--- ray/src/hd/rholo2.c 1998/11/25 17:20:25 3.18 +++ ray/src/hd/rholo2.c 1998/12/07 16:56:08 3.21 @@ -15,66 +15,242 @@ static char SCCSid[] = "$SunId$ SGI"; VIEWPOINT myeye; /* target view position */ +struct gclim { + HOLO *hp; /* holodeck pointer */ + GCOORD gc; /* grid cell */ + FVECT egp; /* eye grid point */ + double erg2; /* mean square eye grid range */ + double gmin[2], gmax[2]; /* grid coordinate limits */ +}; /* a grid coordinate range */ + +static +initeyelim(gcl, hp, gc) /* initialize grid coordinate limits */ +register struct gclim *gcl; +register HOLO *hp; +GCOORD *gc; +{ + register FLOAT *v; + register int i; + + if (hp != NULL) { + hdgrid(gcl->egp, gcl->hp = hp, myeye.vpt); + gcl->erg2 = 0; + for (i = 0, v = hp->wg[0]; i < 3; i++, v += 3) + gcl->erg2 += DOT(v,v); + gcl->erg2 *= (1./3.) * myeye.rng*myeye.rng; + } + if (gc != NULL) + copystruct(&gcl->gc, gc); + gcl->gmin[0] = gcl->gmin[1] = FHUGE; + gcl->gmax[0] = gcl->gmax[1] = -FHUGE; +} + + +static +groweyelim(gcl, gc, r0, r1, tight) /* grow grid limits about eye point */ +register struct gclim *gcl; +GCOORD *gc; +double r0, r1; +int tight; +{ + FVECT gp, ab; + double ab2, od, cfact; + double sqcoef[3], ctcoef[3], licoef[3], cnst; + int gw, gi[2]; + double wallpos, a, b, c, d, e, f; + double root[2], yex; + int n, i, j, nex; + /* point/view cone */ + i = gc->w>>1; + gp[i] = gc->w&1 ? gcl->hp->grid[i] : 0; + gp[hdwg0[gc->w]] = gc->i[0] + r0; + gp[hdwg1[gc->w]] = gc->i[1] + r1; + VSUB(ab, gcl->egp, gp); + ab2 = DOT(ab, ab); + gw = gcl->gc.w>>1; + if ((i==gw ? ab[gw]*ab[gw] : ab2) <= gcl->erg2 + FTINY) { + gcl->gmin[0] = gcl->gmin[1] = -FHUGE; + gcl->gmax[0] = gcl->gmax[1] = FHUGE; + return; /* too close (to wall) */ + } + ab2 = 1./ab2; /* 1/norm2(ab) */ + od = DOT(gp, ab); /* origin dot direction */ + cfact = 1./(1. - ab2*gcl->erg2); /* tan^2 + 1 of cone angle */ + for (i = 0; i < 3; i++) { /* compute cone equation */ + sqcoef[i] = ab[i]*ab[i]*cfact*ab2 - 1.; + ctcoef[i] = 2.*ab[i]*ab[(i+1)%3]*cfact*ab2; + licoef[i] = 2.*(gp[i] - ab[i]*cfact*od*ab2); + } + cnst = cfact*od*od*ab2 - DOT(gp,gp); + /* + * CONE: sqcoef[0]*x*x + sqcoef[1]*y*y + sqcoef[2]*z*z + * + ctcoef[0]*x*y + ctcoef[1]*y*z + ctcoef[2]*z*x + * + licoef[0]*x + licoef[1]*y + licoef[2]*z + cnst == 0 + */ + /* equation for conic section in plane */ + gi[0] = hdwg0[gcl->gc.w]; + gi[1] = hdwg1[gcl->gc.w]; + wallpos = gcl->gc.w&1 ? gcl->hp->grid[gw] : 0; + a = sqcoef[gi[0]]; /* x2 */ + b = ctcoef[gi[0]]; /* xy */ + c = sqcoef[gi[1]]; /* y2 */ + d = ctcoef[gw]*wallpos + licoef[gi[0]]; /* x */ + e = ctcoef[gi[1]]*wallpos + licoef[gi[1]]; /* y */ + f = wallpos*(wallpos*sqcoef[gw] + licoef[gw]) + cnst; + for (i = 0; i < 2; i++) { + if (i) { /* swap x and y coefficients */ + register double t; + t = a; a = c; c = t; + t = d; d = e; e = t; + } + nex = 0; /* check global extrema */ + n = quadratic(root, a*(4.*a*c-b*b), 2.*a*(2.*c*d-b*e), + d*(c*d-b*e) + f*b*b); + while (n-- > 0) { + if (gc->w>>1 == gi[i] && + (gc->w&1) ^ root[n] < gp[gc->w>>1]) { + if (gc->w&1) + gcl->gmin[i] = -FHUGE; + else + gcl->gmax[i] = FHUGE; + nex++; + continue; /* hyperbolic */ + } + if (tight) { + yex = (-2.*a*root[n] - d)/b; + if (yex < gcl->gc.i[1-i] || + yex > gcl->gc.i[1-i]+1) + continue; /* outside cell */ + } + if (root[n] < gcl->gmin[i]) + gcl->gmin[i] = root[n]; + if (root[n] > gcl->gmax[i]) + gcl->gmax[i] = root[n]; + nex++; + } + /* check local extrema */ + for (j = nex < 2 ? 2 : 0; j--; ) { + yex = gcl->gc.i[1-i] + j; + n = quadratic(root, a, b*yex+d, yex*(yex*c+e)+f); + while (n-- > 0) { + if (gc->w>>1 == gi[i] && + (gc->w&1) ^ root[n] < gp[gc->w>>1]) + continue; + if (root[n] < gcl->gmin[i]) + gcl->gmin[i] = root[n]; + if (root[n] > gcl->gmax[i]) + gcl->gmax[i] = root[n]; + } + } + } +} + + +static int +clipeyelim(rrng, gcl) /* clip eye limits to grid cell */ +register short rrng[2][2]; +register struct gclim *gcl; +{ + int incell = 1; + register int i; + + for (i = 0; i < 2; i++) { + if (gcl->gmin[i] < gcl->gc.i[i]) + gcl->gmin[i] = gcl->gc.i[i]; + if (gcl->gmax[i] > gcl->gc.i[i]+1) + gcl->gmax[i] = gcl->gc.i[i]+1; + if (gcl->gmax[i] > gcl->gmin[i]) { + rrng[i][0] = 256.*(gcl->gmin[i] - gcl->gc.i[i]) + + (1.-FTINY); + rrng[i][1] = 256.*(gcl->gmax[i] - gcl->gc.i[i]) + + (1.-FTINY) - rrng[i][0]; + } else + rrng[i][0] = rrng[i][1] = 0; + incell &= rrng[i][1] > 0; + } + return(incell); +} + + packrays(rod, p) /* pack ray origins and directions */ register float *rod; register PACKET *p; { - float packdc2[RPACKSIZ]; - int iterleft = 3*p->nr + 9; - BYTE rpos[2][2]; - FVECT ro, rd, rp1; +#if 0 + double dist2sum = 0.; + FVECT vt; +#endif + int nretries = p->nr + 2; + struct gclim eyelim; + short rrng0[2][2], rrng1[2][2]; + int useyelim; GCOORD gc[2]; - double d, dc2, md2, td2, dc2worst = FHUGE; - int i; - register int ii; + FVECT ro, rd; + double d; + register int i; if (!hdbcoord(gc, hdlist[p->hd], p->bi)) error(CONSISTENCY, "bad beam index in packrays"); - td2 = myeye.rng + FTINY; td2 *= td2; - for (i = 0, md2 = 0.; i < p->nr || (md2 > td2 && iterleft--); ) { - rpos[0][0] = frandom() * 256.; - rpos[0][1] = frandom() * 256.; - rpos[1][0] = frandom() * 256.; - rpos[1][1] = frandom() * 256.; - d = hdray(ro, rd, hdlist[p->hd], gc, rpos); - if (myeye.rng > FTINY) { /* check eyepoint */ - register int nexti; - - VSUM(rp1, ro, rd, d); - dc2 = dist2line(myeye.vpt, ro, rp1) / p->nr; - if (i == p->nr) { /* packet full */ - if (dc2 >= dc2worst) /* quick check */ - continue; - nexti = 0; /* find worst */ - for (ii = i; --ii; ) - if (packdc2[ii] > packdc2[nexti]) - nexti = ii; - if (dc2 >= (dc2worst = packdc2[nexti])) - continue; /* worse than worst */ - md2 -= dc2worst; - } else - nexti = i++; - md2 += packdc2[nexti] = dc2; /* new distance */ - ii = nexti; /* put it here */ - } else - ii = i++; + if ((useyelim = myeye.rng > FTINY)) { + initeyelim(&eyelim, hdlist[p->hd], gc); + groweyelim(&eyelim, gc+1, 0., 0., 0); + groweyelim(&eyelim, gc+1, 1., 1., 0); + useyelim = clipeyelim(rrng0, &eyelim); +#ifdef DEBUG + if (!useyelim) + error(WARNING, "no eye overlap in packrays"); +#endif + } + for (i = 0; i < p->nr; i++) { + retry: + if (useyelim) { + initeyelim(&eyelim, NULL, gc+1); + p->ra[i].r[0][0] = (int)(frandom()*rrng0[0][1]) + + rrng0[0][0]; + p->ra[i].r[0][1] = (int)(frandom()*rrng0[1][1]) + + rrng0[1][0]; + groweyelim(&eyelim, gc, + (1./256.)*(p->ra[i].r[0][0]+.5), + (1./256.)*(p->ra[i].r[0][1]+.5), 1); + if (!clipeyelim(rrng1, &eyelim)) { + useyelim = nretries-- > 0; +#ifdef DEBUG + if (!useyelim) + error(WARNING, + "exceeded retry limit in packrays"); +#endif + goto retry; + } + p->ra[i].r[1][0] = (int)(frandom()*rrng1[0][1]) + + rrng1[0][0]; + p->ra[i].r[1][1] = (int)(frandom()*rrng1[1][1]) + + rrng1[1][0]; + } else { + p->ra[i].r[0][0] = frandom() * 256.; + p->ra[i].r[0][1] = frandom() * 256.; + p->ra[i].r[1][0] = frandom() * 256.; + p->ra[i].r[1][1] = frandom() * 256.; + } + d = hdray(ro, rd, hdlist[p->hd], gc, p->ra[i].r); +#if 0 + VSUM(vt, ro, rd, d); + dist2sum += dist2line(myeye.vpt, ro, vt); +#endif if (p->offset != NULL) { if (!vdef(OBSTRUCTIONS)) d *= frandom(); /* random offset */ VSUM(ro, ro, rd, d); /* advance ray */ - p->offset[ii] = d; + p->offset[i] = d; } - p->ra[ii].r[0][0] = rpos[0][0]; - p->ra[ii].r[0][1] = rpos[0][1]; - p->ra[ii].r[1][0] = rpos[1][0]; - p->ra[ii].r[1][1] = rpos[1][1]; - VCOPY(rod+6*ii, ro); - VCOPY(rod+6*ii+3, rd); + VCOPY(rod, ro); + rod += 3; + VCOPY(rod, rd); + rod += 3; } -#ifdef DEBUG - fprintf(stderr, "%f mean distance for target %f (%d iterations left)\n", - sqrt(md2), myeye.rng, iterleft); +#if 0 + fprintf(stderr, "%f RMS (%d retries)\t", sqrt(dist2sum/p->nr), + p->nr + 2 - nretries); #endif }
