root/radiance/ray/src/hd/rholo2l.c
Changes since 3.15: +32 -21 lines
Diff to previous 3.15 , to selected 3.8
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 3.14 , to selected 3.8
Changes since 3.13: +3 -2 lines
Diff to previous 3.13 , to selected 3.8
Changes since 3.12: +18 -16 lines
Diff to previous 3.12 , to selected 3.8
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.11: +2 -5 lines
Diff to previous 3.11 , to selected 3.8
Tue Jan 20 15:04:23 1998 UTC (26 years, 3 months ago) by gregl
Diff to previous 3.10 , to selected 3.8
added sleep(2) on first rtrace process
Fri Dec 12 18:09:49 1997 UTC (26 years, 4 months ago) by gregl
Diff to previous 3.9 , to selected 3.8
added safety check to start_rtrace()
Fri Dec 12 11:13:17 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.8: +25 -23 lines
Diff to previous 3.8
Revision 3.8 - (view) (download) (annotate) - [selected]
Thu Dec 11 11:51:20 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.7: +3 -2 lines
Diff to previous 3.7
increased MAXPROC from 16 to 64 and made nprocs variable global
Tue Dec 2 16:35:45 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.6: +2 -1 lines
Diff to previous 3.6 , to selected 3.8
leave rtrace -w option alone if rholo -w not set
Mon Dec 1 16:32:49 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.5: +7 -5 lines
Diff to previous 3.5 , to selected 3.8
added "VDISTANCE" variable for virtual distance calculation
made persist file vary with process id so multiple rholo's don't interfere
Mon Nov 24 15:18:47 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 3.4 , to selected 3.8
changed to using immediate distance from rtrace
Mon Nov 3 18:33:13 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 3.3 , to selected 3.8
Fri Oct 31 15:49:41 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2 , to selected 3.8
include selcall.h
Fri Oct 31 11:44:09 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +9 -6 lines
Diff to previous 3.1 , to selected 3.8
initial bug fixes
Fri Oct 31 10:23:29 1997 UTC (26 years, 6 months ago) by gregl
Diff to selected 3.8
