root/radiance/ray/src/hd/rholo.h
Revision: 3.27
Committed: Thu Feb 6 21:45:00 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 3.26: +4 -4 lines
perf: Made printing of variables a little neater; added CAPDATE to holo header
1 /* RCSid: $Id: rholo.h,v 3.26 2016/03/21 19:06:08 greg Exp $ */
2 /*
3 * Header file for rholo program
4 */
5 #ifndef _RAD_RHOLO_H_
6 #define _RAD_RHOLO_H_
7
8 #include "holo.h"
9 #include "view.h"
10 #include "vars.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 #ifndef RPACKSIZ
17 #define RPACKSIZ 21 /* good packet size */
18 #endif
19
20 typedef struct packet {
21 int16 hd; /* holodeck section (first) */
22 int32 bi; /* beam index (second) */
23 int32 nr; /* number of rays (third) */
24 int32 nc; /* number calculated (fourth) */
25 RAYVAL ra[RPACKSIZ]; /* ray values (fifth) */
26 float *offset; /* offset array if !vbool(OBSTRUCTIONS) */
27 struct packet *next; /* next in packet list */
28 } PACKET; /* a beam packet */
29
30 typedef struct {
31 int16 hd; /* holodeck section (first) */
32 int32 bi; /* beam index (second) */
33 int32 nr; /* number of rays (third) */
34 int32 nc; /* number calculated (fourth) */
35 } PACKHEAD; /* followed by ray values */
36
37 #define packsiz(nr) (sizeof(PACKHEAD)+(nr)*sizeof(RAYVAL))
38 #define packra(p) ((RAYVAL *)((p)+1))
39
40 typedef struct {
41 int nb; /* number of beams in list */
42 PACKHEAD *bl; /* allocated beam list */
43 } BEAMLIST; /* a list of beam requests */
44
45 typedef struct {
46 FVECT vpt; /* view (eye point) position */
47 double rng; /* desired mean radius for sample rays */
48 } VIEWPOINT; /* target eye position */
49
50 /* input variables */
51 #define CACHE 0 /* amount of memory to use as cache */
52 #define DISKSPACE 1 /* how much disk space to use */
53 #define EYESEP 2 /* eye separation distance */
54 #define GEOMETRY 3 /* section geometry */
55 #define GRID 4 /* target grid size */
56 #define OBSTRUCTIONS 5 /* shall we track obstructions? */
57 #define OCTREE 6 /* octree file name */
58 #define PORTS 7 /* section portals */
59 #define RENDER 8 /* rendering options */
60 #define REPORT 9 /* report interval and error file */
61 #define RIF 10 /* rad input file */
62 #define SECTION 11 /* holodeck section boundaries */
63 #define TIME 12 /* maximum rendering time */
64 #define VDIST 13 /* virtual distance calculation */
65
66 #define NRHVARS 14 /* number of variables */
67
68 #define RHVINIT { \
69 {"CACHE", 2, 0, NULL, fltvalue}, \
70 {"DISKSPACE", 3, 0, NULL, fltvalue}, \
71 {"EYESEP", 3, 0, NULL, fltvalue}, \
72 {"geometry", 3, 0, NULL, NULL}, \
73 {"GRID", 2, 0, NULL, fltvalue}, \
74 {"OBSTRUCTIONS",3, 0, NULL, boolvalue}, \
75 {"OCTREE", 3, 0, NULL, strvalue}, \
76 {"portals", 3, 0, NULL, NULL}, \
77 {"render", 3, 0, NULL, catvalues}, \
78 {"REPORT", 3, 0, NULL, strvalue}, \
79 {"RIF", 3, 0, NULL, strvalue}, \
80 {"section", 3, 0, NULL, NULL}, \
81 {"TIME", 2, 0, NULL, fltvalue}, \
82 {"VDISTANCE", 2, 0, NULL, boolvalue}, \
83 }
84
85 /* bundle set requests */
86 #define BS_NEW 1 /* replace current set with new one */
87 #define BS_ADD 2 /* add to current set */
88 #define BS_ADJ 3 /* adjust current set quantities */
89 #define BS_DEL 4 /* delete from current set */
90 #define BS_MAX 5 /* set to max of old and new */
91
92 extern char *progname; /* our program name */
93 extern char *hdkfile; /* holodeck file name */
94 extern char froot[]; /* root file name */
95
96 extern char *outdev; /* output device name */
97
98 extern int readinp; /* read input from stdin */
99
100 extern int force; /* allow overwrite of holodeck */
101
102 extern int nowarn; /* turn warnings off? */
103
104 extern int ncprocs; /* number of requested compute processes */
105 extern int nprocs; /* number of running compute processes */
106
107 extern int chunkycmp; /* using "chunky" comparison mode */
108
109 extern VIEWPOINT myeye; /* target view position */
110
111 extern time_t starttime; /* time we got started */
112 extern time_t endtime; /* time we should end by */
113 extern time_t reporttime; /* time for next report */
114
115 extern long nraysdone; /* number of rays done */
116 extern long npacksdone; /* number of packets done */
117
118 #define MAXRTARGC 256
119 extern int rtargc; /* rtrace command */
120 extern char *rtargv[];
121
122 /* rholo.c */
123 extern void done_packets(PACKET *pl);
124 /* rholo2.c */
125 extern void new_rtrace(void);
126 extern int done_rtrace(void);
127 extern void packrays(float *rod, PACKET *p);
128 extern void donerays(PACKET *p, float *rvl);
129 extern int getradfile(void);
130 extern void report(time_t t);
131 /* rholo2l.c */
132 extern int start_rtrace(void);
133 extern int end_rtrace(void);
134 extern PACKET *do_packets(PACKET *pl);
135 extern PACKET *flush_queue(void);
136 /* rholo3.c */
137 extern void init_global(void);
138 extern int next_packet(PACKET *p, int n);
139 extern void bundle_set(int op, PACKHEAD *clist, int nents);
140 /* rholo4.c */
141 extern void disp_open(char *dname);
142 extern void disp_packet(register PACKHEAD *p);
143 extern int disp_check(int block);
144 extern int disp_close(void);
145 /* viewbeams.c */
146 extern int nextview(VIEW *vp, FILE *fp);
147 extern int16 * viewbeams(VIEW *vp, int hr, int vr, BEAMLIST *blp);
148
149 #ifdef __cplusplus
150 }
151 #endif
152 #endif /* _RAD_RHOLO_H_ */
153
