--- ray/src/hd/rholo.h 1997/11/10 18:05:07 3.3 +++ ray/src/hd/rholo.h 1998/11/24 17:05:36 3.16 @@ -1,11 +1,7 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ /* SCCSid "$SunId$ SGI" */ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - /* * Header file for rholo program */ @@ -21,7 +17,8 @@ typedef struct packet { int2 hd; /* holodeck section (first) */ int4 bi; /* beam index (second) */ int4 nr; /* number of rays (third) */ - RAYVAL ra[RPACKSIZ]; /* ray values (fourth) */ + int4 nc; /* number calculated (fourth) */ + RAYVAL ra[RPACKSIZ]; /* ray values (fifth) */ float *offset; /* offset array if !vbool(OBSTRUCTIONS) */ struct packet *next; /* next in packet list */ } PACKET; /* a beam packet */ @@ -30,60 +27,79 @@ typedef struct { int2 hd; /* holodeck section (first) */ int4 bi; /* beam index (second) */ int4 nr; /* number of rays (third) */ + int4 nc; /* number calculated (fourth) */ } PACKHEAD; /* followed by ray values */ #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL)) #define packra(p) ((RAYVAL *)((p)+1)) +typedef struct { + FVECT vpt; /* view (eye point) position */ + double rng; /* desired mean radius for sample rays */ +} VIEWPOINT; /* target eye position */ + /* input variables */ -#define RENDER 0 /* rendering options */ -#define SECTION 1 /* holodeck section boundaries */ -#define OCTREE 2 /* octree file name */ -#define RIF 3 /* rad input file */ -#define EXPOSURE 4 /* section exposure value */ -#define TIME 5 /* maximum rendering time */ -#define DISKSPACE 6 /* how much disk space to use */ -#define CACHE 7 /* amount of memory to use as cache */ -#define GRID 8 /* target grid size */ -#define OBSTRUCTIONS 9 /* shall we track obstructions? */ -#define OCCUPANCY 10 /* expected occupancy probability */ -#define REPORT 11 /* report interval and error file */ +#define CACHE 0 /* amount of memory to use as cache */ +#define DISKSPACE 1 /* how much disk space to use */ +#define EYESEP 2 /* eye separation distance */ +#define GRID 3 /* target grid size */ +#define OBSTRUCTIONS 4 /* shall we track obstructions? */ +#define OCTREE 5 /* octree file name */ +#define RENDER 6 /* rendering options */ +#define REPORT 7 /* report interval and error file */ +#define RIF 8 /* rad input file */ +#define SECTION 9 /* holodeck section boundaries */ +#define TIME 10 /* maximum rendering time */ +#define VDIST 11 /* virtual distance calculation */ #define NRHVARS 12 /* number of variables */ #define RHVINIT { \ - {"render", 3, 0, NULL, catvalues}, \ - {"section", 3, 0, NULL, NULL}, \ - {"OCTREE", 3, 0, NULL, onevalue}, \ - {"RIF", 3, 0, NULL, onevalue}, \ - {"EXPOSURE", 3, 0, NULL, fltvalue}, \ - {"TIME", 2, 0, NULL, fltvalue}, \ - {"DISKSPACE", 3, 0, NULL, fltvalue}, \ {"CACHE", 2, 0, NULL, fltvalue}, \ + {"DISKSPACE", 3, 0, NULL, fltvalue}, \ + {"EYESEP", 3, 0, NULL, fltvalue}, \ {"GRID", 2, 0, NULL, fltvalue}, \ {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \ - {"OCCUPANCY", 3, 0, NULL, onevalue}, \ + {"OCTREE", 3, 0, NULL, onevalue}, \ + {"render", 3, 0, NULL, catvalues}, \ {"REPORT", 3, 0, NULL, onevalue}, \ + {"RIF", 3, 0, NULL, onevalue}, \ + {"section", 3, 0, NULL, NULL}, \ + {"TIME", 2, 0, NULL, fltvalue}, \ + {"VDISTANCE", 2, 0, NULL, boolvalue}, \ } /* bundle set requests */ -#define BS_NEW 0 /* replace current set with new one */ -#define BS_ADD 1 /* add to current set */ -#define BS_DEL 2 /* delete from current set */ +#define BS_NEW 1 /* replace current set with new one */ +#define BS_ADD 2 /* add to current set */ +#define BS_ADJ 3 /* adjust current set quantities */ +#define BS_DEL 4 /* delete from current set */ extern char *progname; /* our program name */ extern char *hdkfile; /* holodeck file name */ extern char froot[]; /* root file name */ +extern char *outdev; /* output device name */ + +extern int readinp; /* read input from stdin */ + +extern int force; /* allow overwrite of holodeck */ + extern int nowarn; /* turn warnings off? */ +extern int ncprocs; /* number of requested compute processes */ +extern int nprocs; /* number of running compute processes */ + extern double expval; /* global exposure value */ -extern int ncprocs; /* number of compute processes */ +extern VIEWPOINT myeye; /* target view position */ extern time_t starttime; /* time we got started */ extern time_t endtime; /* time we should end by */ extern time_t reporttime; /* time for next report */ + +extern long nraysdone; /* number of rays done */ +extern long npacksdone; /* number of packets done */ extern int rtargc; /* rtrace command */ extern char *rtargv[];
