55 sprintf(buf1, "%d", RPACKSIZ);
56 rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1;
57 rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0";
58 rtargv[rtargc++] = "-fff";
59 rtargv[rtargc++] = vbool(VDIST) ? "-ovl" : "-ovL";
60 if (nowarn)
61 rtargv[rtargc++] = "-w-";
62 if (npt > 1) {
63 mktemp(pfile);
64 rtargv[rtargc++] = "-PP"; rtargv[rtargc++] = pfile;
65 }
66 rtargv[rtargc++] = vval(OCTREE);
67 rtargv[rtargc] = NULL;
68 maxqlen = 0;
69 for (nprocs = 0; nprocs < npt; nprocs++) { /* spawn children */
70 psiz = open_process(rtpd[nprocs], rtargv);
71 if (psiz <= 0)
72 error(SYSTEM, "cannot start rtrace process");
73 n = psiz/(RPACKSIZ*6*sizeof(float));
74 if (maxqlen == 0) {
75 if (!(maxqlen = n))
76 error(INTERNAL,
77 "bad pipe buffer size assumption");
78 } else if (n != maxqlen)
79 error(INTERNAL, "varying pipe buffer size!");
80 rmaxpack += n;
81 }
82 rtbuf = (float *)malloc(RPACKSIZ*6*sizeof(float)*maxqlen);
83 if (rtbuf == NULL)
84 error(SYSTEM, "malloc failure in start_rtrace");
85 return(rmaxpack);
86 }
87
88
89 static int
90 bestout() /* get best process to process packet */
91 {
92 int cnt;
93 register int pn, i;
94
95 pn = 0; /* find shortest queue */
96 for (i = 1; i < nprocs; i++)
97 if (pqlen[i] < pqlen[pn])
98 pn = i;
99 /* sanity check */
100 if (pqlen[pn] == maxqlen)
101 return(-1);
102 cnt = 0; /* count number of ties */
103 for (i = pn; i < nprocs; i++)
104 if (pqlen[i] == pqlen[pn])
105 cnt++;
106 /* break ties fairly */
107 if ((cnt = random() % cnt))
108 for (i = pn; i < nprocs; i++)
109 if (pqlen[i] == pqlen[pn] && !cnt--)
110 return(i);
111 return(pn);
112 }
113
114
115 int
116 slots_avail() /* count packet slots available */
117 {
118 register int nslots = 0;
119 register int i;
120
121 for (i = nprocs; i--; )
122 nslots += maxqlen - pqlen[i];
123 return(nslots);
124 }
125
126
127 queue_packet(p) /* queue up a beam packet */
128 register PACKET *p;
129 {
130 int pn, n;
131 /* determine process to write to */
132 if ((pn = bestout()) < 0)
133 error(INTERNAL, "rtrace input queues are full!");
134 /* write out the packet */
135 packrays(rtbuf, p);
136 if ((n = p->nr) < RPACKSIZ) /* add flush block? */
137 bzero((char *)(rtbuf+6*n++), 6*sizeof(float));
138 if (writebuf(rtpd[pn][1], (char *)rtbuf, 6*sizeof(float)*n) < 0)
139 error(SYSTEM, "write error in queue_packet");
140 p->next = NULL;
141 if (!pqlen[pn]++) /* add it to the end of the queue */
142 pqueue[pn] = p;
143 else {
144 register PACKET *rpl = pqueue[pn];
145 while (rpl->next != NULL)
146 rpl = rpl->next;
147 rpl->next = p;
148 }
149 }
150
151
152 PACKET *
153 get_packets(poll) /* read packets from rtrace processes */
154 int poll;
155 {
156 static struct timeval tpoll; /* zero timeval struct */
157 fd_set readset, errset;
158 PACKET *pldone = NULL, *plend;
159 register PACKET *p;
160 int n, nr;
161 register int pn;
162 float *bp;
163 /* prepare select call */
164 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
165 for (pn = nprocs; pn--; ) {
166 if (pqlen[pn])
167 FD_SET(rtpd[pn][0], &readset);
168 FD_SET(rtpd[pn][0], &errset);
169 if (rtpd[pn][0] >= n)
170 n = rtpd[pn][0] + 1;
171 }
172 /* make the call */
173 n = select(n, &readset, (fd_set *)NULL, &errset,
174 poll ? &tpoll : (struct timeval *)NULL);
175 if (n < 0) {
176 if (errno == EINTR) /* interrupted select call */
177 return(NULL);
178 error(SYSTEM, "select call failure in get_packets");
179 }
180 if (n == 0) /* is nothing ready? */
181 return(NULL);
182 /* make read call(s) */
183 for (pn = 0; pn < nprocs; pn++) {
184 if (!FD_ISSET(rtpd[pn][0], &readset) &&
185 !FD_ISSET(rtpd[pn][0], &errset))
186 continue;
187 reread:
188 n = read(rtpd[pn][0], (char *)rtbuf,
189 4*sizeof(float)*RPACKSIZ*pqlen[pn]);
190 if (n < 0) {
191 if (errno == EINTR | errno == EAGAIN)
192 goto reread;
193 error(SYSTEM, "read error in get_packets");
194 }
195 if (n == 0)
196 goto eoferr;
197 bp = rtbuf; /* finish processing */
198 for (p = pqueue[pn]; n && p != NULL; p = p->next) {
199 if ((nr = p->nr) < RPACKSIZ)
200 nr++; /* add flush block */
201 n -= 4*sizeof(float)*nr;
202 if (n < 0) { /* get remainder */
203 n += readbuf(rtpd[pn][0],
204 (char *)(bp+4*nr)+n, -n);
205 if (n)
206 goto eoferr;
207 }
208 donerays(p, bp);
209 bp += 4*nr;
210 pqlen[pn]--;
211 }
212 if (n) /* read past end? */
213 error(INTERNAL, "packet sync error in get_packets");
214 /* take from queue */
215 if (pldone == NULL)
216 pldone = plend = pqueue[pn];
217 else
218 plend->next = pqueue[pn];
219 while (plend->next != p)
220 plend = plend->next;
221 plend->next = NULL;
222 pqueue[pn] = p;
223 }
224 return(pldone); /* return finished packets */
225 eoferr:
226 error(USER, "rtrace process died");
227 }
228
229
230 PACKET *
231 do_packets(pl) /* queue a packet list, return finished */
232 register PACKET *pl;
233 {
234 register PACKET *p;
235 /* consistency check */
236 if (nprocs < 1)
237 error(CONSISTENCY, "do_packets called with no active process");
238 /* queue each new packet */
239 while (pl != NULL) {
240 p = pl; pl = p->next; p->next = NULL;
241 queue_packet(p);
242 }
243 return(get_packets(slots_avail())); /* return processed packets */
244 }
245
246
247 PACKET *
248 flush_queue() /* empty all rtrace queues */
249 {
250 PACKET *rpdone = NULL;
251 register PACKET *rpl;
252 float *bp;
253 register PACKET *p;
254 int i, n, nr;
255
256 for (i = 0; i < nprocs; i++)
257 if (pqlen[i]) {
258 if (rpdone == NULL) { /* tack on queue */
259 rpdone = rpl = pqueue[i];
260 if ((nr = rpl->nr) < RPACKSIZ) nr++;
261 } else {
262 rpl->next = pqueue[i];
263 nr = 0;
264 }
265 while (rpl->next != NULL) {
266 nr += (rpl = rpl->next)->nr;
267 if (rpl->nr < RPACKSIZ)
268 nr++; /* add flush block */
269 }
270 n = readbuf(rtpd[i][0], (char *)rtbuf,
271 4*sizeof(float)*nr);
272 if (n < 0)
273 error(SYSTEM, "read failure in flush_queue");
274 bp = rtbuf; /* process packets */
275 for (p = pqueue[i]; p != NULL; p = p->next) {
276 if ((nr = p->nr) < RPACKSIZ)
277 nr++; /* add flush block */
278 n -= 4*sizeof(float)*nr;
279 if (n >= 0)
280 donerays(p, bp);
281 else
282 p->nr = 0; /* short data error */
283 bp += 4*nr;
284 }
285 pqueue[i] = NULL; /* zero this queue */
286 pqlen[i] = 0;
287 }
288 return(rpdone); /* return all packets completed */
289 }
290
291
292 static
293 killpersist() /* kill persistent process */
294 {
295 FILE *fp;
296 int pid;
297
298 if ((fp = fopen(pfile, "r")) == NULL)
299 return;
300 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
301 unlink(pfile);
302 fclose(fp);
303 }
304
305
306 int
307 end_rtrace() /* close rtrace process(es) */
308 {
309 int status = 0, rv;
310
311 if (nprocs > 1)
312 killpersist();
313 while (nprocs > 0) {
314 rv = close_process(rtpd[--nprocs]);
315 if (rv > 0)
316 status = rv;
317 }
318 free((char *)rtbuf);
319 rtbuf = NULL;
320 maxqlen = 0;
321 return(status);
322 }
