1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* Header file for rholo program |
7 |
8 |
9 |
#include "holo.h" |
10 |
#include "vars.h" |
11 |
12 |
#ifndef RPACKSIZ |
13 |
#define RPACKSIZ 21 /* good packet size */ |
14 |
#endif |
15 |
16 |
typedef struct packet { |
17 |
int2 hd; /* holodeck section (first) */ |
18 |
int4 bi; /* beam index (second) */ |
19 |
int4 nr; /* number of rays (third) */ |
20 |
int4 nc; /* number calculated (fourth) */ |
21 |
RAYVAL ra[RPACKSIZ]; /* ray values (fourth) */ |
22 |
float *offset; /* offset array if !vbool(OBSTRUCTIONS) */ |
23 |
struct packet *next; /* next in packet list */ |
24 |
} PACKET; /* a beam packet */ |
25 |
26 |
typedef struct { |
27 |
28 |
29 |
30 |
31 |
} PACKHEAD; /* followed by ray values */ |
32 |
33 |
#define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL)) |
34 |
#define packra(p) ((RAYVAL *)((p)+1)) |
35 |
36 |
/* input variables */ |
37 |
#define RENDER 0 /* rendering options */ |
38 |
#define SECTION 1 /* holodeck section boundaries */ |
39 |
#define OCTREE 2 /* octree file name */ |
40 |
#define RIF 3 /* rad input file */ |
41 |
#define TIME 4 /* maximum rendering time */ |
42 |
#define DISKSPACE 5 /* how much disk space to use */ |
43 |
#define CACHE 6 /* amount of memory to use as cache */ |
44 |
#define GRID 7 /* target grid size */ |
45 |
#define OBSTRUCTIONS 8 /* shall we track obstructions? */ |
46 |
#define VDIST 9 /* virtual distance calculation */ |
47 |
#define OCCUPANCY 10 /* expected occupancy probability */ |
48 |
#define REPORT 11 /* report interval and error file */ |
49 |
50 |
#define NRHVARS 12 /* number of variables */ |
51 |
52 |
#define RHVINIT { \ |
53 |
{"render", 3, 0, NULL, catvalues}, \ |
54 |
{"section", 3, 0, NULL, NULL}, \ |
55 |
{"OCTREE", 3, 0, NULL, onevalue}, \ |
56 |
{"RIF", 3, 0, NULL, onevalue}, \ |
57 |
{"TIME", 2, 0, NULL, fltvalue}, \ |
58 |
{"DISKSPACE", 3, 0, NULL, fltvalue}, \ |
59 |
{"CACHE", 2, 0, NULL, fltvalue}, \ |
60 |
{"GRID", 2, 0, NULL, fltvalue}, \ |
61 |
{"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \ |
62 |
{"VDISTANCE", 2, 0, NULL, boolvalue}, \ |
63 |
{"OCCUPANCY", 3, 0, NULL, onevalue}, \ |
64 |
{"REPORT", 3, 0, NULL, onevalue}, \ |
65 |
66 |
67 |
/* bundle set requests */ |
68 |
#define BS_NEW 1 /* replace current set with new one */ |
69 |
#define BS_ADD 2 /* add to current set */ |
70 |
#define BS_ADJ 3 /* adjust current set quantities */ |
71 |
#define BS_DEL 4 /* delete from current set */ |
72 |
73 |
extern char *progname; /* our program name */ |
74 |
extern char *hdkfile; /* holodeck file name */ |
75 |
extern char froot[]; /* root file name */ |
76 |
77 |
extern char *outdev; /* output device name */ |
78 |
79 |
extern int readinp; /* read input from stdin */ |
80 |
81 |
extern int force; /* allow overwrite of holodeck */ |
82 |
83 |
extern int nowarn; /* turn warnings off? */ |
84 |
85 |
extern int ncprocs; /* number of requested compute processes */ |
86 |
extern int nprocs; /* number of running compute processes */ |
87 |
88 |
extern double expval; /* global exposure value */ |
89 |
90 |
extern time_t starttime; /* time we got started */ |
91 |
extern time_t endtime; /* time we should end by */ |
92 |
extern time_t reporttime; /* time for next report */ |
93 |
94 |
extern long nraysdone; /* number of rays done */ |
95 |
extern long npacksdone; /* number of packets done */ |
96 |
97 |
extern int rtargc; /* rtrace command */ |
98 |
extern char *rtargv[]; |
99 |
100 |
extern PACKET *do_packets(), *get_packets(), *flush_queue(); |
