1 |
/* RCSid: $Id: rholo.h,v 3.25 2004/06/08 19:48:30 greg Exp $ */ |
2 |
3 |
* Header file for rholo program |
4 |
5 |
#ifndef _RAD_RHOLO_H_ |
6 |
#define _RAD_RHOLO_H_ |
7 |
8 |
#include "holo.h" |
9 |
#include "view.h" |
10 |
#include "vars.h" |
11 |
12 |
#ifdef __cplusplus |
13 |
extern "C" { |
14 |
#endif |
15 |
16 |
#ifndef RPACKSIZ |
17 |
#define RPACKSIZ 21 /* good packet size */ |
18 |
#endif |
19 |
20 |
typedef struct packet { |
21 |
int16 hd; /* holodeck section (first) */ |
22 |
int32 bi; /* beam index (second) */ |
23 |
int32 nr; /* number of rays (third) */ |
24 |
int32 nc; /* number calculated (fourth) */ |
25 |
RAYVAL ra[RPACKSIZ]; /* ray values (fifth) */ |
26 |
float *offset; /* offset array if !vbool(OBSTRUCTIONS) */ |
27 |
struct packet *next; /* next in packet list */ |
28 |
} PACKET; /* a beam packet */ |
29 |
30 |
typedef struct { |
31 |
32 |
33 |
34 |
35 |
} PACKHEAD; /* followed by ray values */ |
36 |
37 |
#define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL)) |
38 |
#define packra(p) ((RAYVAL *)((p)+1)) |
39 |
40 |
typedef struct { |
41 |
int nb; /* number of beams in list */ |
42 |
PACKHEAD *bl; /* allocated beam list */ |
43 |
} BEAMLIST; /* a list of beam requests */ |
44 |
45 |
typedef struct { |
46 |
FVECT vpt; /* view (eye point) position */ |
47 |
double rng; /* desired mean radius for sample rays */ |
48 |
} VIEWPOINT; /* target eye position */ |
49 |
50 |
/* input variables */ |
51 |
#define CACHE 0 /* amount of memory to use as cache */ |
52 |
#define DISKSPACE 1 /* how much disk space to use */ |
53 |
#define EYESEP 2 /* eye separation distance */ |
54 |
#define GEOMETRY 3 /* section geometry */ |
55 |
#define GRID 4 /* target grid size */ |
56 |
#define OBSTRUCTIONS 5 /* shall we track obstructions? */ |
57 |
#define OCTREE 6 /* octree file name */ |
58 |
#define PORTS 7 /* section portals */ |
59 |
#define RENDER 8 /* rendering options */ |
60 |
#define REPORT 9 /* report interval and error file */ |
61 |
#define RIF 10 /* rad input file */ |
62 |
#define SECTION 11 /* holodeck section boundaries */ |
63 |
#define TIME 12 /* maximum rendering time */ |
64 |
#define VDIST 13 /* virtual distance calculation */ |
65 |
66 |
#define NRHVARS 14 /* number of variables */ |
67 |
68 |
#define RHVINIT { \ |
69 |
{"CACHE", 2, 0, NULL, fltvalue}, \ |
70 |
{"DISKSPACE", 3, 0, NULL, fltvalue}, \ |
71 |
{"EYESEP", 3, 0, NULL, fltvalue}, \ |
72 |
{"geometry", 3, 0, NULL, NULL}, \ |
73 |
{"GRID", 2, 0, NULL, fltvalue}, \ |
74 |
{"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \ |
75 |
{"OCTREE", 3, 0, NULL, onevalue}, \ |
76 |
{"portals", 3, 0, NULL, NULL}, \ |
77 |
{"render", 3, 0, NULL, catvalues}, \ |
78 |
{"REPORT", 3, 0, NULL, onevalue}, \ |
79 |
{"RIF", 3, 0, NULL, onevalue}, \ |
80 |
{"section", 3, 0, NULL, NULL}, \ |
81 |
{"TIME", 2, 0, NULL, fltvalue}, \ |
82 |
{"VDISTANCE", 2, 0, NULL, boolvalue}, \ |
83 |
84 |
85 |
/* bundle set requests */ |
86 |
#define BS_NEW 1 /* replace current set with new one */ |
87 |
#define BS_ADD 2 /* add to current set */ |
88 |
#define BS_ADJ 3 /* adjust current set quantities */ |
89 |
#define BS_DEL 4 /* delete from current set */ |
90 |
#define BS_MAX 5 /* set to max of old and new */ |
91 |
92 |
extern char *progname; /* our program name */ |
93 |
extern char *hdkfile; /* holodeck file name */ |
94 |
extern char froot[]; /* root file name */ |
95 |
96 |
extern char *outdev; /* output device name */ |
97 |
98 |
extern int readinp; /* read input from stdin */ |
99 |
100 |
extern int force; /* allow overwrite of holodeck */ |
101 |
102 |
extern int nowarn; /* turn warnings off? */ |
103 |
104 |
extern int ncprocs; /* number of requested compute processes */ |
105 |
extern int nprocs; /* number of running compute processes */ |
106 |
107 |
extern int chunkycmp; /* using "chunky" comparison mode */ |
108 |
109 |
extern VIEWPOINT myeye; /* target view position */ |
110 |
111 |
extern time_t starttime; /* time we got started */ |
112 |
extern time_t endtime; /* time we should end by */ |
113 |
extern time_t reporttime; /* time for next report */ |
114 |
115 |
extern long nraysdone; /* number of rays done */ |
116 |
extern long npacksdone; /* number of packets done */ |
117 |
118 |
#define MAXRTARGC 256 |
119 |
extern int rtargc; /* rtrace command */ |
120 |
extern char *rtargv[]; |
121 |
122 |
/* rholo.c */ |
123 |
extern void done_packets(PACKET *pl); |
124 |
/* rholo2.c */ |
125 |
extern void new_rtrace(void); |
126 |
extern int done_rtrace(void); |
127 |
extern void packrays(float *rod, PACKET *p); |
128 |
extern void donerays(PACKET *p, float *rvl); |
129 |
extern int getradfile(void); |
130 |
extern void report(time_t t); |
131 |
/* rholo2l.c */ |
132 |
extern int start_rtrace(void); |
133 |
extern int end_rtrace(void); |
134 |
extern PACKET *do_packets(PACKET *pl); |
135 |
extern PACKET *flush_queue(void); |
136 |
/* rholo3.c */ |
137 |
extern void init_global(void); |
138 |
extern int next_packet(PACKET *p, int n); |
139 |
extern void bundle_set(int op, PACKHEAD *clist, int nents); |
140 |
/* rholo4.c */ |
141 |
extern void disp_open(char *dname); |
142 |
extern void disp_packet(register PACKHEAD *p); |
143 |
extern int disp_check(int block); |
144 |
extern int disp_close(void); |
145 |
/* viewbeams.c */ |
146 |
extern int nextview(VIEW *vp, FILE *fp); |
147 |
extern int16 * viewbeams(VIEW *vp, int hr, int vr, BEAMLIST *blp); |
148 |
149 |
150 |
151 |
#endif |
152 |
#endif /* _RAD_RHOLO_H_ */ |
153 |
