--- ray/src/hd/rholo2.c 1998/07/06 18:17:20 3.13 +++ ray/src/hd/rholo2.c 2022/04/21 22:31:42 3.31 @@ -1,42 +1,251 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo2.c,v 3.31 2022/04/21 22:31:42 greg Exp $"; #endif - /* * Rtrace support routines for holodeck rendering */ +#include + #include "rholo.h" #include "paths.h" #include "random.h" -packrays(rod, p) /* pack ray origins and directions */ -register float *rod; -register PACKET *p; +VIEWPOINT myeye; /* target view position */ + +struct gclim { + HOLO *hp; /* holodeck pointer */ + GCOORD gc; /* grid cell */ + FVECT egp; /* eye grid point */ + double erg2; /* mean square eye grid range */ + double gmin[2], gmax[2]; /* grid coordinate limits */ +}; /* a grid coordinate range */ + +static void initeyelim(struct gclim *gcl, HOLO *hp, GCOORD *gc); +static void groweyelim(struct gclim *gcl, GCOORD *gc, + double r0, double r1, int tight); +static int clipeyelim(short rrng[2][2], struct gclim *gcl); + + +static void +initeyelim( /* initialize grid coordinate limits */ + struct gclim *gcl, + HOLO *hp, + GCOORD *gc +) { - static FVECT ro, rd; + RREAL *v; + int i; + + if (hp != NULL) { + hdgrid(gcl->egp, gcl->hp = hp, myeye.vpt); + gcl->erg2 = 0; + for (i = 0, v = hp->wg[0]; i < 3; i++, v += 3) + gcl->erg2 += DOT(v,v); + gcl->erg2 *= (1./3.) * myeye.rng*myeye.rng; + } + if (gc != NULL) + gcl->gc = *gc; + gcl->gmin[0] = gcl->gmin[1] = FHUGE; + gcl->gmax[0] = gcl->gmax[1] = -FHUGE; +} + + +static void +groweyelim( /* grow grid limits about eye point */ + struct gclim *gcl, + GCOORD *gc, + double r0, + double r1, + int tight +) +{ + FVECT gp, ab; + double ab2, od, cfact; + double sqcoef[3], ctcoef[3], licoef[3], cnst; + int gw, gi[2]; + double wallpos, a, b, c, d, e, f; + double root[2], yex; + int n, i, j, nex; + /* point/view cone */ + i = gc->w>>1; + gp[i] = gc->w&1 ? gcl->hp->grid[i] : 0; + gp[hdwg0[gc->w]] = gc->i[0] + r0; + gp[hdwg1[gc->w]] = gc->i[1] + r1; + VSUB(ab, gcl->egp, gp); + ab2 = DOT(ab, ab); + gw = gcl->gc.w>>1; + if ((i==gw ? ab[gw]*ab[gw] : ab2) <= gcl->erg2 + FTINY) { + gcl->gmin[0] = gcl->gmin[1] = -FHUGE; + gcl->gmax[0] = gcl->gmax[1] = FHUGE; + return; /* too close (to wall) */ + } + ab2 = 1./ab2; /* 1/norm2(ab) */ + od = DOT(gp, ab); /* origin dot direction */ + cfact = 1./(1. - ab2*gcl->erg2); /* tan^2 + 1 of cone angle */ + for (i = 0; i < 3; i++) { /* compute cone equation */ + sqcoef[i] = ab[i]*ab[i]*cfact*ab2 - 1.; + ctcoef[i] = 2.*ab[i]*ab[(i+1)%3]*cfact*ab2; + licoef[i] = 2.*(gp[i] - ab[i]*cfact*od*ab2); + } + cnst = cfact*od*od*ab2 - DOT(gp,gp); + /* + * CONE: sqcoef[0]*x*x + sqcoef[1]*y*y + sqcoef[2]*z*z + * + ctcoef[0]*x*y + ctcoef[1]*y*z + ctcoef[2]*z*x + * + licoef[0]*x + licoef[1]*y + licoef[2]*z + cnst == 0 + */ + /* equation for conic section in plane */ + gi[0] = hdwg0[gcl->gc.w]; + gi[1] = hdwg1[gcl->gc.w]; + wallpos = gcl->gc.w&1 ? gcl->hp->grid[gw] : 0; + a = sqcoef[gi[0]]; /* x2 */ + b = ctcoef[gi[0]]; /* xy */ + c = sqcoef[gi[1]]; /* y2 */ + d = ctcoef[gw]*wallpos + licoef[gi[0]]; /* x */ + e = ctcoef[gi[1]]*wallpos + licoef[gi[1]]; /* y */ + f = wallpos*(wallpos*sqcoef[gw] + licoef[gw]) + cnst; + for (i = 0; i < 2; i++) { + if (i) { /* swap x and y coefficients */ + double t; + t = a; a = c; c = t; + t = d; d = e; e = t; + } + nex = 0; /* check global extrema */ + n = quadratic(root, a*(4.*a*c-b*b), 2.*a*(2.*c*d-b*e), + d*(c*d-b*e) + f*b*b); + while (n-- > 0) { + if (gc->w>>1 == gi[i] && + (gc->w&1) ^ (root[n] < gp[gc->w>>1])) { + if (gc->w&1) + gcl->gmin[i] = -FHUGE; + else + gcl->gmax[i] = FHUGE; + nex++; + continue; /* hyperbolic */ + } + if (tight) { + yex = (-2.*a*root[n] - d)/b; + if (yex < gcl->gc.i[1-i] || + yex > gcl->gc.i[1-i]+1) + continue; /* outside cell */ + } + if (root[n] < gcl->gmin[i]) + gcl->gmin[i] = root[n]; + if (root[n] > gcl->gmax[i]) + gcl->gmax[i] = root[n]; + nex++; + } + /* check local extrema */ + for (j = nex < 2 ? 2 : 0; j--; ) { + yex = gcl->gc.i[1-i] + j; + n = quadratic(root, a, b*yex+d, yex*(yex*c+e)+f); + while (n-- > 0) { + if (gc->w>>1 == gi[i] && + (gc->w&1) ^ (root[n] < gp[gc->w>>1])) + continue; + if (root[n] < gcl->gmin[i]) + gcl->gmin[i] = root[n]; + if (root[n] > gcl->gmax[i]) + gcl->gmax[i] = root[n]; + } + } + } +} + + +static int +clipeyelim( /* clip eye limits to grid cell */ + short rrng[2][2], + struct gclim *gcl +) +{ + int incell = 1; + int i; + + for (i = 0; i < 2; i++) { + if (gcl->gmin[i] < gcl->gc.i[i]) + gcl->gmin[i] = gcl->gc.i[i]; + if (gcl->gmax[i] > gcl->gc.i[i]+1) + gcl->gmax[i] = gcl->gc.i[i]+1; + if (gcl->gmax[i] > gcl->gmin[i]) { + rrng[i][0] = 256.*(gcl->gmin[i] - gcl->gc.i[i]) + + (1.-FTINY); + rrng[i][1] = 256.*(gcl->gmax[i] - gcl->gc.i[i]) + + (1.-FTINY) - rrng[i][0]; + } else + rrng[i][0] = rrng[i][1] = 0; + incell &= rrng[i][1] > 0; + } + return(incell); +} + + +void +packrays( /* pack ray origins and directions */ + float *rod, + PACKET *p +) +{ +#if 0 + double dist2sum = 0.; + FVECT vt; +#endif + int nretries = p->nr + 2; + struct gclim eyelim; + short rrng0[2][2], rrng1[2][2]; + int useyelim; GCOORD gc[2]; - int ila[2], hsh; - double d, sl[4]; - register int i; + FVECT ro, rd; + double d; + int i; if (!hdbcoord(gc, hdlist[p->hd], p->bi)) error(CONSISTENCY, "bad beam index in packrays"); - ila[0] = p->hd; ila[1] = p->bi; - hsh = ilhash(ila,2) + p->nc; + if ((useyelim = myeye.rng > FTINY)) { + initeyelim(&eyelim, hdlist[p->hd], gc); + groweyelim(&eyelim, gc+1, 0., 0., 0); + groweyelim(&eyelim, gc+1, 1., 1., 0); + useyelim = clipeyelim(rrng0, &eyelim); +#ifdef DEBUG + if (!useyelim) + error(WARNING, "no eye overlap in packrays"); +#endif + } for (i = 0; i < p->nr; i++) { - multisamp(sl, 4, urand(hsh+i)); - p->ra[i].r[0][0] = sl[0] * 256.; - p->ra[i].r[0][1] = sl[1] * 256.; - p->ra[i].r[1][0] = sl[2] * 256.; - p->ra[i].r[1][1] = sl[3] * 256.; + retry: + if (useyelim) { + initeyelim(&eyelim, NULL, gc+1); + p->ra[i].r[0][0] = irandom(rrng0[0][1]) + rrng0[0][0]; + p->ra[i].r[0][1] = irandom(rrng0[1][1]) + rrng0[1][0]; + groweyelim(&eyelim, gc, + (1./256.)*(p->ra[i].r[0][0]+.5), + (1./256.)*(p->ra[i].r[0][1]+.5), 1); + if (!clipeyelim(rrng1, &eyelim)) { + useyelim = nretries-- > 0; +#ifdef DEBUG + if (!useyelim) + error(WARNING, + "exceeded retry limit in packrays"); +#endif + goto retry; + } + p->ra[i].r[1][0] = irandom(rrng1[0][1]) + rrng1[0][0]; + p->ra[i].r[1][1] = irandom(rrng1[1][1]) + rrng1[1][0]; + } else { + p->ra[i].r[0][0] = random() & 0xff; + p->ra[i].r[0][1] = random() & 0xff; + p->ra[i].r[1][0] = random() & 0xff; + p->ra[i].r[1][1] = random() & 0xff; + } d = hdray(ro, rd, hdlist[p->hd], gc, p->ra[i].r); - if (!vdef(OBSTRUCTIONS)) - d *= frandom(); /* random offset */ +#if 0 + VSUM(vt, ro, rd, d); + dist2sum += dist2line(myeye.vpt, ro, vt); +#endif if (p->offset != NULL) { + if (!vdef(OBSTRUCTIONS)) + d *= frandom(); /* random offset */ VSUM(ro, ro, rd, d); /* advance ray */ p->offset[i] = d; } @@ -45,15 +254,21 @@ register PACKET *p; VCOPY(rod, rd); rod += 3; } +#if 0 + fprintf(stderr, "%f RMS (%d retries)\t", sqrt(dist2sum/p->nr), + p->nr + 2 - nretries); +#endif } -donerays(p, rvl) /* encode finished ray computations */ -register PACKET *p; -register float *rvl; +void +donerays( /* encode finished ray computations */ + PACKET *p, + float *rvl +) { double d; - register int i; + int i; for (i = 0; i < p->nr; i++) { setcolr(p->ra[i].v, rvl[0], rvl[1], rvl[2]); @@ -68,12 +283,12 @@ register float *rvl; int -done_rtrace() /* clean up and close rtrace calculation */ +done_rtrace(void) /* clean up and close rtrace calculation */ { int status; /* already closed? */ if (!nprocs) - return; + return(0); /* flush beam queue */ done_packets(flush_queue()); /* sync holodeck */ @@ -89,7 +304,8 @@ done_rtrace() /* clean up and close rtrace calculati } -new_rtrace() /* restart rtrace calculation */ +void +new_rtrace(void) /* restart rtrace calculation */ { char combuf[128]; @@ -113,15 +329,16 @@ new_rtrace() /* restart rtrace calculation */ } -getradfile() /* run rad and get needed variables */ +int +getradfile(void) /* run rad and get needed variables */ { static short mvar[] = {OCTREE,EYESEP,-1}; static char tf1[] = TEMPLATE; char tf2[64]; char combuf[256]; - char *pippt; - register int i; - register char *cp; + char *pippt = NULL; + int i; + char *cp; /* check if rad file specified */ if (!vdef(RIF)) return(0); @@ -144,7 +361,7 @@ getradfile() /* run rad and get needed variables */ pippt = NULL; } if (pippt != NULL) - strcpy(pippt, "> /dev/null"); /* nothing to match */ + strcpy(pippt, "> " NULL_DEVICE); /* nothing to match */ else sprintf(cp, ")[ \t]*=' > %s", tf2); #ifdef DEBUG @@ -155,14 +372,17 @@ getradfile() /* run rad and get needed variables */ loadvars(tf2); /* load variables */ unlink(tf2); } - rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */ + /* get rtrace options */ + rtargc += wordfile(rtargv+rtargc, MAXRTARGC-rtargc, tf1); unlink(tf1); /* clean up */ return(1); } -report(t) /* report progress so far */ -time_t t; +void +report( /* report progress so far */ + time_t t +) { static time_t seconds2go = 1000000;
