| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
/* SCCSid "$SunId$ SGI" */
| 4 |
| 5 |
| 6 |
* Header file for rholo program
| 7 |
| 8 |
| 9 |
#include "holo.h"
| 10 |
#include "vars.h"
| 11 |
| 12 |
#ifndef RPACKSIZ
| 13 |
#define RPACKSIZ 21 /* good packet size */
| 14 |
#endif
| 15 |
| 16 |
typedef struct packet {
| 17 |
int2 hd; /* holodeck section (first) */
| 18 |
int4 bi; /* beam index (second) */
| 19 |
int4 nr; /* number of rays (third) */
| 20 |
RAYVAL ra[RPACKSIZ]; /* ray values (fourth) */
| 21 |
float *offset; /* offset array if !vbool(OBSTRUCTIONS) */
| 22 |
struct packet *next; /* next in packet list */
| 23 |
} PACKET; /* a beam packet */
| 24 |
| 25 |
typedef struct {
| 26 |
| 27 |
| 28 |
| 29 |
} PACKHEAD; /* followed by ray values */
| 30 |
| 31 |
#define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL))
| 32 |
#define packra(p) ((RAYVAL *)((p)+1))
| 33 |
| 34 |
/* input variables */
| 35 |
#define RENDER 0 /* rendering options */
| 36 |
#define SECTION 1 /* holodeck section boundaries */
| 37 |
#define OCTREE 2 /* octree file name */
| 38 |
#define RIF 3 /* rad input file */
| 39 |
#define EXPOSURE 4 /* section exposure value */
| 40 |
#define TIME 5 /* maximum rendering time */
| 41 |
#define DISKSPACE 6 /* how much disk space to use */
| 42 |
#define CACHE 7 /* amount of memory to use as cache */
| 43 |
#define GRID 8 /* target grid size */
| 44 |
#define OBSTRUCTIONS 9 /* shall we track obstructions? */
| 45 |
#define OCCUPANCY 10 /* expected occupancy probability */
| 46 |
#define REPORT 11 /* report interval and error file */
| 47 |
| 48 |
#define NRHVARS 12 /* number of variables */
| 49 |
| 50 |
#define RHVINIT { \
| 51 |
{"render", 3, 0, NULL, catvalues}, \
| 52 |
{"section", 3, 0, NULL, NULL}, \
| 53 |
{"OCTREE", 3, 0, NULL, onevalue}, \
| 54 |
{"RIF", 3, 0, NULL, onevalue}, \
| 55 |
{"EXPOSURE", 3, 0, NULL, fltvalue}, \
| 56 |
{"TIME", 2, 0, NULL, fltvalue}, \
| 57 |
{"DISKSPACE", 3, 0, NULL, fltvalue}, \
| 58 |
{"CACHE", 2, 0, NULL, fltvalue}, \
| 59 |
{"GRID", 2, 0, NULL, fltvalue}, \
| 60 |
{"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \
| 61 |
{"OCCUPANCY", 3, 0, NULL, onevalue}, \
| 62 |
{"REPORT", 3, 0, NULL, onevalue}, \
| 63 |
| 64 |
| 65 |
/* bundle set requests */
| 66 |
#define BS_NEW 1 /* replace current set with new one */
| 67 |
#define BS_ADD 2 /* add to current set */
| 68 |
#define BS_DEL 3 /* delete from current set */
| 69 |
| 70 |
extern char *progname; /* our program name */
| 71 |
extern char *hdkfile; /* holodeck file name */
| 72 |
extern char froot[]; /* root file name */
| 73 |
| 74 |
extern char *outdev; /* output device name */
| 75 |
| 76 |
extern int nowarn; /* turn warnings off? */
| 77 |
| 78 |
extern int ncprocs; /* number of compute processes */
| 79 |
| 80 |
extern double expval; /* global exposure value */
| 81 |
| 82 |
extern time_t starttime; /* time we got started */
| 83 |
extern time_t endtime; /* time we should end by */
| 84 |
extern time_t reporttime; /* time for next report */
| 85 |
| 86 |
extern int rtargc; /* rtrace command */
| 87 |
extern char *rtargv[];
| 88 |
| 89 |
extern PACKET *do_packets(), *get_packets(), *flush_queue();
