root/radiance/ray/src/hd/rholo.h
Revision: 3.18
Committed: Sun Jan 31 10:56:57 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.17: +14 -12 lines
added new "portals" variable for multiple section geometry
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for rholo program
7 */
8
9 #include "holo.h"
10 #include "vars.h"
11
12 #ifndef RPACKSIZ
13 #define RPACKSIZ 21 /* good packet size */
14 #endif
15
16 typedef struct packet {
17 int2 hd; /* holodeck section (first) */
18 int4 bi; /* beam index (second) */
19 int4 nr; /* number of rays (third) */
20 int4 nc; /* number calculated (fourth) */
21 RAYVAL ra[RPACKSIZ]; /* ray values (fifth) */
22 float *offset; /* offset array if !vbool(OBSTRUCTIONS) */
23 struct packet *next; /* next in packet list */
24 } PACKET; /* a beam packet */
25
26 typedef struct {
27 int2 hd; /* holodeck section (first) */
28 int4 bi; /* beam index (second) */
29 int4 nr; /* number of rays (third) */
30 int4 nc; /* number calculated (fourth) */
31 } PACKHEAD; /* followed by ray values */
32
33 #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL))
34 #define packra(p) ((RAYVAL *)((p)+1))
35
36 typedef struct {
37 FVECT vpt; /* view (eye point) position */
38 double rng; /* desired mean radius for sample rays */
39 } VIEWPOINT; /* target eye position */
40
41 /* input variables */
42 #define CACHE 0 /* amount of memory to use as cache */
43 #define DISKSPACE 1 /* how much disk space to use */
44 #define EYESEP 2 /* eye separation distance */
45 #define GEOMETRY 3 /* section geometry */
46 #define GRID 4 /* target grid size */
47 #define OBSTRUCTIONS 5 /* shall we track obstructions? */
48 #define OCTREE 6 /* octree file name */
49 #define PORTS 7 /* section portals */
50 #define RENDER 8 /* rendering options */
51 #define REPORT 9 /* report interval and error file */
52 #define RIF 10 /* rad input file */
53 #define SECTION 11 /* holodeck section boundaries */
54 #define TIME 12 /* maximum rendering time */
55 #define VDIST 13 /* virtual distance calculation */
56
57 #define NRHVARS 14 /* number of variables */
58
59 #define RHVINIT { \
60 {"CACHE", 2, 0, NULL, fltvalue}, \
61 {"DISKSPACE", 3, 0, NULL, fltvalue}, \
62 {"EYESEP", 3, 0, NULL, fltvalue}, \
63 {"geometry", 3, 0, NULL, NULL}, \
64 {"GRID", 2, 0, NULL, fltvalue}, \
65 {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \
66 {"OCTREE", 3, 0, NULL, onevalue}, \
67 {"portals", 3, 0, NULL, NULL}, \
68 {"render", 3, 0, NULL, catvalues}, \
69 {"REPORT", 3, 0, NULL, onevalue}, \
70 {"RIF", 3, 0, NULL, onevalue}, \
71 {"section", 3, 0, NULL, NULL}, \
72 {"TIME", 2, 0, NULL, fltvalue}, \
73 {"VDISTANCE", 2, 0, NULL, boolvalue}, \
74 }
75
76 /* bundle set requests */
77 #define BS_NEW 1 /* replace current set with new one */
78 #define BS_ADD 2 /* add to current set */
79 #define BS_ADJ 3 /* adjust current set quantities */
80 #define BS_DEL 4 /* delete from current set */
81
82 extern char *progname; /* our program name */
83 extern char *hdkfile; /* holodeck file name */
84 extern char froot[]; /* root file name */
85
86 extern char *outdev; /* output device name */
87
88 extern int readinp; /* read input from stdin */
89
90 extern int force; /* allow overwrite of holodeck */
91
92 extern int nowarn; /* turn warnings off? */
93
94 extern int ncprocs; /* number of requested compute processes */
95 extern int nprocs; /* number of running compute processes */
96
97 extern double expval; /* global exposure value */
98
99 extern VIEWPOINT myeye; /* target view position */
100
101 extern time_t starttime; /* time we got started */
102 extern time_t endtime; /* time we should end by */
103 extern time_t reporttime; /* time for next report */
104
105 extern long nraysdone; /* number of rays done */
106 extern long npacksdone; /* number of packets done */
107
108 extern int rtargc; /* rtrace command */
109 extern char *rtargv[];
110
111 extern PACKET *do_packets(), *get_packets(), *flush_queue();
