--- ray/src/hd/rholo2.c 2003/07/21 22:30:18 3.26 +++ ray/src/hd/rholo2.c 2004/01/01 11:21:55 3.28 @@ -1,10 +1,12 @@ #ifndef lint -static const char RCSid[] = "$Id: rholo2.c,v 3.26 2003/07/21 22:30:18 schorsch Exp $"; +static const char RCSid[] = "$Id: rholo2.c,v 3.28 2004/01/01 11:21:55 schorsch Exp $"; #endif /* * Rtrace support routines for holodeck rendering */ +#include + #include "rholo.h" #include "paths.h" #include "random.h" @@ -20,12 +22,18 @@ struct gclim { double gmin[2], gmax[2]; /* grid coordinate limits */ }; /* a grid coordinate range */ +static void initeyelim(struct gclim *gcl, HOLO *hp, GCOORD *gc); +static void groweyelim(struct gclim *gcl, GCOORD *gc, + double r0, double r1, int tight); +static int clipeyelim(short rrng[2][2], struct gclim *gcl); -static -initeyelim(gcl, hp, gc) /* initialize grid coordinate limits */ -register struct gclim *gcl; -register HOLO *hp; -GCOORD *gc; + +static void +initeyelim( /* initialize grid coordinate limits */ + register struct gclim *gcl, + register HOLO *hp, + GCOORD *gc +) { register RREAL *v; register int i; @@ -44,12 +52,14 @@ GCOORD *gc; } -static -groweyelim(gcl, gc, r0, r1, tight) /* grow grid limits about eye point */ -register struct gclim *gcl; -GCOORD *gc; -double r0, r1; -int tight; +static void +groweyelim( /* grow grid limits about eye point */ + register struct gclim *gcl, + GCOORD *gc, + double r0, + double r1, + int tight +) { FVECT gp, ab; double ab2, od, cfact; @@ -106,7 +116,7 @@ int tight; d*(c*d-b*e) + f*b*b); while (n-- > 0) { if (gc->w>>1 == gi[i] && - (gc->w&1) ^ root[n] < gp[gc->w>>1]) { + (gc->w&1) ^ (root[n] < gp[gc->w>>1])) { if (gc->w&1) gcl->gmin[i] = -FHUGE; else @@ -132,7 +142,7 @@ int tight; n = quadratic(root, a, b*yex+d, yex*(yex*c+e)+f); while (n-- > 0) { if (gc->w>>1 == gi[i] && - (gc->w&1) ^ root[n] < gp[gc->w>>1]) + (gc->w&1) ^ (root[n] < gp[gc->w>>1])) continue; if (root[n] < gcl->gmin[i]) gcl->gmin[i] = root[n]; @@ -145,9 +155,10 @@ int tight; static int -clipeyelim(rrng, gcl) /* clip eye limits to grid cell */ -register short rrng[2][2]; -register struct gclim *gcl; +clipeyelim( /* clip eye limits to grid cell */ + register short rrng[2][2], + register struct gclim *gcl +) { int incell = 1; register int i; @@ -170,9 +181,11 @@ register struct gclim *gcl; } -packrays(rod, p) /* pack ray origins and directions */ -register float *rod; -register PACKET *p; +extern void +packrays( /* pack ray origins and directions */ + register float *rod, + register PACKET *p +) { #if 0 double dist2sum = 0.; @@ -252,9 +265,11 @@ register PACKET *p; } -donerays(p, rvl) /* encode finished ray computations */ -register PACKET *p; -register float *rvl; +extern void +donerays( /* encode finished ray computations */ + register PACKET *p, + register float *rvl +) { double d; register int i; @@ -271,8 +286,8 @@ register float *rvl; } -int -done_rtrace() /* clean up and close rtrace calculation */ +extern int +done_rtrace(void) /* clean up and close rtrace calculation */ { int status; /* already closed? */ @@ -293,7 +308,8 @@ done_rtrace() /* clean up and close rtrace calculati } -new_rtrace() /* restart rtrace calculation */ +extern void +new_rtrace(void) /* restart rtrace calculation */ { char combuf[128]; @@ -317,13 +333,14 @@ new_rtrace() /* restart rtrace calculation */ } -getradfile() /* run rad and get needed variables */ +extern int +getradfile(void) /* run rad and get needed variables */ { static short mvar[] = {OCTREE,EYESEP,-1}; static char tf1[] = TEMPLATE; char tf2[64]; char combuf[256]; - char *pippt; + char *pippt = NULL; register int i; register char *cp; /* check if rad file specified */ @@ -365,8 +382,10 @@ getradfile() /* run rad and get needed variables */ } -report(t) /* report progress so far */ -time_t t; +extern void +report( /* report progress so far */ + time_t t +) { static time_t seconds2go = 1000000;
