--- ray/src/hd/rholo2.c 1998/12/03 15:21:05 3.20 +++ ray/src/hd/rholo2.c 2003/07/27 22:12:02 3.27 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo2.c,v 3.27 2003/07/27 22:12:02 schorsch Exp $"; #endif - /* * Rtrace support routines for holodeck rendering */ @@ -30,7 +27,7 @@ register struct gclim *gcl; register HOLO *hp; GCOORD *gc; { - register FLOAT *v; + register RREAL *v; register int i; if (hp != NULL) { @@ -41,64 +38,108 @@ GCOORD *gc; gcl->erg2 *= (1./3.) * myeye.rng*myeye.rng; } if (gc != NULL) - copystruct(&gcl->gc, gc); + gcl->gc = *gc; gcl->gmin[0] = gcl->gmin[1] = FHUGE; gcl->gmax[0] = gcl->gmax[1] = -FHUGE; } static -groweyelim(gcl, gc, r0, r1) /* grow grid limits about eye point */ +groweyelim(gcl, gc, r0, r1, tight) /* grow grid limits about eye point */ register struct gclim *gcl; GCOORD *gc; double r0, r1; +int tight; { FVECT gp, ab; - double vlen, plen, dv0, dv1; - double rd2, dwall, gpos; - int eyeout; - register int i, g0, g1; - + double ab2, od, cfact; + double sqcoef[3], ctcoef[3], licoef[3], cnst; + int gw, gi[2]; + double wallpos, a, b, c, d, e, f; + double root[2], yex; + int n, i, j, nex; + /* point/view cone */ i = gc->w>>1; - if (gc->w&1) - eyeout = (gp[i] = gcl->hp->grid[i]) < gcl->egp[i]; - else - eyeout = (gp[i] = 0) > gcl->egp[i]; + gp[i] = gc->w&1 ? gcl->hp->grid[i] : 0; gp[hdwg0[gc->w]] = gc->i[0] + r0; gp[hdwg1[gc->w]] = gc->i[1] + r1; VSUB(ab, gcl->egp, gp); - rd2 = DOT(ab,ab); - if (rd2 <= gcl->erg2) { + ab2 = DOT(ab, ab); + gw = gcl->gc.w>>1; + if ((i==gw ? ab[gw]*ab[gw] : ab2) <= gcl->erg2 + FTINY) { gcl->gmin[0] = gcl->gmin[1] = -FHUGE; gcl->gmax[0] = gcl->gmax[1] = FHUGE; - return; + return; /* too close (to wall) */ } - rd2 = gcl->erg2 / rd2; - vlen = 1. - rd2; - plen = sqrt(rd2 * vlen); - g0 = gcl->gc.w>>1; - dwall = (gcl->gc.w&1 ? gcl->hp->grid[g0] : 0) - gp[g0]; - for (i = 0; i < 4; i++) { - if (i == 2) - plen = -plen; - g1 = (g0+(i&1)+1)%3; - dv0 = vlen*ab[g0] + plen*ab[g1]; - dv1 = vlen*ab[g1] - plen*ab[g0]; - if ((dv0 < 0 ^ dwall < 0 ^ eyeout) || - (dv0 <= FTINY && dv0 >= -FTINY)) { - if (eyeout) - dv1 = -dv1; - if (dv1 > FTINY) - gcl->gmax[i&1] = FHUGE; - else if (dv1 < -FTINY) - gcl->gmin[i&1] = -FHUGE; - } else { - gpos = gp[g1] + dv1*dwall/dv0; - if (gpos < gcl->gmin[i&1]) - gcl->gmin[i&1] = gpos; - if (gpos > gcl->gmax[i&1]) - gcl->gmax[i&1] = gpos; + ab2 = 1./ab2; /* 1/norm2(ab) */ + od = DOT(gp, ab); /* origin dot direction */ + cfact = 1./(1. - ab2*gcl->erg2); /* tan^2 + 1 of cone angle */ + for (i = 0; i < 3; i++) { /* compute cone equation */ + sqcoef[i] = ab[i]*ab[i]*cfact*ab2 - 1.; + ctcoef[i] = 2.*ab[i]*ab[(i+1)%3]*cfact*ab2; + licoef[i] = 2.*(gp[i] - ab[i]*cfact*od*ab2); + } + cnst = cfact*od*od*ab2 - DOT(gp,gp); + /* + * CONE: sqcoef[0]*x*x + sqcoef[1]*y*y + sqcoef[2]*z*z + * + ctcoef[0]*x*y + ctcoef[1]*y*z + ctcoef[2]*z*x + * + licoef[0]*x + licoef[1]*y + licoef[2]*z + cnst == 0 + */ + /* equation for conic section in plane */ + gi[0] = hdwg0[gcl->gc.w]; + gi[1] = hdwg1[gcl->gc.w]; + wallpos = gcl->gc.w&1 ? gcl->hp->grid[gw] : 0; + a = sqcoef[gi[0]]; /* x2 */ + b = ctcoef[gi[0]]; /* xy */ + c = sqcoef[gi[1]]; /* y2 */ + d = ctcoef[gw]*wallpos + licoef[gi[0]]; /* x */ + e = ctcoef[gi[1]]*wallpos + licoef[gi[1]]; /* y */ + f = wallpos*(wallpos*sqcoef[gw] + licoef[gw]) + cnst; + for (i = 0; i < 2; i++) { + if (i) { /* swap x and y coefficients */ + register double t; + t = a; a = c; c = t; + t = d; d = e; e = t; } + nex = 0; /* check global extrema */ + n = quadratic(root, a*(4.*a*c-b*b), 2.*a*(2.*c*d-b*e), + d*(c*d-b*e) + f*b*b); + while (n-- > 0) { + if (gc->w>>1 == gi[i] && + (gc->w&1) ^ (root[n] < gp[gc->w>>1])) { + if (gc->w&1) + gcl->gmin[i] = -FHUGE; + else + gcl->gmax[i] = FHUGE; + nex++; + continue; /* hyperbolic */ + } + if (tight) { + yex = (-2.*a*root[n] - d)/b; + if (yex < gcl->gc.i[1-i] || + yex > gcl->gc.i[1-i]+1) + continue; /* outside cell */ + } + if (root[n] < gcl->gmin[i]) + gcl->gmin[i] = root[n]; + if (root[n] > gcl->gmax[i]) + gcl->gmax[i] = root[n]; + nex++; + } + /* check local extrema */ + for (j = nex < 2 ? 2 : 0; j--; ) { + yex = gcl->gc.i[1-i] + j; + n = quadratic(root, a, b*yex+d, yex*(yex*c+e)+f); + while (n-- > 0) { + if (gc->w>>1 == gi[i] && + (gc->w&1) ^ (root[n] < gp[gc->w>>1])) + continue; + if (root[n] < gcl->gmin[i]) + gcl->gmin[i] = root[n]; + if (root[n] > gcl->gmax[i]) + gcl->gmax[i] = root[n]; + } + } } } @@ -133,6 +174,10 @@ packrays(rod, p) /* pack ray origins and directions * register float *rod; register PACKET *p; { +#if 0 + double dist2sum = 0.; + FVECT vt; +#endif int nretries = p->nr + 2; struct gclim eyelim; short rrng0[2][2], rrng1[2][2]; @@ -146,9 +191,13 @@ register PACKET *p; error(CONSISTENCY, "bad beam index in packrays"); if ((useyelim = myeye.rng > FTINY)) { initeyelim(&eyelim, hdlist[p->hd], gc); - groweyelim(&eyelim, gc+1, 0., 0.); - groweyelim(&eyelim, gc+1, 1., 1.); - useyelim &= clipeyelim(rrng0, &eyelim); + groweyelim(&eyelim, gc+1, 0., 0., 0); + groweyelim(&eyelim, gc+1, 1., 1., 0); + useyelim = clipeyelim(rrng0, &eyelim); +#ifdef DEBUG + if (!useyelim) + error(WARNING, "no eye overlap in packrays"); +#endif } for (i = 0; i < p->nr; i++) { retry: @@ -160,9 +209,14 @@ register PACKET *p; + rrng0[1][0]; groweyelim(&eyelim, gc, (1./256.)*(p->ra[i].r[0][0]+.5), - (1./256.)*(p->ra[i].r[0][1]+.5)); + (1./256.)*(p->ra[i].r[0][1]+.5), 1); if (!clipeyelim(rrng1, &eyelim)) { - useyelim &= nretries-- > 0; + useyelim = nretries-- > 0; +#ifdef DEBUG + if (!useyelim) + error(WARNING, + "exceeded retry limit in packrays"); +#endif goto retry; } p->ra[i].r[1][0] = (int)(frandom()*rrng1[0][1]) @@ -176,6 +230,10 @@ register PACKET *p; p->ra[i].r[1][1] = frandom() * 256.; } d = hdray(ro, rd, hdlist[p->hd], gc, p->ra[i].r); +#if 0 + VSUM(vt, ro, rd, d); + dist2sum += dist2line(myeye.vpt, ro, vt); +#endif if (p->offset != NULL) { if (!vdef(OBSTRUCTIONS)) d *= frandom(); /* random offset */ @@ -187,6 +245,10 @@ register PACKET *p; VCOPY(rod, rd); rod += 3; } +#if 0 + fprintf(stderr, "%f RMS (%d retries)\t", sqrt(dist2sum/p->nr), + p->nr + 2 - nretries); +#endif } @@ -215,7 +277,7 @@ done_rtrace() /* clean up and close rtrace calculati int status; /* already closed? */ if (!nprocs) - return; + return(0); /* flush beam queue */ done_packets(flush_queue()); /* sync holodeck */ @@ -286,7 +348,7 @@ getradfile() /* run rad and get needed variables */ pippt = NULL; } if (pippt != NULL) - strcpy(pippt, "> /dev/null"); /* nothing to match */ + strcpy(pippt, "> " NULL_DEVICE); /* nothing to match */ else sprintf(cp, ")[ \t]*=' > %s", tf2); #ifdef DEBUG
