--- ray/src/hd/rholo2.c 1997/12/01 16:34:36 3.4 +++ ray/src/hd/rholo2.c 1997/12/12 18:23:09 3.5 @@ -9,6 +9,7 @@ static char SCCSid[] = "$SunId$ SGI"; */ #include "rholo.h" +#include "paths.h" #include "random.h" @@ -61,4 +62,91 @@ register float *rvl; rvl += 4; } p->nc += p->nr; +} + + +int +done_rtrace() /* clean up and close rtrace calculation */ +{ + int status; + /* already closed? */ + if (!nprocs) + return; + /* report activity */ + wputs("closing rtrace process...\n"); + /* flush beam queue */ + done_packets(flush_queue()); + /* close rtrace */ + if ((status = end_rtrace())) + error(WARNING, "bad exit status from rtrace"); + if (vdef(REPORT)) /* report time */ + report(0); + return(status); /* return status */ +} + + +new_rtrace() /* restart rtrace calculation */ +{ + char combuf[128]; + + if (nprocs > 0) /* already running? */ + return; + wputs("restarting rtrace process...\n"); + if (vdef(RIF)) { /* rerun rad to update octree */ + sprintf(combuf, "rad -v 0 -s -w %s", vval(RIF)); + if (system(combuf)) + error(WARNING, "error running rad"); + } + if (start_rtrace() < 1) /* start rtrace */ + error(WARNING, "cannot restart rtrace"); + else if (vdef(REPORT)) + report(0); +} + + +getradfile() /* run rad and get needed variables */ +{ + static short mvar[] = {OCTREE,-1}; + static char tf1[] = TEMPLATE; + char tf2[64]; + char combuf[256]; + char *pippt; + register int i; + register char *cp; + /* check if rad file specified */ + if (!vdef(RIF)) + return; + /* create rad command */ + mktemp(tf1); + sprintf(tf2, "%s.rif", tf1); + sprintf(combuf, + "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH", + vval(RIF), tf1); + cp = combuf; + while (*cp){ + if (*cp == '|') pippt = cp; + cp++; + } /* match unset variables */ + for (i = 0; mvar[i] >= 0; i++) + if (!vdef(mvar[i])) { + *cp++ = '|'; + strcpy(cp, vnam(mvar[i])); + while (*cp) cp++; + pippt = NULL; + } + if (pippt != NULL) + strcpy(pippt, "> /dev/null"); /* nothing to match */ + else + sprintf(cp, ")[ \t]*=' > %s", tf2); + if (system(combuf)) { + unlink(tf2); /* clean up */ + unlink(tf1); + error(SYSTEM, "cannot execute rad command"); + } + if (pippt == NULL) { + loadvars(tf2); /* load variables */ + unlink(tf2); + } + rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */ + unlink(tf1); /* clean up */ }
