1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Radiance holodeck generation controller |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "random.h" |
13 |
#include <signal.h> |
14 |
#include <sys/types.h> |
15 |
#include <sys/stat.h> |
16 |
17 |
/* the following must be consistent with rholo.h */ |
18 |
int NVARS = NRHVARS; /* total number of variables */ |
19 |
20 |
VARIABLE vv[] = RHVINIT; /* variable-value pairs */ |
21 |
22 |
char *progname; /* our program name */ |
23 |
char *hdkfile; /* holodeck file name */ |
24 |
char froot[256]; /* root file name */ |
25 |
26 |
int nowarn = 0; /* turn warnings off? */ |
27 |
28 |
int ncprocs = 0; /* desired number of compute processes */ |
29 |
30 |
char *outdev = NULL; /* output device name */ |
31 |
32 |
int readinp = 0; /* read commands from stdin */ |
33 |
34 |
int force = 0; /* allow overwrite of holodeck */ |
35 |
36 |
time_t starttime; /* time we got started */ |
37 |
time_t endtime; /* time we should end by */ |
38 |
time_t reporttime; /* time for next report */ |
39 |
40 |
long maxdisk; /* maximum file space (bytes) */ |
41 |
42 |
int rtargc = 1; /* rtrace command */ |
43 |
char *rtargv[128] = {"rtrace", NULL}; |
44 |
45 |
int orig_mode = -1; /* original file mode (-1 if unchanged) */ |
46 |
47 |
long nraysdone = 0L; /* number of rays done */ |
48 |
long npacksdone = 0L; /* number of packets done */ |
49 |
50 |
PACKET *freepacks; /* available packets */ |
51 |
52 |
char *sigerr[NSIG]; /* signal error messages */ |
53 |
54 |
extern time_t time(); |
55 |
56 |
57 |
main(argc, argv) |
58 |
int argc; |
59 |
char *argv[]; |
60 |
61 |
int i; |
62 |
/* mark start time */ |
63 |
starttime = time(NULL); |
64 |
initurand(16384); /* initialize urand */ |
65 |
progname = argv[0]; /* get arguments */ |
66 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
67 |
switch (argv[i][1]) { |
68 |
case 'w': /* turn off warnings */ |
69 |
nowarn++; |
70 |
break; |
71 |
case 'f': /* force overwrite */ |
72 |
force++; |
73 |
break; |
74 |
case 'i': /* read input from stdin */ |
75 |
readinp++; |
76 |
break; |
77 |
case 'n': /* compute processes */ |
78 |
if (i >= argc-2) |
79 |
goto userr; |
80 |
ncprocs = atoi(argv[++i]); |
81 |
break; |
82 |
case 'o': /* output display */ |
83 |
if (i >= argc-2) |
84 |
goto userr; |
85 |
outdev = argv[++i]; |
86 |
break; |
87 |
default: |
88 |
goto userr; |
89 |
90 |
/* get root file name */ |
91 |
rootname(froot, hdkfile=argv[i++]); |
92 |
/* load variables? */ |
93 |
if (i < argc) |
94 |
if (argv[i][0] != '-' && argv[i][0] != '+') |
95 |
loadvars(argv[i]); /* load variables from file */ |
96 |
97 |
if (i >= argc || argv[i][0] == '+') |
98 |
loadholo(); /* load existing holodeck */ |
99 |
100 |
while (++i < argc) /* get command line settings */ |
101 |
if (setvariable(argv[i], matchvar) < 0) { |
102 |
sprintf(errmsg, "unknown variable: %s", argv[i]); |
103 |
error(USER, errmsg); |
104 |
105 |
/* check settings */ |
106 |
checkvalues(); |
107 |
/* load RIF if any */ |
108 |
getradfile(); |
109 |
110 |
if (hdlist[0] == NULL) { /* create new holodeck */ |
111 |
HDGRID hdg[HDMAX]; |
112 |
/* set defaults */ |
113 |
setdefaults(hdg); |
114 |
/* holodeck exists? */ |
115 |
if (!force && access(hdkfile, R_OK|W_OK) == 0) |
116 |
error(USER, |
117 |
"holodeck file exists -- use -f to overwrite"); |
118 |
/* create holodeck */ |
119 |
creatholo(hdg); |
120 |
} else /* else just set defaults */ |
121 |
setdefaults(NULL); |
122 |
/* initialize */ |
123 |
initrholo(); |
124 |
/* main loop */ |
125 |
while (rholo()) |
126 |
127 |
/* done */ |
128 |
quit(0); |
129 |
userr: |
130 |
fprintf(stderr, |
131 |
"Usage: %s [-n nprocs][-o disp][-w][-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", |
132 |
progname); |
133 |
quit(1); |
134 |
135 |
136 |
137 |
onsig(signo) /* fatal signal */ |
138 |
int signo; |
139 |
140 |
static int gotsig = 0; |
141 |
142 |
if (gotsig++) /* two signals and we're gone! */ |
143 |
_exit(signo); |
144 |
145 |
alarm(60); /* allow 60 seconds to clean up */ |
146 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
147 |
eputs("signal - "); |
148 |
eputs(sigerr[signo]); |
149 |
eputs("\n"); |
150 |
quit(3); |
151 |
152 |
153 |
154 |
sigdie(signo, msg) /* set fatal signal */ |
155 |
int signo; |
156 |
char *msg; |
157 |
158 |
if (signal(signo, onsig) == SIG_IGN) |
159 |
signal(signo, SIG_IGN); |
160 |
sigerr[signo] = msg; |
161 |
162 |
163 |
164 |
int |
165 |
resfmode(fd, mod) /* restrict open file access mode */ |
166 |
int fd, mod; |
167 |
168 |
struct stat stbuf; |
169 |
/* get original mode */ |
170 |
if (fstat(fd, &stbuf) < 0) |
171 |
error(SYSTEM, "cannot stat open holodeck file"); |
172 |
mod &= stbuf.st_mode; /* always more restrictive */ |
173 |
if (mod == stbuf.st_mode) |
174 |
return(-1); /* already set */ |
175 |
/* else change it */ |
176 |
if (fchmod(fd, mod) < 0) { |
177 |
error(WARNING, "cannot change holodeck file access mode"); |
178 |
return(-1); |
179 |
180 |
return(stbuf.st_mode); /* return original mode */ |
181 |
182 |
183 |
184 |
initrholo() /* get our holodeck running */ |
185 |
186 |
extern int global_packet(); |
187 |
register int i; |
188 |
/* close holodeck on exec() */ |
189 |
fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC); |
190 |
191 |
if (outdev != NULL) /* open output device */ |
192 |
disp_open(outdev); |
193 |
else if (ncprocs > 0) /* else use global ray feed */ |
194 |
init_global(); |
195 |
/* record disk space limit */ |
196 |
if (!vdef(DISKSPACE)) |
197 |
maxdisk = 0; |
198 |
else |
199 |
maxdisk = 1024.*1024.*vflt(DISKSPACE); |
200 |
/* record end time */ |
201 |
if (!vdef(TIME) || vflt(TIME) <= FTINY) |
202 |
endtime = 0; |
203 |
else |
204 |
endtime = starttime + vflt(TIME)*3600. + .5; |
205 |
/* set up memory cache */ |
206 |
if (outdev == NULL) |
207 |
hdcachesize = 0; /* manual flushing */ |
208 |
else if (vdef(CACHE)) |
209 |
hdcachesize = 1024.*1024.*vflt(CACHE); |
210 |
/* open report file */ |
211 |
if (vdef(REPORT)) { |
212 |
register char *s = sskip2(vval(REPORT), 1); |
213 |
if (*s && freopen(s, "a", stderr) == NULL) |
214 |
quit(2); |
215 |
216 |
/* start rtrace */ |
217 |
if (ncprocs > 0) { |
218 |
i = start_rtrace(); |
219 |
if (i < 1) |
220 |
error(USER, "cannot start rtrace process(es)"); |
221 |
if (vdef(REPORT)) { /* make first report */ |
222 |
printargs(rtargc, rtargv, stderr); |
223 |
report(0); |
224 |
225 |
/* allocate packets */ |
226 |
freepacks = (PACKET *)bmalloc(i*sizeof(PACKET)); |
227 |
if (freepacks == NULL) |
228 |
goto memerr; |
229 |
freepacks[--i].nr = 0; |
230 |
freepacks[i].next = NULL; |
231 |
if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) { |
232 |
freepacks[i].offset = (float *)bmalloc( |
233 |
RPACKSIZ*sizeof(float)*(i+1) ); |
234 |
if (freepacks[i].offset == NULL) |
235 |
goto memerr; |
236 |
} else |
237 |
freepacks[i].offset = NULL; |
238 |
while (i--) { |
239 |
freepacks[i].nr = 0; |
240 |
freepacks[i].offset = freepacks[i+1].offset == NULL ? |
241 |
NULL : freepacks[i+1].offset+RPACKSIZ ; |
242 |
freepacks[i].next = &freepacks[i+1]; |
243 |
244 |
245 |
/* set up signal handling */ |
246 |
sigdie(SIGINT, "Interrupt"); |
247 |
sigdie(SIGHUP, "Hangup"); |
248 |
sigdie(SIGTERM, "Terminate"); |
249 |
sigdie(SIGPIPE, "Broken pipe"); |
250 |
sigdie(SIGALRM, "Alarm clock"); |
251 |
#ifdef SIGXCPU |
252 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
253 |
sigdie(SIGXFSZ, "File size exceeded"); |
254 |
#endif |
255 |
/* protect holodeck file */ |
256 |
orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444); |
257 |
return; |
258 |
memerr: |
259 |
error(SYSTEM, "out of memory in initrholo"); |
260 |
261 |
262 |
263 |
rholo() /* holodeck main loop */ |
264 |
265 |
static int idle = 0; |
266 |
PACKET *pl = NULL, *plend; |
267 |
register PACKET *p; |
268 |
time_t t; |
269 |
long l; |
270 |
/* check display */ |
271 |
if (nprocs <= 0) |
272 |
idle = 1; |
273 |
if (outdev != NULL) { |
274 |
if (!disp_check(idle)) |
275 |
return(0); /* quit request */ |
276 |
if (nprocs <= 0) |
277 |
return(1); |
278 |
} else if (idle) |
279 |
return(0); /* all done */ |
280 |
/* check file size */ |
281 |
if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { |
282 |
error(WARNING, "file limit exceeded"); |
283 |
done_rtrace(); |
284 |
return(1); /* comes back */ |
285 |
286 |
/* check time */ |
287 |
if (endtime > 0 || reporttime > 0) |
288 |
t = time(NULL); |
289 |
if (endtime > 0 && t >= endtime) { |
290 |
error(WARNING, "time limit exceeded"); |
291 |
done_rtrace(); |
292 |
293 |
294 |
if (reporttime > 0 && t >= reporttime) |
295 |
report(t); |
296 |
idle = 0; /* get packets to process */ |
297 |
while (freepacks != NULL) { |
298 |
p = freepacks; freepacks = p->next; p->next = NULL; |
299 |
if (!next_packet(p)) { |
300 |
p->next = freepacks; freepacks = p; |
301 |
idle = 1; |
302 |
break; |
303 |
304 |
if (pl == NULL) pl = p; |
305 |
else plend->next = p; |
306 |
plend = p; |
307 |
308 |
/* process packets */ |
309 |
done_packets(do_packets(pl)); |
310 |
return(1); /* and continue */ |
311 |
312 |
313 |
314 |
setdefaults(gp) /* set default values */ |
315 |
register HDGRID *gp; |
316 |
317 |
extern char *atos(); |
318 |
register int i; |
319 |
int n; |
320 |
double len[3], maxlen, d; |
321 |
char buf[64]; |
322 |
323 |
if (!vdef(SECTION)) { |
324 |
sprintf(errmsg, "%s must be defined", vnam(SECTION)); |
325 |
326 |
327 |
if (!vdef(OCTREE)) { |
328 |
if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL) |
329 |
error(SYSTEM, "out of memory"); |
330 |
sprintf(vval(OCTREE), "%s.oct", froot); |
331 |
vdef(OCTREE)++; |
332 |
333 |
if (!vdef(VDIST)) { |
334 |
vval(VDIST) = "F"; |
335 |
vdef(VDIST)++; |
336 |
337 |
/* append rendering options */ |
338 |
if (vdef(RENDER)) |
339 |
rtargc += wordstring(rtargv+rtargc, vval(RENDER)); |
340 |
341 |
if (gp == NULL) /* already initialized? */ |
342 |
return; |
343 |
/* set grid parameters */ |
344 |
for (n = 0; n < vdef(SECTION); n++, gp++) { |
345 |
gp->grid[0] = gp->grid[1] = gp->grid[2] = 0; |
346 |
if (sscanf(nvalue(SECTION, n), |
347 |
"%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd", |
348 |
&gp->orig[0], &gp->orig[1], &gp->orig[2], |
349 |
&gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2], |
350 |
&gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2], |
351 |
&gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2], |
352 |
&gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12) |
353 |
badvalue(SECTION); |
354 |
maxlen = 0.; |
355 |
for (i = 0; i < 3; i++) |
356 |
if ((len[i] = VLEN(gp->xv[i])) > maxlen) |
357 |
maxlen = len[i]; |
358 |
if (!vdef(GRID)) |
359 |
d = 0.125*maxlen; |
360 |
else if ((d = vflt(GRID)) <= FTINY) |
361 |
badvalue(GRID); |
362 |
363 |
if (gp->grid[i] <= 0) |
364 |
gp->grid[i] = len[i]/d + (1.-FTINY); |
365 |
366 |
367 |
368 |
369 |
creatholo(gp) /* create a holodeck output file */ |
370 |
HDGRID *gp; |
371 |
372 |
extern char VersionID[]; |
373 |
int4 lastloc, nextloc; |
374 |
int n; |
375 |
int fd; |
376 |
FILE *fp; |
377 |
/* open & truncate file */ |
378 |
if ((fp = fopen(hdkfile, "w+")) == NULL) { |
379 |
sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile); |
380 |
error(SYSTEM, errmsg); |
381 |
382 |
/* write information header */ |
383 |
newheader("RADIANCE", fp); |
384 |
fprintf(fp, "SOFTWARE= %s\n", VersionID); |
385 |
printvars(fp); |
386 |
fputformat(HOLOFMT, fp); |
387 |
fputc('\n', fp); |
388 |
putw(HOLOMAGIC, fp); /* put magic number */ |
389 |
fd = dup(fileno(fp)); |
390 |
fclose(fp); /* flush and close stdio stream */ |
391 |
lastloc = lseek(fd, 0L, 2); |
392 |
for (n = vdef(SECTION); n--; gp++) { /* initialize each section */ |
393 |
nextloc = 0L; |
394 |
write(fd, (char *)&nextloc, sizeof(nextloc)); |
395 |
hdinit(fd, gp); /* writes beam index */ |
396 |
if (!n) |
397 |
break; |
398 |
nextloc = hdfilen(fd); /* write section pointer */ |
399 |
if (lseek(fd, (long)lastloc, 0) < 0) |
400 |
error(SYSTEM, |
401 |
"cannot seek on holodeck file in creatholo"); |
402 |
403 |
lseek(fd, (long)(lastloc=nextloc), 0); |
404 |
405 |
406 |
407 |
408 |
headline(s) /* process information header line */ |
409 |
char *s; |
410 |
411 |
extern char FMTSTR[]; |
412 |
register char *cp; |
413 |
char fmt[32]; |
414 |
415 |
if (formatval(fmt, s)) { |
416 |
if (strcmp(fmt, HOLOFMT)) { |
417 |
sprintf(errmsg, "%s file \"%s\" has %s%s", |
418 |
HOLOFMT, hdkfile, FMTSTR, fmt); |
419 |
420 |
421 |
return; |
422 |
423 |
for (cp = s; *cp; cp++) /* take off any comments */ |
424 |
if (*cp == '#') { |
425 |
*cp = '\0'; |
426 |
break; |
427 |
428 |
setvariable(s, matchvar); /* don't flag errors */ |
429 |
430 |
431 |
432 |
loadholo() /* start loading a holodeck from fname */ |
433 |
434 |
extern long ftell(); |
435 |
FILE *fp; |
436 |
int fd; |
437 |
int n; |
438 |
int4 nextloc; |
439 |
/* open holodeck file */ |
440 |
if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) { |
441 |
sprintf(errmsg, "cannot open \"%s\" for %s", hdkfile, |
442 |
ncprocs>0 ? "appending" : "reading"); |
443 |
444 |
445 |
/* load variables from header */ |
446 |
getheader(fp, headline, NULL); |
447 |
/* check magic number */ |
448 |
if (getw(fp) != HOLOMAGIC) { |
449 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"", |
450 |
hdkfile); |
451 |
452 |
453 |
nextloc = ftell(fp); /* get stdio position */ |
454 |
455 |
fclose(fp); /* done with stdio */ |
456 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */ |
457 |
lseek(fd, (long)nextloc, 0); |
458 |
read(fd, (char *)&nextloc, sizeof(nextloc)); |
459 |
hdinit(fd, NULL); |
460 |
461 |
if (n != vdef(SECTION)) { |
462 |
sprintf(errmsg, "number of sections does not match %s setting", |
463 |
vnam(SECTION)); |
464 |
error(WARNING, errmsg); |
465 |
466 |
467 |
468 |
469 |
done_packets(pl) /* handle finished packets */ |
470 |
PACKET *pl; |
471 |
472 |
static int n2flush = 0; |
473 |
474 |
475 |
while (pl != NULL) { |
476 |
p = pl; pl = p->next; p->next = NULL; |
477 |
if (p->nr > 0) { /* add to holodeck */ |
478 |
bcopy((char *)p->ra, |
479 |
(char *)hdnewrays(hdlist[p->hd],p->bi,p->nr), |
480 |
p->nr*sizeof(RAYVAL)); |
481 |
if (outdev != NULL) /* display it */ |
482 |
disp_packet((PACKHEAD *)p); |
483 |
if (hdcachesize <= 0) /* manual flushing */ |
484 |
n2flush += p->nr; |
485 |
nraysdone += p->nr; |
486 |
npacksdone++; |
487 |
488 |
p->nr = 0; /* push onto free list */ |
489 |
p->next = freepacks; |
490 |
freepacks = p; |
491 |
492 |
if (n2flush > 1024*RPACKSIZ*nprocs) { |
493 |
hdflush(NULL); /* flush holodeck buffers */ |
494 |
n2flush = 0; |
495 |
496 |
497 |
498 |
499 |
rootname(rn, fn) /* remove tail from end of fn */ |
500 |
register char *rn, *fn; |
501 |
502 |
char *tp, *dp; |
503 |
504 |
for (tp = NULL, dp = rn; *rn = *fn++; rn++) |
505 |
if (*rn == '/') |
506 |
dp = rn; |
507 |
else if (*rn == '.') |
508 |
tp = rn; |
509 |
if (tp != NULL && tp > dp) |
510 |
*tp = '\0'; |
511 |
512 |
513 |
514 |
badvalue(vc) /* report bad variable value and exit */ |
515 |
int vc; |
516 |
517 |
sprintf(errmsg, "bad value for variable '%s'", vnam(vc)); |
518 |
519 |
520 |
521 |
522 |
eputs(s) /* put error message to stderr */ |
523 |
register char *s; |
524 |
525 |
static int midline = 0; |
526 |
527 |
if (!*s) |
528 |
return; |
529 |
if (!midline++) { /* prepend line with program name */ |
530 |
fputs(progname, stderr); |
531 |
fputs(": ", stderr); |
532 |
533 |
fputs(s, stderr); |
534 |
if (s[strlen(s)-1] == '\n') { |
535 |
fflush(stderr); |
536 |
midline = 0; |
537 |
538 |
539 |
540 |
541 |
wputs(s) /* put warning string to stderr */ |
542 |
char *s; |
543 |
544 |
if (!nowarn) |
545 |
eputs(s); |
546 |
547 |
548 |
549 |
quit(ec) /* exit program gracefully */ |
550 |
int ec; |
551 |
552 |
int status = 0; |
553 |
554 |
if (hdlist[0] != NULL) { /* close holodeck */ |
555 |
if (nprocs > 0) |
556 |
status = done_rtrace(); /* calls hdsync() */ |
557 |
if (ncprocs > 0 && vdef(REPORT)) { |
558 |
long fsiz, fuse; |
559 |
fsiz = hdfilen(hdlist[0]->fd); |
560 |
fuse = hdfiluse(hdlist[0]->fd, 1); |
561 |
fprintf(stderr, |
562 |
"%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n", |
563 |
hdkfile, fsiz/(1024.*1024.), |
564 |
100.*(fsiz-fuse)/fsiz); |
565 |
566 |
567 |
if (orig_mode >= 0) /* reset holodeck access mode */ |
568 |
fchmod(hdlist[0]->fd, orig_mode); |
569 |
if (outdev != NULL) /* close display */ |
570 |
disp_close(); |
571 |
exit(ec ? ec : status); /* exit */ |
572 |
