root/radiance/ray/src/hd/rholo2l.c
Revision: 3.19
Committed: Thu Apr 21 03:11:55 2022 UTC (2 years, 1 month ago) by greg
Changes since 3.18: +2 -2 lines
perf: Replaced random()%modulus with irandom(modulus) where appropriate
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.19 static const char RCSid[] = "$Id: rholo2l.c,v 3.18 2018/10/05 19:19:16 greg Exp $";
3 gregl 3.1 #endif
4     /*
5     * Routines for local rtrace execution
6     */
7
8 schorsch 3.13 #include <signal.h>
9     #include <sys/time.h>
10 schorsch 3.14 #include <string.h>
11 schorsch 3.13
12 gregl 3.1 #include "rholo.h"
13     #include "random.h"
14 gregl 3.6 #include "paths.h"
15 gregl 3.3 #include "selcall.h"
16 schorsch 3.13 #include "rtprocess.h"
17 gregl 3.1
18     #ifndef MAXPROC
19 gregl 3.8 #define MAXPROC 64
20 gregl 3.1 #endif
21
22 gregl 3.8 int nprocs = 0; /* running process count */
23
24 gregl 3.6 static char pfile[] = TEMPLATE; /* persist file name */
25 gregl 3.1
26 schorsch 3.13 static SUBPROC rtpd[MAXPROC]; /* process descriptors */
27 gregl 3.1 static float *rtbuf = NULL; /* allocated i/o buffer */
28     static int maxqlen = 0; /* maximum packets per queue */
29
30     static PACKET *pqueue[MAXPROC]; /* packet queues */
31     static int pqlen[MAXPROC]; /* packet queue lengths */
32
33 schorsch 3.16 static int bestout(void);
34     static int slots_avail(void);
35     static void queue_packet(PACKET *p);
36     static PACKET * get_packets(int poll);
37     static void killpersist(void);
38 gregl 3.1
39 schorsch 3.16
40 greg 3.18 int
41 schorsch 3.16 start_rtrace(void) /* start rtrace process */
42 gregl 3.1 {
43     static char buf1[8];
44     int rmaxpack = 0;
45 gregl 3.9 int psiz, n;
46 gregl 3.1 /* get number of processes */
47 gregl 3.10 if (ncprocs <= 0 || nprocs > 0)
48 gregl 3.1 return(0);
49 gregl 3.9 if (ncprocs > MAXPROC) {
50 gregl 3.1 sprintf(errmsg,
51     "number of rtrace processes reduced from %d to %d",
52 gregl 3.9 ncprocs, MAXPROC);
53 gregl 3.1 error(WARNING, errmsg);
54 gregl 3.9 ncprocs = MAXPROC;
55 gregl 3.1 }
56 gregl 3.9 if (rtargv[rtargc-1] != vval(OCTREE)) {
57     /* add compulsory options */
58     rtargv[rtargc++] = "-i-";
59     rtargv[rtargc++] = "-I-";
60     rtargv[rtargc++] = "-h-";
61     rtargv[rtargc++] = "-ld-";
62     sprintf(buf1, "%d", RPACKSIZ);
63     rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1;
64     rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0";
65     rtargv[rtargc++] = "-fff";
66     rtargv[rtargc++] = vbool(VDIST) ? "-ovl" : "-ovL";
67     if (nowarn)
68     rtargv[rtargc++] = "-w-";
69     if (ncprocs > 1) {
70     mktemp(pfile);
71     rtargv[rtargc++] = "-PP"; rtargv[rtargc++] = pfile;
72     }
73     rtargv[rtargc++] = vval(OCTREE);
74     rtargv[rtargc] = NULL;
75 gregl 3.1 }
76     maxqlen = 0;
77 gregl 3.9 for (nprocs = 0; nprocs < ncprocs; nprocs++) { /* spawn children */
78 schorsch 3.13 psiz = open_process(&rtpd[nprocs], rtargv);
79 gregl 3.1 if (psiz <= 0)
80     error(SYSTEM, "cannot start rtrace process");
81     n = psiz/(RPACKSIZ*6*sizeof(float));
82     if (maxqlen == 0) {
83     if (!(maxqlen = n))
84     error(INTERNAL,
85     "bad pipe buffer size assumption");
86 gregl 3.11 sleep(2);
87 gregl 3.1 } else if (n != maxqlen)
88     error(INTERNAL, "varying pipe buffer size!");
89     rmaxpack += n;
90     }
91     rtbuf = (float *)malloc(RPACKSIZ*6*sizeof(float)*maxqlen);
92     if (rtbuf == NULL)
93     error(SYSTEM, "malloc failure in start_rtrace");
94     return(rmaxpack);
95     }
96
97
98     static int
99 schorsch 3.16 bestout(void) /* get best process to process packet */
100 gregl 3.1 {
101     int cnt;
102 greg 3.18 int pn, i;
103 gregl 3.1
104     pn = 0; /* find shortest queue */
105     for (i = 1; i < nprocs; i++)
106     if (pqlen[i] < pqlen[pn])
107     pn = i;
108     /* sanity check */
109     if (pqlen[pn] == maxqlen)
110     return(-1);
111     cnt = 0; /* count number of ties */
112     for (i = pn; i < nprocs; i++)
113     if (pqlen[i] == pqlen[pn])
114     cnt++;
115     /* break ties fairly */
116 greg 3.19 if ((cnt = irandom(cnt)))
117 gregl 3.1 for (i = pn; i < nprocs; i++)
118     if (pqlen[i] == pqlen[pn] && !cnt--)
119     return(i);
120     return(pn);
121     }
122
123
124 schorsch 3.16 static int
125     slots_avail(void) /* count packet slots available */
126 gregl 3.1 {
127 greg 3.18 int nslots = 0;
128     int i;
129 gregl 3.1
130     for (i = nprocs; i--; )
131     nslots += maxqlen - pqlen[i];
132     return(nslots);
133     }
134
135
136 schorsch 3.16 static void
137     queue_packet( /* queue up a beam packet */
138 greg 3.18 PACKET *p
139 schorsch 3.16 )
140 gregl 3.1 {
141     int pn, n;
142     /* determine process to write to */
143     if ((pn = bestout()) < 0)
144     error(INTERNAL, "rtrace input queues are full!");
145     /* write out the packet */
146     packrays(rtbuf, p);
147     if ((n = p->nr) < RPACKSIZ) /* add flush block? */
148 schorsch 3.14 memset((char *)(rtbuf+6*n++), '\0', 6*sizeof(float));
149 schorsch 3.13 if (writebuf(rtpd[pn].w, (char *)rtbuf, 6*sizeof(float)*n) < 0)
150 gregl 3.1 error(SYSTEM, "write error in queue_packet");
151     p->next = NULL;
152     if (!pqlen[pn]++) /* add it to the end of the queue */
153     pqueue[pn] = p;
154     else {
155 greg 3.18 PACKET *rpl = pqueue[pn];
156 gregl 3.1 while (rpl->next != NULL)
157     rpl = rpl->next;
158     rpl->next = p;
159     }
160     }
161
162
163 schorsch 3.16 static PACKET *
164     get_packets( /* read packets from rtrace processes */
165     int poll
166     )
167 gregl 3.1 {
168     static struct timeval tpoll; /* zero timeval struct */
169     fd_set readset, errset;
170     PACKET *pldone = NULL, *plend;
171 greg 3.18 PACKET *p;
172 gregl 3.1 int n, nr;
173 greg 3.18 int pn;
174 gregl 3.1 float *bp;
175     /* prepare select call */
176     FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
177     for (pn = nprocs; pn--; ) {
178     if (pqlen[pn])
179 schorsch 3.13 FD_SET(rtpd[pn].r, &readset);
180     FD_SET(rtpd[pn].r, &errset);
181     if (rtpd[pn].r >= n)
182     n = rtpd[pn].r + 1;
183 gregl 3.1 }
184     /* make the call */
185     n = select(n, &readset, (fd_set *)NULL, &errset,
186     poll ? &tpoll : (struct timeval *)NULL);
187     if (n < 0) {
188     if (errno == EINTR) /* interrupted select call */
189     return(NULL);
190     error(SYSTEM, "select call failure in get_packets");
191     }
192     if (n == 0) /* is nothing ready? */
193     return(NULL);
194     /* make read call(s) */
195     for (pn = 0; pn < nprocs; pn++) {
196 schorsch 3.13 if (!FD_ISSET(rtpd[pn].r, &readset) &&
197     !FD_ISSET(rtpd[pn].r, &errset))
198 gregl 3.1 continue;
199     reread:
200 schorsch 3.13 n = read(rtpd[pn].r, (char *)rtbuf,
201 gregl 3.1 4*sizeof(float)*RPACKSIZ*pqlen[pn]);
202     if (n < 0) {
203 schorsch 3.15 if ((errno == EINTR) | (errno == EAGAIN))
204 gregl 3.1 goto reread;
205     error(SYSTEM, "read error in get_packets");
206     }
207     if (n == 0)
208     goto eoferr;
209     bp = rtbuf; /* finish processing */
210     for (p = pqueue[pn]; n && p != NULL; p = p->next) {
211     if ((nr = p->nr) < RPACKSIZ)
212     nr++; /* add flush block */
213     n -= 4*sizeof(float)*nr;
214     if (n < 0) { /* get remainder */
215 schorsch 3.13 n += readbuf(rtpd[pn].r,
216 gregl 3.1 (char *)(bp+4*nr)+n, -n);
217     if (n)
218     goto eoferr;
219     }
220     donerays(p, bp);
221     bp += 4*nr;
222     pqlen[pn]--;
223     }
224     if (n) /* read past end? */
225     error(INTERNAL, "packet sync error in get_packets");
226     /* take from queue */
227 gregl 3.2 if (pldone == NULL)
228 gregl 3.1 pldone = plend = pqueue[pn];
229     else
230     plend->next = pqueue[pn];
231     while (plend->next != p)
232     plend = plend->next;
233     plend->next = NULL;
234     pqueue[pn] = p;
235     }
236     return(pldone); /* return finished packets */
237     eoferr:
238 gregl 3.3 error(USER, "rtrace process died");
239 schorsch 3.16 return NULL; /* pro forma return */
240 gregl 3.1 }
241
242
243 greg 3.18 PACKET *
244 schorsch 3.16 do_packets( /* queue a packet list, return finished */
245 greg 3.18 PACKET *pl
246 schorsch 3.16 )
247 gregl 3.1 {
248 greg 3.18 PACKET *p;
249 gregl 3.1 /* consistency check */
250     if (nprocs < 1)
251     error(CONSISTENCY, "do_packets called with no active process");
252     /* queue each new packet */
253     while (pl != NULL) {
254     p = pl; pl = p->next; p->next = NULL;
255     queue_packet(p);
256     }
257     return(get_packets(slots_avail())); /* return processed packets */
258     }
259
260
261 greg 3.18 PACKET *
262 schorsch 3.16 flush_queue(void) /* empty all rtrace queues */
263 gregl 3.1 {
264     PACKET *rpdone = NULL;
265 greg 3.18 PACKET *rpl = NULL;
266 gregl 3.1 float *bp;
267 greg 3.18 PACKET *p;
268 gregl 3.1 int i, n, nr;
269
270     for (i = 0; i < nprocs; i++)
271     if (pqlen[i]) {
272     if (rpdone == NULL) { /* tack on queue */
273     rpdone = rpl = pqueue[i];
274 gregl 3.4 if ((nr = rpl->nr) < RPACKSIZ) nr++;
275 gregl 3.1 } else {
276     rpl->next = pqueue[i];
277 gregl 3.2 nr = 0;
278 gregl 3.1 }
279 gregl 3.2 while (rpl->next != NULL) {
280     nr += (rpl = rpl->next)->nr;
281     if (rpl->nr < RPACKSIZ)
282     nr++; /* add flush block */
283     }
284 schorsch 3.13 n = readbuf(rtpd[i].r, (char *)rtbuf,
285 gregl 3.2 4*sizeof(float)*nr);
286 gregl 3.1 if (n < 0)
287     error(SYSTEM, "read failure in flush_queue");
288     bp = rtbuf; /* process packets */
289     for (p = pqueue[i]; p != NULL; p = p->next) {
290     if ((nr = p->nr) < RPACKSIZ)
291     nr++; /* add flush block */
292     n -= 4*sizeof(float)*nr;
293     if (n >= 0)
294     donerays(p, bp);
295     else
296     p->nr = 0; /* short data error */
297     bp += 4*nr;
298     }
299     pqueue[i] = NULL; /* zero this queue */
300     pqlen[i] = 0;
301     }
302     return(rpdone); /* return all packets completed */
303     }
304
305
306 schorsch 3.16 static void
307     killpersist(void) /* kill persistent process */
308 gregl 3.1 {
309     FILE *fp;
310     int pid;
311
312 gregl 3.6 if ((fp = fopen(pfile, "r")) == NULL)
313 gregl 3.1 return;
314     if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
315 gregl 3.6 unlink(pfile);
316 gregl 3.1 fclose(fp);
317     }
318
319
320 greg 3.18 int
321 schorsch 3.16 end_rtrace(void) /* close rtrace process(es) */
322 gregl 3.1 {
323     int status = 0, rv;
324
325     if (nprocs > 1)
326     killpersist();
327 greg 3.17 status = close_processes(rtpd, nprocs);
328     nprocs = 0;
329 greg 3.12 free((void *)rtbuf);
330 gregl 3.1 rtbuf = NULL;
331     maxqlen = 0;
332     return(status);
333     }
