--- ray/src/hd/rholo.h 1999/03/04 10:29:23 3.20 +++ ray/src/hd/rholo.h 2003/07/14 22:24:00 3.23 @@ -1,33 +1,36 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid: $Id: rholo.h,v 3.23 2003/07/14 22:24:00 schorsch Exp $ */ /* * Header file for rholo program */ +#ifndef _RAD_RHOLO_H_ +#define _RAD_RHOLO_H_ #include "holo.h" #include "vars.h" +#ifdef __cplusplus +extern "C" { +#endif + #ifndef RPACKSIZ #define RPACKSIZ 21 /* good packet size */ #endif typedef struct packet { - int2 hd; /* holodeck section (first) */ - int4 bi; /* beam index (second) */ - int4 nr; /* number of rays (third) */ - int4 nc; /* number calculated (fourth) */ + int16 hd; /* holodeck section (first) */ + int32 bi; /* beam index (second) */ + int32 nr; /* number of rays (third) */ + int32 nc; /* number calculated (fourth) */ RAYVAL ra[RPACKSIZ]; /* ray values (fifth) */ float *offset; /* offset array if !vbool(OBSTRUCTIONS) */ struct packet *next; /* next in packet list */ } PACKET; /* a beam packet */ typedef struct { - int2 hd; /* holodeck section (first) */ - int4 bi; /* beam index (second) */ - int4 nr; /* number of rays (third) */ - int4 nc; /* number calculated (fourth) */ + int16 hd; /* holodeck section (first) */ + int32 bi; /* beam index (second) */ + int32 nr; /* number of rays (third) */ + int32 nc; /* number calculated (fourth) */ } PACKHEAD; /* followed by ray values */ #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL)) @@ -116,4 +119,11 @@ extern char *rtargv[]; extern PACKET *do_packets(), *get_packets(), *flush_queue(); -extern int2 *viewbeams(); +extern int16 *viewbeams(); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_RHOLO_H_ */ +
