root/radiance/ray/src/hd/rholo.c
Revision: 3.48
Committed: Tue Feb 2 16:13:24 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.47: +6 -5 lines
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Radiance holodeck generation controller
9 */
10
11 #include "rholo.h"
12 #include "random.h"
13 #include <signal.h>
14 #include <sys/types.h>
15 #include <sys/stat.h>
16
17 #ifndef RTFLUSH
18 #define RTFLUSH 0 /* flush one at a time in batch */
19 #endif
20 #ifndef FRAGWARN
21 #define FRAGWARN 20 /* fragmentation for warning (%) */
22 #endif
23 #ifndef MAXQTIME
24 #define MAXQTIME 5 /* target maximum seconds in queue */
25 #endif
26 /* the following must be consistent with rholo.h */
27 int NVARS = NRHVARS; /* total number of variables */
28
29 VARIABLE vv[] = RHVINIT; /* variable-value pairs */
30
31 char *progname; /* our program name */
32 char *hdkfile; /* holodeck file name */
33 char froot[256]; /* root file name */
34
35 int ncprocs = 0; /* desired number of compute processes */
36
37 char *outdev = NULL; /* output device name */
38
39 int readinp = 0; /* read commands from stdin */
40
41 int force = 0; /* allow overwrite of holodeck */
42
43 time_t starttime; /* time we got started */
44 time_t endtime; /* time we should end by */
45 time_t reporttime; /* time for next report */
46
47 long maxdisk; /* maximum file space (bytes) */
48
49 int rtargc = 1; /* rtrace command */
50 char *rtargv[128] = {"rtrace", NULL};
51
52 int orig_mode = -1; /* original file mode (-1 if unchanged) */
53
54 long nraysdone = 0L; /* number of rays done */
55 long npacksdone = 0L; /* number of packets done */
56
57 PACKET *freepacks; /* available packets */
58 int totqlen; /* maximum queue length when full */
59
60 char *sigerr[NSIG]; /* signal error messages */
61
62 extern int nowarn; /* turn warnings off? */
63
64 extern time_t time();
65
66
67 main(argc, argv)
68 int argc;
69 char *argv[];
70 {
71 int i;
72
73 initurand(16384); /* initialize urand */
74 progname = argv[0]; /* get arguments */
75 for (i = 1; i < argc && argv[i][0] == '-'; i++)
76 switch (argv[i][1]) {
77 case 'w': /* turn off warnings */
78 nowarn++;
79 break;
80 case 'f': /* force overwrite */
81 force++;
82 break;
83 case 'i': /* read input from stdin */
84 readinp++;
85 break;
86 case 'n': /* compute processes */
87 if (i >= argc-2)
88 goto userr;
89 ncprocs = atoi(argv[++i]);
90 break;
91 case 'o': /* output display */
92 if (i >= argc-2)
93 goto userr;
94 outdev = argv[++i];
95 break;
96 default:
97 goto userr;
98 }
99 /* get root file name */
100 if (i >= argc)
101 goto userr;
102 rootname(froot, hdkfile=argv[i++]);
103 /* load variables? */
104 if (i < argc)
105 if (argv[i][0] != '-' && argv[i][0] != '+')
106 loadvars(argv[i]); /* load variables from file */
107
108 if (i >= argc || argv[i][0] == '+')
109 loadholo(); /* load existing holodeck */
110
111 while (++i < argc) /* get command line settings */
112 if (setvariable(argv[i], matchvar) < 0) {
113 sprintf(errmsg, "unknown variable: %s", argv[i]);
114 error(USER, errmsg);
115 }
116 /* check settings */
117 checkvalues();
118 /* load rad input file */
119 getradfile();
120
121 if (hdlist[0] == NULL) { /* create new holodeck */
122 HDGRID hdg[HDMAX];
123 /* set defaults */
124 setdefaults(hdg);
125 /* holodeck exists? */
126 if (!force && access(hdkfile, R_OK|W_OK) == 0)
127 error(USER,
128 "holodeck file exists -- use -f to overwrite");
129 /* create holodeck */
130 creatholo(hdg);
131 } else /* else just set defaults */
132 setdefaults(NULL);
133 /* initialize */
134 initrholo();
135 /* main loop */
136 while (rholo())
137 ;
138 /* done */
139 quit(0);
140 userr:
141 fprintf(stderr,
142 "Usage: %s [-n nprocs][-o disp][-w][-f] output.hdk [control.hif|+|- [VAR=val ..]]\n",
143 progname);
144 quit(1);
145 }
146
147
148 onsig(signo) /* fatal signal */
149 int signo;
150 {
151 static int gotsig = 0;
152
153 if (gotsig > 1) /* we're going as fast as we can! */
154 return;
155 if (gotsig++) { /* two signals and we split */
156 hdsync(NULL, 0); /* don't leave w/o saying goodbye */
157 _exit(signo);
158 }
159 alarm(300); /* allow 5 minutes to clean up */
160 eputs("signal - ");
161 eputs(sigerr[signo]);
162 eputs("\n");
163 quit(3);
164 }
165
166
167 sigdie(signo, msg) /* set fatal signal */
168 int signo;
169 char *msg;
170 {
171 if (signal(signo, onsig) == SIG_IGN)
172 signal(signo, SIG_IGN);
173 sigerr[signo] = msg;
174 }
175
176
177 int
178 resfmode(fd, mod) /* restrict open file access mode */
179 int fd, mod;
180 {
181 struct stat stbuf;
182 /* get original mode */
183 if (fstat(fd, &stbuf) < 0)
184 error(SYSTEM, "cannot stat open holodeck file");
185 mod &= stbuf.st_mode; /* always more restrictive */
186 if (mod == (stbuf.st_mode & 0777))
187 return(-1); /* already set */
188 /* else change it */
189 if (fchmod(fd, mod) < 0) {
190 error(WARNING, "cannot change holodeck file access mode");
191 return(-1);
192 }
193 return(stbuf.st_mode); /* return original mode */
194 }
195
196
197 initrholo() /* get our holodeck running */
198 {
199 extern int global_packet();
200 register int i;
201 /* close holodeck on exec() */
202 fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC);
203
204 if (outdev != NULL) /* open output device */
205 disp_open(outdev);
206 else if (ncprocs > 0) /* else use global ray feed */
207 init_global();
208 /* record disk space limit */
209 if (!vdef(DISKSPACE))
210 maxdisk = 0;
211 else
212 maxdisk = 1024.*1024.*vflt(DISKSPACE);
213 /* set up memory cache */
214 if (outdev == NULL)
215 hdcachesize = 0; /* manual flushing */
216 else if (vdef(CACHE))
217 hdcachesize = 1024.*1024.*vflt(CACHE);
218 /* open report file */
219 if (vdef(REPORT)) {
220 register char *s = sskip2(vval(REPORT), 1);
221 if (*s && freopen(s, "a", stderr) == NULL)
222 quit(2);
223 }
224 /* mark the starting time */
225 starttime = time(NULL);
226 /* compute end time */
227 if (!vdef(TIME) || vflt(TIME) <= FTINY)
228 endtime = 0;
229 else
230 endtime = starttime + vflt(TIME)*3600. + .5;
231 /* start rtrace */
232 if (ncprocs > 0) {
233 totqlen = i = start_rtrace();
234 if (i < 1)
235 error(USER, "cannot start rtrace process(es)");
236 if (vdef(REPORT)) { /* make first report */
237 printargs(rtargc, rtargv, stderr);
238 report(0);
239 }
240 /* allocate packets */
241 freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
242 if (freepacks == NULL)
243 goto memerr;
244 freepacks[--i].nr = 0;
245 freepacks[i].next = NULL;
246 if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) {
247 freepacks[i].offset = (float *)bmalloc(
248 RPACKSIZ*sizeof(float)*(i+1) );
249 if (freepacks[i].offset == NULL)
250 goto memerr;
251 } else
252 freepacks[i].offset = NULL;
253 while (i--) {
254 freepacks[i].nr = 0;
255 freepacks[i].offset = freepacks[i+1].offset == NULL ?
256 NULL : freepacks[i+1].offset+RPACKSIZ ;
257 freepacks[i].next = &freepacks[i+1];
258 }
259 }
260 /* set up signal handling */
261 sigdie(SIGINT, "Interrupt");
262 sigdie(SIGHUP, "Hangup");
263 sigdie(SIGTERM, "Terminate");
264 sigdie(SIGPIPE, "Broken pipe");
265 sigdie(SIGALRM, "Alarm clock");
266 #ifdef SIGXCPU
267 sigdie(SIGXCPU, "CPU limit exceeded");
268 sigdie(SIGXFSZ, "File size exceeded");
269 #endif
270 /* protect holodeck file */
271 orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444);
272 return;
273 memerr:
274 error(SYSTEM, "out of memory in initrholo");
275 }
276
277
278 rholo() /* holodeck main loop */
279 {
280 static long nextfragwarn = 100*(1L<<20);
281 static int idle = 0;
282 PACKET *pl = NULL, *plend;
283 long fsiz;
284 int pksiz;
285 register PACKET *p;
286 time_t t;
287 /* check display */
288 if (nprocs <= 0)
289 idle = 1;
290 if (outdev != NULL) {
291 if (!disp_check(idle))
292 return(0); /* quit request */
293 if (nprocs <= 0)
294 return(1);
295 } else if (idle)
296 return(0); /* all done */
297 fsiz = hdfilen(hdlist[0]->fd); /* check file size */
298 if (maxdisk > 0 && fsiz >= maxdisk) {
299 error(WARNING, "file limit exceeded");
300 done_rtrace();
301 return(1); /* comes back */
302 }
303 #if FRAGWARN
304 if (fsiz >= nextfragwarn &&
305 (fsiz-hdfiluse(hdlist[0]->fd,0))/(fsiz/100) > FRAGWARN) {
306 sprintf(errmsg, "holodeck file fragmentation is %.0f%%",
307 100.*(fsiz-hdfiluse(hdlist[0]->fd,1))/fsiz);
308 error(WARNING, errmsg);
309 nextfragwarn = fsiz + (fsiz>>2); /* decent interval */
310 }
311 #endif
312 t = time(NULL); /* check time */
313 if (endtime > 0 && t >= endtime) {
314 error(WARNING, "time limit exceeded");
315 done_rtrace();
316 return(1); /* comes back */
317 }
318 if (reporttime > 0 && t >= reporttime)
319 report(t);
320 /* figure out good packet size */
321 pksiz = RPACKSIZ;
322 #if MAXQTIME
323 if (!chunkycmp) {
324 pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L));
325 if (pksiz < 1) pksiz = 1;
326 else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ;
327 }
328 #endif
329 idle = 0; /* get packets to process */
330 while (freepacks != NULL) {
331 p = freepacks; freepacks = p->next; p->next = NULL;
332 if (!next_packet(p, pksiz)) {
333 p->next = freepacks; freepacks = p;
334 idle = 1;
335 break;
336 }
337 if (pl == NULL) pl = p;
338 else plend->next = p;
339 plend = p;
340 }
341 /* process packets */
342 done_packets(do_packets(pl));
343 return(1); /* and continue */
344 }
345
346
347 setdefaults(gp) /* set default values */
348 register HDGRID *gp;
349 {
350 extern char *atos();
351 register int i;
352 int n;
353 double len[3], d;
354 char buf[64];
355
356 if (!vdef(SECTION)) {
357 sprintf(errmsg, "%s must be defined", vnam(SECTION));
358 error(USER, errmsg);
359 }
360 if (!vdef(OCTREE)) {
361 if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
362 error(SYSTEM, "out of memory");
363 sprintf(vval(OCTREE), "%s.oct", froot);
364 vdef(OCTREE)++;
365 }
366 if (!vdef(VDIST)) {
367 vval(VDIST) = "F";
368 vdef(VDIST)++;
369 }
370 /* append rendering options */
371 if (vdef(RENDER))
372 rtargc += wordstring(rtargv+rtargc, vval(RENDER));
373
374 if (gp == NULL) /* already initialized? */
375 return;
376 /* set grid parameters */
377 for (n = 0; n < vdef(SECTION); n++, gp++) {
378 gp->grid[0] = gp->grid[1] = gp->grid[2] = 0;
379 if (sscanf(nvalue(SECTION, n),
380 "%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd",
381 &gp->orig[0], &gp->orig[1], &gp->orig[2],
382 &gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
383 &gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
384 &gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2],
385 &gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12)
386 badvalue(SECTION);
387 for (i = 0; i < 3; i++)
388 len[i] = VLEN(gp->xv[i]);
389 if (!vdef(GRID)) {
390 d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] +
391 len[2]*len[2] + 4*len[1]*len[2])
392 + len[1]*len[1]*len[2]*(len[2] + 4*len[0])
393 + 4*len[0]*len[1]*len[2]*len[2] );
394 d = sqrt(sqrt(d));
395 } else if ((d = vflt(GRID)) <= FTINY)
396 badvalue(GRID);
397 for (i = 0; i < 3; i++)
398 if (gp->grid[i] <= 0)
399 gp->grid[i] = len[i]/d + (1.-FTINY);
400 }
401 }
402
403
404 creatholo(gp) /* create a holodeck output file */
405 HDGRID *gp;
406 {
407 extern char VersionID[];
408 int4 lastloc, nextloc;
409 int n;
410 int fd;
411 FILE *fp;
412 /* open & truncate file */
413 if ((fp = fopen(hdkfile, "w+")) == NULL) {
414 sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
415 error(SYSTEM, errmsg);
416 }
417 /* write information header */
418 newheader("RADIANCE", fp);
419 fprintf(fp, "SOFTWARE= %s\n", VersionID);
420 printvars(fp);
421 fputformat(HOLOFMT, fp);
422 fputc('\n', fp);
423 putw(HOLOMAGIC, fp); /* put magic number */
424 fd = dup(fileno(fp));
425 fclose(fp); /* flush and close stdio stream */
426 lastloc = lseek(fd, 0L, 2);
427 for (n = vdef(SECTION); n--; gp++) { /* initialize each section */
428 nextloc = 0L;
429 write(fd, (char *)&nextloc, sizeof(nextloc));
430 hdinit(fd, gp); /* writes beam index */
431 if (!n)
432 break;
433 nextloc = hdfilen(fd); /* write section pointer */
434 if (lseek(fd, (long)lastloc, 0) < 0)
435 error(SYSTEM,
436 "cannot seek on holodeck file in creatholo");
437 write(fd, (char *)&nextloc, sizeof(nextloc));
438 lseek(fd, (long)(lastloc=nextloc), 0);
439 }
440 }
441
442
443 int
444 headline(s) /* process information header line */
445 char *s;
446 {
447 extern char FMTSTR[];
448 register char *cp;
449 char fmt[32];
450
451 if (formatval(fmt, s)) {
452 if (strcmp(fmt, HOLOFMT)) {
453 sprintf(errmsg, "%s file \"%s\" has %s%s",
454 HOLOFMT, hdkfile, FMTSTR, fmt);
455 error(USER, errmsg);
456 }
457 return(0);
458 }
459 for (cp = s; *cp; cp++) /* take off any comments */
460 if (*cp == '#') {
461 *cp = '\0';
462 break;
463 }
464 setvariable(s, matchvar); /* don't flag errors */
465 return(0);
466 }
467
468
469 loadholo() /* start loading a holodeck from fname */
470 {
471 extern long ftell();
472 FILE *fp;
473 int fd;
474 int n;
475 int4 nextloc;
476 /* open holodeck file */
477 if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) {
478 sprintf(errmsg, "cannot %s \"%s\"",
479 ncprocs>0 ? "append" : "read", hdkfile);
480 error(SYSTEM, errmsg);
481 }
482 /* load variables from header */
483 getheader(fp, headline, NULL);
484 /* check magic number */
485 if (getw(fp) != HOLOMAGIC) {
486 sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
487 hdkfile);
488 error(USER, errmsg);
489 }
490 nextloc = ftell(fp); /* get stdio position */
491 fd = dup(fileno(fp));
492 fclose(fp); /* done with stdio */
493 for (n = 0; nextloc > 0L; n++) { /* initialize each section */
494 lseek(fd, (long)nextloc, 0);
495 read(fd, (char *)&nextloc, sizeof(nextloc));
496 hdinit(fd, NULL);
497 }
498 if (n != vdef(SECTION)) {
499 sprintf(errmsg, "number of sections does not match %s setting",
500 vnam(SECTION));
501 error(WARNING, errmsg);
502 }
503 }
504
505
506 done_packets(pl) /* handle finished packets */
507 PACKET *pl;
508 {
509 static int n2flush = 0;
510 register PACKET *p;
511
512 while (pl != NULL) {
513 p = pl; pl = p->next; p->next = NULL;
514 if (p->nr > 0) { /* add to holodeck */
515 bcopy((char *)p->ra,
516 (char *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
517 p->nr*sizeof(RAYVAL));
518 if (outdev != NULL) /* display it */
519 disp_packet((PACKHEAD *)p);
520 if (hdcachesize <= 0) {
521 #if RTFLUSH
522 if (outdev == NULL)
523 hdfreebeam(hdlist[p->hd], p->bi);
524 #endif
525 n2flush++;
526 }
527 nraysdone += p->nr;
528 npacksdone++;
529 p->nr = 0;
530 }
531 p->next = freepacks; /* push onto free list */
532 freepacks = p;
533 }
534 #if MAXQTIME
535 if (n2flush > 300/MAXQTIME*totqlen) {
536 #else
537 if (n2flush > 50*totqlen) {
538 #endif
539 #if RTFLUSH
540 hdsync(NULL, outdev!=NULL); /* sync beams & directories */
541 #else
542 if (outdev != NULL)
543 hdsync(NULL, 1);
544 else
545 hdflush(NULL);
546 #endif
547 n2flush = 0;
548 }
549 }
550
551
552 rootname(rn, fn) /* remove tail from end of fn */
553 register char *rn, *fn;
554 {
555 char *tp, *dp;
556
557 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
558 if (*rn == '/')
559 dp = rn;
560 else if (*rn == '.')
561 tp = rn;
562 if (tp != NULL && tp > dp)
563 *tp = '\0';
564 }
565
566
567 badvalue(vc) /* report bad variable value and exit */
568 int vc;
569 {
570 sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
571 error(USER, errmsg);
572 }
573
574
575 eputs(s) /* put error message to stderr */
576 register char *s;
577 {
578 static int midline = 0;
579
580 if (!*s)
581 return;
582 if (!midline++) { /* prepend line with program name */
583 fputs(progname, stderr);
584 fputs(": ", stderr);
585 }
586 fputs(s, stderr);
587 if (s[strlen(s)-1] == '\n') {
588 fflush(stderr);
589 midline = 0;
590 }
591 }
592
593
594 quit(ec) /* exit program gracefully */
595 int ec;
596 {
597 int status = 0;
598
599 if (hdlist[0] != NULL) { /* close holodeck */
600 if (nprocs > 0)
601 status = done_rtrace(); /* calls hdsync() */
602 if (ncprocs > 0 && vdef(REPORT)) {
603 long fsiz, fuse;
604 fsiz = hdfilen(hdlist[0]->fd);
605 fuse = hdfiluse(hdlist[0]->fd, 1);
606 fprintf(stderr,
607 "%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
608 hdkfile, fsiz/(1024.*1024.),
609 100.*(fsiz-fuse)/fsiz);
610 }
611 }
612 if (orig_mode >= 0) /* reset holodeck access mode */
613 fchmod(hdlist[0]->fd, orig_mode);
614 if (outdev != NULL) /* close display */
615 disp_close();
616 exit(ec ? ec : status); /* exit */
617 }
