root/radiance/ray/src/hd/rholo2l.c
Revision: 3.7
Committed: Tue Dec 2 16:35:45 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.6: +2 -1 lines
leave rtrace -w option alone if rholo -w not set
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for local rtrace execution
9 */
10
11 #include "rholo.h"
12 #include "random.h"
13 #include "paths.h"
14 #include "selcall.h"
15 #include <signal.h>
16 #include <sys/time.h>
17
18 #ifndef MAXPROC
19 #define MAXPROC 16
20 #endif
21
22 static char pfile[] = TEMPLATE; /* persist file name */
23
24 static int rtpd[MAXPROC][3]; /* process descriptors */
25 static float *rtbuf = NULL; /* allocated i/o buffer */
26 static int maxqlen = 0; /* maximum packets per queue */
27 static int nprocs = 0; /* number of processes */
28
29 static PACKET *pqueue[MAXPROC]; /* packet queues */
30 static int pqlen[MAXPROC]; /* packet queue lengths */
31
32
33 int
34 start_rtrace() /* start rtrace process */
35 {
36 static char buf1[8];
37 int rmaxpack = 0;
38 int psiz, npt, n;
39 /* get number of processes */
40 if ((npt = ncprocs) <= 0)
41 return(0);
42 if (npt > MAXPROC) {
43 sprintf(errmsg,
44 "number of rtrace processes reduced from %d to %d",
45 npt, MAXPROC);
46 error(WARNING, errmsg);
47 npt = MAXPROC;
48 }
49 /* add compulsory options */
50 rtargv[rtargc++] = "-i-";
51 rtargv[rtargc++] = "-I-";
52 rtargv[rtargc++] = "-h-";
53 rtargv[rtargc++] = "-ld-";
54 sprintf(buf1, "%d", RPACKSIZ);
55 rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1;
56 rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0";
57 rtargv[rtargc++] = "-fff";
58 rtargv[rtargc++] = vbool(VDIST) ? "-ovl" : "-ovL";
59 if (nowarn)
60 rtargv[rtargc++] = "-w-";
61 if (npt > 1) {
62 mktemp(pfile);
63 rtargv[rtargc++] = "-PP"; rtargv[rtargc++] = pfile;
64 }
65 rtargv[rtargc++] = vval(OCTREE);
66 rtargv[rtargc] = NULL;
67 maxqlen = 0;
68 for (nprocs = 0; nprocs < npt; nprocs++) { /* spawn children */
69 psiz = open_process(rtpd[nprocs], rtargv);
70 if (psiz <= 0)
71 error(SYSTEM, "cannot start rtrace process");
72 n = psiz/(RPACKSIZ*6*sizeof(float));
73 if (maxqlen == 0) {
74 if (!(maxqlen = n))
75 error(INTERNAL,
76 "bad pipe buffer size assumption");
77 } else if (n != maxqlen)
78 error(INTERNAL, "varying pipe buffer size!");
79 rmaxpack += n;
80 }
81 rtbuf = (float *)malloc(RPACKSIZ*6*sizeof(float)*maxqlen);
82 if (rtbuf == NULL)
83 error(SYSTEM, "malloc failure in start_rtrace");
84 return(rmaxpack);
85 }
86
87
88 static int
89 bestout() /* get best process to process packet */
90 {
91 int cnt;
92 register int pn, i;
93
94 pn = 0; /* find shortest queue */
95 for (i = 1; i < nprocs; i++)
96 if (pqlen[i] < pqlen[pn])
97 pn = i;
98 /* sanity check */
99 if (pqlen[pn] == maxqlen)
100 return(-1);
101 cnt = 0; /* count number of ties */
102 for (i = pn; i < nprocs; i++)
103 if (pqlen[i] == pqlen[pn])
104 cnt++;
105 /* break ties fairly */
106 if ((cnt = random() % cnt))
107 for (i = pn; i < nprocs; i++)
108 if (pqlen[i] == pqlen[pn] && !cnt--)
109 return(i);
110 return(pn);
111 }
112
113
114 int
115 slots_avail() /* count packet slots available */
116 {
117 register int nslots = 0;
118 register int i;
119
120 for (i = nprocs; i--; )
121 nslots += maxqlen - pqlen[i];
122 return(nslots);
123 }
124
125
126 queue_packet(p) /* queue up a beam packet */
127 register PACKET *p;
128 {
129 int pn, n;
130 /* determine process to write to */
131 if ((pn = bestout()) < 0)
132 error(INTERNAL, "rtrace input queues are full!");
133 /* write out the packet */
134 packrays(rtbuf, p);
135 if ((n = p->nr) < RPACKSIZ) /* add flush block? */
136 bzero((char *)(rtbuf+6*n++), 6*sizeof(float));
137 if (writebuf(rtpd[pn][1], (char *)rtbuf, 6*sizeof(float)*n) < 0)
138 error(SYSTEM, "write error in queue_packet");
139 p->next = NULL;
140 if (!pqlen[pn]++) /* add it to the end of the queue */
141 pqueue[pn] = p;
142 else {
143 register PACKET *rpl = pqueue[pn];
144 while (rpl->next != NULL)
145 rpl = rpl->next;
146 rpl->next = p;
147 }
148 }
149
150
151 PACKET *
152 get_packets(poll) /* read packets from rtrace processes */
153 int poll;
154 {
155 static struct timeval tpoll; /* zero timeval struct */
156 fd_set readset, errset;
157 PACKET *pldone = NULL, *plend;
158 register PACKET *p;
159 int n, nr;
160 register int pn;
161 float *bp;
162 /* prepare select call */
163 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
164 for (pn = nprocs; pn--; ) {
165 if (pqlen[pn])
166 FD_SET(rtpd[pn][0], &readset);
167 FD_SET(rtpd[pn][0], &errset);
168 if (rtpd[pn][0] >= n)
169 n = rtpd[pn][0] + 1;
170 }
171 /* make the call */
172 n = select(n, &readset, (fd_set *)NULL, &errset,
173 poll ? &tpoll : (struct timeval *)NULL);
174 if (n < 0) {
175 if (errno == EINTR) /* interrupted select call */
176 return(NULL);
177 error(SYSTEM, "select call failure in get_packets");
178 }
179 if (n == 0) /* is nothing ready? */
180 return(NULL);
181 /* make read call(s) */
182 for (pn = 0; pn < nprocs; pn++) {
183 if (!FD_ISSET(rtpd[pn][0], &readset) &&
184 !FD_ISSET(rtpd[pn][0], &errset))
185 continue;
186 reread:
187 n = read(rtpd[pn][0], (char *)rtbuf,
188 4*sizeof(float)*RPACKSIZ*pqlen[pn]);
189 if (n < 0) {
190 if (errno == EINTR | errno == EAGAIN)
191 goto reread;
192 error(SYSTEM, "read error in get_packets");
193 }
194 if (n == 0)
195 goto eoferr;
196 bp = rtbuf; /* finish processing */
197 for (p = pqueue[pn]; n && p != NULL; p = p->next) {
198 if ((nr = p->nr) < RPACKSIZ)
199 nr++; /* add flush block */
200 n -= 4*sizeof(float)*nr;
201 if (n < 0) { /* get remainder */
202 n += readbuf(rtpd[pn][0],
203 (char *)(bp+4*nr)+n, -n);
204 if (n)
205 goto eoferr;
206 }
207 donerays(p, bp);
208 bp += 4*nr;
209 pqlen[pn]--;
210 }
211 if (n) /* read past end? */
212 error(INTERNAL, "packet sync error in get_packets");
213 /* take from queue */
214 if (pldone == NULL)
215 pldone = plend = pqueue[pn];
216 else
217 plend->next = pqueue[pn];
218 while (plend->next != p)
219 plend = plend->next;
220 plend->next = NULL;
221 pqueue[pn] = p;
222 }
223 return(pldone); /* return finished packets */
224 eoferr:
225 error(USER, "rtrace process died");
226 }
227
228
229 PACKET *
230 do_packets(pl) /* queue a packet list, return finished */
231 register PACKET *pl;
232 {
233 register PACKET *p;
234 /* consistency check */
235 if (nprocs < 1)
236 error(CONSISTENCY, "do_packets called with no active process");
237 /* queue each new packet */
238 while (pl != NULL) {
239 p = pl; pl = p->next; p->next = NULL;
240 queue_packet(p);
241 }
242 return(get_packets(slots_avail())); /* return processed packets */
243 }
244
245
246 PACKET *
247 flush_queue() /* empty all rtrace queues */
248 {
249 PACKET *rpdone = NULL;
250 register PACKET *rpl;
251 float *bp;
252 register PACKET *p;
253 int i, n, nr;
254
255 for (i = 0; i < nprocs; i++)
256 if (pqlen[i]) {
257 if (rpdone == NULL) { /* tack on queue */
258 rpdone = rpl = pqueue[i];
259 if ((nr = rpl->nr) < RPACKSIZ) nr++;
260 } else {
261 rpl->next = pqueue[i];
262 nr = 0;
263 }
264 while (rpl->next != NULL) {
265 nr += (rpl = rpl->next)->nr;
266 if (rpl->nr < RPACKSIZ)
267 nr++; /* add flush block */
268 }
269 n = readbuf(rtpd[i][0], (char *)rtbuf,
270 4*sizeof(float)*nr);
271 if (n < 0)
272 error(SYSTEM, "read failure in flush_queue");
273 bp = rtbuf; /* process packets */
274 for (p = pqueue[i]; p != NULL; p = p->next) {
275 if ((nr = p->nr) < RPACKSIZ)
276 nr++; /* add flush block */
277 n -= 4*sizeof(float)*nr;
278 if (n >= 0)
279 donerays(p, bp);
280 else
281 p->nr = 0; /* short data error */
282 bp += 4*nr;
283 }
284 pqueue[i] = NULL; /* zero this queue */
285 pqlen[i] = 0;
286 }
287 return(rpdone); /* return all packets completed */
288 }
289
290
291 static
292 killpersist() /* kill persistent process */
293 {
294 FILE *fp;
295 int pid;
296
297 if ((fp = fopen(pfile, "r")) == NULL)
298 return;
299 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
300 unlink(pfile);
301 fclose(fp);
302 }
303
304
305 int
306 end_rtrace() /* close rtrace process(es) */
307 {
308 int status = 0, rv;
309
310 if (nprocs > 1)
311 killpersist();
312 while (nprocs > 0) {
313 rv = close_process(rtpd[--nprocs]);
314 if (rv > 0)
315 status = rv;
316 }
317 free((char *)rtbuf);
318 rtbuf = NULL;
319 maxqlen = 0;
320 return(status);
321 }
