1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for local rtrace execution |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "random.h" |
13 |
#include "selcall.h" |
14 |
#include <signal.h> |
15 |
#include <sys/time.h> |
16 |
17 |
#ifndef MAXPROC |
18 |
#define MAXPROC 16 |
19 |
#endif |
20 |
21 |
static char PFILE[] = "/usr/tmp/RHpersist"; /* persist file name */ |
22 |
23 |
static int rtpd[MAXPROC][3]; /* process descriptors */ |
24 |
static float *rtbuf = NULL; /* allocated i/o buffer */ |
25 |
static int maxqlen = 0; /* maximum packets per queue */ |
26 |
static int nprocs = 0; /* number of processes */ |
27 |
28 |
static PACKET *pqueue[MAXPROC]; /* packet queues */ |
29 |
static int pqlen[MAXPROC]; /* packet queue lengths */ |
30 |
31 |
32 |
int |
33 |
start_rtrace() /* start rtrace process */ |
34 |
35 |
static char buf1[8]; |
36 |
int rmaxpack = 0; |
37 |
int psiz, npt, n; |
38 |
/* get number of processes */ |
39 |
if ((npt = ncprocs) <= 0) |
40 |
return(0); |
41 |
if (npt > MAXPROC) { |
42 |
sprintf(errmsg, |
43 |
"number of rtrace processes reduced from %d to %d", |
44 |
npt, MAXPROC); |
45 |
error(WARNING, errmsg); |
46 |
npt = MAXPROC; |
47 |
48 |
/* add compulsory options */ |
49 |
rtargv[rtargc++] = "-i-"; |
50 |
rtargv[rtargc++] = "-I-"; |
51 |
rtargv[rtargc++] = "-h-"; |
52 |
rtargv[rtargc++] = "-ld-"; |
53 |
sprintf(buf1, "%d", RPACKSIZ); |
54 |
rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1; |
55 |
rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0"; |
56 |
rtargv[rtargc++] = "-fff"; |
57 |
rtargv[rtargc++] = "-ovl"; |
58 |
rtargv[rtargc++] = nowarn ? "-w-" : "-w+"; |
59 |
if (npt > 1) { |
60 |
rtargv[rtargc++] = "-PP"; rtargv[rtargc++] = PFILE; |
61 |
62 |
rtargv[rtargc++] = vval(OCTREE); |
63 |
rtargv[rtargc] = NULL; |
64 |
maxqlen = 0; |
65 |
for (nprocs = 0; nprocs < npt; nprocs++) { /* spawn children */ |
66 |
psiz = open_process(rtpd[nprocs], rtargv); |
67 |
if (psiz <= 0) |
68 |
error(SYSTEM, "cannot start rtrace process"); |
69 |
n = psiz/(RPACKSIZ*6*sizeof(float)); |
70 |
if (maxqlen == 0) { |
71 |
if (!(maxqlen = n)) |
72 |
error(INTERNAL, |
73 |
"bad pipe buffer size assumption"); |
74 |
} else if (n != maxqlen) |
75 |
error(INTERNAL, "varying pipe buffer size!"); |
76 |
rmaxpack += n; |
77 |
78 |
rtbuf = (float *)malloc(RPACKSIZ*6*sizeof(float)*maxqlen); |
79 |
if (rtbuf == NULL) |
80 |
error(SYSTEM, "malloc failure in start_rtrace"); |
81 |
return(rmaxpack); |
82 |
83 |
84 |
85 |
static int |
86 |
bestout() /* get best process to process packet */ |
87 |
88 |
int cnt; |
89 |
register int pn, i; |
90 |
91 |
pn = 0; /* find shortest queue */ |
92 |
for (i = 1; i < nprocs; i++) |
93 |
if (pqlen[i] < pqlen[pn]) |
94 |
pn = i; |
95 |
/* sanity check */ |
96 |
if (pqlen[pn] == maxqlen) |
97 |
return(-1); |
98 |
cnt = 0; /* count number of ties */ |
99 |
for (i = pn; i < nprocs; i++) |
100 |
if (pqlen[i] == pqlen[pn]) |
101 |
cnt++; |
102 |
/* break ties fairly */ |
103 |
if ((cnt = random() % cnt)) |
104 |
105 |
if (pqlen[i] == pqlen[pn] && !cnt--) |
106 |
return(i); |
107 |
return(pn); |
108 |
109 |
110 |
111 |
int |
112 |
slots_avail() /* count packet slots available */ |
113 |
114 |
register int nslots = 0; |
115 |
register int i; |
116 |
117 |
for (i = nprocs; i--; ) |
118 |
nslots += maxqlen - pqlen[i]; |
119 |
return(nslots); |
120 |
121 |
122 |
123 |
queue_packet(p) /* queue up a beam packet */ |
124 |
register PACKET *p; |
125 |
126 |
int pn, n; |
127 |
/* determine process to write to */ |
128 |
if ((pn = bestout()) < 0) |
129 |
error(INTERNAL, "rtrace input queues are full!"); |
130 |
/* write out the packet */ |
131 |
packrays(rtbuf, p); |
132 |
if ((n = p->nr) < RPACKSIZ) /* add flush block? */ |
133 |
bzero((char *)(rtbuf+6*n++), 6*sizeof(float)); |
134 |
if (writebuf(rtpd[pn][1], (char *)rtbuf, 6*sizeof(float)*n) < 0) |
135 |
error(SYSTEM, "write error in queue_packet"); |
136 |
p->next = NULL; |
137 |
if (!pqlen[pn]++) /* add it to the end of the queue */ |
138 |
pqueue[pn] = p; |
139 |
else { |
140 |
register PACKET *rpl = pqueue[pn]; |
141 |
while (rpl->next != NULL) |
142 |
rpl = rpl->next; |
143 |
rpl->next = p; |
144 |
145 |
146 |
147 |
148 |
PACKET * |
149 |
get_packets(poll) /* read packets from rtrace processes */ |
150 |
int poll; |
151 |
152 |
static struct timeval tpoll; /* zero timeval struct */ |
153 |
fd_set readset, errset; |
154 |
PACKET *pldone = NULL, *plend; |
155 |
156 |
int n, nr; |
157 |
register int pn; |
158 |
float *bp; |
159 |
/* prepare select call */ |
160 |
FD_ZERO(&readset); FD_ZERO(&errset); n = 0; |
161 |
for (pn = nprocs; pn--; ) { |
162 |
if (pqlen[pn]) |
163 |
FD_SET(rtpd[pn][0], &readset); |
164 |
FD_SET(rtpd[pn][0], &errset); |
165 |
if (rtpd[pn][0] >= n) |
166 |
n = rtpd[pn][0] + 1; |
167 |
168 |
/* make the call */ |
169 |
n = select(n, &readset, (fd_set *)NULL, &errset, |
170 |
poll ? &tpoll : (struct timeval *)NULL); |
171 |
if (n < 0) { |
172 |
if (errno == EINTR) /* interrupted select call */ |
173 |
return(NULL); |
174 |
error(SYSTEM, "select call failure in get_packets"); |
175 |
176 |
if (n == 0) /* is nothing ready? */ |
177 |
return(NULL); |
178 |
/* make read call(s) */ |
179 |
for (pn = 0; pn < nprocs; pn++) { |
180 |
if (!FD_ISSET(rtpd[pn][0], &readset) && |
181 |
!FD_ISSET(rtpd[pn][0], &errset)) |
182 |
continue; |
183 |
reread: |
184 |
n = read(rtpd[pn][0], (char *)rtbuf, |
185 |
4*sizeof(float)*RPACKSIZ*pqlen[pn]); |
186 |
if (n < 0) { |
187 |
if (errno == EINTR | errno == EAGAIN) |
188 |
goto reread; |
189 |
error(SYSTEM, "read error in get_packets"); |
190 |
191 |
if (n == 0) |
192 |
goto eoferr; |
193 |
bp = rtbuf; /* finish processing */ |
194 |
for (p = pqueue[pn]; n && p != NULL; p = p->next) { |
195 |
if ((nr = p->nr) < RPACKSIZ) |
196 |
nr++; /* add flush block */ |
197 |
n -= 4*sizeof(float)*nr; |
198 |
if (n < 0) { /* get remainder */ |
199 |
n += readbuf(rtpd[pn][0], |
200 |
(char *)(bp+4*nr)+n, -n); |
201 |
if (n) |
202 |
goto eoferr; |
203 |
204 |
donerays(p, bp); |
205 |
bp += 4*nr; |
206 |
pqlen[pn]--; |
207 |
208 |
if (n) /* read past end? */ |
209 |
error(INTERNAL, "packet sync error in get_packets"); |
210 |
/* take from queue */ |
211 |
if (pldone == NULL) |
212 |
pldone = plend = pqueue[pn]; |
213 |
else |
214 |
plend->next = pqueue[pn]; |
215 |
while (plend->next != p) |
216 |
plend = plend->next; |
217 |
plend->next = NULL; |
218 |
pqueue[pn] = p; |
219 |
220 |
return(pldone); /* return finished packets */ |
221 |
eoferr: |
222 |
error(USER, "rtrace process died"); |
223 |
224 |
225 |
226 |
PACKET * |
227 |
do_packets(pl) /* queue a packet list, return finished */ |
228 |
register PACKET *pl; |
229 |
230 |
231 |
/* consistency check */ |
232 |
if (nprocs < 1) |
233 |
error(CONSISTENCY, "do_packets called with no active process"); |
234 |
/* queue each new packet */ |
235 |
while (pl != NULL) { |
236 |
p = pl; pl = p->next; p->next = NULL; |
237 |
queue_packet(p); |
238 |
239 |
return(get_packets(slots_avail())); /* return processed packets */ |
240 |
241 |
242 |
243 |
PACKET * |
244 |
flush_queue() /* empty all rtrace queues */ |
245 |
246 |
PACKET *rpdone = NULL; |
247 |
register PACKET *rpl; |
248 |
float *bp; |
249 |
250 |
int i, n, nr; |
251 |
252 |
for (i = 0; i < nprocs; i++) |
253 |
if (pqlen[i]) { |
254 |
if (rpdone == NULL) { /* tack on queue */ |
255 |
rpdone = rpl = pqueue[i]; |
256 |
nr = rpl->nr; |
257 |
} else { |
258 |
rpl->next = pqueue[i]; |
259 |
nr = 0; |
260 |
261 |
while (rpl->next != NULL) { |
262 |
nr += (rpl = rpl->next)->nr; |
263 |
if (rpl->nr < RPACKSIZ) |
264 |
265 |
266 |
n = readbuf(rtpd[i][0], (char *)rtbuf, |
267 |
4*sizeof(float)*nr); |
268 |
if (n < 0) |
269 |
error(SYSTEM, "read failure in flush_queue"); |
270 |
bp = rtbuf; /* process packets */ |
271 |
for (p = pqueue[i]; p != NULL; p = p->next) { |
272 |
273 |
274 |
275 |
if (n >= 0) |
276 |
donerays(p, bp); |
277 |
else |
278 |
p->nr = 0; /* short data error */ |
279 |
bp += 4*nr; |
280 |
281 |
pqueue[i] = NULL; /* zero this queue */ |
282 |
pqlen[i] = 0; |
283 |
284 |
return(rpdone); /* return all packets completed */ |
285 |
286 |
287 |
288 |
static |
289 |
killpersist() /* kill persistent process */ |
290 |
291 |
FILE *fp; |
292 |
int pid; |
293 |
294 |
if ((fp = fopen(PFILE, "r")) == NULL) |
295 |
return; |
296 |
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0) |
297 |
unlink(PFILE); |
298 |
fclose(fp); |
299 |
300 |
301 |
302 |
int |
303 |
end_rtrace() /* close rtrace process(es) */ |
304 |
305 |
int status = 0, rv; |
306 |
307 |
if (nprocs > 1) |
308 |
killpersist(); |
309 |
while (nprocs > 0) { |
310 |
rv = close_process(rtpd[--nprocs]); |
311 |
if (rv > 0) |
312 |
status = rv; |
313 |
314 |
free((char *)rtbuf); |
315 |
rtbuf = NULL; |
316 |
maxqlen = 0; |
317 |
return(status); |
318 |
