root/radiance/ray/src/hd/rholo.h
Revision: 3.3
Committed: Mon Nov 10 18:05:07 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.2: +17 -15 lines
took out VIEW type and changed packray() macro to packra()
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /* Copyright (c) 1997 Silicon Graphics, Inc. */
6
7 /* SCCSid "$SunId$ SGI" */
8
9 /*
10 * Header file for rholo program
11 */
12
13 #include "holo.h"
14 #include "vars.h"
15
16 #ifndef RPACKSIZ
17 #define RPACKSIZ 21 /* good packet size */
18 #endif
19
20 typedef struct packet {
21 int2 hd; /* holodeck section (first) */
22 int4 bi; /* beam index (second) */
23 int4 nr; /* number of rays (third) */
24 RAYVAL ra[RPACKSIZ]; /* ray values (fourth) */
25 float *offset; /* offset array if !vbool(OBSTRUCTIONS) */
26 struct packet *next; /* next in packet list */
27 } PACKET; /* a beam packet */
28
29 typedef struct {
30 int2 hd; /* holodeck section (first) */
31 int4 bi; /* beam index (second) */
32 int4 nr; /* number of rays (third) */
33 } PACKHEAD; /* followed by ray values */
34
35 #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL))
36 #define packra(p) ((RAYVAL *)((p)+1))
37
38 /* input variables */
39 #define RENDER 0 /* rendering options */
40 #define SECTION 1 /* holodeck section boundaries */
41 #define OCTREE 2 /* octree file name */
42 #define RIF 3 /* rad input file */
43 #define EXPOSURE 4 /* section exposure value */
44 #define TIME 5 /* maximum rendering time */
45 #define DISKSPACE 6 /* how much disk space to use */
46 #define CACHE 7 /* amount of memory to use as cache */
47 #define GRID 8 /* target grid size */
48 #define OBSTRUCTIONS 9 /* shall we track obstructions? */
49 #define OCCUPANCY 10 /* expected occupancy probability */
50 #define REPORT 11 /* report interval and error file */
51
52 #define NRHVARS 12 /* number of variables */
53
54 #define RHVINIT { \
55 {"render", 3, 0, NULL, catvalues}, \
56 {"section", 3, 0, NULL, NULL}, \
57 {"OCTREE", 3, 0, NULL, onevalue}, \
58 {"RIF", 3, 0, NULL, onevalue}, \
59 {"EXPOSURE", 3, 0, NULL, fltvalue}, \
60 {"TIME", 2, 0, NULL, fltvalue}, \
61 {"DISKSPACE", 3, 0, NULL, fltvalue}, \
62 {"CACHE", 2, 0, NULL, fltvalue}, \
63 {"GRID", 2, 0, NULL, fltvalue}, \
64 {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \
65 {"OCCUPANCY", 3, 0, NULL, onevalue}, \
66 {"REPORT", 3, 0, NULL, onevalue}, \
67 }
68
69 /* bundle set requests */
70 #define BS_NEW 0 /* replace current set with new one */
71 #define BS_ADD 1 /* add to current set */
72 #define BS_DEL 2 /* delete from current set */
73
74 extern char *progname; /* our program name */
75 extern char *hdkfile; /* holodeck file name */
76 extern char froot[]; /* root file name */
77
78 extern int nowarn; /* turn warnings off? */
79
80 extern double expval; /* global exposure value */
81
82 extern int ncprocs; /* number of compute processes */
83
84 extern time_t starttime; /* time we got started */
85 extern time_t endtime; /* time we should end by */
86 extern time_t reporttime; /* time for next report */
87
88 extern int rtargc; /* rtrace command */
89 extern char *rtargv[];
90
91 extern PACKET *do_packets(), *get_packets(), *flush_queue();
