--- ray/src/hd/rholo2l.c 2003/06/26 00:58:10 3.13 +++ ray/src/hd/rholo2l.c 2004/01/01 11:21:55 3.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rholo2l.c,v 3.13 2003/06/26 00:58:10 schorsch Exp $"; +static const char RCSid[] = "$Id: rholo2l.c,v 3.16 2004/01/01 11:21:55 schorsch Exp $"; #endif /* * Routines for local rtrace execution @@ -7,6 +7,7 @@ static const char RCSid[] = "$Id: rholo2l.c,v 3.13 200 #include #include +#include #include "rholo.h" #include "random.h" @@ -29,9 +30,15 @@ static int maxqlen = 0; /* maximum packets per queue static PACKET *pqueue[MAXPROC]; /* packet queues */ static int pqlen[MAXPROC]; /* packet queue lengths */ +static int bestout(void); +static int slots_avail(void); +static void queue_packet(PACKET *p); +static PACKET * get_packets(int poll); +static void killpersist(void); -int -start_rtrace() /* start rtrace process */ + +extern int +start_rtrace(void) /* start rtrace process */ { static char buf1[8]; int rmaxpack = 0; @@ -89,7 +96,7 @@ start_rtrace() /* start rtrace process */ static int -bestout() /* get best process to process packet */ +bestout(void) /* get best process to process packet */ { int cnt; register int pn, i; @@ -114,8 +121,8 @@ bestout() /* get best process to process packet */ } -int -slots_avail() /* count packet slots available */ +static int +slots_avail(void) /* count packet slots available */ { register int nslots = 0; register int i; @@ -126,8 +133,10 @@ slots_avail() /* count packet slots available */ } -queue_packet(p) /* queue up a beam packet */ -register PACKET *p; +static void +queue_packet( /* queue up a beam packet */ + register PACKET *p +) { int pn, n; /* determine process to write to */ @@ -136,7 +145,7 @@ register PACKET *p; /* write out the packet */ packrays(rtbuf, p); if ((n = p->nr) < RPACKSIZ) /* add flush block? */ - bzero((char *)(rtbuf+6*n++), 6*sizeof(float)); + memset((char *)(rtbuf+6*n++), '\0', 6*sizeof(float)); if (writebuf(rtpd[pn].w, (char *)rtbuf, 6*sizeof(float)*n) < 0) error(SYSTEM, "write error in queue_packet"); p->next = NULL; @@ -151,9 +160,10 @@ register PACKET *p; } -PACKET * -get_packets(poll) /* read packets from rtrace processes */ -int poll; +static PACKET * +get_packets( /* read packets from rtrace processes */ + int poll +) { static struct timeval tpoll; /* zero timeval struct */ fd_set readset, errset; @@ -190,7 +200,7 @@ int poll; n = read(rtpd[pn].r, (char *)rtbuf, 4*sizeof(float)*RPACKSIZ*pqlen[pn]); if (n < 0) { - if (errno == EINTR | errno == EAGAIN) + if ((errno == EINTR) | (errno == EAGAIN)) goto reread; error(SYSTEM, "read error in get_packets"); } @@ -226,12 +236,14 @@ int poll; return(pldone); /* return finished packets */ eoferr: error(USER, "rtrace process died"); + return NULL; /* pro forma return */ } -PACKET * -do_packets(pl) /* queue a packet list, return finished */ -register PACKET *pl; +extern PACKET * +do_packets( /* queue a packet list, return finished */ + register PACKET *pl +) { register PACKET *p; /* consistency check */ @@ -246,11 +258,11 @@ register PACKET *pl; } -PACKET * -flush_queue() /* empty all rtrace queues */ +extern PACKET * +flush_queue(void) /* empty all rtrace queues */ { PACKET *rpdone = NULL; - register PACKET *rpl; + register PACKET *rpl = NULL; float *bp; register PACKET *p; int i, n, nr; @@ -291,8 +303,8 @@ flush_queue() /* empty all rtrace queues */ } -static -killpersist() /* kill persistent process */ +static void +killpersist(void) /* kill persistent process */ { FILE *fp; int pid; @@ -305,8 +317,8 @@ killpersist() /* kill persistent process */ } -int -end_rtrace() /* close rtrace process(es) */ +extern int +end_rtrace(void) /* close rtrace process(es) */ { int status = 0, rv;
