root/radiance/ray/src/hd/rholo2.c
Thu Jan 23 19:07:35 2025 UTC (6 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.31: +5 -4 lines
Diff to previous 3.31 , to selected 3.30
perf(rholo): Added -N option to rad command for mkillum and mkpmap efficiency
Thu Apr 21 22:31:42 2022 UTC (3 years, 3 months ago) by greg
Changes since 3.30: +9 -13 lines
Diff to previous 3.30
refactor: Switched to using irandom() where appropriate
Revision 3.30 - (view) (download) (annotate) - [selected]
Fri Oct 5 19:19:16 2018 UTC (6 years, 10 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 3.29: +24 -24 lines
Diff to previous 3.29
Mon Mar 21 19:06:08 2016 UTC (9 years, 4 months ago) by greg
Changes since 3.28: +3 -2 lines
Diff to previous 3.28 , to selected 3.30
Thu Jan 1 11:21:55 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 3.27: +47 -28 lines
Diff to previous 3.27 , to selected 3.30
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (22 years ago) by schorsch
Changes since 3.26: +3 -3 lines
Diff to previous 3.26 , to selected 3.30
Mon Jul 21 22:30:18 2003 UTC (22 years ago) by schorsch
Changes since 3.25: +2 -2 lines
Diff to previous 3.25 , to selected 3.30
Mon Jul 7 17:21:51 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 3.24 , to selected 3.30
Mon Jun 30 14:59:12 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 3.23 , to selected 3.30
Thu Jun 26 00:58:10 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 3.22 , to selected 3.30
Sat Feb 22 02:07:25 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.21: +1 -4 lines
Diff to previous 3.21 , to selected 3.30
Mon Dec 7 16:56:08 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.20: +108 -43 lines
Diff to previous 3.20 , to selected 3.30
went to more sophisticated cone extrema for view vicinity ray samples
Thu Dec 3 15:21:05 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.19: +67 -74 lines
Diff to previous 3.19 , to selected 3.30
improved sampling in packrays() but still not perfect
Tue Dec 1 15:47:05 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.18: +162 -44 lines
Diff to previous 3.18 , to selected 3.30
eliminated rejection sampling, but problems remain
Wed Nov 25 17:20:25 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.17: +13 -18 lines
Diff to previous 3.17 , to selected 3.30
eliminated unnecessary sort on distance list
Tue Nov 24 17:38:09 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.16: +12 -10 lines
Diff to previous 3.16 , to selected 3.30
changed to RMS distance
Tue Nov 24 17:05:36 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.15: +54 -20 lines
Diff to previous 3.15 , to selected 3.30
Mon Nov 23 18:17:53 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.14: +10 -51 lines
Diff to previous 3.14 , to selected 3.30
took duplicate ray checking out again (too expensive)
Mon Nov 23 17:50:26 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.13: +51 -10 lines
Diff to previous 3.13 , to selected 3.30
added duplicate ray checking
Mon Jul 6 18:17:20 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.12: +4 -6 lines
Diff to previous 3.12 , to selected 3.30
fixed bug by eliminated exit code check on rad
Wed Jun 10 17:46:21 1998 UTC (27 years, 2 months ago) by gwlarson
Diff to previous 3.11 , to selected 3.30
allowed for new rad EYESEP variable
Sat Jan 10 16:37:10 1998 UTC (27 years, 7 months ago) by gregl
Changes since 3.10: +4 -2 lines
Diff to previous 3.10 , to selected 3.30
made loading of rad input file optional
Thu Dec 18 09:33:35 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.9: +2 -2 lines
Diff to previous 3.9 , to selected 3.30
changed user messages slightly
Mon Dec 15 21:04:24 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.8: +6 -4 lines
Diff to previous 3.8 , to selected 3.30
only report starting/stopping rtrace if REPORT variable set
Sat Dec 13 10:30:55 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.7: +3 -1 lines
Diff to previous 3.7 , to selected 3.30
allow OBSTRUCTIONS to be undefined, and use random offset in that case
Fri Dec 12 19:52:32 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.6: +2 -0 lines
Diff to previous 3.6 , to selected 3.30
modified hdsync() to optionally sync all unflushed beams
Fri Dec 12 18:33:50 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.5: +21 -1 lines
Diff to previous 3.5 , to selected 3.30
reset start time and ray counts in new_rtrace()
Fri Dec 12 18:23:09 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.4: +88 -0 lines
Diff to previous 3.4 , to selected 3.30
moved a few routines from rholo.c to rholo2.c
Mon Dec 1 16:34:36 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.3: +10 -7 lines
Diff to previous 3.3 , to selected 3.30
changed ray sampling to low discrepency sequence
Thu Nov 6 16:37:45 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.2: +1 -1 lines
Diff to previous 3.2 , to selected 3.30
changed BCOORD to GCOORD[2]
Fri Oct 31 11:44:09 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.1: +6 -1 lines
Diff to previous 3.1 , to selected 3.30
initial bug fixes
Fri Oct 31 10:23:29 1997 UTC (27 years, 9 months ago) by gregl
Diff to selected 3.30
