--- ray/src/hd/rholo2l.c 2003/02/22 02:07:25 3.12 +++ ray/src/hd/rholo2l.c 2003/06/30 14:59:12 3.14 @@ -1,16 +1,19 @@ #ifndef lint -static const char RCSid[] = "$Id: rholo2l.c,v 3.12 2003/02/22 02:07:25 greg Exp $"; +static const char RCSid[] = "$Id: rholo2l.c,v 3.14 2003/06/30 14:59:12 schorsch Exp $"; #endif /* * Routines for local rtrace execution */ +#include +#include +#include + #include "rholo.h" #include "random.h" #include "paths.h" #include "selcall.h" -#include -#include +#include "rtprocess.h" #ifndef MAXPROC #define MAXPROC 64 @@ -20,7 +23,7 @@ int nprocs = 0; /* running process count */ static char pfile[] = TEMPLATE; /* persist file name */ -static int rtpd[MAXPROC][3]; /* process descriptors */ +static SUBPROC rtpd[MAXPROC]; /* process descriptors */ static float *rtbuf = NULL; /* allocated i/o buffer */ static int maxqlen = 0; /* maximum packets per queue */ @@ -66,7 +69,7 @@ start_rtrace() /* start rtrace process */ } maxqlen = 0; for (nprocs = 0; nprocs < ncprocs; nprocs++) { /* spawn children */ - psiz = open_process(rtpd[nprocs], rtargv); + psiz = open_process(&rtpd[nprocs], rtargv); if (psiz <= 0) error(SYSTEM, "cannot start rtrace process"); n = psiz/(RPACKSIZ*6*sizeof(float)); @@ -134,8 +137,8 @@ register PACKET *p; /* write out the packet */ packrays(rtbuf, p); if ((n = p->nr) < RPACKSIZ) /* add flush block? */ - bzero((char *)(rtbuf+6*n++), 6*sizeof(float)); - if (writebuf(rtpd[pn][1], (char *)rtbuf, 6*sizeof(float)*n) < 0) + memset((char *)(rtbuf+6*n++), '\0', 6*sizeof(float)); + if (writebuf(rtpd[pn].w, (char *)rtbuf, 6*sizeof(float)*n) < 0) error(SYSTEM, "write error in queue_packet"); p->next = NULL; if (!pqlen[pn]++) /* add it to the end of the queue */ @@ -164,10 +167,10 @@ int poll; FD_ZERO(&readset); FD_ZERO(&errset); n = 0; for (pn = nprocs; pn--; ) { if (pqlen[pn]) - FD_SET(rtpd[pn][0], &readset); - FD_SET(rtpd[pn][0], &errset); - if (rtpd[pn][0] >= n) - n = rtpd[pn][0] + 1; + FD_SET(rtpd[pn].r, &readset); + FD_SET(rtpd[pn].r, &errset); + if (rtpd[pn].r >= n) + n = rtpd[pn].r + 1; } /* make the call */ n = select(n, &readset, (fd_set *)NULL, &errset, @@ -181,11 +184,11 @@ int poll; return(NULL); /* make read call(s) */ for (pn = 0; pn < nprocs; pn++) { - if (!FD_ISSET(rtpd[pn][0], &readset) && - !FD_ISSET(rtpd[pn][0], &errset)) + if (!FD_ISSET(rtpd[pn].r, &readset) && + !FD_ISSET(rtpd[pn].r, &errset)) continue; reread: - n = read(rtpd[pn][0], (char *)rtbuf, + n = read(rtpd[pn].r, (char *)rtbuf, 4*sizeof(float)*RPACKSIZ*pqlen[pn]); if (n < 0) { if (errno == EINTR | errno == EAGAIN) @@ -200,7 +203,7 @@ int poll; nr++; /* add flush block */ n -= 4*sizeof(float)*nr; if (n < 0) { /* get remainder */ - n += readbuf(rtpd[pn][0], + n += readbuf(rtpd[pn].r, (char *)(bp+4*nr)+n, -n); if (n) goto eoferr; @@ -267,7 +270,7 @@ flush_queue() /* empty all rtrace queues */ if (rpl->nr < RPACKSIZ) nr++; /* add flush block */ } - n = readbuf(rtpd[i][0], (char *)rtbuf, + n = readbuf(rtpd[i].r, (char *)rtbuf, 4*sizeof(float)*nr); if (n < 0) error(SYSTEM, "read failure in flush_queue"); @@ -311,7 +314,7 @@ end_rtrace() /* close rtrace process(es) */ if (nprocs > 1) killpersist(); while (nprocs > 0) { - rv = close_process(rtpd[--nprocs]); + rv = close_process(&rtpd[--nprocs]); if (rv > 0) status = rv; }
