root/radiance/ray/src/hd/rholo.h
Revision: 3.23
Committed: Mon Jul 14 22:24:00 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.22: +14 -1 lines
1 /* RCSid: $Id: rholo.h,v 3.22 2003/06/20 00:25:49 greg Exp $ */
2 /*
3 * Header file for rholo program
4 */
5 #ifndef _RAD_RHOLO_H_
6 #define _RAD_RHOLO_H_
7
8 #include "holo.h"
9 #include "vars.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 #ifndef RPACKSIZ
16 #define RPACKSIZ 21 /* good packet size */
17 #endif
18
19 typedef struct packet {
20 int16 hd; /* holodeck section (first) */
21 int32 bi; /* beam index (second) */
22 int32 nr; /* number of rays (third) */
23 int32 nc; /* number calculated (fourth) */
24 RAYVAL ra[RPACKSIZ]; /* ray values (fifth) */
25 float *offset; /* offset array if !vbool(OBSTRUCTIONS) */
26 struct packet *next; /* next in packet list */
27 } PACKET; /* a beam packet */
28
29 typedef struct {
30 int16 hd; /* holodeck section (first) */
31 int32 bi; /* beam index (second) */
32 int32 nr; /* number of rays (third) */
33 int32 nc; /* number calculated (fourth) */
34 } PACKHEAD; /* followed by ray values */
35
36 #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL))
37 #define packra(p) ((RAYVAL *)((p)+1))
38
39 typedef struct {
40 int nb; /* number of beams in list */
41 PACKHEAD *bl; /* allocated beam list */
42 } BEAMLIST; /* a list of beam requests */
43
44 typedef struct {
45 FVECT vpt; /* view (eye point) position */
46 double rng; /* desired mean radius for sample rays */
47 } VIEWPOINT; /* target eye position */
48
49 /* input variables */
50 #define CACHE 0 /* amount of memory to use as cache */
51 #define DISKSPACE 1 /* how much disk space to use */
52 #define EYESEP 2 /* eye separation distance */
53 #define GEOMETRY 3 /* section geometry */
54 #define GRID 4 /* target grid size */
55 #define OBSTRUCTIONS 5 /* shall we track obstructions? */
56 #define OCTREE 6 /* octree file name */
57 #define PORTS 7 /* section portals */
58 #define RENDER 8 /* rendering options */
59 #define REPORT 9 /* report interval and error file */
60 #define RIF 10 /* rad input file */
61 #define SECTION 11 /* holodeck section boundaries */
62 #define TIME 12 /* maximum rendering time */
63 #define VDIST 13 /* virtual distance calculation */
64
65 #define NRHVARS 14 /* number of variables */
66
67 #define RHVINIT { \
68 {"CACHE", 2, 0, NULL, fltvalue}, \
69 {"DISKSPACE", 3, 0, NULL, fltvalue}, \
70 {"EYESEP", 3, 0, NULL, fltvalue}, \
71 {"geometry", 3, 0, NULL, NULL}, \
72 {"GRID", 2, 0, NULL, fltvalue}, \
73 {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \
74 {"OCTREE", 3, 0, NULL, onevalue}, \
75 {"portals", 3, 0, NULL, NULL}, \
76 {"render", 3, 0, NULL, catvalues}, \
77 {"REPORT", 3, 0, NULL, onevalue}, \
78 {"RIF", 3, 0, NULL, onevalue}, \
79 {"section", 3, 0, NULL, NULL}, \
80 {"TIME", 2, 0, NULL, fltvalue}, \
81 {"VDISTANCE", 2, 0, NULL, boolvalue}, \
82 }
83
84 /* bundle set requests */
85 #define BS_NEW 1 /* replace current set with new one */
86 #define BS_ADD 2 /* add to current set */
87 #define BS_ADJ 3 /* adjust current set quantities */
88 #define BS_DEL 4 /* delete from current set */
89 #define BS_MAX 5 /* set to max of old and new */
90
91 extern char *progname; /* our program name */
92 extern char *hdkfile; /* holodeck file name */
93 extern char froot[]; /* root file name */
94
95 extern char *outdev; /* output device name */
96
97 extern int readinp; /* read input from stdin */
98
99 extern int force; /* allow overwrite of holodeck */
100
101 extern int nowarn; /* turn warnings off? */
102
103 extern int ncprocs; /* number of requested compute processes */
104 extern int nprocs; /* number of running compute processes */
105
106 extern int chunkycmp; /* using "chunky" comparison mode */
107
108 extern VIEWPOINT myeye; /* target view position */
109
110 extern time_t starttime; /* time we got started */
111 extern time_t endtime; /* time we should end by */
112 extern time_t reporttime; /* time for next report */
113
114 extern long nraysdone; /* number of rays done */
115 extern long npacksdone; /* number of packets done */
116
117 extern int rtargc; /* rtrace command */
118 extern char *rtargv[];
119
120 extern PACKET *do_packets(), *get_packets(), *flush_queue();
121
122 extern int16 *viewbeams();
123
124
125 #ifdef __cplusplus
126 }
127 #endif
128 #endif /* _RAD_RHOLO_H_ */
129
