root/radiance/ray/src/hd/rholo2.c
Revision: 3.6
Committed: Fri Dec 12 18:33:50 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.5: +21 -1 lines
reset start time and ray counts in new_rtrace()
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Rtrace support routines for holodeck rendering
9 */
10
11 #include "rholo.h"
12 #include "paths.h"
13 #include "random.h"
14
15
16 packrays(rod, p) /* pack ray origins and directions */
17 register float *rod;
18 register PACKET *p;
19 {
20 static FVECT ro, rd;
21 GCOORD gc[2];
22 int ila[2], hsh;
23 double d, sl[4];
24 register int i;
25
26 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
27 error(CONSISTENCY, "bad beam index in packrays");
28 ila[0] = p->hd; ila[1] = p->bi;
29 hsh = ilhash(ila,2) + p->nc;
30 for (i = 0; i < p->nr; i++) {
31 multisamp(sl, 4, urand(hsh+i));
32 p->ra[i].r[0][0] = sl[0] * 256.;
33 p->ra[i].r[0][1] = sl[1] * 256.;
34 p->ra[i].r[1][0] = sl[2] * 256.;
35 p->ra[i].r[1][1] = sl[3] * 256.;
36 d = hdray(ro, rd, hdlist[p->hd], gc, p->ra[i].r);
37 if (p->offset != NULL) {
38 VSUM(ro, ro, rd, d); /* exterior only */
39 p->offset[i] = d;
40 }
41 VCOPY(rod, ro);
42 rod += 3;
43 VCOPY(rod, rd);
44 rod += 3;
45 }
46 }
47
48
49 donerays(p, rvl) /* encode finished ray computations */
50 register PACKET *p;
51 register float *rvl;
52 {
53 double d;
54 register int i;
55
56 for (i = 0; i < p->nr; i++) {
57 setcolr(p->ra[i].v, rvl[0], rvl[1], rvl[2]);
58 d = rvl[3];
59 if (p->offset != NULL)
60 d += p->offset[i];
61 p->ra[i].d = hdcode(hdlist[p->hd], d);
62 rvl += 4;
63 }
64 p->nc += p->nr;
65 }
66
67
68 int
69 done_rtrace() /* clean up and close rtrace calculation */
70 {
71 int status;
72 /* already closed? */
73 if (!nprocs)
74 return;
75 wputs("closing rtrace process...\n");
76 /* flush beam queue */
77 done_packets(flush_queue());
78 /* close rtrace */
79 if ((status = end_rtrace()))
80 error(WARNING, "bad exit status from rtrace");
81 if (vdef(REPORT)) /* report time */
82 report(0);
83 return(status); /* return status */
84 }
85
86
87 new_rtrace() /* restart rtrace calculation */
88 {
89 char combuf[128];
90
91 if (nprocs > 0) /* already running? */
92 return;
93 wputs("restarting rtrace process...\n");
94 starttime = time(NULL); /* reset start time and counts */
95 npacksdone = nraysdone = 0L;
96 if (vdef(TIME)) /* reset end time */
97 endtime = starttime + vflt(TIME)*3600. + .5;
98 if (vdef(RIF)) { /* rerun rad to update octree */
99 sprintf(combuf, "rad -v 0 -s -w %s", vval(RIF));
100 if (system(combuf))
101 error(WARNING, "error running rad");
102 }
103 if (start_rtrace() < 1) /* start rtrace */
104 error(WARNING, "cannot restart rtrace");
105 else if (vdef(REPORT))
106 report(0);
107 }
108
109
110 getradfile() /* run rad and get needed variables */
111 {
112 static short mvar[] = {OCTREE,-1};
113 static char tf1[] = TEMPLATE;
114 char tf2[64];
115 char combuf[256];
116 char *pippt;
117 register int i;
118 register char *cp;
119 /* check if rad file specified */
120 if (!vdef(RIF))
121 return;
122 /* create rad command */
123 mktemp(tf1);
124 sprintf(tf2, "%s.rif", tf1);
125 sprintf(combuf,
126 "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
127 vval(RIF), tf1);
128 cp = combuf;
129 while (*cp){
130 if (*cp == '|') pippt = cp;
131 cp++;
132 } /* match unset variables */
133 for (i = 0; mvar[i] >= 0; i++)
134 if (!vdef(mvar[i])) {
135 *cp++ = '|';
136 strcpy(cp, vnam(mvar[i]));
137 while (*cp) cp++;
138 pippt = NULL;
139 }
140 if (pippt != NULL)
141 strcpy(pippt, "> /dev/null"); /* nothing to match */
142 else
143 sprintf(cp, ")[ \t]*=' > %s", tf2);
144 if (system(combuf)) {
145 unlink(tf2); /* clean up */
146 unlink(tf1);
147 error(SYSTEM, "cannot execute rad command");
148 }
149 if (pippt == NULL) {
150 loadvars(tf2); /* load variables */
151 unlink(tf2);
152 }
153 rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */
154 unlink(tf1); /* clean up */
155 }
156
157
158 report(t) /* report progress so far */
159 time_t t;
160 {
161 static time_t seconds2go = 1000000;
162
163 if (t == 0L)
164 t = time(NULL);
165 sprintf(errmsg, "%ld packets (%ld rays) done after %.2f hours\n",
166 npacksdone, nraysdone, (t-starttime)/3600.);
167 eputs(errmsg);
168 if (seconds2go == 1000000)
169 seconds2go = vdef(REPORT) ? (long)(vflt(REPORT)*60. + .5) : 0L;
170 if (seconds2go)
171 reporttime = t + seconds2go;
172 }
