root/radiance/ray/src/hd/rholo.h
Revision: 3.2
Committed: Mon Nov 3 18:33:12 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +5 -0 lines
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for rholo program
7 */
8
9 #include "holo.h"
10 #include "vars.h"
11
12 #ifndef RPACKSIZ
13 #define RPACKSIZ 21 /* good packet size */
14 #endif
15
16 typedef struct packet {
17 int2 hd; /* holodeck section (first) */
18 int4 bi; /* beam index (second) */
19 int4 nr; /* number of rays (third) */
20 RAYVAL ra[RPACKSIZ]; /* ray values (fourth) */
21 float *offset; /* offset array if !vbool(OBSTRUCTIONS) */
22 struct packet *next; /* next in packet list */
23 } PACKET; /* a beam packet */
24
25 typedef struct {
26 int2 hd; /* holodeck section (first) */
27 int4 bi; /* beam index (second) */
28 int4 nr; /* number of rays (third) */
29 } PACKHEAD; /* followed by ray values */
30
31 #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL))
32 #define packray(p) (RAYVAL *)((PACKHEAD *)(p)+1)
33
34 /* input variables */
35 #define RENDER 0 /* rendering options */
36 #define VIEW 1 /* starting view */
37 #define SECTION 2 /* holodeck section boundaries */
38 #define OCTREE 3 /* octree file name */
39 #define RIF 4 /* rad input file */
40 #define EXPOSURE 5 /* section exposure value */
41 #define TIME 6 /* maximum rendering time */
42 #define DISKSPACE 7 /* how much disk space to use */
43 #define CACHE 8 /* amount of memory to use as cache */
44 #define GRID 9 /* target grid size */
45 #define OBSTRUCTIONS 10 /* shall we track obstructions? */
46 #define OCCUPANCY 11 /* expected occupancy probability */
47 #define REPORT 12 /* report interval and error file */
48
49 #define NRHVARS 13 /* number of variables */
50
51 #define RHVINIT { \
52 {"render", 3, 0, NULL, catvalues}, \
53 {"view", 2, 0, NULL, NULL}, \
54 {"section", 3, 0, NULL, NULL}, \
55 {"OCTREE", 3, 0, NULL, onevalue}, \
56 {"RIF", 3, 0, NULL, onevalue}, \
57 {"EXPOSURE", 3, 0, NULL, fltvalue}, \
58 {"TIME", 2, 0, NULL, fltvalue}, \
59 {"DISKSPACE", 3, 0, NULL, fltvalue}, \
60 {"CACHE", 2, 0, NULL, fltvalue}, \
61 {"GRID", 2, 0, NULL, fltvalue}, \
62 {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \
63 {"OCCUPANCY", 3, 0, NULL, onevalue}, \
64 {"REPORT", 3, 0, NULL, onevalue}, \
65 }
66
67 /* bundle set requests */
68 #define BS_NEW 0 /* replace current set with new one */
69 #define BS_ADD 1 /* add to current set */
70 #define BS_DEL 2 /* delete from current set */
71
72 extern char *progname; /* our program name */
73 extern char *hdkfile; /* holodeck file name */
74 extern char froot[]; /* root file name */
75
76 extern int nowarn; /* turn warnings off? */
77
78 extern double expval; /* global exposure value */
79
80 extern int ncprocs; /* number of compute processes */
81
82 extern time_t starttime; /* time we got started */
83 extern time_t endtime; /* time we should end by */
84 extern time_t reporttime; /* time for next report */
85
86 extern int rtargc; /* rtrace command */
87 extern char *rtargv[];
88
89 extern PACKET *do_packets(), *get_packets(), *flush_queue();
