1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rholo.c,v 3.78 2016/03/21 19:06:08 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Radiance holodeck generation controller |
6 |
7 |
8 |
#include <stdio.h> |
9 |
#include <time.h> |
10 |
#include <signal.h> |
11 |
#include <sys/stat.h> |
12 |
#include <string.h> |
13 |
14 |
#include "platform.h" |
15 |
#include "rterror.h" |
16 |
#include "resolu.h" |
17 |
#include "rholo.h" |
18 |
#include "random.h" |
19 |
20 |
#ifndef FRAGWARN |
21 |
#define FRAGWARN 20 /* fragmentation for warning (%) */ |
22 |
#endif |
23 |
#ifndef MAXQTIME |
24 |
#define MAXQTIME 3 /* target maximum seconds in queue */ |
25 |
#endif |
26 |
/* manual cache flushing frequency */ |
27 |
#ifndef RTFLUSH |
28 |
#if MAXQTIME |
29 |
#define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */ |
30 |
#else |
31 |
#define RTFLUSH (50*totqlen) /* just guess */ |
32 |
#endif |
33 |
#endif |
34 |
/* the following must be consistent with rholo.h */ |
35 |
int NVARS = NRHVARS; /* total number of variables */ |
36 |
37 |
VARIABLE vv[] = RHVINIT; /* variable-value pairs */ |
38 |
39 |
char *progname; /* our program name */ |
40 |
char *hdkfile; /* holodeck file name */ |
41 |
char froot[256]; /* root file name */ |
42 |
43 |
int ncprocs = 0; /* desired number of compute processes */ |
44 |
45 |
char *outdev = NULL; /* output device name */ |
46 |
47 |
int readinp = 0; /* read commands from stdin */ |
48 |
49 |
int force = 0; /* allow overwrite of holodeck (-1 == read-only) */ |
50 |
51 |
time_t starttime; /* time we got started */ |
52 |
time_t endtime; /* time we should end by */ |
53 |
time_t reporttime; /* time for next report */ |
54 |
55 |
off_t maxdisk; /* maximum file space (bytes) */ |
56 |
57 |
int rtargc = 1; /* rtrace command */ |
58 |
char *rtargv[MAXRTARGC] = {"rtrace", NULL}; |
59 |
60 |
int orig_mode = -1; /* original file mode (-1 if unchanged) */ |
61 |
62 |
long nraysdone = 0L; /* number of rays done */ |
63 |
long npacksdone = 0L; /* number of packets done */ |
64 |
65 |
PACKET *freepacks; /* available packets */ |
66 |
int totqlen; /* maximum queue length (number of packets) */ |
67 |
68 |
char *sigerr[NSIG]; /* signal error messages */ |
69 |
70 |
extern int nowarn; /* turn warnings off? */ |
71 |
72 |
static void onsig(int signo); |
73 |
static void sigdie(int signo, char *msg); |
74 |
static int resfmode(int fd, int mod); |
75 |
static void initrholo(void); |
76 |
static int rholo(void); |
77 |
static void setdefaults(HDGRID *gp); |
78 |
static void creatholo(HDGRID *gp); |
79 |
static gethfunc headline; |
80 |
static void loadholo(void); |
81 |
static void rootname(char *rn, char *fn); |
82 |
static void badvalue(int vc); |
83 |
84 |
85 |
int |
86 |
main( |
87 |
int argc, |
88 |
char *argv[] |
89 |
90 |
91 |
int i; |
92 |
93 |
progname = argv[0]; /* get arguments */ |
94 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
95 |
switch (argv[i][1]) { |
96 |
case 'w': /* turn off warnings */ |
97 |
nowarn++; |
98 |
break; |
99 |
case 'f': /* force overwrite */ |
100 |
force = 1; |
101 |
break; |
102 |
case 'r': /* read-only mode */ |
103 |
force = -1; |
104 |
break; |
105 |
case 'i': /* read input from stdin */ |
106 |
readinp++; |
107 |
break; |
108 |
case 'n': /* compute processes */ |
109 |
if (i >= argc-2) |
110 |
goto userr; |
111 |
ncprocs = atoi(argv[++i]); |
112 |
break; |
113 |
case 'o': /* output display */ |
114 |
if (i >= argc-2) |
115 |
goto userr; |
116 |
outdev = argv[++i]; |
117 |
break; |
118 |
default: |
119 |
goto userr; |
120 |
121 |
/* get root file name */ |
122 |
if (i >= argc) |
123 |
goto userr; |
124 |
rootname(froot, hdkfile=argv[i++]); |
125 |
/* load variables? */ |
126 |
if (i < argc) |
127 |
if (argv[i][0] != '-' && argv[i][0] != '+') |
128 |
loadvars(argv[i]); /* load variables from file */ |
129 |
130 |
if (i >= argc || argv[i][0] == '+') |
131 |
loadholo(); /* load existing holodeck */ |
132 |
133 |
while (++i < argc) /* get command line settings */ |
134 |
if (setvariable(argv[i], matchvar) < 0) { |
135 |
sprintf(errmsg, "unknown variable: %s", argv[i]); |
136 |
error(USER, errmsg); |
137 |
138 |
/* check settings */ |
139 |
checkvalues(); |
140 |
/* load rad input file */ |
141 |
getradfile(); |
142 |
143 |
if (hdlist[0] == NULL) { /* create new holodeck */ |
144 |
HDGRID hdg[HDMAX]; |
145 |
/* set defaults */ |
146 |
setdefaults(hdg); |
147 |
/* check read-only */ |
148 |
if (force < 0) |
149 |
error(USER, "cannot create read-only holodeck"); |
150 |
/* holodeck exists? */ |
151 |
if (!force && access(hdkfile, R_OK|W_OK) == 0) |
152 |
error(USER, |
153 |
"holodeck file exists -- use -f to overwrite"); |
154 |
/* create holodeck */ |
155 |
creatholo(hdg); |
156 |
} else /* else just set defaults */ |
157 |
setdefaults(NULL); |
158 |
/* initialize */ |
159 |
initrholo(); |
160 |
/* main loop */ |
161 |
while (rholo()) |
162 |
163 |
/* done */ |
164 |
quit(0); |
165 |
userr: |
166 |
fprintf(stderr, |
167 |
"Usage: %s [-n nprocs][-o disp][-i][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", |
168 |
progname); |
169 |
quit(1); |
170 |
return 1; /* pro forma return */ |
171 |
172 |
173 |
174 |
static void |
175 |
onsig( /* fatal signal */ |
176 |
int signo |
177 |
178 |
179 |
static int gotsig = 0; |
180 |
181 |
if (gotsig > 1) /* we're going as fast as we can! */ |
182 |
return; |
183 |
if (gotsig++) { /* two signals and we split */ |
184 |
hdsync(NULL, 0); /* don't leave w/o saying goodbye */ |
185 |
_exit(signo); |
186 |
187 |
alarm(300); /* allow 10 minutes to clean up */ |
188 |
eputs("signal - "); |
189 |
eputs(sigerr[signo]); |
190 |
eputs("\n"); |
191 |
quit(3); |
192 |
193 |
194 |
195 |
static void |
196 |
sigdie( /* set fatal signal */ |
197 |
int signo, |
198 |
char *msg |
199 |
200 |
201 |
if (signal(signo, onsig) == SIG_IGN) |
202 |
signal(signo, SIG_IGN); |
203 |
sigerr[signo] = msg; |
204 |
205 |
206 |
207 |
static int |
208 |
resfmode( /* restrict open file access mode */ |
209 |
int fd, |
210 |
int mod |
211 |
212 |
213 |
struct stat stbuf; |
214 |
/* get original mode */ |
215 |
if (fstat(fd, &stbuf) < 0) |
216 |
error(SYSTEM, "cannot stat open holodeck file"); |
217 |
mod &= stbuf.st_mode; /* always more restrictive */ |
218 |
if (mod == (stbuf.st_mode & 0777)) |
219 |
return(-1); /* already set */ |
220 |
/* else change it */ |
221 |
if (fchmod(fd, mod) < 0) { |
222 |
error(WARNING, "cannot change holodeck file access mode"); |
223 |
return(-1); |
224 |
225 |
return(stbuf.st_mode); /* return original mode */ |
226 |
227 |
228 |
229 |
static void |
230 |
initrholo(void) /* get our holodeck running */ |
231 |
232 |
extern int global_packet(); |
233 |
register int i; |
234 |
/* close holodeck on exec() */ |
235 |
fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC); |
236 |
237 |
if (outdev != NULL) /* open output device */ |
238 |
disp_open(outdev); |
239 |
else if (ncprocs > 0) /* else use global ray feed */ |
240 |
init_global(); |
241 |
/* record disk space limit */ |
242 |
if (!vdef(DISKSPACE)) |
243 |
maxdisk = ((off_t)1<<(sizeof(off_t)*8-2)) - 1024; |
244 |
else |
245 |
maxdisk = 1024.*1024.*vflt(DISKSPACE); |
246 |
/* set up memory cache */ |
247 |
if (outdev == NULL) |
248 |
hdcachesize = 0; /* manual flushing */ |
249 |
else if (vdef(CACHE)) |
250 |
hdcachesize = 1024.*1024.*vflt(CACHE); |
251 |
/* open report file */ |
252 |
if (vdef(REPORT)) { |
253 |
register char *s = sskip2(vval(REPORT), 1); |
254 |
if (*s && freopen(s, "a", stderr) == NULL) |
255 |
quit(2); |
256 |
257 |
/* mark the starting time */ |
258 |
starttime = time(NULL); |
259 |
/* compute end time */ |
260 |
if (!vdef(TIME) || vflt(TIME) <= FTINY) |
261 |
endtime = 0; |
262 |
else |
263 |
endtime = starttime + vflt(TIME)*3600. + .5; |
264 |
/* start rtrace */ |
265 |
if (ncprocs > 0) { |
266 |
totqlen = i = start_rtrace(); |
267 |
if (i < 1) |
268 |
error(USER, "cannot start rtrace process(es)"); |
269 |
if (vdef(REPORT)) { /* make first report */ |
270 |
printargs(rtargc, rtargv, stderr); |
271 |
report(0); |
272 |
273 |
/* allocate packets */ |
274 |
freepacks = (PACKET *)bmalloc(i*sizeof(PACKET)); |
275 |
if (freepacks == NULL) |
276 |
goto memerr; |
277 |
freepacks[--i].nr = 0; |
278 |
freepacks[i].next = NULL; |
279 |
if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) { |
280 |
freepacks[i].offset = (float *)bmalloc( |
281 |
RPACKSIZ*sizeof(float)*(i+1) ); |
282 |
if (freepacks[i].offset == NULL) |
283 |
goto memerr; |
284 |
} else |
285 |
freepacks[i].offset = NULL; |
286 |
while (i--) { |
287 |
freepacks[i].nr = 0; |
288 |
freepacks[i].offset = freepacks[i+1].offset == NULL ? |
289 |
NULL : freepacks[i+1].offset+RPACKSIZ ; |
290 |
freepacks[i].next = &freepacks[i+1]; |
291 |
292 |
293 |
/* set up signal handling */ |
294 |
sigdie(SIGINT, "Interrupt"); |
295 |
sigdie(SIGTERM, "Terminate"); |
296 |
#ifdef SIGHUP |
297 |
sigdie(SIGHUP, "Hangup"); |
298 |
#endif |
299 |
#ifdef SIGPIPE |
300 |
sigdie(SIGPIPE, "Broken pipe"); |
301 |
#endif |
302 |
#ifdef SIGALRM |
303 |
sigdie(SIGALRM, "Alarm clock"); |
304 |
#endif |
305 |
#ifdef SIGXCPU |
306 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
307 |
#endif |
308 |
#ifdef SIGXFSZ |
309 |
sigdie(SIGXFSZ, "File size exceeded"); |
310 |
#endif |
311 |
/* protect holodeck file */ |
312 |
orig_mode = resfmode(hdlist[0]->fd, (ncprocs>0) & (force>=0) ? 0 : 0444); |
313 |
return; |
314 |
memerr: |
315 |
error(SYSTEM, "out of memory in initrholo"); |
316 |
317 |
318 |
319 |
static int |
320 |
rholo(void) /* holodeck main loop */ |
321 |
322 |
static off_t nextfragwarn = 100L<<20; |
323 |
static int idle = 0; |
324 |
PACKET *pl = NULL, *plend; |
325 |
off_t fsiz; |
326 |
int pksiz; |
327 |
register PACKET *p; |
328 |
time_t t; |
329 |
/* check display */ |
330 |
if (nprocs <= 0) |
331 |
idle = 1; |
332 |
if (outdev != NULL) { |
333 |
if (!disp_check(idle)) |
334 |
return(0); /* quit request */ |
335 |
if (nprocs <= 0) |
336 |
return(1); |
337 |
} else if (idle) |
338 |
return(0); /* all done */ |
339 |
fsiz = hdfilen(hdlist[0]->fd); /* check file size */ |
340 |
if (maxdisk > 0 && fsiz >= maxdisk) { |
341 |
error(USER, "file limit exceeded"); |
342 |
done_rtrace(); |
343 |
return(1); /* comes back */ |
344 |
345 |
#if FRAGWARN |
346 |
if (fsiz >= nextfragwarn) { |
347 |
double pctfrag = 100.*(fsiz-hdfiluse(hdlist[0]->fd))/fsiz; |
348 |
if (pctfrag >= (double)FRAGWARN) { |
349 |
sprintf(errmsg, "holodeck file fragmentation is %.0f%%", |
350 |
pctfrag); |
351 |
error(WARNING, errmsg); |
352 |
nextfragwarn = fsiz + (fsiz>>2); |
353 |
} else |
354 |
nextfragwarn = fsiz + (10L<<20); |
355 |
356 |
#endif |
357 |
t = time(NULL); /* check time */ |
358 |
if (endtime > 0 && t >= endtime) { |
359 |
error(USER, "time limit exceeded"); |
360 |
done_rtrace(); |
361 |
362 |
363 |
if (reporttime > 0 && t >= reporttime) |
364 |
report(t); |
365 |
/* figure out good packet size */ |
366 |
pksiz = RPACKSIZ; |
367 |
#if MAXQTIME |
368 |
if (!chunkycmp) { |
369 |
pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L)); |
370 |
if (pksiz < 1) pksiz = 1; |
371 |
else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ; |
372 |
373 |
#endif |
374 |
idle = 0; /* get packets to process */ |
375 |
while (freepacks != NULL) { |
376 |
p = freepacks; freepacks = p->next; p->next = NULL; |
377 |
if (!next_packet(p, pksiz)) { |
378 |
p->next = freepacks; freepacks = p; |
379 |
idle = 1; |
380 |
break; |
381 |
382 |
if (pl == NULL) pl = p; |
383 |
else plend->next = p; |
384 |
plend = p; |
385 |
386 |
/* process packets */ |
387 |
done_packets(do_packets(pl)); |
388 |
return(1); /* and continue */ |
389 |
390 |
391 |
392 |
static void |
393 |
setdefaults( /* set default values */ |
394 |
register HDGRID *gp |
395 |
396 |
397 |
extern char *atos(); |
398 |
register int i; |
399 |
int n; |
400 |
double len[3], d; |
401 |
402 |
if (!vdef(SECTION)) { |
403 |
sprintf(errmsg, "%s must be defined", vnam(SECTION)); |
404 |
405 |
406 |
if (!vdef(OCTREE)) { |
407 |
if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL) |
408 |
error(SYSTEM, "out of memory"); |
409 |
sprintf(vval(OCTREE), "%s.oct", froot); |
410 |
vdef(OCTREE)++; |
411 |
412 |
if (!vdef(VDIST)) { |
413 |
vval(VDIST) = "F"; |
414 |
vdef(VDIST)++; |
415 |
416 |
/* append rendering options */ |
417 |
if (vdef(RENDER)) |
418 |
rtargc += wordstring(rtargv+rtargc, MAXRTARGC-rtargc, vval(RENDER)); |
419 |
420 |
if (gp == NULL) /* already initialized? */ |
421 |
return; |
422 |
/* set grid parameters */ |
423 |
for (n = 0; n < vdef(SECTION); n++, gp++) { |
424 |
gp->grid[0] = gp->grid[1] = gp->grid[2] = 0; |
425 |
if (sscanf(nvalue(SECTION, n), |
426 |
"%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd", |
427 |
&gp->orig[0], &gp->orig[1], &gp->orig[2], |
428 |
&gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2], |
429 |
&gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2], |
430 |
&gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2], |
431 |
&gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12) |
432 |
badvalue(SECTION); |
433 |
for (i = 0; i < 3; i++) |
434 |
len[i] = VLEN(gp->xv[i]); |
435 |
if (!vdef(GRID)) { |
436 |
d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] + |
437 |
len[2]*len[2] + 4*len[1]*len[2]) |
438 |
+ len[1]*len[1]*len[2]*(len[2] + 4*len[0]) |
439 |
+ 4*len[0]*len[1]*len[2]*len[2] ); |
440 |
d = sqrt(sqrt(d)); |
441 |
} else if ((d = vflt(GRID)) <= FTINY) |
442 |
badvalue(GRID); |
443 |
444 |
if (gp->grid[i] <= 0) |
445 |
gp->grid[i] = len[i]/d + (1.-FTINY); |
446 |
447 |
448 |
449 |
450 |
static void |
451 |
creatholo( /* create a holodeck output file */ |
452 |
HDGRID *gp |
453 |
454 |
455 |
extern char VersionID[]; |
456 |
off_t lastloc, nextloc; |
457 |
int n; |
458 |
int fd; |
459 |
FILE *fp; |
460 |
/* open & truncate file */ |
461 |
if ((fp = fopen(hdkfile, "w+")) == NULL) { |
462 |
sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile); |
463 |
error(SYSTEM, errmsg); |
464 |
465 |
/* write information header */ |
466 |
newheader("RADIANCE", fp); |
467 |
fprintf(fp, "SOFTWARE= %s\n", VersionID); |
468 |
printvars(fp); |
469 |
fputformat(HOLOFMT, fp); |
470 |
fputc('\n', fp); |
471 |
putw(HOLOMAGIC, fp); /* put magic number */ |
472 |
fd = dup(fileno(fp)); |
473 |
fclose(fp); /* flush and close stdio stream */ |
474 |
lastloc = lseek(fd, (off_t)0, SEEK_END); |
475 |
for (n = vdef(SECTION); n--; gp++) { /* initialize each section */ |
476 |
nextloc = 0L; |
477 |
write(fd, (char *)&nextloc, sizeof(nextloc)); |
478 |
hdinit(fd, gp); /* writes beam index */ |
479 |
if (!n) |
480 |
break; |
481 |
nextloc = hdfilen(fd); /* write section pointer */ |
482 |
if (lseek(fd, lastloc, SEEK_SET) < 0) |
483 |
error(SYSTEM, |
484 |
"cannot seek on holodeck file in creatholo"); |
485 |
486 |
lseek(fd, (lastloc=nextloc), SEEK_SET); |
487 |
488 |
489 |
490 |
491 |
static int |
492 |
headline( /* process information header line */ |
493 |
char *s, |
494 |
void *p |
495 |
496 |
497 |
extern char FMTSTR[]; |
498 |
register char *cp; |
499 |
char fmt[MAXFMTLEN]; |
500 |
501 |
if (formatval(fmt, s)) { |
502 |
if (strcmp(fmt, HOLOFMT)) { |
503 |
sprintf(errmsg, "%s file \"%s\" has %s%s", |
504 |
HOLOFMT, hdkfile, FMTSTR, fmt); |
505 |
506 |
507 |
return(0); |
508 |
509 |
for (cp = s; *cp; cp++) /* take off any comments */ |
510 |
if (*cp == '#') { |
511 |
*cp = '\0'; |
512 |
break; |
513 |
514 |
setvariable(s, matchvar); /* don't flag errors */ |
515 |
return(0); |
516 |
517 |
518 |
519 |
static void |
520 |
loadholo(void) /* start loading a holodeck from fname */ |
521 |
522 |
FILE *fp; |
523 |
int fd; |
524 |
int n; |
525 |
off_t nextloc; |
526 |
527 |
if ((ncprocs > 0) & (force >= 0)) |
528 |
fp = fopen(hdkfile, "r+"); |
529 |
else |
530 |
fp = NULL; |
531 |
if (fp == NULL) { |
532 |
if ((fp = fopen(hdkfile, "r")) == NULL) { |
533 |
sprintf(errmsg, "cannot open \"%s\"", hdkfile); |
534 |
535 |
536 |
537 |
sprintf(errmsg, "\"%s\" is read-only", hdkfile); |
538 |
539 |
540 |
strcat(errmsg, "; new rays will be discarded"); |
541 |
542 |
force = -1; |
543 |
544 |
545 |
/* load variables from header */ |
546 |
getheader(fp, headline, NULL); |
547 |
/* check magic number */ |
548 |
if (getw(fp) != HOLOMAGIC) { |
549 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"", |
550 |
hdkfile); |
551 |
552 |
553 |
nextloc = ftell(fp); /* get stdio position */ |
554 |
555 |
fclose(fp); /* done with stdio */ |
556 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */ |
557 |
lseek(fd, nextloc, SEEK_SET); |
558 |
read(fd, (char *)&nextloc, sizeof(nextloc)); |
559 |
hdinit(fd, NULL); |
560 |
561 |
if (n != vdef(SECTION)) { |
562 |
sprintf(errmsg, "number of sections does not match %s setting", |
563 |
vnam(SECTION)); |
564 |
565 |
566 |
567 |
568 |
569 |
extern void |
570 |
done_packets( /* handle finished packets */ |
571 |
PACKET *pl |
572 |
573 |
574 |
static int n2flush = 0; |
575 |
576 |
577 |
while (pl != NULL) { |
578 |
p = pl; pl = p->next; p->next = NULL; |
579 |
if (p->nr > 0) { /* add to holodeck */ |
580 |
memcpy( (void *)hdnewrays(hdlist[p->hd],p->bi,p->nr), |
581 |
(void *)p->ra, |
582 |
p->nr*sizeof(RAYVAL)); |
583 |
if (outdev != NULL) /* display it */ |
584 |
disp_packet((PACKHEAD *)p); |
585 |
if (hdcachesize <= 0) |
586 |
n2flush++; |
587 |
nraysdone += p->nr; |
588 |
npacksdone++; |
589 |
p->nr = 0; |
590 |
591 |
p->next = freepacks; /* push onto free list */ |
592 |
freepacks = p; |
593 |
594 |
if (n2flush >= RTFLUSH) { |
595 |
if (outdev != NULL) |
596 |
hdsync(NULL, 1); |
597 |
else |
598 |
hdflush(NULL); |
599 |
n2flush = 0; |
600 |
601 |
602 |
603 |
604 |
static void |
605 |
rootname( /* remove tail from end of fn */ |
606 |
register char *rn, |
607 |
register char *fn |
608 |
609 |
610 |
char *tp, *dp; |
611 |
612 |
for (tp = NULL, dp = rn; (*rn = *fn++); rn++) { |
613 |
if (*rn == '/') |
614 |
dp = rn; |
615 |
else if (*rn == '.') |
616 |
tp = rn; |
617 |
618 |
if (tp != NULL && tp > dp) |
619 |
*tp = '\0'; |
620 |
621 |
622 |
623 |
static void |
624 |
badvalue( /* report bad variable value and exit */ |
625 |
int vc |
626 |
627 |
628 |
sprintf(errmsg, "bad value for variable '%s'", vnam(vc)); |
629 |
630 |
631 |
632 |
633 |
void |
634 |
eputs(s) /* put error message to stderr */ |
635 |
register char *s; |
636 |
637 |
static int midline = 0; |
638 |
639 |
if (!*s) |
640 |
return; |
641 |
if (!midline++) { /* prepend line with program name */ |
642 |
fputs(progname, stderr); |
643 |
fputs(": ", stderr); |
644 |
645 |
fputs(s, stderr); |
646 |
if (s[strlen(s)-1] == '\n') { |
647 |
fflush(stderr); |
648 |
midline = 0; |
649 |
650 |
651 |
652 |
653 |
void |
654 |
quit(ec) /* exit program gracefully */ |
655 |
int ec; |
656 |
657 |
int status = 0; |
658 |
659 |
if (hdlist[0] != NULL) { /* close holodeck */ |
660 |
if (nprocs > 0) |
661 |
status = done_rtrace(); /* calls hdsync() */ |
662 |
if ((ncprocs > 0) & (force >= 0) && vdef(REPORT)) { |
663 |
off_t fsiz, fuse; |
664 |
fsiz = hdfilen(hdlist[0]->fd); |
665 |
fuse = hdfiluse(hdlist[0]->fd); |
666 |
fprintf(stderr, |
667 |
"%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n", |
668 |
hdkfile, fsiz/(1024.*1024.), |
669 |
100.*(fsiz-fuse)/fsiz); |
670 |
671 |
672 |
if (orig_mode >= 0) /* reset holodeck access mode */ |
673 |
fchmod(hdlist[0]->fd, orig_mode); |
674 |
if (outdev != NULL) /* close display */ |
675 |
disp_close(); |
676 |
exit(ec ? ec : status); /* exit */ |
677 |
