--- ray/src/hd/rholo2l.c 2003/02/22 02:07:25 3.12 +++ ray/src/hd/rholo2l.c 2025/01/22 18:28:32 3.23 @@ -1,16 +1,19 @@ #ifndef lint -static const char RCSid[] = "$Id: rholo2l.c,v 3.12 2003/02/22 02:07:25 greg Exp $"; +static const char RCSid[] = "$Id: rholo2l.c,v 3.23 2025/01/22 18:28:32 greg Exp $"; #endif /* * Routines for local rtrace execution */ +#include +#include +#include + #include "rholo.h" #include "random.h" #include "paths.h" #include "selcall.h" -#include -#include +#include "rtprocess.h" #ifndef MAXPROC #define MAXPROC 64 @@ -20,16 +23,22 @@ int nprocs = 0; /* running process count */ static char pfile[] = TEMPLATE; /* persist file name */ -static int rtpd[MAXPROC][3]; /* process descriptors */ +static SUBPROC rtpd[MAXPROC]; /* process descriptors */ static float *rtbuf = NULL; /* allocated i/o buffer */ -static int maxqlen = 0; /* maximum packets per queue */ +static int maxqlen; /* maximum packets per queue */ static PACKET *pqueue[MAXPROC]; /* packet queues */ static int pqlen[MAXPROC]; /* packet queue lengths */ +static int bestout(void); +static int slots_avail(void); +static void queue_packet(PACKET *p); +static PACKET * get_packets(int poll); +static void killpersist(void); + int -start_rtrace() /* start rtrace process */ +start_rtrace(void) /* start rtrace process */ { static char buf1[8]; int rmaxpack = 0; @@ -50,6 +59,7 @@ start_rtrace() /* start rtrace process */ rtargv[rtargc++] = "-I-"; rtargv[rtargc++] = "-h-"; rtargv[rtargc++] = "-ld-"; + rtargv[rtargc++] = "-co-"; sprintf(buf1, "%d", RPACKSIZ); rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1; rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0"; @@ -66,14 +76,12 @@ start_rtrace() /* start rtrace process */ } maxqlen = 0; for (nprocs = 0; nprocs < ncprocs; nprocs++) { /* spawn children */ - psiz = open_process(rtpd[nprocs], rtargv); + psiz = open_process(&rtpd[nprocs], rtargv); if (psiz <= 0) error(SYSTEM, "cannot start rtrace process"); - n = psiz/(RPACKSIZ*6*sizeof(float)); - if (maxqlen == 0) { - if (!(maxqlen = n)) - error(INTERNAL, - "bad pipe buffer size assumption"); + n = psiz/(RPACKSIZ*6*sizeof(float)) + 1; + if (!maxqlen) { + maxqlen = n; sleep(2); } else if (n != maxqlen) error(INTERNAL, "varying pipe buffer size!"); @@ -87,10 +95,10 @@ start_rtrace() /* start rtrace process */ static int -bestout() /* get best process to process packet */ +bestout(void) /* get best process to process packet */ { int cnt; - register int pn, i; + int pn, i; pn = 0; /* find shortest queue */ for (i = 1; i < nprocs; i++) @@ -104,7 +112,7 @@ bestout() /* get best process to process packet */ if (pqlen[i] == pqlen[pn]) cnt++; /* break ties fairly */ - if ((cnt = random() % cnt)) + if ((cnt = irandom(cnt))) for (i = pn; i < nprocs; i++) if (pqlen[i] == pqlen[pn] && !cnt--) return(i); @@ -112,11 +120,11 @@ bestout() /* get best process to process packet */ } -int -slots_avail() /* count packet slots available */ +static int +slots_avail(void) /* count packet slots available */ { - register int nslots = 0; - register int i; + int nslots = 0; + int i; for (i = nprocs; i--; ) nslots += maxqlen - pqlen[i]; @@ -124,8 +132,10 @@ slots_avail() /* count packet slots available */ } -queue_packet(p) /* queue up a beam packet */ -register PACKET *p; +static void +queue_packet( /* queue up a beam packet */ + PACKET *p +) { int pn, n; /* determine process to write to */ @@ -134,14 +144,14 @@ register PACKET *p; /* write out the packet */ packrays(rtbuf, p); if ((n = p->nr) < RPACKSIZ) /* add flush block? */ - bzero((char *)(rtbuf+6*n++), 6*sizeof(float)); - if (writebuf(rtpd[pn][1], (char *)rtbuf, 6*sizeof(float)*n) < 0) + memset((char *)(rtbuf+6*n++), '\0', 6*sizeof(float)); + if (writebuf(rtpd[pn].w, rtbuf, 6*sizeof(float)*n) < 0) error(SYSTEM, "write error in queue_packet"); p->next = NULL; if (!pqlen[pn]++) /* add it to the end of the queue */ pqueue[pn] = p; else { - register PACKET *rpl = pqueue[pn]; + PACKET *rpl = pqueue[pn]; while (rpl->next != NULL) rpl = rpl->next; rpl->next = p; @@ -149,25 +159,26 @@ register PACKET *p; } -PACKET * -get_packets(poll) /* read packets from rtrace processes */ -int poll; +static PACKET * +get_packets( /* read packets from rtrace processes */ + int poll +) { static struct timeval tpoll; /* zero timeval struct */ fd_set readset, errset; PACKET *pldone = NULL, *plend; - register PACKET *p; + PACKET *p; int n, nr; - register int pn; + int pn; float *bp; /* prepare select call */ FD_ZERO(&readset); FD_ZERO(&errset); n = 0; for (pn = nprocs; pn--; ) { if (pqlen[pn]) - FD_SET(rtpd[pn][0], &readset); - FD_SET(rtpd[pn][0], &errset); - if (rtpd[pn][0] >= n) - n = rtpd[pn][0] + 1; + FD_SET(rtpd[pn].r, &readset); + FD_SET(rtpd[pn].r, &errset); + if (rtpd[pn].r >= n) + n = rtpd[pn].r + 1; } /* make the call */ n = select(n, &readset, (fd_set *)NULL, &errset, @@ -181,14 +192,14 @@ int poll; return(NULL); /* make read call(s) */ for (pn = 0; pn < nprocs; pn++) { - if (!FD_ISSET(rtpd[pn][0], &readset) && - !FD_ISSET(rtpd[pn][0], &errset)) + if (!FD_ISSET(rtpd[pn].r, &readset) && + !FD_ISSET(rtpd[pn].r, &errset)) continue; reread: - n = read(rtpd[pn][0], (char *)rtbuf, + n = read(rtpd[pn].r, (char *)rtbuf, 4*sizeof(float)*RPACKSIZ*pqlen[pn]); if (n < 0) { - if (errno == EINTR | errno == EAGAIN) + if ((errno == EINTR) | (errno == EAGAIN)) goto reread; error(SYSTEM, "read error in get_packets"); } @@ -200,7 +211,7 @@ int poll; nr++; /* add flush block */ n -= 4*sizeof(float)*nr; if (n < 0) { /* get remainder */ - n += readbuf(rtpd[pn][0], + n += readbuf(rtpd[pn].r, (char *)(bp+4*nr)+n, -n); if (n) goto eoferr; @@ -224,14 +235,16 @@ int poll; return(pldone); /* return finished packets */ eoferr: error(USER, "rtrace process died"); + return NULL; /* pro forma return */ } PACKET * -do_packets(pl) /* queue a packet list, return finished */ -register PACKET *pl; +do_packets( /* queue a packet list, return finished */ + PACKET *pl +) { - register PACKET *p; + PACKET *p; /* consistency check */ if (nprocs < 1) error(CONSISTENCY, "do_packets called with no active process"); @@ -245,12 +258,12 @@ register PACKET *pl; PACKET * -flush_queue() /* empty all rtrace queues */ +flush_queue(void) /* empty all rtrace queues */ { PACKET *rpdone = NULL; - register PACKET *rpl; + PACKET *rpl = NULL; float *bp; - register PACKET *p; + PACKET *p; int i, n, nr; for (i = 0; i < nprocs; i++) @@ -267,8 +280,7 @@ flush_queue() /* empty all rtrace queues */ if (rpl->nr < RPACKSIZ) nr++; /* add flush block */ } - n = readbuf(rtpd[i][0], (char *)rtbuf, - 4*sizeof(float)*nr); + n = readbuf(rtpd[i].r, rtbuf, 4*sizeof(float)*nr); if (n < 0) error(SYSTEM, "read failure in flush_queue"); bp = rtbuf; /* process packets */ @@ -289,8 +301,8 @@ flush_queue() /* empty all rtrace queues */ } -static -killpersist() /* kill persistent process */ +static void +killpersist(void) /* kill persistent process */ { FILE *fp; int pid; @@ -304,17 +316,14 @@ killpersist() /* kill persistent process */ int -end_rtrace() /* close rtrace process(es) */ +end_rtrace(void) /* close rtrace process(es) */ { int status = 0, rv; if (nprocs > 1) killpersist(); - while (nprocs > 0) { - rv = close_process(rtpd[--nprocs]); - if (rv > 0) - status = rv; - } + status = close_processes(rtpd, nprocs); + nprocs = 0; free((void *)rtbuf); rtbuf = NULL; maxqlen = 0;
