root/radiance/ray/src/hd/rholo2l.c
Sat Dec 16 18:33:55 2023 UTC (5 months, 4 weeks ago) by greg
Changes since 3.19: +2 -1 lines
Diff to previous 3.19 , to selected 3.3
fix(rholo): Added -co- switch to overriding rtrace options
Thu Apr 21 03:11:55 2022 UTC (2 years, 1 month ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.3
perf: Replaced random()%modulus with irandom(modulus) where appropriate
Fri Oct 5 19:19:16 2018 UTC (5 years, 8 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 3.17: +16 -16 lines
Diff to previous 3.17 , to selected 3.3
Fri Mar 4 02:48:14 2016 UTC (8 years, 3 months ago) by greg
Changes since 3.16: +3 -6 lines
Diff to previous 3.16 , to selected 3.3
Made quitting rvu, rholo and rcontrib quicker with multiple processes on Unix
Changes since 3.15: +32 -21 lines
Diff to previous 3.15 , to selected 3.3
Ansification and prototypes.
Diff to previous 3.14 , to selected 3.3
Changes since 3.13: +3 -2 lines
Diff to previous 3.13 , to selected 3.3
Changes since 3.12: +18 -16 lines
Diff to previous 3.12 , to selected 3.3
Sat Feb 22 02:07:25 2003 UTC (21 years, 3 months ago) by greg
Changes since 3.11: +2 -5 lines
Diff to previous 3.11 , to selected 3.3
Tue Jan 20 15:04:23 1998 UTC (26 years, 4 months ago) by gregl
Diff to previous 3.10 , to selected 3.3
added sleep(2) on first rtrace process
Fri Dec 12 18:09:49 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 3.9 , to selected 3.3
added safety check to start_rtrace()
Fri Dec 12 11:13:17 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.8: +25 -23 lines
Diff to previous 3.8 , to selected 3.3
Thu Dec 11 11:51:20 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.7: +3 -2 lines
Diff to previous 3.7 , to selected 3.3
increased MAXPROC from 16 to 64 and made nprocs variable global
Tue Dec 2 16:35:45 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.6: +2 -1 lines
Diff to previous 3.6 , to selected 3.3
leave rtrace -w option alone if rholo -w not set
Mon Dec 1 16:32:49 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.5: +7 -5 lines
Diff to previous 3.5 , to selected 3.3
added "VDISTANCE" variable for virtual distance calculation
made persist file vary with process id so multiple rholo's don't interfere
Mon Nov 24 15:18:47 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 3.4 , to selected 3.3
changed to using immediate distance from rtrace
Mon Nov 3 18:33:13 1997 UTC (26 years, 7 months ago) by gregl
Diff to previous 3.3
Revision 3.3 - (view) (download) (annotate) - [selected]
Fri Oct 31 15:49:41 1997 UTC (26 years, 7 months ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2
include selcall.h
Fri Oct 31 11:44:09 1997 UTC (26 years, 7 months ago) by gregl
Changes since 3.1: +9 -6 lines
Diff to previous 3.1 , to selected 3.3
initial bug fixes
Fri Oct 31 10:23:29 1997 UTC (26 years, 7 months ago) by gregl
Diff to selected 3.3
