root/radiance/ray/src/hd/rholo2.c
Revision: 3.16
Committed: Tue Nov 24 17:05:36 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.15: +54 -20 lines
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Rtrace support routines for holodeck rendering
9 */
10
11 #include "rholo.h"
12 #include "paths.h"
13 #include "random.h"
14
15
16 VIEWPOINT myeye; /* target view position */
17
18
19 packrays(rod, p) /* pack ray origins and directions */
20 register float *rod;
21 register PACKET *p;
22 {
23 short packord[RPACKSIZ];
24 float packdc[RPACKSIZ];
25 int iterleft = 3*p->nr;
26 BYTE rpos[2][2];
27 FVECT ro, rd, rp1;
28 GCOORD gc[2];
29 double d, dc, meandist;
30 int i;
31 register int ii;
32
33 if (!hdbcoord(gc, hdlist[p->hd], p->bi))
34 error(CONSISTENCY, "bad beam index in packrays");
35 for (i = 0, meandist = 0.; i < p->nr || meandist > myeye.rng+FTINY; ) {
36 rpos[0][0] = frandom() * 256.;
37 rpos[0][1] = frandom() * 256.;
38 rpos[1][0] = frandom() * 256.;
39 rpos[1][1] = frandom() * 256.;
40 d = hdray(ro, rd, hdlist[p->hd], gc, rpos);
41 if (myeye.rng > FTINY) { /* check eyepoint */
42 register int nexti;
43
44 VSUM(rp1, ro, rd, d);
45 dc = sqrt(dist2line(myeye.vpt, ro, rp1)) / p->nr;
46 if (i == p->nr) { /* packet full */
47 nexti = packord[i-1];
48 if (!iterleft--)
49 break; /* tried enough! */
50 if (dc >= packdc[nexti])
51 continue; /* worse than worst */
52 meandist -= packdc[nexti];
53 } else
54 nexti = i++;
55 meandist += packdc[nexti] = dc; /* new distance */
56 for (ii = i; --ii; ) { /* insertion sort */
57 if (dc > packdc[packord[ii-1]])
58 break;
59 packord[ii] = packord[ii-1];
60 }
61 packord[ii] = nexti;
62 ii = nexti; /* put it here */
63 } else
64 ii = i++;
65 if (p->offset != NULL) {
66 if (!vdef(OBSTRUCTIONS))
67 d *= frandom(); /* random offset */
68 VSUM(ro, ro, rd, d); /* advance ray */
69 p->offset[ii] = d;
70 }
71 p->ra[ii].r[0][0] = rpos[0][0];
72 p->ra[ii].r[0][1] = rpos[0][1];
73 p->ra[ii].r[1][0] = rpos[1][0];
74 p->ra[ii].r[1][1] = rpos[1][1];
75 VCOPY(rod+6*ii, ro);
76 VCOPY(rod+6*ii+3, rd);
77 }
78 #ifdef DEBUG
79 fprintf(stderr, "%f mean distance for target %f (%d iterations)\n",
80 meandist, myeye.rng, 3*p->nr - iterleft);
81 #endif
82 }
83
84
85 donerays(p, rvl) /* encode finished ray computations */
86 register PACKET *p;
87 register float *rvl;
88 {
89 double d;
90 register int i;
91
92 for (i = 0; i < p->nr; i++) {
93 setcolr(p->ra[i].v, rvl[0], rvl[1], rvl[2]);
94 d = rvl[3];
95 if (p->offset != NULL)
96 d += p->offset[i];
97 p->ra[i].d = hdcode(hdlist[p->hd], d);
98 rvl += 4;
99 }
100 p->nc += p->nr;
101 }
102
103
104 int
105 done_rtrace() /* clean up and close rtrace calculation */
106 {
107 int status;
108 /* already closed? */
109 if (!nprocs)
110 return;
111 /* flush beam queue */
112 done_packets(flush_queue());
113 /* sync holodeck */
114 hdsync(NULL, 1);
115 /* close rtrace */
116 if ((status = end_rtrace()))
117 error(WARNING, "bad exit status from rtrace");
118 if (vdef(REPORT)) { /* report time */
119 eputs("rtrace process closed\n");
120 report(0);
121 }
122 return(status); /* return status */
123 }
124
125
126 new_rtrace() /* restart rtrace calculation */
127 {
128 char combuf[128];
129
130 if (nprocs > 0) /* already running? */
131 return;
132 starttime = time(NULL); /* reset start time and counts */
133 npacksdone = nraysdone = 0L;
134 if (vdef(TIME)) /* reset end time */
135 endtime = starttime + vflt(TIME)*3600. + .5;
136 if (vdef(RIF)) { /* rerun rad to update octree */
137 sprintf(combuf, "rad -v 0 -s -w %s", vval(RIF));
138 if (system(combuf))
139 error(WARNING, "error running rad");
140 }
141 if (start_rtrace() < 1) /* start rtrace */
142 error(WARNING, "cannot restart rtrace");
143 else if (vdef(REPORT)) {
144 eputs("rtrace process restarted\n");
145 report(0);
146 }
147 }
148
149
150 getradfile() /* run rad and get needed variables */
151 {
152 static short mvar[] = {OCTREE,EYESEP,-1};
153 static char tf1[] = TEMPLATE;
154 char tf2[64];
155 char combuf[256];
156 char *pippt;
157 register int i;
158 register char *cp;
159 /* check if rad file specified */
160 if (!vdef(RIF))
161 return(0);
162 /* create rad command */
163 mktemp(tf1);
164 sprintf(tf2, "%s.rif", tf1);
165 sprintf(combuf,
166 "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
167 vval(RIF), tf1);
168 cp = combuf;
169 while (*cp){
170 if (*cp == '|') pippt = cp;
171 cp++;
172 } /* match unset variables */
173 for (i = 0; mvar[i] >= 0; i++)
174 if (!vdef(mvar[i])) {
175 *cp++ = '|';
176 strcpy(cp, vnam(mvar[i]));
177 while (*cp) cp++;
178 pippt = NULL;
179 }
180 if (pippt != NULL)
181 strcpy(pippt, "> /dev/null"); /* nothing to match */
182 else
183 sprintf(cp, ")[ \t]*=' > %s", tf2);
184 #ifdef DEBUG
185 wputs(combuf); wputs("\n");
186 #endif
187 system(combuf); /* ignore exit code */
188 if (pippt == NULL) {
189 loadvars(tf2); /* load variables */
190 unlink(tf2);
191 }
192 rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */
193 unlink(tf1); /* clean up */
194 return(1);
195 }
196
197
198 report(t) /* report progress so far */
199 time_t t;
200 {
201 static time_t seconds2go = 1000000;
202
203 if (t == 0L)
204 t = time(NULL);
205 sprintf(errmsg, "%ld packets (%ld rays) done after %.2f hours\n",
206 npacksdone, nraysdone, (t-starttime)/3600.);
207 eputs(errmsg);
208 if (seconds2go == 1000000)
209 seconds2go = vdef(REPORT) ? (long)(vflt(REPORT)*60. + .5) : 0L;
210 if (seconds2go)
211 reporttime = t + seconds2go;
212 }
