root/radiance/ray/src/hd/rholo2l.c
Revision: 3.9
Committed: Fri Dec 12 11:13:17 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.8: +25 -23 lines
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for local rtrace execution
9 */
10
11 #include "rholo.h"
12 #include "random.h"
13 #include "paths.h"
14 #include "selcall.h"
15 #include <signal.h>
16 #include <sys/time.h>
17
18 #ifndef MAXPROC
19 #define MAXPROC 64
20 #endif
21
22 int nprocs = 0; /* running process count */
23
24 static char pfile[] = TEMPLATE; /* persist file name */
25
26 static int rtpd[MAXPROC][3]; /* process descriptors */
27 static float *rtbuf = NULL; /* allocated i/o buffer */
28 static int maxqlen = 0; /* maximum packets per queue */
29
30 static PACKET *pqueue[MAXPROC]; /* packet queues */
31 static int pqlen[MAXPROC]; /* packet queue lengths */
32
33
34 int
35 start_rtrace() /* start rtrace process */
36 {
37 static char buf1[8];
38 int rmaxpack = 0;
39 int psiz, n;
40 /* get number of processes */
41 if (ncprocs <= 0)
42 return(0);
43 if (ncprocs > MAXPROC) {
44 sprintf(errmsg,
45 "number of rtrace processes reduced from %d to %d",
46 ncprocs, MAXPROC);
47 error(WARNING, errmsg);
48 ncprocs = MAXPROC;
49 }
50 if (rtargv[rtargc-1] != vval(OCTREE)) {
51 /* add compulsory options */
52 rtargv[rtargc++] = "-i-";
53 rtargv[rtargc++] = "-I-";
54 rtargv[rtargc++] = "-h-";
55 rtargv[rtargc++] = "-ld-";
56 sprintf(buf1, "%d", RPACKSIZ);
57 rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1;
58 rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0";
59 rtargv[rtargc++] = "-fff";
60 rtargv[rtargc++] = vbool(VDIST) ? "-ovl" : "-ovL";
61 if (nowarn)
62 rtargv[rtargc++] = "-w-";
63 if (ncprocs > 1) {
64 mktemp(pfile);
65 rtargv[rtargc++] = "-PP"; rtargv[rtargc++] = pfile;
66 }
67 rtargv[rtargc++] = vval(OCTREE);
68 rtargv[rtargc] = NULL;
69 }
70 maxqlen = 0;
71 for (nprocs = 0; nprocs < ncprocs; nprocs++) { /* spawn children */
72 psiz = open_process(rtpd[nprocs], rtargv);
73 if (psiz <= 0)
74 error(SYSTEM, "cannot start rtrace process");
75 n = psiz/(RPACKSIZ*6*sizeof(float));
76 if (maxqlen == 0) {
77 if (!(maxqlen = n))
78 error(INTERNAL,
79 "bad pipe buffer size assumption");
80 } else if (n != maxqlen)
81 error(INTERNAL, "varying pipe buffer size!");
82 rmaxpack += n;
83 }
84 rtbuf = (float *)malloc(RPACKSIZ*6*sizeof(float)*maxqlen);
85 if (rtbuf == NULL)
86 error(SYSTEM, "malloc failure in start_rtrace");
87 return(rmaxpack);
88 }
89
90
91 static int
92 bestout() /* get best process to process packet */
93 {
94 int cnt;
95 register int pn, i;
96
97 pn = 0; /* find shortest queue */
98 for (i = 1; i < nprocs; i++)
99 if (pqlen[i] < pqlen[pn])
100 pn = i;
101 /* sanity check */
102 if (pqlen[pn] == maxqlen)
103 return(-1);
104 cnt = 0; /* count number of ties */
105 for (i = pn; i < nprocs; i++)
106 if (pqlen[i] == pqlen[pn])
107 cnt++;
108 /* break ties fairly */
109 if ((cnt = random() % cnt))
110 for (i = pn; i < nprocs; i++)
111 if (pqlen[i] == pqlen[pn] && !cnt--)
112 return(i);
113 return(pn);
114 }
115
116
117 int
118 slots_avail() /* count packet slots available */
119 {
120 register int nslots = 0;
121 register int i;
122
123 for (i = nprocs; i--; )
124 nslots += maxqlen - pqlen[i];
125 return(nslots);
126 }
127
128
129 queue_packet(p) /* queue up a beam packet */
130 register PACKET *p;
131 {
132 int pn, n;
133 /* determine process to write to */
134 if ((pn = bestout()) < 0)
135 error(INTERNAL, "rtrace input queues are full!");
136 /* write out the packet */
137 packrays(rtbuf, p);
138 if ((n = p->nr) < RPACKSIZ) /* add flush block? */
139 bzero((char *)(rtbuf+6*n++), 6*sizeof(float));
140 if (writebuf(rtpd[pn][1], (char *)rtbuf, 6*sizeof(float)*n) < 0)
141 error(SYSTEM, "write error in queue_packet");
142 p->next = NULL;
143 if (!pqlen[pn]++) /* add it to the end of the queue */
144 pqueue[pn] = p;
145 else {
146 register PACKET *rpl = pqueue[pn];
147 while (rpl->next != NULL)
148 rpl = rpl->next;
149 rpl->next = p;
150 }
151 }
152
153
154 PACKET *
155 get_packets(poll) /* read packets from rtrace processes */
156 int poll;
157 {
158 static struct timeval tpoll; /* zero timeval struct */
159 fd_set readset, errset;
160 PACKET *pldone = NULL, *plend;
161 register PACKET *p;
162 int n, nr;
163 register int pn;
164 float *bp;
165 /* prepare select call */
166 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
167 for (pn = nprocs; pn--; ) {
168 if (pqlen[pn])
169 FD_SET(rtpd[pn][0], &readset);
170 FD_SET(rtpd[pn][0], &errset);
171 if (rtpd[pn][0] >= n)
172 n = rtpd[pn][0] + 1;
173 }
174 /* make the call */
175 n = select(n, &readset, (fd_set *)NULL, &errset,
176 poll ? &tpoll : (struct timeval *)NULL);
177 if (n < 0) {
178 if (errno == EINTR) /* interrupted select call */
179 return(NULL);
180 error(SYSTEM, "select call failure in get_packets");
181 }
182 if (n == 0) /* is nothing ready? */
183 return(NULL);
184 /* make read call(s) */
185 for (pn = 0; pn < nprocs; pn++) {
186 if (!FD_ISSET(rtpd[pn][0], &readset) &&
187 !FD_ISSET(rtpd[pn][0], &errset))
188 continue;
189 reread:
190 n = read(rtpd[pn][0], (char *)rtbuf,
191 4*sizeof(float)*RPACKSIZ*pqlen[pn]);
192 if (n < 0) {
193 if (errno == EINTR | errno == EAGAIN)
194 goto reread;
195 error(SYSTEM, "read error in get_packets");
196 }
197 if (n == 0)
198 goto eoferr;
199 bp = rtbuf; /* finish processing */
200 for (p = pqueue[pn]; n && p != NULL; p = p->next) {
201 if ((nr = p->nr) < RPACKSIZ)
202 nr++; /* add flush block */
203 n -= 4*sizeof(float)*nr;
204 if (n < 0) { /* get remainder */
205 n += readbuf(rtpd[pn][0],
206 (char *)(bp+4*nr)+n, -n);
207 if (n)
208 goto eoferr;
209 }
210 donerays(p, bp);
211 bp += 4*nr;
212 pqlen[pn]--;
213 }
214 if (n) /* read past end? */
215 error(INTERNAL, "packet sync error in get_packets");
216 /* take from queue */
217 if (pldone == NULL)
218 pldone = plend = pqueue[pn];
219 else
220 plend->next = pqueue[pn];
221 while (plend->next != p)
222 plend = plend->next;
223 plend->next = NULL;
224 pqueue[pn] = p;
225 }
226 return(pldone); /* return finished packets */
227 eoferr:
228 error(USER, "rtrace process died");
229 }
230
231
232 PACKET *
233 do_packets(pl) /* queue a packet list, return finished */
234 register PACKET *pl;
235 {
236 register PACKET *p;
237 /* consistency check */
238 if (nprocs < 1)
239 error(CONSISTENCY, "do_packets called with no active process");
240 /* queue each new packet */
241 while (pl != NULL) {
242 p = pl; pl = p->next; p->next = NULL;
243 queue_packet(p);
244 }
245 return(get_packets(slots_avail())); /* return processed packets */
246 }
247
248
249 PACKET *
250 flush_queue() /* empty all rtrace queues */
251 {
252 PACKET *rpdone = NULL;
253 register PACKET *rpl;
254 float *bp;
255 register PACKET *p;
256 int i, n, nr;
257
258 for (i = 0; i < nprocs; i++)
259 if (pqlen[i]) {
260 if (rpdone == NULL) { /* tack on queue */
261 rpdone = rpl = pqueue[i];
262 if ((nr = rpl->nr) < RPACKSIZ) nr++;
263 } else {
264 rpl->next = pqueue[i];
265 nr = 0;
266 }
267 while (rpl->next != NULL) {
268 nr += (rpl = rpl->next)->nr;
269 if (rpl->nr < RPACKSIZ)
270 nr++; /* add flush block */
271 }
272 n = readbuf(rtpd[i][0], (char *)rtbuf,
273 4*sizeof(float)*nr);
274 if (n < 0)
275 error(SYSTEM, "read failure in flush_queue");
276 bp = rtbuf; /* process packets */
277 for (p = pqueue[i]; p != NULL; p = p->next) {
278 if ((nr = p->nr) < RPACKSIZ)
279 nr++; /* add flush block */
280 n -= 4*sizeof(float)*nr;
281 if (n >= 0)
282 donerays(p, bp);
283 else
284 p->nr = 0; /* short data error */
285 bp += 4*nr;
286 }
287 pqueue[i] = NULL; /* zero this queue */
288 pqlen[i] = 0;
289 }
290 return(rpdone); /* return all packets completed */
291 }
292
293
294 static
295 killpersist() /* kill persistent process */
296 {
297 FILE *fp;
298 int pid;
299
300 if ((fp = fopen(pfile, "r")) == NULL)
301 return;
302 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
303 unlink(pfile);
304 fclose(fp);
305 }
306
307
308 int
309 end_rtrace() /* close rtrace process(es) */
310 {
311 int status = 0, rv;
312
313 if (nprocs > 1)
314 killpersist();
315 while (nprocs > 0) {
316 rv = close_process(rtpd[--nprocs]);
317 if (rv > 0)
318 status = rv;
319 }
320 free((char *)rtbuf);
321 rtbuf = NULL;
322 maxqlen = 0;
323 return(status);
324 }
