| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rholo.c,v 3.85 2025/02/06 21:45:00 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Radiance holodeck generation controller
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
#include <time.h>
| 10 |
#include <signal.h>
| 11 |
#include <sys/stat.h>
| 12 |
#include <string.h>
| 13 |
| 14 |
#include "platform.h"
| 15 |
#include "rterror.h"
| 16 |
#include "resolu.h"
| 17 |
#include "rholo.h"
| 18 |
#include "random.h"
| 19 |
| 20 |
#ifndef FRAGWARN
| 21 |
#define FRAGWARN 20 /* fragmentation for warning (%) */
| 22 |
#endif
| 23 |
#ifndef MAXQTIME
| 24 |
#define MAXQTIME 3 /* target maximum seconds in queue */
| 25 |
#endif
| 26 |
/* manual cache flushing frequency */
| 27 |
#ifndef RTFLUSH
| 28 |
#if MAXQTIME
| 29 |
#define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */
| 30 |
#else
| 31 |
#define RTFLUSH (50*totqlen) /* just guess */
| 32 |
#endif
| 33 |
#endif
| 34 |
/* the following must be consistent with rholo.h */
| 35 |
int NVARS = NRHVARS; /* total number of variables */
| 36 |
| 37 |
VARIABLE vv[] = RHVINIT; /* variable-value pairs */
| 38 |
| 39 |
char *hdkfile; /* holodeck file name */
| 40 |
char froot[256]; /* root file name */
| 41 |
| 42 |
int ncprocs = 0; /* desired number of compute processes */
| 43 |
| 44 |
char *outdev = NULL; /* output device name */
| 45 |
| 46 |
int readinp = 0; /* read commands from stdin */
| 47 |
| 48 |
int force = 0; /* allow overwrite of holodeck (-1 == read-only) */
| 49 |
| 50 |
time_t starttime; /* time we got started */
| 51 |
time_t endtime; /* time we should end by */
| 52 |
time_t reporttime; /* time for next report */
| 53 |
| 54 |
off_t maxdisk; /* maximum file space (bytes) */
| 55 |
| 56 |
int rtargc = 1; /* rtrace command */
| 57 |
char *rtargv[MAXRTARGC] = {"rtrace", NULL};
| 58 |
| 59 |
int orig_mode = -1; /* original file mode (-1 if unchanged) */
| 60 |
| 61 |
long nraysdone = 0L; /* number of rays done */
| 62 |
long npacksdone = 0L; /* number of packets done */
| 63 |
| 64 |
PACKET *freepacks; /* available packets */
| 65 |
int totqlen; /* maximum queue length (number of packets) */
| 66 |
| 67 |
char *sigerr[NSIG]; /* signal error messages */
| 68 |
| 69 |
extern int nowarn; /* turn warnings off? */
| 70 |
| 71 |
static void onsig(int signo);
| 72 |
static void sigdie(int signo, char *msg);
| 73 |
static int resfmode(int fd, int mod);
| 74 |
static void initrholo(void);
| 75 |
static int rholo(void);
| 76 |
static void setdefaults(HDGRID *gp);
| 77 |
static void creatholo(HDGRID *gp);
| 78 |
static gethfunc headline;
| 79 |
static void loadholo(void);
| 80 |
static void rootname(char *rn, char *fn);
| 81 |
static void badvalue(int vc);
| 82 |
| 83 |
| 84 |
int
| 85 |
main(
| 86 |
int argc,
| 87 |
char *argv[]
| 88 |
| 89 |
| 90 |
int i;
| 91 |
| 92 |
fixargv0(argv[0]); /* get arguments */
| 93 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 94 |
switch (argv[i][1]) {
| 95 |
case 'w': /* turn off warnings */
| 96 |
nowarn++;
| 97 |
break;
| 98 |
case 'f': /* force overwrite */
| 99 |
force = 1;
| 100 |
break;
| 101 |
case 'r': /* read-only mode */
| 102 |
force = -1;
| 103 |
break;
| 104 |
case 'i': /* read input from stdin */
| 105 |
readinp++;
| 106 |
break;
| 107 |
case 'n': /* compute processes */
| 108 |
if (i >= argc-2)
| 109 |
goto userr;
| 110 |
ncprocs = atoi(argv[++i]);
| 111 |
break;
| 112 |
case 'o': /* output display */
| 113 |
if (i >= argc-2)
| 114 |
goto userr;
| 115 |
outdev = argv[++i];
| 116 |
break;
| 117 |
default:
| 118 |
goto userr;
| 119 |
| 120 |
/* get root file name */
| 121 |
if (i >= argc)
| 122 |
goto userr;
| 123 |
rootname(froot, hdkfile=argv[i++]);
| 124 |
/* load variables? */
| 125 |
if (i < argc)
| 126 |
if (argv[i][0] != '-' && argv[i][0] != '+')
| 127 |
loadvars(argv[i]); /* load variables from file */
| 128 |
| 129 |
if (i >= argc || argv[i][0] == '+')
| 130 |
loadholo(); /* load existing holodeck */
| 131 |
| 132 |
while (++i < argc) /* get command line settings */
| 133 |
if (setvariable(argv[i], matchvar) < 0) {
| 134 |
sprintf(errmsg, "unknown variable: %s", argv[i]);
| 135 |
error(USER, errmsg);
| 136 |
| 137 |
/* check settings */
| 138 |
checkvalues();
| 139 |
/* load rad input file */
| 140 |
getradfile();
| 141 |
| 142 |
if (hdlist[0] == NULL) { /* create new holodeck */
| 143 |
HDGRID hdg[HDMAX];
| 144 |
/* set defaults */
| 145 |
setdefaults(hdg);
| 146 |
/* check read-only */
| 147 |
if (force < 0)
| 148 |
error(USER, "cannot create read-only holodeck");
| 149 |
/* holodeck exists? */
| 150 |
if (!force && access(hdkfile, R_OK|W_OK) == 0)
| 151 |
error(USER,
| 152 |
"holodeck file exists -- use -f to overwrite");
| 153 |
/* create holodeck */
| 154 |
creatholo(hdg);
| 155 |
} else /* else just set defaults */
| 156 |
setdefaults(NULL);
| 157 |
/* initialize */
| 158 |
initrholo();
| 159 |
/* main loop */
| 160 |
while (rholo())
| 161 |
| 162 |
/* done */
| 163 |
quit(0);
| 164 |
userr:
| 165 |
fprintf(stderr,
| 166 |
"Usage: %s [-n nprocs][-o disp][-i][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n",
| 167 |
progname);
| 168 |
quit(1);
| 169 |
return 1; /* pro forma return */
| 170 |
| 171 |
| 172 |
| 173 |
static void
| 174 |
onsig( /* fatal signal */
| 175 |
int signo
| 176 |
| 177 |
| 178 |
static int gotsig = 0;
| 179 |
| 180 |
if (gotsig > 1) /* we're going as fast as we can! */
| 181 |
return;
| 182 |
if (gotsig++) { /* two signals and we split */
| 183 |
hdsync(NULL, 0); /* don't leave w/o saying goodbye */
| 184 |
_exit(signo);
| 185 |
| 186 |
alarm(300); /* allow 10 minutes to clean up */
| 187 |
eputs("signal - ");
| 188 |
eputs(sigerr[signo]);
| 189 |
eputs("\n");
| 190 |
quit(3);
| 191 |
| 192 |
| 193 |
| 194 |
static void
| 195 |
sigdie( /* set fatal signal */
| 196 |
int signo,
| 197 |
char *msg
| 198 |
| 199 |
| 200 |
if (signal(signo, onsig) == SIG_IGN)
| 201 |
signal(signo, SIG_IGN);
| 202 |
sigerr[signo] = msg;
| 203 |
| 204 |
| 205 |
| 206 |
static int
| 207 |
resfmode( /* restrict open file access mode */
| 208 |
int fd,
| 209 |
int mod
| 210 |
| 211 |
| 212 |
struct stat stbuf;
| 213 |
/* get original mode */
| 214 |
if (fstat(fd, &stbuf) < 0)
| 215 |
error(SYSTEM, "cannot stat open holodeck file");
| 216 |
mod &= stbuf.st_mode; /* always more restrictive */
| 217 |
if (mod == (stbuf.st_mode & 0777))
| 218 |
return(-1); /* already set */
| 219 |
/* else change it */
| 220 |
if (fchmod(fd, mod) < 0) {
| 221 |
error(WARNING, "cannot change holodeck file access mode");
| 222 |
return(-1);
| 223 |
| 224 |
return(stbuf.st_mode); /* return original mode */
| 225 |
| 226 |
| 227 |
| 228 |
static void
| 229 |
initrholo(void) /* get our holodeck running */
| 230 |
| 231 |
int i;
| 232 |
/* close holodeck on exec() */
| 233 |
fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC);
| 234 |
| 235 |
if (outdev != NULL) /* open output device */
| 236 |
disp_open(outdev);
| 237 |
else if (ncprocs > 0) /* else use global ray feed */
| 238 |
init_global();
| 239 |
/* record disk space limit */
| 240 |
if (!vdef(DISKSPACE))
| 241 |
maxdisk = ((off_t)1<<(sizeof(off_t)*8-2)) - 1024;
| 242 |
else
| 243 |
maxdisk = 1024.*1024.*vflt(DISKSPACE);
| 244 |
/* set up memory cache */
| 245 |
if (outdev == NULL)
| 246 |
hdcachesize = 0; /* manual flushing */
| 247 |
else if (vdef(CACHE))
| 248 |
hdcachesize = 1024.*1024.*vflt(CACHE);
| 249 |
/* open report file */
| 250 |
if (vdef(REPORT)) {
| 251 |
char *s = sskip2(vval(REPORT), 1);
| 252 |
if (*s && freopen(s, "a", stderr) == NULL)
| 253 |
quit(2);
| 254 |
| 255 |
/* mark the starting time */
| 256 |
starttime = time(NULL);
| 257 |
/* compute end time */
| 258 |
if (!vdef(TIME) || vflt(TIME) <= FTINY)
| 259 |
endtime = 0;
| 260 |
else
| 261 |
endtime = starttime + vflt(TIME)*3600. + .5;
| 262 |
/* start rtrace */
| 263 |
if (ncprocs > 0) {
| 264 |
totqlen = i = start_rtrace();
| 265 |
if (i < 1)
| 266 |
error(USER, "cannot start rtrace process(es)");
| 267 |
if (vdef(REPORT)) { /* make first report */
| 268 |
printargs(rtargc, rtargv, stderr);
| 269 |
report(0);
| 270 |
| 271 |
/* allocate packets */
| 272 |
freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
| 273 |
if (freepacks == NULL)
| 274 |
goto memerr;
| 275 |
freepacks[--i].nr = 0;
| 276 |
freepacks[i].next = NULL;
| 277 |
if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) {
| 278 |
freepacks[i].offset = (float *)bmalloc(
| 279 |
RPACKSIZ*sizeof(float)*(i+1) );
| 280 |
if (freepacks[i].offset == NULL)
| 281 |
goto memerr;
| 282 |
} else
| 283 |
freepacks[i].offset = NULL;
| 284 |
while (i--) {
| 285 |
freepacks[i].nr = 0;
| 286 |
freepacks[i].offset = freepacks[i+1].offset == NULL ?
| 287 |
NULL : freepacks[i+1].offset+RPACKSIZ ;
| 288 |
freepacks[i].next = &freepacks[i+1];
| 289 |
| 290 |
| 291 |
/* set up signal handling */
| 292 |
sigdie(SIGINT, "Interrupt");
| 293 |
sigdie(SIGTERM, "Terminate");
| 294 |
#ifdef SIGHUP
| 295 |
sigdie(SIGHUP, "Hangup");
| 296 |
#endif
| 297 |
#ifdef SIGPIPE
| 298 |
sigdie(SIGPIPE, "Broken pipe");
| 299 |
#endif
| 300 |
#ifdef SIGALRM
| 301 |
sigdie(SIGALRM, "Alarm clock");
| 302 |
#endif
| 303 |
#ifdef SIGXCPU
| 304 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 305 |
#endif
| 306 |
#ifdef SIGXFSZ
| 307 |
sigdie(SIGXFSZ, "File size exceeded");
| 308 |
#endif
| 309 |
/* protect holodeck file */
| 310 |
orig_mode = resfmode(hdlist[0]->fd, (ncprocs>0) & (force>=0) ? 0 : 0444);
| 311 |
return;
| 312 |
memerr:
| 313 |
error(SYSTEM, "out of memory in initrholo");
| 314 |
| 315 |
| 316 |
| 317 |
static int
| 318 |
rholo(void) /* holodeck main loop */
| 319 |
| 320 |
static off_t nextfragwarn = 100L<<20;
| 321 |
static int idle = 0;
| 322 |
PACKET *pl = NULL, *plend;
| 323 |
off_t fsiz;
| 324 |
int pksiz;
| 325 |
PACKET *p;
| 326 |
time_t t;
| 327 |
/* check display */
| 328 |
if (nprocs <= 0)
| 329 |
idle = 1;
| 330 |
if (outdev != NULL) {
| 331 |
if (!disp_check(idle))
| 332 |
return(0); /* quit request */
| 333 |
if (nprocs <= 0)
| 334 |
return(1);
| 335 |
} else if (idle)
| 336 |
return(0); /* all done */
| 337 |
fsiz = hdfilen(hdlist[0]->fd); /* check file size */
| 338 |
if (maxdisk > 0 && fsiz >= maxdisk) {
| 339 |
error(USER, "file limit exceeded");
| 340 |
done_rtrace();
| 341 |
return(1); /* comes back */
| 342 |
| 343 |
#if FRAGWARN
| 344 |
if (fsiz >= nextfragwarn) {
| 345 |
double pctfrag = 100.*(fsiz-hdfiluse(hdlist[0]->fd))/fsiz;
| 346 |
if (pctfrag >= (double)FRAGWARN) {
| 347 |
sprintf(errmsg, "holodeck file fragmentation is %.0f%%",
| 348 |
pctfrag);
| 349 |
error(WARNING, errmsg);
| 350 |
nextfragwarn = fsiz + (fsiz>>2);
| 351 |
} else
| 352 |
nextfragwarn = fsiz + (10L<<20);
| 353 |
| 354 |
#endif
| 355 |
t = time(NULL); /* check time */
| 356 |
if (endtime > 0 && t >= endtime) {
| 357 |
error(USER, "time limit exceeded");
| 358 |
done_rtrace();
| 359 |
| 360 |
| 361 |
if (reporttime > 0 && t >= reporttime)
| 362 |
report(t);
| 363 |
/* figure out good packet size */
| 364 |
pksiz = RPACKSIZ;
| 365 |
#if MAXQTIME
| 366 |
if (!chunkycmp) {
| 367 |
pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L));
| 368 |
if (pksiz < 1) pksiz = 1;
| 369 |
else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ;
| 370 |
| 371 |
#endif
| 372 |
idle = 0; /* get packets to process */
| 373 |
while (freepacks != NULL) {
| 374 |
p = freepacks; freepacks = p->next; p->next = NULL;
| 375 |
if (!next_packet(p, pksiz)) {
| 376 |
p->next = freepacks; freepacks = p;
| 377 |
idle = 1;
| 378 |
break;
| 379 |
| 380 |
if (pl == NULL) pl = p;
| 381 |
else plend->next = p;
| 382 |
plend = p;
| 383 |
| 384 |
/* process packets */
| 385 |
done_packets(do_packets(pl));
| 386 |
return(1); /* and continue */
| 387 |
| 388 |
| 389 |
| 390 |
static void
| 391 |
setdefaults( /* set default values */
| 392 |
HDGRID *gp
| 393 |
| 394 |
| 395 |
int i;
| 396 |
int n;
| 397 |
double len[3], d;
| 398 |
| 399 |
if (!vdef(SECTION)) {
| 400 |
sprintf(errmsg, "%s must be defined", vnam(SECTION));
| 401 |
| 402 |
| 403 |
if (!vdef(OCTREE)) {
| 404 |
if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
| 405 |
error(SYSTEM, "out of memory");
| 406 |
sprintf(vval(OCTREE), "%s.oct", froot);
| 407 |
vdef(OCTREE)++;
| 408 |
| 409 |
if (!vdef(VDIST)) {
| 410 |
vval(VDIST) = "F";
| 411 |
vdef(VDIST)++;
| 412 |
| 413 |
/* append rendering options */
| 414 |
if (vdef(RENDER))
| 415 |
rtargc += wordstring(rtargv+rtargc, MAXRTARGC-rtargc, vval(RENDER));
| 416 |
| 417 |
if (gp == NULL) /* already initialized? */
| 418 |
return;
| 419 |
/* set grid parameters */
| 420 |
for (n = 0; n < vdef(SECTION); n++, gp++) {
| 421 |
gp->grid[0] = gp->grid[1] = gp->grid[2] = 0;
| 422 |
if (sscanf(nvalue(SECTION, n),
| 423 |
"%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd",
| 424 |
&gp->orig[0], &gp->orig[1], &gp->orig[2],
| 425 |
&gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
| 426 |
&gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
| 427 |
&gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2],
| 428 |
&gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12)
| 429 |
badvalue(SECTION);
| 430 |
for (i = 0; i < 3; i++)
| 431 |
len[i] = VLEN(gp->xv[i]);
| 432 |
if (!vdef(GRID)) {
| 433 |
d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] +
| 434 |
len[2]*len[2] + 4*len[1]*len[2])
| 435 |
+ len[1]*len[1]*len[2]*(len[2] + 4*len[0])
| 436 |
+ 4*len[0]*len[1]*len[2]*len[2] );
| 437 |
d = sqrt(sqrt(d));
| 438 |
} else if ((d = vflt(GRID)) <= FTINY)
| 439 |
badvalue(GRID);
| 440 |
| 441 |
if (gp->grid[i] <= 0)
| 442 |
gp->grid[i] = len[i]/d + (1.-FTINY);
| 443 |
| 444 |
| 445 |
| 446 |
| 447 |
static void
| 448 |
creatholo( /* create a holodeck output file */
| 449 |
HDGRID *gp
| 450 |
| 451 |
| 452 |
extern char VersionID[];
| 453 |
off_t lastloc, nextloc;
| 454 |
int n;
| 455 |
int fd;
| 456 |
FILE *fp;
| 457 |
/* open & truncate file */
| 458 |
if ((fp = fopen(hdkfile, "wb+")) == NULL) {
| 459 |
sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
| 460 |
error(SYSTEM, errmsg);
| 461 |
| 462 |
/* write information header */
| 463 |
newheader("RADIANCE", fp);
| 464 |
fprintf(fp, "SOFTWARE= %s\n", VersionID);
| 465 |
fputnow(fp);
| 466 |
printvars(fp);
| 467 |
fputendian(fp);
| 468 |
fputformat(HOLOFMT, fp);
| 469 |
fputc('\n', fp);
| 470 |
putw(HOLOMAGIC, fp); /* put magic number */
| 471 |
fd = dup(fileno(fp));
| 472 |
fclose(fp); /* flush and close stdio stream */
| 473 |
lastloc = lseek(fd, (off_t)0, SEEK_END);
| 474 |
for (n = vdef(SECTION); n--; gp++) { /* initialize each section */
| 475 |
nextloc = 0L;
| 476 |
write(fd, (char *)&nextloc, sizeof(nextloc));
| 477 |
hdinit(fd, gp); /* writes beam index */
| 478 |
if (!n)
| 479 |
break;
| 480 |
nextloc = hdfilen(fd); /* write section pointer */
| 481 |
if (lseek(fd, lastloc, SEEK_SET) < 0)
| 482 |
error(SYSTEM,
| 483 |
"cannot seek on holodeck file in creatholo");
| 484 |
| 485 |
lseek(fd, (lastloc=nextloc), SEEK_SET);
| 486 |
| 487 |
| 488 |
| 489 |
| 490 |
static int
| 491 |
headline( /* process information header line */
| 492 |
char *s,
| 493 |
void *p
| 494 |
| 495 |
| 496 |
extern char FMTSTR[];
| 497 |
char *cp;
| 498 |
char fmt[MAXFMTLEN];
| 499 |
| 500 |
if (formatval(fmt, s)) {
| 501 |
if (strcmp(fmt, HOLOFMT)) {
| 502 |
sprintf(errmsg, "%s file \"%s\" has %s%s",
| 503 |
HOLOFMT, hdkfile, FMTSTR, fmt);
| 504 |
| 505 |
| 506 |
return(0);
| 507 |
| 508 |
for (cp = s; *cp; cp++) /* take off any comments */
| 509 |
if (*cp == '#') {
| 510 |
*cp = '\0';
| 511 |
break;
| 512 |
| 513 |
setvariable(s, matchvar); /* don't flag errors */
| 514 |
return(0);
| 515 |
| 516 |
| 517 |
| 518 |
static void
| 519 |
loadholo(void) /* start loading a holodeck from fname */
| 520 |
| 521 |
FILE *fp;
| 522 |
int fd;
| 523 |
int n;
| 524 |
off_t nextloc;
| 525 |
| 526 |
if ((ncprocs > 0) & (force >= 0))
| 527 |
fp = fopen(hdkfile, "rb+");
| 528 |
else
| 529 |
fp = NULL;
| 530 |
if (fp == NULL) {
| 531 |
if ((fp = fopen(hdkfile, "rb")) == NULL) {
| 532 |
sprintf(errmsg, "cannot open \"%s\"", hdkfile);
| 533 |
| 534 |
| 535 |
if (ncprocs > 0) {
| 536 |
sprintf(errmsg, "\"%s\" is read-only", hdkfile);
| 537 |
if (outdev == NULL)
| 538 |
| 539 |
strcat(errmsg, "; new rays will be discarded");
| 540 |
| 541 |
force = -1;
| 542 |
| 543 |
| 544 |
/* load variables from header */
| 545 |
getheader(fp, headline, NULL);
| 546 |
/* check magic number */
| 547 |
if (getw(fp) != HOLOMAGIC) {
| 548 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
| 549 |
hdkfile);
| 550 |
| 551 |
| 552 |
nextloc = ftell(fp); /* get stdio position */
| 553 |
| 554 |
fclose(fp); /* done with stdio */
| 555 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */
| 556 |
lseek(fd, nextloc, SEEK_SET);
| 557 |
read(fd, (char *)&nextloc, sizeof(nextloc));
| 558 |
hdinit(fd, NULL);
| 559 |
| 560 |
if (n != vdef(SECTION)) {
| 561 |
sprintf(errmsg, "number of sections does not match %s setting",
| 562 |
vnam(SECTION));
| 563 |
| 564 |
| 565 |
| 566 |
| 567 |
| 568 |
void
| 569 |
done_packets( /* handle finished packets */
| 570 |
PACKET *pl
| 571 |
| 572 |
| 573 |
static int n2flush = 0;
| 574 |
PACKET *p;
| 575 |
| 576 |
while (pl != NULL) {
| 577 |
p = pl; pl = p->next; p->next = NULL;
| 578 |
if (p->nr > 0) { /* add to holodeck */
| 579 |
memcpy( (void *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
| 580 |
(void *)p->ra,
| 581 |
p->nr*sizeof(RAYVAL));
| 582 |
if (outdev != NULL) /* display it */
| 583 |
disp_packet((PACKHEAD *)p);
| 584 |
if (hdcachesize <= 0)
| 585 |
n2flush++;
| 586 |
nraysdone += p->nr;
| 587 |
npacksdone++;
| 588 |
p->nr = 0;
| 589 |
| 590 |
p->next = freepacks; /* push onto free list */
| 591 |
freepacks = p;
| 592 |
| 593 |
if (n2flush >= RTFLUSH) {
| 594 |
if (outdev != NULL)
| 595 |
hdsync(NULL, 1);
| 596 |
else
| 597 |
hdflush(NULL);
| 598 |
n2flush = 0;
| 599 |
| 600 |
| 601 |
| 602 |
| 603 |
static void
| 604 |
rootname( /* remove tail from end of fn */
| 605 |
char *rn,
| 606 |
char *fn
| 607 |
| 608 |
| 609 |
char *tp, *dp;
| 610 |
| 611 |
for (tp = NULL, dp = rn; (*rn = *fn++); rn++) {
| 612 |
if (*rn == '/')
| 613 |
dp = rn;
| 614 |
else if (*rn == '.')
| 615 |
tp = rn;
| 616 |
| 617 |
if (tp != NULL && tp > dp)
| 618 |
*tp = '\0';
| 619 |
| 620 |
| 621 |
| 622 |
static void
| 623 |
badvalue( /* report bad variable value and exit */
| 624 |
int vc
| 625 |
| 626 |
| 627 |
sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
| 628 |
| 629 |
| 630 |
| 631 |
| 632 |
void
| 633 |
eputs(const char *s) /* put error message to stderr */
| 634 |
| 635 |
static int midline = 0;
| 636 |
| 637 |
if (!*s)
| 638 |
return;
| 639 |
if (!midline++) { /* prepend line with program name */
| 640 |
fputs(progname, stderr);
| 641 |
fputs(": ", stderr);
| 642 |
| 643 |
fputs(s, stderr);
| 644 |
if (s[strlen(s)-1] == '\n') {
| 645 |
fflush(stderr);
| 646 |
midline = 0;
| 647 |
| 648 |
| 649 |
| 650 |
| 651 |
void
| 652 |
quit(int ec) /* exit program gracefully */
| 653 |
| 654 |
int status = 0;
| 655 |
| 656 |
if (hdlist[0] != NULL) { /* close holodeck */
| 657 |
if (nprocs > 0)
| 658 |
status = done_rtrace(); /* calls hdsync() */
| 659 |
if ((ncprocs > 0) & (force >= 0) && vdef(REPORT)) {
| 660 |
off_t fsiz, fuse;
| 661 |
| 662 |
fuse = hdfiluse(hdlist[0]->fd);
| 663 |
fprintf(stderr,
| 664 |
"%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
| 665 |
hdkfile, fsiz/(1024.*1024.),
| 666 |
100.*(fsiz-fuse)/fsiz);
| 667 |
| 668 |
| 669 |
if (orig_mode >= 0) /* reset holodeck access mode */
| 670 |
fchmod(hdlist[0]->fd, orig_mode);
| 671 |
if (outdev != NULL) /* close display */
| 672 |
disp_close();
| 673 |
exit(ec ? ec : status); /* exit */
| 674 |
