root/radiance/ray/src/hd/rholo.h
Mon Mar 21 19:06:08 2016 UTC (8 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 3.25: +2 -1 lines
Diff to previous 3.25 , to selected 3.4
Tue Jun 8 19:48:30 2004 UTC (19 years, 11 months ago) by greg
Changes since 3.24: +2 -4 lines
Diff to previous 3.24 , to selected 3.4
Changes since 3.23: +30 -5 lines
Diff to previous 3.23 , to selected 3.4
Ansification and prototypes.
Mon Jul 14 22:24:00 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.22: +14 -1 lines
Diff to previous 3.22 , to selected 3.4
Changes since 3.21: +10 -10 lines
Diff to previous 3.21 , to selected 3.4
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.20: +1 -4 lines
Diff to previous 3.20 , to selected 3.4
Thu Mar 4 10:29:23 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.19: +8 -0 lines
Diff to previous 3.19 , to selected 3.4
Tue Feb 2 16:13:24 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.18: +1 -1 lines
Diff to previous 3.18 , to selected 3.4
Sun Jan 31 10:56:57 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.17: +14 -12 lines
Diff to previous 3.17 , to selected 3.4
added new "portals" variable for multiple section geometry
Fri Dec 18 11:56:10 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.16: +9 -7 lines
Diff to previous 3.16 , to selected 3.4
Tue Nov 24 17:05:36 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.15: +8 -1 lines
Diff to previous 3.15 , to selected 3.4
Wed Aug 26 12:42:27 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.14: +1 -1 lines
Diff to previous 3.14 , to selected 3.4
fixed error in comment
Wed Jun 3 16:39:14 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 3.13: +20 -20 lines
Diff to previous 3.13 , to selected 3.4
Fri May 22 08:30:40 1998 UTC (26 years ago) by gwlarson
Changes since 3.12: +3 -1 lines
Diff to previous 3.12 , to selected 3.4
Mon Dec 15 20:41:39 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.11: +2 -4 lines
Diff to previous 3.11 , to selected 3.4
eliminated OCCUPANCY variable
Fri Dec 12 18:33:51 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.10: +3 -0 lines
Diff to previous 3.10 , to selected 3.4
reset start time and ray counts in new_rtrace()
Fri Dec 12 11:13:17 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.9: +2 -0 lines
Diff to previous 3.9 , to selected 3.4
Thu Dec 11 11:51:20 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.8: +2 -1 lines
Diff to previous 3.8 , to selected 3.4
increased MAXPROC from 16 to 64 and made nprocs variable global
Mon Dec 8 18:51:15 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.7: +2 -0 lines
Diff to previous 3.7 , to selected 3.4
Tue Dec 2 12:29:18 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.6: +9 -11 lines
Diff to previous 3.6 , to selected 3.4
removed useless EXPOSURE variable
added setdefaults() call after loading holodeck
Mon Dec 1 16:31:50 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.5: +5 -3 lines
Diff to previous 3.5 , to selected 3.4
added "VDISTANCE" variable for virtual distance calculation
Wed Nov 26 21:34:27 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.4: +4 -1 lines
Diff to previous 3.4
Revision 3.4 - (view) (download) (annotate) - [selected]
Wed Nov 26 20:16:01 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.3: +7 -9 lines
Diff to previous 3.3
minor changes
Mon Nov 10 18:05:07 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.2: +17 -15 lines
Diff to previous 3.2 , to selected 3.4
took out VIEW type and changed packray() macro to packra()
Mon Nov 3 18:33:12 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +5 -0 lines
Diff to previous 3.1 , to selected 3.4
Fri Oct 31 10:23:29 1997 UTC (26 years, 6 months ago) by gregl
Diff to selected 3.4
