| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Radiance holodeck generation controller
| 9 |
| 10 |
| 11 |
#include "rholo.h"
| 12 |
#include "random.h"
| 13 |
#include <signal.h>
| 14 |
#include <sys/types.h>
| 15 |
#include <sys/stat.h>
| 16 |
| 17 |
/* the following must be consistent with rholo.h */
| 18 |
int NVARS = NRHVARS; /* total number of variables */
| 19 |
| 20 |
VARIABLE vv[] = RHVINIT; /* variable-value pairs */
| 21 |
| 22 |
char *progname; /* our program name */
| 23 |
char *hdkfile; /* holodeck file name */
| 24 |
char froot[256]; /* root file name */
| 25 |
| 26 |
int nowarn = 0; /* turn warnings off? */
| 27 |
| 28 |
int ncprocs = 0; /* desired number of compute processes */
| 29 |
| 30 |
char *outdev = NULL; /* output device name */
| 31 |
| 32 |
int readinp = 0; /* read commands from stdin */
| 33 |
| 34 |
int force = 0; /* allow overwrite of holodeck */
| 35 |
| 36 |
time_t starttime; /* time we got started */
| 37 |
time_t endtime; /* time we should end by */
| 38 |
time_t reporttime; /* time for next report */
| 39 |
| 40 |
long maxdisk; /* maximum file space (bytes) */
| 41 |
| 42 |
int rtargc = 1; /* rtrace command */
| 43 |
char *rtargv[128] = {"rtrace", NULL};
| 44 |
| 45 |
int orig_mode = -1; /* original file mode (-1 if unchanged) */
| 46 |
| 47 |
long nraysdone = 0L; /* number of rays done */
| 48 |
long npacksdone = 0L; /* number of packets done */
| 49 |
| 50 |
PACKET *freepacks; /* available packets */
| 51 |
| 52 |
char *sigerr[NSIG]; /* signal error messages */
| 53 |
| 54 |
extern time_t time();
| 55 |
| 56 |
| 57 |
main(argc, argv)
| 58 |
int argc;
| 59 |
char *argv[];
| 60 |
| 61 |
HDGRID hdg;
| 62 |
int i;
| 63 |
/* mark start time */
| 64 |
starttime = time(NULL);
| 65 |
initurand(16384); /* initialize urand */
| 66 |
progname = argv[0]; /* get arguments */
| 67 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 68 |
switch (argv[i][1]) {
| 69 |
case 'w': /* turn off warnings */
| 70 |
nowarn++;
| 71 |
break;
| 72 |
case 'f': /* force overwrite */
| 73 |
force++;
| 74 |
break;
| 75 |
case 'i': /* read input from stdin */
| 76 |
readinp++;
| 77 |
break;
| 78 |
case 'n': /* compute processes */
| 79 |
if (i >= argc-2)
| 80 |
goto userr;
| 81 |
ncprocs = atoi(argv[++i]);
| 82 |
break;
| 83 |
case 'o': /* output display */
| 84 |
if (i >= argc-2)
| 85 |
goto userr;
| 86 |
outdev = argv[++i];
| 87 |
break;
| 88 |
default:
| 89 |
goto userr;
| 90 |
| 91 |
/* get root file name */
| 92 |
rootname(froot, hdkfile=argv[i++]);
| 93 |
/* load variables? */
| 94 |
if (i < argc)
| 95 |
if (argv[i][0] != '-' && argv[i][0] != '+')
| 96 |
loadvars(argv[i]); /* load variables from file */
| 97 |
| 98 |
if (i >= argc || argv[i][0] == '+')
| 99 |
loadholo(); /* load existing holodeck */
| 100 |
| 101 |
while (++i < argc) /* get command line settings */
| 102 |
if (setvariable(argv[i], matchvar) < 0) {
| 103 |
sprintf(errmsg, "unknown variable: %s", argv[i]);
| 104 |
error(USER, errmsg);
| 105 |
| 106 |
/* check settings */
| 107 |
checkvalues();
| 108 |
/* load RIF if any */
| 109 |
getradfile();
| 110 |
| 111 |
if (hdlist[0] == NULL) { /* create new holodeck */
| 112 |
/* set defaults */
| 113 |
setdefaults(&hdg);
| 114 |
/* holodeck exists? */
| 115 |
if (!force && access(hdkfile, R_OK|W_OK) == 0)
| 116 |
error(USER,
| 117 |
"holodeck file exists -- use -f to overwrite");
| 118 |
/* create holodeck */
| 119 |
creatholo(&hdg);
| 120 |
} else /* else just set defaults */
| 121 |
setdefaults(NULL);
| 122 |
/* initialize */
| 123 |
initrholo();
| 124 |
/* main loop */
| 125 |
while (rholo())
| 126 |
| 127 |
/* done */
| 128 |
quit(0);
| 129 |
userr:
| 130 |
fprintf(stderr,
| 131 |
"Usage: %s [-n nprocs][-o disp][-w][-f] output.hdk [control.hif|+|- [VAR=val ..]]\n",
| 132 |
progname);
| 133 |
quit(1);
| 134 |
| 135 |
| 136 |
| 137 |
onsig(signo) /* fatal signal */
| 138 |
int signo;
| 139 |
| 140 |
static int gotsig = 0;
| 141 |
| 142 |
if (gotsig++) /* two signals and we're gone! */
| 143 |
_exit(signo);
| 144 |
| 145 |
alarm(60); /* allow 60 seconds to clean up */
| 146 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 147 |
eputs("signal - ");
| 148 |
eputs(sigerr[signo]);
| 149 |
eputs("\n");
| 150 |
quit(3);
| 151 |
| 152 |
| 153 |
| 154 |
sigdie(signo, msg) /* set fatal signal */
| 155 |
int signo;
| 156 |
char *msg;
| 157 |
| 158 |
if (signal(signo, onsig) == SIG_IGN)
| 159 |
signal(signo, SIG_IGN);
| 160 |
sigerr[signo] = msg;
| 161 |
| 162 |
| 163 |
| 164 |
int
| 165 |
resfmode(fd, mod) /* restrict open file access mode */
| 166 |
int fd, mod;
| 167 |
| 168 |
struct stat stbuf;
| 169 |
/* get original mode */
| 170 |
if (fstat(fd, &stbuf) < 0)
| 171 |
error(SYSTEM, "cannot stat open holodeck file");
| 172 |
mod &= stbuf.st_mode; /* always more restrictive */
| 173 |
if (mod == stbuf.st_mode)
| 174 |
return(-1); /* already set */
| 175 |
/* else change it */
| 176 |
if (fchmod(fd, mod) < 0) {
| 177 |
error(WARNING, "cannot change holodeck file access mode");
| 178 |
return(-1);
| 179 |
| 180 |
return(stbuf.st_mode); /* return original mode */
| 181 |
| 182 |
| 183 |
| 184 |
initrholo() /* get our holodeck running */
| 185 |
| 186 |
extern int global_packet();
| 187 |
register int i;
| 188 |
/* close holodeck on exec() */
| 189 |
fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC);
| 190 |
| 191 |
if (outdev != NULL) /* open output device */
| 192 |
disp_open(outdev);
| 193 |
else if (ncprocs > 0) /* else use global ray feed */
| 194 |
init_global();
| 195 |
/* record disk space limit */
| 196 |
if (!vdef(DISKSPACE))
| 197 |
maxdisk = 0;
| 198 |
else
| 199 |
maxdisk = 1024.*1024.*vflt(DISKSPACE);
| 200 |
/* record end time */
| 201 |
if (!vdef(TIME) || vflt(TIME) <= FTINY)
| 202 |
endtime = 0;
| 203 |
else
| 204 |
endtime = starttime + vflt(TIME)*3600. + .5;
| 205 |
/* set up memory cache */
| 206 |
if (outdev == NULL)
| 207 |
hdcachesize = 0; /* manual flushing */
| 208 |
else if (vdef(CACHE))
| 209 |
hdcachesize = 1024.*1024.*vflt(CACHE);
| 210 |
/* open report file */
| 211 |
if (vdef(REPORT)) {
| 212 |
register char *s = sskip2(vval(REPORT), 1);
| 213 |
if (*s && freopen(s, "a", stderr) == NULL)
| 214 |
quit(2);
| 215 |
| 216 |
/* start rtrace */
| 217 |
if (ncprocs > 0) {
| 218 |
i = start_rtrace();
| 219 |
if (i < 1)
| 220 |
error(USER, "cannot start rtrace process(es)");
| 221 |
if (vdef(REPORT)) { /* make first report */
| 222 |
printargs(rtargc, rtargv, stderr);
| 223 |
report(0);
| 224 |
| 225 |
/* allocate packets */
| 226 |
freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
| 227 |
if (freepacks == NULL)
| 228 |
goto memerr;
| 229 |
freepacks[--i].nr = 0;
| 230 |
freepacks[i].next = NULL;
| 231 |
if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) {
| 232 |
freepacks[i].offset = (float *)bmalloc(
| 233 |
RPACKSIZ*sizeof(float)*(i+1) );
| 234 |
if (freepacks[i].offset == NULL)
| 235 |
goto memerr;
| 236 |
} else
| 237 |
freepacks[i].offset = NULL;
| 238 |
while (i--) {
| 239 |
freepacks[i].nr = 0;
| 240 |
freepacks[i].offset = freepacks[i+1].offset == NULL ?
| 241 |
NULL : freepacks[i+1].offset+RPACKSIZ ;
| 242 |
freepacks[i].next = &freepacks[i+1];
| 243 |
| 244 |
| 245 |
/* set up signal handling */
| 246 |
sigdie(SIGINT, "Interrupt");
| 247 |
sigdie(SIGHUP, "Hangup");
| 248 |
sigdie(SIGTERM, "Terminate");
| 249 |
sigdie(SIGPIPE, "Broken pipe");
| 250 |
sigdie(SIGALRM, "Alarm clock");
| 251 |
#ifdef SIGXCPU
| 252 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 253 |
sigdie(SIGXFSZ, "File size exceeded");
| 254 |
#endif
| 255 |
/* protect holodeck file */
| 256 |
orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444);
| 257 |
return;
| 258 |
memerr:
| 259 |
error(SYSTEM, "out of memory in initrholo");
| 260 |
| 261 |
| 262 |
| 263 |
rholo() /* holodeck main loop */
| 264 |
| 265 |
static int idle = 1;
| 266 |
PACKET *pl = NULL, *plend;
| 267 |
register PACKET *p;
| 268 |
time_t t;
| 269 |
long l;
| 270 |
| 271 |
if (outdev != NULL) /* check display */
| 272 |
if (!disp_check(idle))
| 273 |
return(0);
| 274 |
/* display only? */
| 275 |
if (nprocs <= 0) {
| 276 |
idle = 1;
| 277 |
return(outdev != NULL);
| 278 |
| 279 |
/* check file size */
| 280 |
if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) {
| 281 |
error(WARNING, "file limit exceeded");
| 282 |
done_rtrace();
| 283 |
return(1); /* comes back */
| 284 |
| 285 |
/* check time */
| 286 |
if (endtime > 0 || reporttime > 0)
| 287 |
t = time(NULL);
| 288 |
if (endtime > 0 && t >= endtime) {
| 289 |
error(WARNING, "time limit exceeded");
| 290 |
done_rtrace();
| 291 |
| 292 |
| 293 |
if (reporttime > 0 && t >= reporttime)
| 294 |
report(t);
| 295 |
idle = 0; /* get packets to process */
| 296 |
while (freepacks != NULL) {
| 297 |
p = freepacks; freepacks = p->next; p->next = NULL;
| 298 |
if (!next_packet(p)) {
| 299 |
p->next = freepacks; freepacks = p;
| 300 |
idle = 1;
| 301 |
break;
| 302 |
| 303 |
if (pl == NULL) pl = p;
| 304 |
else plend->next = p;
| 305 |
plend = p;
| 306 |
| 307 |
/* process packets */
| 308 |
done_packets(do_packets(pl));
| 309 |
return(1); /* and continue */
| 310 |
| 311 |
| 312 |
| 313 |
setdefaults(gp) /* set default values */
| 314 |
register HDGRID *gp;
| 315 |
| 316 |
extern char *atos();
| 317 |
register int i;
| 318 |
double len[3], maxlen, d;
| 319 |
char buf[64];
| 320 |
| 321 |
if (!vdef(SECTION)) {
| 322 |
sprintf(errmsg, "%s must be defined", vnam(SECTION));
| 323 |
| 324 |
| 325 |
if (vdef(SECTION) > 1) {
| 326 |
sprintf(errmsg, "ignoring all but first %s", vnam(SECTION));
| 327 |
error(WARNING, errmsg);
| 328 |
| 329 |
if (!vdef(OCTREE)) {
| 330 |
if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
| 331 |
error(SYSTEM, "out of memory");
| 332 |
sprintf(vval(OCTREE), "%s.oct", froot);
| 333 |
vdef(OCTREE)++;
| 334 |
| 335 |
if (!vdef(VDIST)) {
| 336 |
vval(VDIST) = "F";
| 337 |
vdef(VDIST)++;
| 338 |
| 339 |
/* append rendering options */
| 340 |
if (vdef(RENDER))
| 341 |
rtargc += wordstring(rtargv+rtargc, vval(RENDER));
| 342 |
| 343 |
if (gp == NULL) /* already initialized? */
| 344 |
return;
| 345 |
/* set grid parameters */
| 346 |
gp->grid[0] = gp->grid[1] = gp->grid[2] = 0;
| 347 |
if (sscanf(vval(SECTION),
| 348 |
"%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd",
| 349 |
&gp->orig[0], &gp->orig[1], &gp->orig[2],
| 350 |
&gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
| 351 |
&gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
| 352 |
&gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2],
| 353 |
&gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12)
| 354 |
badvalue(SECTION);
| 355 |
maxlen = 0.;
| 356 |
for (i = 0; i < 3; i++)
| 357 |
if ((len[i] = VLEN(gp->xv[i])) > maxlen)
| 358 |
maxlen = len[i];
| 359 |
if (!vdef(GRID)) {
| 360 |
sprintf(buf, "%.4f", maxlen/8.);
| 361 |
vval(GRID) = savqstr(buf);
| 362 |
vdef(GRID)++;
| 363 |
| 364 |
if ((d = vflt(GRID)) <= FTINY)
| 365 |
badvalue(GRID);
| 366 |
| 367 |
if (gp->grid[i] <= 0)
| 368 |
gp->grid[i] = len[i]/d + (1.-FTINY);
| 369 |
| 370 |
| 371 |
| 372 |
creatholo(gp) /* create a holodeck output file */
| 373 |
HDGRID *gp;
| 374 |
| 375 |
extern char VersionID[];
| 376 |
long endloc = 0;
| 377 |
int fd;
| 378 |
FILE *fp;
| 379 |
/* open & truncate file */
| 380 |
if ((fp = fopen(hdkfile, "w+")) == NULL) {
| 381 |
sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
| 382 |
error(SYSTEM, errmsg);
| 383 |
| 384 |
/* write information header */
| 385 |
newheader("RADIANCE", fp);
| 386 |
fprintf(fp, "SOFTWARE= %s\n", VersionID);
| 387 |
printvars(fp);
| 388 |
fputformat(HOLOFMT, fp);
| 389 |
fputc('\n', fp);
| 390 |
putw(HOLOMAGIC, fp); /* put magic number & terminus */
| 391 |
fwrite(&endloc, sizeof(long), 1, fp);
| 392 |
fd = dup(fileno(fp));
| 393 |
fclose(fp); /* flush and close stdio stream */
| 394 |
hdinit(fd, gp); /* allocate and initialize index */
| 395 |
| 396 |
| 397 |
| 398 |
headline(s) /* process information header line */
| 399 |
char *s;
| 400 |
| 401 |
extern char FMTSTR[];
| 402 |
register char *cp;
| 403 |
char fmt[32];
| 404 |
| 405 |
if (formatval(fmt, s)) {
| 406 |
if (strcmp(fmt, HOLOFMT)) {
| 407 |
sprintf(errmsg, "%s file \"%s\" has %s%s",
| 408 |
HOLOFMT, hdkfile, FMTSTR, fmt);
| 409 |
| 410 |
| 411 |
return;
| 412 |
| 413 |
for (cp = s; *cp; cp++) /* take off any comments */
| 414 |
if (*cp == '#') {
| 415 |
*cp = '\0';
| 416 |
break;
| 417 |
| 418 |
setvariable(s, matchvar); /* don't flag errors */
| 419 |
| 420 |
| 421 |
| 422 |
loadholo() /* start loading a holodeck from fname */
| 423 |
| 424 |
extern long ftell();
| 425 |
FILE *fp;
| 426 |
int fd;
| 427 |
long fpos;
| 428 |
/* open holodeck file */
| 429 |
if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) {
| 430 |
sprintf(errmsg, "cannot open \"%s\" for %s", hdkfile,
| 431 |
ncprocs>0 ? "appending" : "reading");
| 432 |
| 433 |
| 434 |
/* load variables from header */
| 435 |
getheader(fp, headline, NULL);
| 436 |
/* check magic number */
| 437 |
if (getw(fp) != HOLOMAGIC) {
| 438 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
| 439 |
hdkfile);
| 440 |
| 441 |
| 442 |
fread(&fpos, sizeof(long), 1, fp);
| 443 |
if (fpos != 0)
| 444 |
error(WARNING, "ignoring multiple sections in holodeck file");
| 445 |
fpos = ftell(fp); /* get stdio position */
| 446 |
| 447 |
fclose(fp); /* done with stdio */
| 448 |
lseek(fd, fpos, 0); /* align system file pointer */
| 449 |
hdinit(fd, NULL); /* allocate and load index */
| 450 |
| 451 |
| 452 |
| 453 |
done_packets(pl) /* handle finished packets */
| 454 |
PACKET *pl;
| 455 |
| 456 |
static int n2flush = 0;
| 457 |
register PACKET *p;
| 458 |
| 459 |
while (pl != NULL) {
| 460 |
p = pl; pl = p->next; p->next = NULL;
| 461 |
if (p->nr > 0) { /* add to holodeck */
| 462 |
bcopy((char *)p->ra,
| 463 |
(char *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
| 464 |
p->nr*sizeof(RAYVAL));
| 465 |
if (outdev != NULL) /* display it */
| 466 |
disp_packet((PACKHEAD *)p);
| 467 |
if (hdcachesize <= 0) /* manual flushing */
| 468 |
n2flush += p->nr;
| 469 |
nraysdone += p->nr;
| 470 |
npacksdone++;
| 471 |
| 472 |
p->nr = 0; /* push onto free list */
| 473 |
| 474 |
freepacks = p;
| 475 |
| 476 |
if (n2flush > 512*RPACKSIZ*nprocs) {
| 477 |
hdflush(NULL); /* flush holodeck buffers */
| 478 |
n2flush = 0;
| 479 |
| 480 |
| 481 |
| 482 |
| 483 |
rootname(rn, fn) /* remove tail from end of fn */
| 484 |
register char *rn, *fn;
| 485 |
| 486 |
char *tp, *dp;
| 487 |
| 488 |
for (tp = NULL, dp = rn; *rn = *fn++; rn++)
| 489 |
if (*rn == '/')
| 490 |
dp = rn;
| 491 |
else if (*rn == '.')
| 492 |
tp = rn;
| 493 |
if (tp != NULL && tp > dp)
| 494 |
*tp = '\0';
| 495 |
| 496 |
| 497 |
| 498 |
badvalue(vc) /* report bad variable value and exit */
| 499 |
int vc;
| 500 |
| 501 |
sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
| 502 |
| 503 |
| 504 |
| 505 |
| 506 |
eputs(s) /* put error message to stderr */
| 507 |
register char *s;
| 508 |
| 509 |
static int midline = 0;
| 510 |
| 511 |
if (!*s)
| 512 |
return;
| 513 |
if (!midline++) { /* prepend line with program name */
| 514 |
fputs(progname, stderr);
| 515 |
fputs(": ", stderr);
| 516 |
| 517 |
fputs(s, stderr);
| 518 |
if (s[strlen(s)-1] == '\n') {
| 519 |
fflush(stderr);
| 520 |
midline = 0;
| 521 |
| 522 |
| 523 |
| 524 |
| 525 |
wputs(s) /* put warning string to stderr */
| 526 |
char *s;
| 527 |
| 528 |
if (!nowarn)
| 529 |
eputs(s);
| 530 |
| 531 |
| 532 |
| 533 |
quit(ec) /* exit program gracefully */
| 534 |
int ec;
| 535 |
| 536 |
int status = 0;
| 537 |
| 538 |
if (hdlist[0] != NULL) { /* close holodeck */
| 539 |
if (nprocs > 0)
| 540 |
status = done_rtrace(); /* calls hdsync() */
| 541 |
if (ncprocs > 0 && vdef(REPORT)) {
| 542 |
long fsiz, fuse;
| 543 |
fsiz = hdfilen(hdlist[0]->fd);
| 544 |
fuse = hdfiluse(hdlist[0]->fd, 1);
| 545 |
fprintf(stderr,
| 546 |
"%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
| 547 |
hdkfile, fsiz/(1024.*1024.),
| 548 |
100.*(fsiz-fuse)/fsiz);
| 549 |
| 550 |
| 551 |
if (orig_mode >= 0) /* reset holodeck access mode */
| 552 |
fchmod(hdlist[0]->fd, orig_mode);
| 553 |
if (outdev != NULL) /* close display */
| 554 |
disp_close();
| 555 |
exit(ec ? ec : status); /* exit */
| 556 |
