--- ray/src/hd/rholo.h 1997/10/31 10:23:29 3.1 +++ ray/src/hd/rholo.h 1997/12/11 11:51:20 3.9 @@ -17,6 +17,7 @@ typedef struct packet { int2 hd; /* holodeck section (first) */ int4 bi; /* beam index (second) */ int4 nr; /* number of rays (third) */ + int4 nc; /* number calculated (fourth) */ RAYVAL ra[RPACKSIZ]; /* ray values (fourth) */ float *offset; /* offset array if !vbool(OBSTRUCTIONS) */ struct packet *next; /* next in packet list */ @@ -26,53 +27,63 @@ typedef struct { int2 hd; /* holodeck section (first) */ int4 bi; /* beam index (second) */ int4 nr; /* number of rays (third) */ + int4 nc; /* number calculated (fourth) */ } PACKHEAD; /* followed by ray values */ #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL)) -#define packray(p) (RAYVAL *)((PACKHEAD *)(p)+1) +#define packra(p) ((RAYVAL *)((p)+1)) /* input variables */ #define RENDER 0 /* rendering options */ -#define VIEW 1 /* starting view */ -#define SECTION 2 /* holodeck section boundaries */ -#define OCTREE 3 /* octree file name */ -#define RIF 4 /* rad input file */ -#define EXPOSURE 5 /* section exposure value */ -#define TIME 6 /* maximum rendering time */ -#define DISKSPACE 7 /* how much disk space to use */ -#define CACHE 8 /* amount of memory to use as cache */ -#define GRID 9 /* target grid size */ -#define OBSTRUCTIONS 10 /* shall we track obstructions? */ -#define OCCUPANCY 11 /* expected occupancy probability */ -#define REPORT 12 /* report interval and error file */ +#define SECTION 1 /* holodeck section boundaries */ +#define OCTREE 2 /* octree file name */ +#define RIF 3 /* rad input file */ +#define TIME 4 /* maximum rendering time */ +#define DISKSPACE 5 /* how much disk space to use */ +#define CACHE 6 /* amount of memory to use as cache */ +#define GRID 7 /* target grid size */ +#define OBSTRUCTIONS 8 /* shall we track obstructions? */ +#define VDIST 9 /* virtual distance calculation */ +#define OCCUPANCY 10 /* expected occupancy probability */ +#define REPORT 11 /* report interval and error file */ -#define NRHVARS 13 /* number of variables */ +#define NRHVARS 12 /* number of variables */ #define RHVINIT { \ {"render", 3, 0, NULL, catvalues}, \ - {"view", 2, 0, NULL, NULL}, \ {"section", 3, 0, NULL, NULL}, \ {"OCTREE", 3, 0, NULL, onevalue}, \ {"RIF", 3, 0, NULL, onevalue}, \ - {"EXPOSURE", 3, 0, NULL, fltvalue}, \ {"TIME", 2, 0, NULL, fltvalue}, \ {"DISKSPACE", 3, 0, NULL, fltvalue}, \ {"CACHE", 2, 0, NULL, fltvalue}, \ {"GRID", 2, 0, NULL, fltvalue}, \ {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \ + {"VDISTANCE", 2, 0, NULL, boolvalue}, \ {"OCCUPANCY", 3, 0, NULL, onevalue}, \ {"REPORT", 3, 0, NULL, onevalue}, \ } + /* bundle set requests */ +#define BS_NEW 1 /* replace current set with new one */ +#define BS_ADD 2 /* add to current set */ +#define BS_ADJ 3 /* adjust current set quantities */ +#define BS_DEL 4 /* delete from current set */ + extern char *progname; /* our program name */ extern char *hdkfile; /* holodeck file name */ extern char froot[]; /* root file name */ +extern char *outdev; /* output device name */ + +extern int readinp; /* read input from stdin */ + extern int nowarn; /* turn warnings off? */ -extern double expval; /* global exposure value */ +extern int ncprocs; /* number of requested compute processes */ +extern int nprocs; /* number of running compute processes */ -extern int ncprocs; /* number of compute processes */ +extern double expval; /* global exposure value */ extern time_t starttime; /* time we got started */ extern time_t endtime; /* time we should end by */
