1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Rtrace support routines for holodeck rendering |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "paths.h" |
13 |
#include "random.h" |
14 |
15 |
16 |
packrays(rod, p) /* pack ray origins and directions */ |
17 |
register float *rod; |
18 |
register PACKET *p; |
19 |
20 |
static FVECT ro, rd; |
21 |
GCOORD gc[2]; |
22 |
int ila[2], hsh; |
23 |
double d, sl[4]; |
24 |
register int i; |
25 |
26 |
if (!hdbcoord(gc, hdlist[p->hd], p->bi)) |
27 |
error(CONSISTENCY, "bad beam index in packrays"); |
28 |
ila[0] = p->hd; ila[1] = p->bi; |
29 |
hsh = ilhash(ila,2) + p->nc; |
30 |
for (i = 0; i < p->nr; i++) { |
31 |
multisamp(sl, 4, urand(hsh+i)); |
32 |
p->ra[i].r[0][0] = sl[0] * 256.; |
33 |
p->ra[i].r[0][1] = sl[1] * 256.; |
34 |
p->ra[i].r[1][0] = sl[2] * 256.; |
35 |
p->ra[i].r[1][1] = sl[3] * 256.; |
36 |
d = hdray(ro, rd, hdlist[p->hd], gc, p->ra[i].r); |
37 |
if (p->offset != NULL) { |
38 |
VSUM(ro, ro, rd, d); /* exterior only */ |
39 |
p->offset[i] = d; |
40 |
41 |
VCOPY(rod, ro); |
42 |
rod += 3; |
43 |
VCOPY(rod, rd); |
44 |
rod += 3; |
45 |
46 |
47 |
48 |
49 |
donerays(p, rvl) /* encode finished ray computations */ |
50 |
51 |
register float *rvl; |
52 |
53 |
double d; |
54 |
register int i; |
55 |
56 |
57 |
setcolr(p->ra[i].v, rvl[0], rvl[1], rvl[2]); |
58 |
d = rvl[3]; |
59 |
if (p->offset != NULL) |
60 |
d += p->offset[i]; |
61 |
p->ra[i].d = hdcode(hdlist[p->hd], d); |
62 |
rvl += 4; |
63 |
64 |
p->nc += p->nr; |
65 |
66 |
67 |
68 |
int |
69 |
done_rtrace() /* clean up and close rtrace calculation */ |
70 |
71 |
int status; |
72 |
/* already closed? */ |
73 |
if (!nprocs) |
74 |
return; |
75 |
wputs("closing rtrace process...\n"); |
76 |
/* flush beam queue */ |
77 |
done_packets(flush_queue()); |
78 |
/* close rtrace */ |
79 |
if ((status = end_rtrace())) |
80 |
error(WARNING, "bad exit status from rtrace"); |
81 |
if (vdef(REPORT)) /* report time */ |
82 |
report(0); |
83 |
return(status); /* return status */ |
84 |
85 |
86 |
87 |
new_rtrace() /* restart rtrace calculation */ |
88 |
89 |
char combuf[128]; |
90 |
91 |
if (nprocs > 0) /* already running? */ |
92 |
return; |
93 |
wputs("restarting rtrace process...\n"); |
94 |
starttime = time(NULL); /* reset start time and counts */ |
95 |
npacksdone = nraysdone = 0L; |
96 |
if (vdef(TIME)) /* reset end time */ |
97 |
endtime = starttime + vflt(TIME)*3600. + .5; |
98 |
if (vdef(RIF)) { /* rerun rad to update octree */ |
99 |
sprintf(combuf, "rad -v 0 -s -w %s", vval(RIF)); |
100 |
if (system(combuf)) |
101 |
error(WARNING, "error running rad"); |
102 |
103 |
if (start_rtrace() < 1) /* start rtrace */ |
104 |
error(WARNING, "cannot restart rtrace"); |
105 |
else if (vdef(REPORT)) |
106 |
report(0); |
107 |
108 |
109 |
110 |
getradfile() /* run rad and get needed variables */ |
111 |
112 |
static short mvar[] = {OCTREE,-1}; |
113 |
static char tf1[] = TEMPLATE; |
114 |
char tf2[64]; |
115 |
char combuf[256]; |
116 |
char *pippt; |
117 |
register int i; |
118 |
register char *cp; |
119 |
/* check if rad file specified */ |
120 |
if (!vdef(RIF)) |
121 |
return; |
122 |
/* create rad command */ |
123 |
mktemp(tf1); |
124 |
sprintf(tf2, "%s.rif", tf1); |
125 |
sprintf(combuf, |
126 |
"rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH", |
127 |
vval(RIF), tf1); |
128 |
cp = combuf; |
129 |
while (*cp){ |
130 |
if (*cp == '|') pippt = cp; |
131 |
cp++; |
132 |
} /* match unset variables */ |
133 |
for (i = 0; mvar[i] >= 0; i++) |
134 |
if (!vdef(mvar[i])) { |
135 |
*cp++ = '|'; |
136 |
strcpy(cp, vnam(mvar[i])); |
137 |
while (*cp) cp++; |
138 |
pippt = NULL; |
139 |
140 |
if (pippt != NULL) |
141 |
strcpy(pippt, "> /dev/null"); /* nothing to match */ |
142 |
else |
143 |
sprintf(cp, ")[ \t]*=' > %s", tf2); |
144 |
if (system(combuf)) { |
145 |
unlink(tf2); /* clean up */ |
146 |
unlink(tf1); |
147 |
error(SYSTEM, "cannot execute rad command"); |
148 |
149 |
if (pippt == NULL) { |
150 |
loadvars(tf2); /* load variables */ |
151 |
unlink(tf2); |
152 |
153 |
rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */ |
154 |
unlink(tf1); /* clean up */ |
155 |
156 |
157 |
158 |
report(t) /* report progress so far */ |
159 |
time_t t; |
160 |
161 |
static time_t seconds2go = 1000000; |
162 |
163 |
if (t == 0L) |
164 |
t = time(NULL); |
165 |
sprintf(errmsg, "%ld packets (%ld rays) done after %.2f hours\n", |
166 |
npacksdone, nraysdone, (t-starttime)/3600.); |
167 |
eputs(errmsg); |
168 |
if (seconds2go == 1000000) |
169 |
seconds2go = vdef(REPORT) ? (long)(vflt(REPORT)*60. + .5) : 0L; |
170 |
if (seconds2go) |
171 |
reporttime = t + seconds2go; |
172 |
