--- ray/src/hd/rholo.h 1998/11/24 17:05:36 3.16 +++ ray/src/hd/rholo.h 1999/03/04 10:29:23 3.20 @@ -34,6 +34,11 @@ typedef struct { #define packra(p) ((RAYVAL *)((p)+1)) typedef struct { + int nb; /* number of beams in list */ + PACKHEAD *bl; /* allocated beam list */ +} BEAMLIST; /* a list of beam requests */ + +typedef struct { FVECT vpt; /* view (eye point) position */ double rng; /* desired mean radius for sample rays */ } VIEWPOINT; /* target eye position */ @@ -42,25 +47,29 @@ typedef struct { #define CACHE 0 /* amount of memory to use as cache */ #define DISKSPACE 1 /* how much disk space to use */ #define EYESEP 2 /* eye separation distance */ -#define GRID 3 /* target grid size */ -#define OBSTRUCTIONS 4 /* shall we track obstructions? */ -#define OCTREE 5 /* octree file name */ -#define RENDER 6 /* rendering options */ -#define REPORT 7 /* report interval and error file */ -#define RIF 8 /* rad input file */ -#define SECTION 9 /* holodeck section boundaries */ -#define TIME 10 /* maximum rendering time */ -#define VDIST 11 /* virtual distance calculation */ +#define GEOMETRY 3 /* section geometry */ +#define GRID 4 /* target grid size */ +#define OBSTRUCTIONS 5 /* shall we track obstructions? */ +#define OCTREE 6 /* octree file name */ +#define PORTS 7 /* section portals */ +#define RENDER 8 /* rendering options */ +#define REPORT 9 /* report interval and error file */ +#define RIF 10 /* rad input file */ +#define SECTION 11 /* holodeck section boundaries */ +#define TIME 12 /* maximum rendering time */ +#define VDIST 13 /* virtual distance calculation */ -#define NRHVARS 12 /* number of variables */ +#define NRHVARS 14 /* number of variables */ #define RHVINIT { \ {"CACHE", 2, 0, NULL, fltvalue}, \ {"DISKSPACE", 3, 0, NULL, fltvalue}, \ {"EYESEP", 3, 0, NULL, fltvalue}, \ + {"geometry", 3, 0, NULL, NULL}, \ {"GRID", 2, 0, NULL, fltvalue}, \ {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \ {"OCTREE", 3, 0, NULL, onevalue}, \ + {"portals", 3, 0, NULL, NULL}, \ {"render", 3, 0, NULL, catvalues}, \ {"REPORT", 3, 0, NULL, onevalue}, \ {"RIF", 3, 0, NULL, onevalue}, \ @@ -74,6 +83,7 @@ typedef struct { #define BS_ADD 2 /* add to current set */ #define BS_ADJ 3 /* adjust current set quantities */ #define BS_DEL 4 /* delete from current set */ +#define BS_MAX 5 /* set to max of old and new */ extern char *progname; /* our program name */ extern char *hdkfile; /* holodeck file name */ @@ -90,7 +100,7 @@ extern int nowarn; /* turn warnings off? */ extern int ncprocs; /* number of requested compute processes */ extern int nprocs; /* number of running compute processes */ -extern double expval; /* global exposure value */ +extern int chunkycmp; /* using "chunky" comparison mode */ extern VIEWPOINT myeye; /* target view position */ @@ -105,3 +115,5 @@ extern int rtargc; /* rtrace command */ extern char *rtargv[]; extern PACKET *do_packets(), *get_packets(), *flush_queue(); + +extern int2 *viewbeams();
