--- ray/src/hd/rholo2.c 1997/12/01 16:34:36 3.4 +++ ray/src/hd/rholo2.c 1997/12/15 21:04:24 3.9 @@ -9,6 +9,7 @@ static char SCCSid[] = "$SunId$ SGI"; */ #include "rholo.h" +#include "paths.h" #include "random.h" @@ -33,8 +34,10 @@ register PACKET *p; p->ra[i].r[1][0] = sl[2] * 256.; p->ra[i].r[1][1] = sl[3] * 256.; d = hdray(ro, rd, hdlist[p->hd], gc, p->ra[i].r); + if (!vdef(OBSTRUCTIONS)) + d *= frandom(); /* random offset */ if (p->offset != NULL) { - VSUM(ro, ro, rd, d); /* exterior only */ + VSUM(ro, ro, rd, d); /* advance ray */ p->offset[i] = d; } VCOPY(rod, ro); @@ -61,4 +64,115 @@ register float *rvl; rvl += 4; } p->nc += p->nr; +} + + +int +done_rtrace() /* clean up and close rtrace calculation */ +{ + int status; + /* already closed? */ + if (!nprocs) + return; + /* flush beam queue */ + done_packets(flush_queue()); + /* sync holodeck */ + hdsync(NULL, 1); + /* close rtrace */ + if ((status = end_rtrace())) + error(WARNING, "bad exit status from rtrace"); + if (vdef(REPORT)) { /* report time */ + eputs("rtrace process ended\n"); + report(0); + } + return(status); /* return status */ +} + + +new_rtrace() /* restart rtrace calculation */ +{ + char combuf[128]; + + if (nprocs > 0) /* already running? */ + return; + starttime = time(NULL); /* reset start time and counts */ + npacksdone = nraysdone = 0L; + if (vdef(TIME)) /* reset end time */ + endtime = starttime + vflt(TIME)*3600. + .5; + if (vdef(RIF)) { /* rerun rad to update octree */ + sprintf(combuf, "rad -v 0 -s -w %s", vval(RIF)); + if (system(combuf)) + error(WARNING, "error running rad"); + } + if (start_rtrace() < 1) /* start rtrace */ + error(WARNING, "cannot restart rtrace"); + else if (vdef(REPORT)) { + eputs("rtrace process restarted\n"); + report(0); + } +} + + +getradfile() /* run rad and get needed variables */ +{ + static short mvar[] = {OCTREE,-1}; + static char tf1[] = TEMPLATE; + char tf2[64]; + char combuf[256]; + char *pippt; + register int i; + register char *cp; + /* check if rad file specified */ + if (!vdef(RIF)) + return; + /* create rad command */ + mktemp(tf1); + sprintf(tf2, "%s.rif", tf1); + sprintf(combuf, + "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH", + vval(RIF), tf1); + cp = combuf; + while (*cp){ + if (*cp == '|') pippt = cp; + cp++; + } /* match unset variables */ + for (i = 0; mvar[i] >= 0; i++) + if (!vdef(mvar[i])) { + *cp++ = '|'; + strcpy(cp, vnam(mvar[i])); + while (*cp) cp++; + pippt = NULL; + } + if (pippt != NULL) + strcpy(pippt, "> /dev/null"); /* nothing to match */ + else + sprintf(cp, ")[ \t]*=' > %s", tf2); + if (system(combuf)) { + unlink(tf2); /* clean up */ + unlink(tf1); + error(SYSTEM, "cannot execute rad command"); + } + if (pippt == NULL) { + loadvars(tf2); /* load variables */ + unlink(tf2); + } + rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */ + unlink(tf1); /* clean up */ +} + + +report(t) /* report progress so far */ +time_t t; +{ + static time_t seconds2go = 1000000; + + if (t == 0L) + t = time(NULL); + sprintf(errmsg, "%ld packets (%ld rays) done after %.2f hours\n", + npacksdone, nraysdone, (t-starttime)/3600.); + eputs(errmsg); + if (seconds2go == 1000000) + seconds2go = vdef(REPORT) ? (long)(vflt(REPORT)*60. + .5) : 0L; + if (seconds2go) + reporttime = t + seconds2go; }
