root/radiance/ray/src/hd/rholo.c
Revision: 3.84
Committed: Tue Jan 21 22:30:01 2025 UTC (4 months ago) by greg
Changes since 3.83: +1 -3 lines
fix(rholo): Minimum # rays/packet was zero in some cases
2 static const char RCSid[] = "$Id: rholo.c,v 3.83 2023/02/09 21:54:11 greg Exp $";
5 * Radiance holodeck generation controller
6 */
7
8 #include <stdio.h>
9 #include <time.h>
10 #include <signal.h>
11 #include <sys/stat.h>
12 #include <string.h>
13
14 #include "platform.h"
15 #include "rterror.h"
16 #include "resolu.h"
17 #include "rholo.h"
18 #include "random.h"
19
20 #ifndef FRAGWARN
21 #define FRAGWARN 20 /* fragmentation for warning (%) */
22 #endif
23 #ifndef MAXQTIME
24 #define MAXQTIME 3 /* target maximum seconds in queue */
25 #endif
26 /* manual cache flushing frequency */
27 #ifndef RTFLUSH
28 #if MAXQTIME
29 #define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */
30 #else
31 #define RTFLUSH (50*totqlen) /* just guess */
32 #endif
33 #endif
34 /* the following must be consistent with rholo.h */
35 int NVARS = NRHVARS; /* total number of variables */
36
37 VARIABLE vv[] = RHVINIT; /* variable-value pairs */
38
39 char *progname; /* our program name */
40 char *hdkfile; /* holodeck file name */
41 char froot[256]; /* root file name */
42
43 int ncprocs = 0; /* desired number of compute processes */
44
45 char *outdev = NULL; /* output device name */
46
47 int readinp = 0; /* read commands from stdin */
48
49 int force = 0; /* allow overwrite of holodeck (-1 == read-only) */
50
51 time_t starttime; /* time we got started */
52 time_t endtime; /* time we should end by */
53 time_t reporttime; /* time for next report */
54
55 off_t maxdisk; /* maximum file space (bytes) */
56
57 int rtargc = 1; /* rtrace command */
58 char *rtargv[MAXRTARGC] = {"rtrace", NULL};
59
60 int orig_mode = -1; /* original file mode (-1 if unchanged) */
61
62 long nraysdone = 0L; /* number of rays done */
63 long npacksdone = 0L; /* number of packets done */
64
65 PACKET *freepacks; /* available packets */
66 int totqlen; /* maximum queue length (number of packets) */
67
68 char *sigerr[NSIG]; /* signal error messages */
69
70 extern int nowarn; /* turn warnings off? */
71
72 static void onsig(int signo);
73 static void sigdie(int signo, char *msg);
74 static int resfmode(int fd, int mod);
75 static void initrholo(void);
76 static int rholo(void);
77 static void setdefaults(HDGRID *gp);
78 static void creatholo(HDGRID *gp);
79 static gethfunc headline;
80 static void loadholo(void);
81 static void rootname(char *rn, char *fn);
82 static void badvalue(int vc);
83
84
85 int
86 main(
87 int argc,
88 char *argv[]
89 )
90 {
91 int i;
92
93 progname = argv[0]; /* get arguments */
94 for (i = 1; i < argc && argv[i][0] == '-'; i++)
95 switch (argv[i][1]) {
96 case 'w': /* turn off warnings */
97 nowarn++;
98 break;
99 case 'f': /* force overwrite */
100 force = 1;
101 break;
102 case 'r': /* read-only mode */
103 force = -1;
104 break;
105 case 'i': /* read input from stdin */
106 readinp++;
107 break;
108 case 'n': /* compute processes */
109 if (i >= argc-2)
110 goto userr;
111 ncprocs = atoi(argv[++i]);
112 break;
113 case 'o': /* output display */
114 if (i >= argc-2)
115 goto userr;
116 outdev = argv[++i];
117 break;
118 default:
119 goto userr;
120 }
121 /* get root file name */
122 if (i >= argc)
123 goto userr;
124 rootname(froot, hdkfile=argv[i++]);
125 /* load variables? */
126 if (i < argc)
127 if (argv[i][0] != '-' && argv[i][0] != '+')
128 loadvars(argv[i]); /* load variables from file */
129
130 if (i >= argc || argv[i][0] == '+')
131 loadholo(); /* load existing holodeck */
132
133 while (++i < argc) /* get command line settings */
134 if (setvariable(argv[i], matchvar) < 0) {
135 sprintf(errmsg, "unknown variable: %s", argv[i]);
136 error(USER, errmsg);
137 }
138 /* check settings */
139 checkvalues();
140 /* load rad input file */
141 getradfile();
142
143 if (hdlist[0] == NULL) { /* create new holodeck */
144 HDGRID hdg[HDMAX];
145 /* set defaults */
146 setdefaults(hdg);
147 /* check read-only */
148 if (force < 0)
149 error(USER, "cannot create read-only holodeck");
150 /* holodeck exists? */
151 if (!force && access(hdkfile, R_OK|W_OK) == 0)
152 error(USER,
153 "holodeck file exists -- use -f to overwrite");
154 /* create holodeck */
155 creatholo(hdg);
156 } else /* else just set defaults */
157 setdefaults(NULL);
158 /* initialize */
159 initrholo();
160 /* main loop */
161 while (rholo())
162 ;
163 /* done */
164 quit(0);
165 userr:
166 fprintf(stderr,
167 "Usage: %s [-n nprocs][-o disp][-i][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n",
168 progname);
169 quit(1);
170 return 1; /* pro forma return */
171 }
172
173
174 static void
175 onsig( /* fatal signal */
176 int signo
177 )
178 {
179 static int gotsig = 0;
180
181 if (gotsig > 1) /* we're going as fast as we can! */
182 return;
183 if (gotsig++) { /* two signals and we split */
184 hdsync(NULL, 0); /* don't leave w/o saying goodbye */
185 _exit(signo);
186 }
187 alarm(300); /* allow 10 minutes to clean up */
188 eputs("signal - ");
189 eputs(sigerr[signo]);
190 eputs("\n");
191 quit(3);
192 }
193
194
195 static void
196 sigdie( /* set fatal signal */
197 int signo,
198 char *msg
199 )
200 {
201 if (signal(signo, onsig) == SIG_IGN)
202 signal(signo, SIG_IGN);
203 sigerr[signo] = msg;
204 }
205
206
207 static int
208 resfmode( /* restrict open file access mode */
209 int fd,
210 int mod
211 )
212 {
213 struct stat stbuf;
214 /* get original mode */
215 if (fstat(fd, &stbuf) < 0)
216 error(SYSTEM, "cannot stat open holodeck file");
217 mod &= stbuf.st_mode; /* always more restrictive */
218 if (mod == (stbuf.st_mode & 0777))
219 return(-1); /* already set */
220 /* else change it */
221 if (fchmod(fd, mod) < 0) {
222 error(WARNING, "cannot change holodeck file access mode");
223 return(-1);
224 }
225 return(stbuf.st_mode); /* return original mode */
226 }
227
228
229 static void
230 initrholo(void) /* get our holodeck running */
231 {
232 int i;
233 /* close holodeck on exec() */
234 fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC);
235
236 if (outdev != NULL) /* open output device */
237 disp_open(outdev);
238 else if (ncprocs > 0) /* else use global ray feed */
239 init_global();
240 /* record disk space limit */
241 if (!vdef(DISKSPACE))
242 maxdisk = ((off_t)1<<(sizeof(off_t)*8-2)) - 1024;
243 else
244 maxdisk = 1024.*1024.*vflt(DISKSPACE);
245 /* set up memory cache */
246 if (outdev == NULL)
247 hdcachesize = 0; /* manual flushing */
248 else if (vdef(CACHE))
249 hdcachesize = 1024.*1024.*vflt(CACHE);
250 /* open report file */
251 if (vdef(REPORT)) {
252 char *s = sskip2(vval(REPORT), 1);
253 if (*s && freopen(s, "a", stderr) == NULL)
254 quit(2);
255 }
256 /* mark the starting time */
257 starttime = time(NULL);
258 /* compute end time */
259 if (!vdef(TIME) || vflt(TIME) <= FTINY)
260 endtime = 0;
261 else
262 endtime = starttime + vflt(TIME)*3600. + .5;
263 /* start rtrace */
264 if (ncprocs > 0) {
265 totqlen = i = start_rtrace();
266 if (i < 1)
267 error(USER, "cannot start rtrace process(es)");
268 if (vdef(REPORT)) { /* make first report */
269 printargs(rtargc, rtargv, stderr);
270 report(0);
271 }
272 /* allocate packets */
273 freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
274 if (freepacks == NULL)
275 goto memerr;
276 freepacks[--i].nr = 0;
277 freepacks[i].next = NULL;
278 if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) {
279 freepacks[i].offset = (float *)bmalloc(
280 RPACKSIZ*sizeof(float)*(i+1) );
281 if (freepacks[i].offset == NULL)
282 goto memerr;
283 } else
284 freepacks[i].offset = NULL;
285 while (i--) {
286 freepacks[i].nr = 0;
287 freepacks[i].offset = freepacks[i+1].offset == NULL ?
288 NULL : freepacks[i+1].offset+RPACKSIZ ;
289 freepacks[i].next = &freepacks[i+1];
290 }
291 }
292 /* set up signal handling */
293 sigdie(SIGINT, "Interrupt");
294 sigdie(SIGTERM, "Terminate");
295 #ifdef SIGHUP
296 sigdie(SIGHUP, "Hangup");
297 #endif
298 #ifdef SIGPIPE
299 sigdie(SIGPIPE, "Broken pipe");
300 #endif
301 #ifdef SIGALRM
302 sigdie(SIGALRM, "Alarm clock");
303 #endif
304 #ifdef SIGXCPU
305 sigdie(SIGXCPU, "CPU limit exceeded");
306 #endif
307 #ifdef SIGXFSZ
308 sigdie(SIGXFSZ, "File size exceeded");
309 #endif
310 /* protect holodeck file */
311 orig_mode = resfmode(hdlist[0]->fd, (ncprocs>0) & (force>=0) ? 0 : 0444);
312 return;
313 memerr:
314 error(SYSTEM, "out of memory in initrholo");
315 }
316
317
318 static int
319 rholo(void) /* holodeck main loop */
320 {
321 static off_t nextfragwarn = 100L<<20;
322 static int idle = 0;
323 PACKET *pl = NULL, *plend;
324 off_t fsiz;
325 int pksiz;
326 PACKET *p;
327 time_t t;
328 /* check display */
329 if (nprocs <= 0)
330 idle = 1;
331 if (outdev != NULL) {
332 if (!disp_check(idle))
333 return(0); /* quit request */
334 if (nprocs <= 0)
335 return(1);
336 } else if (idle)
337 return(0); /* all done */
338 fsiz = hdfilen(hdlist[0]->fd); /* check file size */
339 if (maxdisk > 0 && fsiz >= maxdisk) {
340 error(USER, "file limit exceeded");
341 done_rtrace();
342 return(1); /* comes back */
343 }
344 #if FRAGWARN
345 if (fsiz >= nextfragwarn) {
346 double pctfrag = 100.*(fsiz-hdfiluse(hdlist[0]->fd))/fsiz;
347 if (pctfrag >= (double)FRAGWARN) {
348 sprintf(errmsg, "holodeck file fragmentation is %.0f%%",
349 pctfrag);
350 error(WARNING, errmsg);
351 nextfragwarn = fsiz + (fsiz>>2);
352 } else
353 nextfragwarn = fsiz + (10L<<20);
354 }
355 #endif
356 t = time(NULL); /* check time */
357 if (endtime > 0 && t >= endtime) {
358 error(USER, "time limit exceeded");
359 done_rtrace();
360 return(1); /* comes back */
361 }
362 if (reporttime > 0 && t >= reporttime)
363 report(t);
364 /* figure out good packet size */
365 pksiz = RPACKSIZ;
366 #if MAXQTIME
367 if (!chunkycmp) {
368 pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L));
369 if (pksiz < 1) pksiz = 1;
370 else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ;
371 }
372 #endif
373 idle = 0; /* get packets to process */
374 while (freepacks != NULL) {
375 p = freepacks; freepacks = p->next; p->next = NULL;
376 if (!next_packet(p, pksiz)) {
377 p->next = freepacks; freepacks = p;
378 idle = 1;
379 break;
380 }
381 if (pl == NULL) pl = p;
382 else plend->next = p;
383 plend = p;
384 }
385 /* process packets */
386 done_packets(do_packets(pl));
387 return(1); /* and continue */
388 }
389
390
391 static void
392 setdefaults( /* set default values */
393 HDGRID *gp
394 )
395 {
396 int i;
397 int n;
398 double len[3], d;
399
400 if (!vdef(SECTION)) {
401 sprintf(errmsg, "%s must be defined", vnam(SECTION));
402 error(USER, errmsg);
403 }
404 if (!vdef(OCTREE)) {
405 if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
406 error(SYSTEM, "out of memory");
407 sprintf(vval(OCTREE), "%s.oct", froot);
408 vdef(OCTREE)++;
409 }
410 if (!vdef(VDIST)) {
411 vval(VDIST) = "F";
412 vdef(VDIST)++;
413 }
414 /* append rendering options */
415 if (vdef(RENDER))
416 rtargc += wordstring(rtargv+rtargc, MAXRTARGC-rtargc, vval(RENDER));
417
418 if (gp == NULL) /* already initialized? */
419 return;
420 /* set grid parameters */
421 for (n = 0; n < vdef(SECTION); n++, gp++) {
422 gp->grid[0] = gp->grid[1] = gp->grid[2] = 0;
423 if (sscanf(nvalue(SECTION, n),
424 "%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd",
425 &gp->orig[0], &gp->orig[1], &gp->orig[2],
426 &gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
427 &gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
428 &gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2],
429 &gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12)
430 badvalue(SECTION);
431 for (i = 0; i < 3; i++)
432 len[i] = VLEN(gp->xv[i]);
433 if (!vdef(GRID)) {
434 d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] +
435 len[2]*len[2] + 4*len[1]*len[2])
436 + len[1]*len[1]*len[2]*(len[2] + 4*len[0])
437 + 4*len[0]*len[1]*len[2]*len[2] );
438 d = sqrt(sqrt(d));
439 } else if ((d = vflt(GRID)) <= FTINY)
440 badvalue(GRID);
441 for (i = 0; i < 3; i++)
442 if (gp->grid[i] <= 0)
443 gp->grid[i] = len[i]/d + (1.-FTINY);
444 }
445 }
446
447
448 static void
449 creatholo( /* create a holodeck output file */
450 HDGRID *gp
451 )
452 {
453 extern char VersionID[];
454 off_t lastloc, nextloc;
455 int n;
456 int fd;
457 FILE *fp;
458 /* open & truncate file */
459 if ((fp = fopen(hdkfile, "wb+")) == NULL) {
460 sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
461 error(SYSTEM, errmsg);
462 }
463 /* write information header */
464 newheader("RADIANCE", fp);
465 fprintf(fp, "SOFTWARE= %s\n", VersionID);
466 printvars(fp);
467 fputendian(fp);
468 fputformat(HOLOFMT, fp);
469 fputc('\n', fp);
470 putw(HOLOMAGIC, fp); /* put magic number */
471 fd = dup(fileno(fp));
472 fclose(fp); /* flush and close stdio stream */
473 lastloc = lseek(fd, (off_t)0, SEEK_END);
474 for (n = vdef(SECTION); n--; gp++) { /* initialize each section */
475 nextloc = 0L;
476 write(fd, (char *)&nextloc, sizeof(nextloc));
477 hdinit(fd, gp); /* writes beam index */
478 if (!n)
479 break;
480 nextloc = hdfilen(fd); /* write section pointer */
481 if (lseek(fd, lastloc, SEEK_SET) < 0)
482 error(SYSTEM,
483 "cannot seek on holodeck file in creatholo");
484 write(fd, (char *)&nextloc, sizeof(nextloc));
485 lseek(fd, (lastloc=nextloc), SEEK_SET);
486 }
487 }
488
489
490 static int
491 headline( /* process information header line */
492 char *s,
493 void *p
494 )
495 {
496 extern char FMTSTR[];
497 char *cp;
498 char fmt[MAXFMTLEN];
499
500 if (formatval(fmt, s)) {
501 if (strcmp(fmt, HOLOFMT)) {
502 sprintf(errmsg, "%s file \"%s\" has %s%s",
503 HOLOFMT, hdkfile, FMTSTR, fmt);
504 error(USER, errmsg);
505 }
506 return(0);
507 }
508 for (cp = s; *cp; cp++) /* take off any comments */
509 if (*cp == '#') {
510 *cp = '\0';
511 break;
512 }
513 setvariable(s, matchvar); /* don't flag errors */
514 return(0);
515 }
516
517
518 static void
519 loadholo(void) /* start loading a holodeck from fname */
520 {
521 FILE *fp;
522 int fd;
523 int n;
524 off_t nextloc;
525
526 if ((ncprocs > 0) & (force >= 0))
527 fp = fopen(hdkfile, "rb+");
528 else
529 fp = NULL;
530 if (fp == NULL) {
531 if ((fp = fopen(hdkfile, "rb")) == NULL) {
532 sprintf(errmsg, "cannot open \"%s\"", hdkfile);
533 error(SYSTEM, errmsg);
534 }
535 if (ncprocs > 0) {
536 sprintf(errmsg, "\"%s\" is read-only", hdkfile);
537 if (outdev == NULL)
538 error(USER, errmsg);
539 strcat(errmsg, "; new rays will be discarded");
540 error(WARNING, errmsg);
541 force = -1;
542 }
543 }
544 /* load variables from header */
545 getheader(fp, headline, NULL);
546 /* check magic number */
547 if (getw(fp) != HOLOMAGIC) {
548 sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
549 hdkfile);
550 error(USER, errmsg);
551 }
552 nextloc = ftell(fp); /* get stdio position */
553 fd = dup(fileno(fp));
554 fclose(fp); /* done with stdio */
555 for (n = 0; nextloc > 0L; n++) { /* initialize each section */
556 lseek(fd, nextloc, SEEK_SET);
557 read(fd, (char *)&nextloc, sizeof(nextloc));
558 hdinit(fd, NULL);
559 }
560 if (n != vdef(SECTION)) {
561 sprintf(errmsg, "number of sections does not match %s setting",
562 vnam(SECTION));
563 error(WARNING, errmsg);
564 }
565 }
566
567
568 void
569 done_packets( /* handle finished packets */
570 PACKET *pl
571 )
572 {
573 static int n2flush = 0;
574 PACKET *p;
575
576 while (pl != NULL) {
577 p = pl; pl = p->next; p->next = NULL;
578 if (p->nr > 0) { /* add to holodeck */
579 memcpy( (void *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
580 (void *)p->ra,
581 p->nr*sizeof(RAYVAL));
582 if (outdev != NULL) /* display it */
583 disp_packet((PACKHEAD *)p);
584 if (hdcachesize <= 0)
585 n2flush++;
586 nraysdone += p->nr;
587 npacksdone++;
588 p->nr = 0;
589 }
590 p->next = freepacks; /* push onto free list */
591 freepacks = p;
592 }
593 if (n2flush >= RTFLUSH) {
594 if (outdev != NULL)
595 hdsync(NULL, 1);
596 else
597 hdflush(NULL);
598 n2flush = 0;
599 }
600 }
601
602
603 static void
604 rootname( /* remove tail from end of fn */
605 char *rn,
606 char *fn
607 )
608 {
609 char *tp, *dp;
610
611 for (tp = NULL, dp = rn; (*rn = *fn++); rn++) {
612 if (*rn == '/')
613 dp = rn;
614 else if (*rn == '.')
615 tp = rn;
616 }
617 if (tp != NULL && tp > dp)
618 *tp = '\0';
619 }
620
621
622 static void
623 badvalue( /* report bad variable value and exit */
624 int vc
625 )
626 {
627 sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
628 error(USER, errmsg);
629 }
630
631
632 void
633 eputs(const char *s) /* put error message to stderr */
634 {
635 static int midline = 0;
636
637 if (!*s)
638 return;
639 if (!midline++) { /* prepend line with program name */
640 fputs(progname, stderr);
641 fputs(": ", stderr);
642 }
643 fputs(s, stderr);
644 if (s[strlen(s)-1] == '\n') {
645 fflush(stderr);
646 midline = 0;
647 }
648 }
649
650
651 void
652 quit(int ec) /* exit program gracefully */
653 {
654 int status = 0;
655
656 if (hdlist[0] != NULL) { /* close holodeck */
657 if (nprocs > 0)
658 status = done_rtrace(); /* calls hdsync() */
659 if ((ncprocs > 0) & (force >= 0) && vdef(REPORT)) {
660 off_t fsiz, fuse;
661 fsiz = hdfilen(hdlist[0]->fd);
662 fuse = hdfiluse(hdlist[0]->fd);
663 fprintf(stderr,
664 "%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
665 hdkfile, fsiz/(1024.*1024.),
666 100.*(fsiz-fuse)/fsiz);
667 }
668 }
669 if (orig_mode >= 0) /* reset holodeck access mode */
670 fchmod(hdlist[0]->fd, orig_mode);
671 if (outdev != NULL) /* close display */
672 disp_close();
673 exit(ec ? ec : status); /* exit */
674 }
