| 1 |
/* Copyright (c) 1999 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Radiance holodeck generation controller
| 9 |
| 10 |
| 11 |
#include "rholo.h"
| 12 |
#include "random.h"
| 13 |
#include <signal.h>
| 14 |
#include <sys/stat.h>
| 15 |
| 16 |
#ifndef FRAGWARN
| 17 |
#define FRAGWARN 20 /* fragmentation for warning (%) */
| 18 |
#endif
| 19 |
#ifndef MAXQTIME
| 20 |
#define MAXQTIME 5 /* target maximum seconds in queue */
| 21 |
#endif
| 22 |
/* manual cache flushing frequency */
| 23 |
#ifndef RTFLUSH
| 24 |
#if MAXQTIME
| 25 |
#define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */
| 26 |
#else
| 27 |
#define RTFLUSH (50*totqlen) /* just guess */
| 28 |
#endif
| 29 |
#endif
| 30 |
/* the following must be consistent with rholo.h */
| 31 |
int NVARS = NRHVARS; /* total number of variables */
| 32 |
| 33 |
VARIABLE vv[] = RHVINIT; /* variable-value pairs */
| 34 |
| 35 |
char *progname; /* our program name */
| 36 |
char *hdkfile; /* holodeck file name */
| 37 |
char froot[256]; /* root file name */
| 38 |
| 39 |
int ncprocs = 0; /* desired number of compute processes */
| 40 |
| 41 |
char *outdev = NULL; /* output device name */
| 42 |
| 43 |
int readinp = 0; /* read commands from stdin */
| 44 |
| 45 |
int force = 0; /* allow overwrite of holodeck */
| 46 |
| 47 |
time_t starttime; /* time we got started */
| 48 |
time_t endtime; /* time we should end by */
| 49 |
time_t reporttime; /* time for next report */
| 50 |
| 51 |
long maxdisk; /* maximum file space (bytes) */
| 52 |
| 53 |
int rtargc = 1; /* rtrace command */
| 54 |
char *rtargv[128] = {"rtrace", NULL};
| 55 |
| 56 |
int orig_mode = -1; /* original file mode (-1 if unchanged) */
| 57 |
| 58 |
long nraysdone = 0L; /* number of rays done */
| 59 |
long npacksdone = 0L; /* number of packets done */
| 60 |
| 61 |
PACKET *freepacks; /* available packets */
| 62 |
int totqlen; /* maximum queue length (number of packets) */
| 63 |
| 64 |
char *sigerr[NSIG]; /* signal error messages */
| 65 |
| 66 |
extern int nowarn; /* turn warnings off? */
| 67 |
| 68 |
extern time_t time();
| 69 |
| 70 |
| 71 |
main(argc, argv)
| 72 |
int argc;
| 73 |
char *argv[];
| 74 |
| 75 |
int i;
| 76 |
| 77 |
initurand(16384); /* initialize urand */
| 78 |
progname = argv[0]; /* get arguments */
| 79 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 80 |
switch (argv[i][1]) {
| 81 |
case 'w': /* turn off warnings */
| 82 |
nowarn++;
| 83 |
break;
| 84 |
case 'f': /* force overwrite */
| 85 |
force++;
| 86 |
break;
| 87 |
case 'i': /* read input from stdin */
| 88 |
readinp++;
| 89 |
break;
| 90 |
case 'n': /* compute processes */
| 91 |
if (i >= argc-2)
| 92 |
goto userr;
| 93 |
ncprocs = atoi(argv[++i]);
| 94 |
break;
| 95 |
case 'o': /* output display */
| 96 |
if (i >= argc-2)
| 97 |
goto userr;
| 98 |
outdev = argv[++i];
| 99 |
break;
| 100 |
default:
| 101 |
goto userr;
| 102 |
| 103 |
/* get root file name */
| 104 |
if (i >= argc)
| 105 |
goto userr;
| 106 |
rootname(froot, hdkfile=argv[i++]);
| 107 |
/* load variables? */
| 108 |
if (i < argc)
| 109 |
if (argv[i][0] != '-' && argv[i][0] != '+')
| 110 |
loadvars(argv[i]); /* load variables from file */
| 111 |
| 112 |
if (i >= argc || argv[i][0] == '+')
| 113 |
loadholo(); /* load existing holodeck */
| 114 |
| 115 |
while (++i < argc) /* get command line settings */
| 116 |
if (setvariable(argv[i], matchvar) < 0) {
| 117 |
sprintf(errmsg, "unknown variable: %s", argv[i]);
| 118 |
error(USER, errmsg);
| 119 |
| 120 |
/* check settings */
| 121 |
checkvalues();
| 122 |
/* load rad input file */
| 123 |
getradfile();
| 124 |
| 125 |
if (hdlist[0] == NULL) { /* create new holodeck */
| 126 |
HDGRID hdg[HDMAX];
| 127 |
/* set defaults */
| 128 |
setdefaults(hdg);
| 129 |
/* holodeck exists? */
| 130 |
if (!force && access(hdkfile, R_OK|W_OK) == 0)
| 131 |
error(USER,
| 132 |
"holodeck file exists -- use -f to overwrite");
| 133 |
/* create holodeck */
| 134 |
creatholo(hdg);
| 135 |
} else /* else just set defaults */
| 136 |
setdefaults(NULL);
| 137 |
/* initialize */
| 138 |
initrholo();
| 139 |
/* main loop */
| 140 |
while (rholo())
| 141 |
| 142 |
/* done */
| 143 |
quit(0);
| 144 |
userr:
| 145 |
fprintf(stderr,
| 146 |
"Usage: %s [-n nprocs][-o disp][-w][-f] output.hdk [control.hif|+|- [VAR=val ..]]\n",
| 147 |
progname);
| 148 |
quit(1);
| 149 |
| 150 |
| 151 |
| 152 |
onsig(signo) /* fatal signal */
| 153 |
int signo;
| 154 |
| 155 |
static int gotsig = 0;
| 156 |
| 157 |
if (gotsig > 1) /* we're going as fast as we can! */
| 158 |
return;
| 159 |
if (gotsig++) { /* two signals and we split */
| 160 |
hdsync(NULL, 0); /* don't leave w/o saying goodbye */
| 161 |
_exit(signo);
| 162 |
| 163 |
alarm(300); /* allow 5 minutes to clean up */
| 164 |
eputs("signal - ");
| 165 |
eputs(sigerr[signo]);
| 166 |
eputs("\n");
| 167 |
quit(3);
| 168 |
| 169 |
| 170 |
| 171 |
sigdie(signo, msg) /* set fatal signal */
| 172 |
int signo;
| 173 |
char *msg;
| 174 |
| 175 |
if (signal(signo, onsig) == SIG_IGN)
| 176 |
signal(signo, SIG_IGN);
| 177 |
sigerr[signo] = msg;
| 178 |
| 179 |
| 180 |
| 181 |
int
| 182 |
resfmode(fd, mod) /* restrict open file access mode */
| 183 |
int fd, mod;
| 184 |
| 185 |
struct stat stbuf;
| 186 |
/* get original mode */
| 187 |
if (fstat(fd, &stbuf) < 0)
| 188 |
error(SYSTEM, "cannot stat open holodeck file");
| 189 |
mod &= stbuf.st_mode; /* always more restrictive */
| 190 |
if (mod == (stbuf.st_mode & 0777))
| 191 |
return(-1); /* already set */
| 192 |
/* else change it */
| 193 |
if (fchmod(fd, mod) < 0) {
| 194 |
error(WARNING, "cannot change holodeck file access mode");
| 195 |
return(-1);
| 196 |
| 197 |
return(stbuf.st_mode); /* return original mode */
| 198 |
| 199 |
| 200 |
| 201 |
initrholo() /* get our holodeck running */
| 202 |
| 203 |
extern int global_packet();
| 204 |
register int i;
| 205 |
/* close holodeck on exec() */
| 206 |
fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC);
| 207 |
| 208 |
if (outdev != NULL) /* open output device */
| 209 |
disp_open(outdev);
| 210 |
else if (ncprocs > 0) /* else use global ray feed */
| 211 |
init_global();
| 212 |
/* record disk space limit */
| 213 |
if (!vdef(DISKSPACE))
| 214 |
maxdisk = 0;
| 215 |
else
| 216 |
maxdisk = 1024.*1024.*vflt(DISKSPACE);
| 217 |
/* set up memory cache */
| 218 |
if (outdev == NULL)
| 219 |
hdcachesize = 0; /* manual flushing */
| 220 |
else if (vdef(CACHE))
| 221 |
hdcachesize = 1024.*1024.*vflt(CACHE);
| 222 |
/* open report file */
| 223 |
if (vdef(REPORT)) {
| 224 |
register char *s = sskip2(vval(REPORT), 1);
| 225 |
if (*s && freopen(s, "a", stderr) == NULL)
| 226 |
quit(2);
| 227 |
| 228 |
/* mark the starting time */
| 229 |
starttime = time(NULL);
| 230 |
/* compute end time */
| 231 |
if (!vdef(TIME) || vflt(TIME) <= FTINY)
| 232 |
endtime = 0;
| 233 |
else
| 234 |
endtime = starttime + vflt(TIME)*3600. + .5;
| 235 |
/* start rtrace */
| 236 |
if (ncprocs > 0) {
| 237 |
totqlen = i = start_rtrace();
| 238 |
if (i < 1)
| 239 |
error(USER, "cannot start rtrace process(es)");
| 240 |
if (vdef(REPORT)) { /* make first report */
| 241 |
printargs(rtargc, rtargv, stderr);
| 242 |
report(0);
| 243 |
| 244 |
/* allocate packets */
| 245 |
freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
| 246 |
if (freepacks == NULL)
| 247 |
goto memerr;
| 248 |
freepacks[--i].nr = 0;
| 249 |
freepacks[i].next = NULL;
| 250 |
if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) {
| 251 |
freepacks[i].offset = (float *)bmalloc(
| 252 |
RPACKSIZ*sizeof(float)*(i+1) );
| 253 |
if (freepacks[i].offset == NULL)
| 254 |
goto memerr;
| 255 |
} else
| 256 |
freepacks[i].offset = NULL;
| 257 |
while (i--) {
| 258 |
freepacks[i].nr = 0;
| 259 |
freepacks[i].offset = freepacks[i+1].offset == NULL ?
| 260 |
NULL : freepacks[i+1].offset+RPACKSIZ ;
| 261 |
freepacks[i].next = &freepacks[i+1];
| 262 |
| 263 |
| 264 |
/* set up signal handling */
| 265 |
sigdie(SIGINT, "Interrupt");
| 266 |
sigdie(SIGHUP, "Hangup");
| 267 |
sigdie(SIGTERM, "Terminate");
| 268 |
sigdie(SIGPIPE, "Broken pipe");
| 269 |
sigdie(SIGALRM, "Alarm clock");
| 270 |
#ifdef SIGXCPU
| 271 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 272 |
sigdie(SIGXFSZ, "File size exceeded");
| 273 |
#endif
| 274 |
/* protect holodeck file */
| 275 |
orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444);
| 276 |
return;
| 277 |
memerr:
| 278 |
error(SYSTEM, "out of memory in initrholo");
| 279 |
| 280 |
| 281 |
| 282 |
rholo() /* holodeck main loop */
| 283 |
| 284 |
static long nextfragwarn = 100*(1L<<20);
| 285 |
static int idle = 0;
| 286 |
PACKET *pl = NULL, *plend;
| 287 |
long fsiz;
| 288 |
int pksiz;
| 289 |
register PACKET *p;
| 290 |
time_t t;
| 291 |
/* check display */
| 292 |
if (nprocs <= 0)
| 293 |
idle = 1;
| 294 |
if (outdev != NULL) {
| 295 |
if (!disp_check(idle))
| 296 |
return(0); /* quit request */
| 297 |
if (nprocs <= 0)
| 298 |
return(1);
| 299 |
} else if (idle)
| 300 |
return(0); /* all done */
| 301 |
fsiz = hdfilen(hdlist[0]->fd); /* check file size */
| 302 |
if (maxdisk > 0 && fsiz >= maxdisk) {
| 303 |
error(WARNING, "file limit exceeded");
| 304 |
done_rtrace();
| 305 |
return(1); /* comes back */
| 306 |
| 307 |
#if FRAGWARN
| 308 |
if (fsiz >= nextfragwarn &&
| 309 |
(fsiz-hdfiluse(hdlist[0]->fd,0))/(fsiz/100) > FRAGWARN) {
| 310 |
sprintf(errmsg, "holodeck file fragmentation is %.0f%%",
| 311 |
100.*(fsiz-hdfiluse(hdlist[0]->fd,1))/fsiz);
| 312 |
error(WARNING, errmsg);
| 313 |
nextfragwarn = fsiz + (fsiz>>2); /* decent interval */
| 314 |
| 315 |
#endif
| 316 |
t = time(NULL); /* check time */
| 317 |
if (endtime > 0 && t >= endtime) {
| 318 |
error(WARNING, "time limit exceeded");
| 319 |
done_rtrace();
| 320 |
| 321 |
| 322 |
if (reporttime > 0 && t >= reporttime)
| 323 |
report(t);
| 324 |
/* figure out good packet size */
| 325 |
pksiz = RPACKSIZ;
| 326 |
#if MAXQTIME
| 327 |
if (!chunkycmp) {
| 328 |
pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L));
| 329 |
if (pksiz < 1) pksiz = 1;
| 330 |
else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ;
| 331 |
| 332 |
#endif
| 333 |
idle = 0; /* get packets to process */
| 334 |
while (freepacks != NULL) {
| 335 |
p = freepacks; freepacks = p->next; p->next = NULL;
| 336 |
if (!next_packet(p, pksiz)) {
| 337 |
p->next = freepacks; freepacks = p;
| 338 |
idle = 1;
| 339 |
break;
| 340 |
| 341 |
if (pl == NULL) pl = p;
| 342 |
else plend->next = p;
| 343 |
plend = p;
| 344 |
| 345 |
/* process packets */
| 346 |
done_packets(do_packets(pl));
| 347 |
return(1); /* and continue */
| 348 |
| 349 |
| 350 |
| 351 |
setdefaults(gp) /* set default values */
| 352 |
register HDGRID *gp;
| 353 |
| 354 |
extern char *atos();
| 355 |
register int i;
| 356 |
int n;
| 357 |
double len[3], d;
| 358 |
char buf[64];
| 359 |
| 360 |
if (!vdef(SECTION)) {
| 361 |
sprintf(errmsg, "%s must be defined", vnam(SECTION));
| 362 |
| 363 |
| 364 |
if (!vdef(OCTREE)) {
| 365 |
if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
| 366 |
error(SYSTEM, "out of memory");
| 367 |
sprintf(vval(OCTREE), "%s.oct", froot);
| 368 |
vdef(OCTREE)++;
| 369 |
| 370 |
if (!vdef(VDIST)) {
| 371 |
vval(VDIST) = "F";
| 372 |
vdef(VDIST)++;
| 373 |
| 374 |
/* append rendering options */
| 375 |
if (vdef(RENDER))
| 376 |
rtargc += wordstring(rtargv+rtargc, vval(RENDER));
| 377 |
| 378 |
if (gp == NULL) /* already initialized? */
| 379 |
return;
| 380 |
/* set grid parameters */
| 381 |
for (n = 0; n < vdef(SECTION); n++, gp++) {
| 382 |
gp->grid[0] = gp->grid[1] = gp->grid[2] = 0;
| 383 |
if (sscanf(nvalue(SECTION, n),
| 384 |
"%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd",
| 385 |
&gp->orig[0], &gp->orig[1], &gp->orig[2],
| 386 |
&gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
| 387 |
&gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
| 388 |
&gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2],
| 389 |
&gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12)
| 390 |
badvalue(SECTION);
| 391 |
for (i = 0; i < 3; i++)
| 392 |
len[i] = VLEN(gp->xv[i]);
| 393 |
if (!vdef(GRID)) {
| 394 |
d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] +
| 395 |
len[2]*len[2] + 4*len[1]*len[2])
| 396 |
+ len[1]*len[1]*len[2]*(len[2] + 4*len[0])
| 397 |
+ 4*len[0]*len[1]*len[2]*len[2] );
| 398 |
d = sqrt(sqrt(d));
| 399 |
} else if ((d = vflt(GRID)) <= FTINY)
| 400 |
badvalue(GRID);
| 401 |
| 402 |
if (gp->grid[i] <= 0)
| 403 |
gp->grid[i] = len[i]/d + (1.-FTINY);
| 404 |
| 405 |
| 406 |
| 407 |
| 408 |
creatholo(gp) /* create a holodeck output file */
| 409 |
HDGRID *gp;
| 410 |
| 411 |
extern char VersionID[];
| 412 |
int4 lastloc, nextloc;
| 413 |
int n;
| 414 |
int fd;
| 415 |
FILE *fp;
| 416 |
/* open & truncate file */
| 417 |
if ((fp = fopen(hdkfile, "w+")) == NULL) {
| 418 |
sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
| 419 |
error(SYSTEM, errmsg);
| 420 |
| 421 |
/* write information header */
| 422 |
newheader("RADIANCE", fp);
| 423 |
fprintf(fp, "SOFTWARE= %s\n", VersionID);
| 424 |
printvars(fp);
| 425 |
fputformat(HOLOFMT, fp);
| 426 |
fputc('\n', fp);
| 427 |
putw(HOLOMAGIC, fp); /* put magic number */
| 428 |
fd = dup(fileno(fp));
| 429 |
fclose(fp); /* flush and close stdio stream */
| 430 |
lastloc = lseek(fd, 0L, 2);
| 431 |
for (n = vdef(SECTION); n--; gp++) { /* initialize each section */
| 432 |
nextloc = 0L;
| 433 |
write(fd, (char *)&nextloc, sizeof(nextloc));
| 434 |
hdinit(fd, gp); /* writes beam index */
| 435 |
if (!n)
| 436 |
break;
| 437 |
nextloc = hdfilen(fd); /* write section pointer */
| 438 |
if (lseek(fd, (long)lastloc, 0) < 0)
| 439 |
error(SYSTEM,
| 440 |
"cannot seek on holodeck file in creatholo");
| 441 |
| 442 |
lseek(fd, (long)(lastloc=nextloc), 0);
| 443 |
| 444 |
| 445 |
| 446 |
| 447 |
int
| 448 |
headline(s) /* process information header line */
| 449 |
char *s;
| 450 |
| 451 |
extern char FMTSTR[];
| 452 |
register char *cp;
| 453 |
char fmt[32];
| 454 |
| 455 |
if (formatval(fmt, s)) {
| 456 |
if (strcmp(fmt, HOLOFMT)) {
| 457 |
sprintf(errmsg, "%s file \"%s\" has %s%s",
| 458 |
HOLOFMT, hdkfile, FMTSTR, fmt);
| 459 |
| 460 |
| 461 |
return(0);
| 462 |
| 463 |
for (cp = s; *cp; cp++) /* take off any comments */
| 464 |
if (*cp == '#') {
| 465 |
*cp = '\0';
| 466 |
break;
| 467 |
| 468 |
setvariable(s, matchvar); /* don't flag errors */
| 469 |
return(0);
| 470 |
| 471 |
| 472 |
| 473 |
loadholo() /* start loading a holodeck from fname */
| 474 |
| 475 |
extern long ftell();
| 476 |
FILE *fp;
| 477 |
int fd;
| 478 |
int n;
| 479 |
int4 nextloc;
| 480 |
/* open holodeck file */
| 481 |
if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) {
| 482 |
sprintf(errmsg, "cannot %s \"%s\"",
| 483 |
ncprocs>0 ? "append" : "read", hdkfile);
| 484 |
| 485 |
| 486 |
/* load variables from header */
| 487 |
getheader(fp, headline, NULL);
| 488 |
/* check magic number */
| 489 |
if (getw(fp) != HOLOMAGIC) {
| 490 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
| 491 |
hdkfile);
| 492 |
| 493 |
| 494 |
nextloc = ftell(fp); /* get stdio position */
| 495 |
| 496 |
fclose(fp); /* done with stdio */
| 497 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */
| 498 |
lseek(fd, (long)nextloc, 0);
| 499 |
read(fd, (char *)&nextloc, sizeof(nextloc));
| 500 |
hdinit(fd, NULL);
| 501 |
| 502 |
if (n != vdef(SECTION)) {
| 503 |
sprintf(errmsg, "number of sections does not match %s setting",
| 504 |
vnam(SECTION));
| 505 |
| 506 |
| 507 |
| 508 |
| 509 |
| 510 |
done_packets(pl) /* handle finished packets */
| 511 |
PACKET *pl;
| 512 |
| 513 |
static int n2flush = 0;
| 514 |
register PACKET *p;
| 515 |
| 516 |
while (pl != NULL) {
| 517 |
p = pl; pl = p->next; p->next = NULL;
| 518 |
if (p->nr > 0) { /* add to holodeck */
| 519 |
bcopy((char *)p->ra,
| 520 |
(char *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
| 521 |
p->nr*sizeof(RAYVAL));
| 522 |
if (outdev != NULL) /* display it */
| 523 |
disp_packet((PACKHEAD *)p);
| 524 |
if (hdcachesize <= 0)
| 525 |
n2flush++;
| 526 |
nraysdone += p->nr;
| 527 |
npacksdone++;
| 528 |
p->nr = 0;
| 529 |
| 530 |
p->next = freepacks; /* push onto free list */
| 531 |
freepacks = p;
| 532 |
| 533 |
if (n2flush >= RTFLUSH) {
| 534 |
if (outdev != NULL)
| 535 |
hdsync(NULL, 1);
| 536 |
else
| 537 |
hdflush(NULL);
| 538 |
n2flush = 0;
| 539 |
| 540 |
| 541 |
| 542 |
| 543 |
rootname(rn, fn) /* remove tail from end of fn */
| 544 |
register char *rn, *fn;
| 545 |
| 546 |
char *tp, *dp;
| 547 |
| 548 |
for (tp = NULL, dp = rn; *rn = *fn++; rn++)
| 549 |
if (*rn == '/')
| 550 |
dp = rn;
| 551 |
else if (*rn == '.')
| 552 |
tp = rn;
| 553 |
if (tp != NULL && tp > dp)
| 554 |
*tp = '\0';
| 555 |
| 556 |
| 557 |
| 558 |
badvalue(vc) /* report bad variable value and exit */
| 559 |
int vc;
| 560 |
| 561 |
sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
| 562 |
| 563 |
| 564 |
| 565 |
| 566 |
eputs(s) /* put error message to stderr */
| 567 |
register char *s;
| 568 |
| 569 |
static int midline = 0;
| 570 |
| 571 |
if (!*s)
| 572 |
return;
| 573 |
if (!midline++) { /* prepend line with program name */
| 574 |
fputs(progname, stderr);
| 575 |
fputs(": ", stderr);
| 576 |
| 577 |
fputs(s, stderr);
| 578 |
if (s[strlen(s)-1] == '\n') {
| 579 |
fflush(stderr);
| 580 |
midline = 0;
| 581 |
| 582 |
| 583 |
| 584 |
| 585 |
quit(ec) /* exit program gracefully */
| 586 |
int ec;
| 587 |
| 588 |
int status = 0;
| 589 |
| 590 |
if (hdlist[0] != NULL) { /* close holodeck */
| 591 |
if (nprocs > 0)
| 592 |
status = done_rtrace(); /* calls hdsync() */
| 593 |
if (ncprocs > 0 && vdef(REPORT)) {
| 594 |
long fsiz, fuse;
| 595 |
| 596 |
fuse = hdfiluse(hdlist[0]->fd, 1);
| 597 |
fprintf(stderr,
| 598 |
"%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
| 599 |
hdkfile, fsiz/(1024.*1024.),
| 600 |
100.*(fsiz-fuse)/fsiz);
| 601 |
| 602 |
| 603 |
if (orig_mode >= 0) /* reset holodeck access mode */
| 604 |
fchmod(hdlist[0]->fd, orig_mode);
| 605 |
if (outdev != NULL) /* close display */
| 606 |
disp_close();
| 607 |
exit(ec ? ec : status); /* exit */
| 608 |
