root/Development/ray/src/hd/rholo2l.c
Thu Jan 1 11:21:55 2004 UTC (21 years, 10 months ago) by schorsch
Changes since 3.15: +32 -21 lines
Diff to previous 3.15
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 3.14
Mon Jun 30 14:59:12 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 3.13: +3 -2 lines
Diff to previous 3.13
Thu Jun 26 00:58:10 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 3.12: +18 -16 lines
Diff to previous 3.12
Sat Feb 22 02:07:25 2003 UTC (22 years, 9 months ago) by greg
Changes since 3.11: +2 -5 lines
Diff to previous 3.11
Tue Jan 20 15:04:23 1998 UTC (27 years, 10 months ago) by gregl
Diff to previous 3.10
added sleep(2) on first rtrace process
Fri Dec 12 18:09:49 1997 UTC (27 years, 11 months ago) by gregl
Diff to previous 3.9
added safety check to start_rtrace()
Fri Dec 12 11:13:17 1997 UTC (27 years, 11 months ago) by gregl
Changes since 3.8: +25 -23 lines
Diff to previous 3.8
Thu Dec 11 11:51:20 1997 UTC (27 years, 11 months ago) by gregl
Changes since 3.7: +3 -2 lines
Diff to previous 3.7
increased MAXPROC from 16 to 64 and made nprocs variable global
Tue Dec 2 16:35:45 1997 UTC (27 years, 11 months ago) by gregl
Changes since 3.6: +2 -1 lines
Diff to previous 3.6
leave rtrace -w option alone if rholo -w not set
Mon Dec 1 16:32:49 1997 UTC (27 years, 11 months ago) by gregl
Changes since 3.5: +7 -5 lines
Diff to previous 3.5
added "VDISTANCE" variable for virtual distance calculation
made persist file vary with process id so multiple rholo's don't interfere
Mon Nov 24 15:18:47 1997 UTC (28 years ago) by gregl
Diff to previous 3.4
changed to using immediate distance from rtrace
Mon Nov 3 18:33:13 1997 UTC (28 years ago) by gregl
Diff to previous 3.3
Fri Oct 31 15:49:41 1997 UTC (28 years ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2
include selcall.h
Fri Oct 31 11:44:09 1997 UTC (28 years ago) by gregl
Changes since 3.1: +9 -6 lines
initial bug fixes
Fri Oct 31 10:23:29 1997 UTC (28 years ago) by gregl
