Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
went to more sophisticated cone extrema for view vicinity ray samples
improved sampling in packrays() but still not perfect
eliminated rejection sampling, but problems remain
eliminated unnecessary sort on distance list
changed to RMS distance
took duplicate ray checking out again (too expensive)
added duplicate ray checking
fixed bug by eliminated exit code check on rad
allowed for new rad EYESEP variable
made loading of rad input file optional
changed user messages slightly
only report starting/stopping rtrace if REPORT variable set
allow OBSTRUCTIONS to be undefined, and use random offset in that case
modified hdsync() to optionally sync all unflushed beams
reset start time and ray counts in new_rtrace()
moved a few routines from rholo.c to rholo2.c
changed ray sampling to low discrepency sequence
changed BCOORD to GCOORD[2]
initial bug fixes
