| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Radiance holodeck generation controller
| 9 |
| 10 |
| 11 |
#include "rholo.h"
| 12 |
#include "paths.h"
| 13 |
#include <sys/types.h>
| 14 |
| 15 |
/* the following must be consistent with rholo.h */
| 16 |
int NVARS = NRHVARS; /* total number of variables */
| 17 |
| 18 |
VARIABLE vv[] = RHVINIT; /* variable-value pairs */
| 19 |
| 20 |
char *progname; /* our program name */
| 21 |
char *hdkfile; /* holodeck file name */
| 22 |
char froot[MAXPATH]; /* root file name */
| 23 |
| 24 |
int nowarn = 0; /* turn warnings off? */
| 25 |
| 26 |
double expval = 1.; /* global exposure value */
| 27 |
| 28 |
int ncprocs = 0; /* desired number of compute processes */
| 29 |
| 30 |
char *outdev = NULL; /* output device name */
| 31 |
| 32 |
time_t starttime; /* time we got started */
| 33 |
time_t endtime; /* time we should end by */
| 34 |
time_t reporttime; /* time for next report */
| 35 |
| 36 |
long maxdisk; /* maximum file space (bytes) */
| 37 |
| 38 |
int rtargc = 1; /* rtrace command */
| 39 |
char *rtargv[128] = {"rtrace", NULL};
| 40 |
| 41 |
long nraysdone = 0L; /* number of rays done */
| 42 |
long npacksdone = 0L; /* number of packets done */
| 43 |
| 44 |
PACKET *freepacks; /* available packets */
| 45 |
| 46 |
extern time_t time();
| 47 |
| 48 |
| 49 |
main(argc, argv)
| 50 |
int argc;
| 51 |
char *argv[];
| 52 |
| 53 |
HDGRID hdg;
| 54 |
int i;
| 55 |
int force = 0;
| 56 |
/* mark start time */
| 57 |
starttime = time(NULL);
| 58 |
progname = argv[0]; /* get arguments */
| 59 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 60 |
switch (argv[i][1]) {
| 61 |
case 'w': /* turn off warnings */
| 62 |
nowarn++;
| 63 |
break;
| 64 |
case 'f': /* force overwrite */
| 65 |
force++;
| 66 |
break;
| 67 |
case 'n': /* compute processes */
| 68 |
if (i >= argc-2)
| 69 |
goto userr;
| 70 |
ncprocs = atoi(argv[++i]);
| 71 |
break;
| 72 |
case 'o': /* output display */
| 73 |
if (i >= argc-2)
| 74 |
goto userr;
| 75 |
outdev = argv[++i];
| 76 |
break;
| 77 |
default:
| 78 |
goto userr;
| 79 |
| 80 |
/* do we have a job? */
| 81 |
if (outdev == NULL && ncprocs <= 0)
| 82 |
goto userr;
| 83 |
/* get root file name */
| 84 |
rootname(froot, hdkfile=argv[i++]);
| 85 |
/* load... */
| 86 |
if (i < argc) { /* variables */
| 87 |
loadvars(argv[i++]);
| 88 |
/* cmdline settings */
| 89 |
for ( ; i < argc; i++)
| 90 |
if (setvariable(argv[i], matchvar) < 0) {
| 91 |
sprintf(errmsg, "unknown variable: %s",
| 92 |
argv[i]);
| 93 |
error(USER, errmsg);
| 94 |
| 95 |
/* check settings */
| 96 |
checkvalues();
| 97 |
/* load RIF if any */
| 98 |
if (vdef(RIF))
| 99 |
getradfile(vval(RIF));
| 100 |
/* set defaults */
| 101 |
setdefaults(&hdg);
| 102 |
/* holodeck exists? */
| 103 |
if (!force && access(hdkfile, R_OK|W_OK) == 0)
| 104 |
error(USER,
| 105 |
"holodeck file exists -- use -f to overwrite");
| 106 |
/* create holodeck */
| 107 |
creatholo(&hdg);
| 108 |
} else { /* else load holodeck */
| 109 |
loadholo();
| 110 |
if (vdef(RIF)) /* load RIF if any */
| 111 |
| 112 |
| 113 |
/* initialize */
| 114 |
initrholo();
| 115 |
/* run */
| 116 |
while (rholo())
| 117 |
| 118 |
/* done */
| 119 |
quit(0);
| 120 |
userr:
| 121 |
fprintf(stderr,
| 122 |
"Usage: %s {-n nprocs|-o disp} [-w][-f] output.hdk [control.hif [VAR=val ..]]\n",
| 123 |
progname);
| 124 |
quit(1);
| 125 |
| 126 |
| 127 |
| 128 |
initrholo() /* get our holodeck running */
| 129 |
| 130 |
extern int global_packet();
| 131 |
register int i;
| 132 |
| 133 |
if (outdev != NULL) /* open output device */
| 134 |
disp_open(outdev);
| 135 |
else if (ncprocs > 0) /* else use global ray feed */
| 136 |
init_global();
| 137 |
/* record disk space limit */
| 138 |
if (!vdef(DISKSPACE))
| 139 |
maxdisk = 0;
| 140 |
else
| 141 |
maxdisk = 1024.*1024.*vflt(DISKSPACE);
| 142 |
/* record end time */
| 143 |
if (!vdef(TIME) || vflt(TIME) <= FTINY)
| 144 |
endtime = 0;
| 145 |
else
| 146 |
endtime = starttime + vflt(TIME)*3600.;
| 147 |
/* set up memory cache */
| 148 |
if (outdev == NULL)
| 149 |
hdcachesize = 0; /* manual flushing */
| 150 |
else if (vdef(CACHE))
| 151 |
hdcachesize = 1024.*1024.*vflt(CACHE);
| 152 |
/* open report file */
| 153 |
if (vdef(REPORT)) {
| 154 |
register char *s = sskip2(vval(REPORT), 1);
| 155 |
if (*s && freopen(s, "a", stderr) == NULL)
| 156 |
quit(2);
| 157 |
| 158 |
/* start rtrace */
| 159 |
if (ncprocs > 0) {
| 160 |
i = start_rtrace();
| 161 |
if (i < 1)
| 162 |
error(USER, "cannot start rtrace process");
| 163 |
if (vdef(REPORT)) { /* make first report */
| 164 |
printargs(rtargc, rtargv, stderr);
| 165 |
report(0);
| 166 |
| 167 |
/* allocate packets */
| 168 |
freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
| 169 |
if (freepacks == NULL)
| 170 |
goto memerr;
| 171 |
freepacks[--i].nr = 0;
| 172 |
freepacks[i].next = NULL;
| 173 |
if (!vbool(OBSTRUCTIONS)) {
| 174 |
freepacks[i].offset = (float *)bmalloc(
| 175 |
RPACKSIZ*sizeof(float)*(i+1) );
| 176 |
if (freepacks[i].offset == NULL)
| 177 |
goto memerr;
| 178 |
} else
| 179 |
freepacks[i].offset = NULL;
| 180 |
while (i--) {
| 181 |
freepacks[i].nr = 0;
| 182 |
freepacks[i].offset = freepacks[i+1].offset == NULL ?
| 183 |
NULL : freepacks[i+1].offset+RPACKSIZ ;
| 184 |
freepacks[i].next = &freepacks[i+1];
| 185 |
| 186 |
| 187 |
return;
| 188 |
memerr:
| 189 |
error(SYSTEM, "out of memory in initrholo");
| 190 |
| 191 |
| 192 |
| 193 |
rholo() /* holodeck main loop */
| 194 |
| 195 |
static int idle = 1;
| 196 |
PACKET *pl = NULL, *plend;
| 197 |
register PACKET *p;
| 198 |
time_t t;
| 199 |
long l;
| 200 |
| 201 |
if (outdev != NULL) /* check display */
| 202 |
if (!disp_check(idle))
| 203 |
return(0);
| 204 |
/* display only? */
| 205 |
if (ncprocs <= 0)
| 206 |
return(1);
| 207 |
/* check file size */
| 208 |
if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) {
| 209 |
error(WARNING, "file limit exceeded");
| 210 |
return(0);
| 211 |
| 212 |
/* check time */
| 213 |
if (endtime > 0 || reporttime > 0)
| 214 |
t = time(NULL);
| 215 |
if (endtime > 0 && t >= endtime) {
| 216 |
error(WARNING, "time limit exceeded");
| 217 |
return(0);
| 218 |
| 219 |
if (reporttime > 0 && t >= reporttime)
| 220 |
report(t);
| 221 |
/* get packets to process */
| 222 |
while (freepacks != NULL) {
| 223 |
p = freepacks; freepacks = p->next; p->next = NULL;
| 224 |
if (!next_packet(p)) {
| 225 |
p->next = freepacks; freepacks = p;
| 226 |
break;
| 227 |
| 228 |
if (pl == NULL) pl = p;
| 229 |
else plend->next = p;
| 230 |
plend = p;
| 231 |
| 232 |
idle = pl == NULL && freepacks != NULL;
| 233 |
/* are we out of stuff to do? */
| 234 |
if (idle && outdev == NULL)
| 235 |
return(0);
| 236 |
/* else process packets */
| 237 |
done_packets(do_packets(pl));
| 238 |
return(1); /* and continue */
| 239 |
| 240 |
| 241 |
| 242 |
report(t) /* report progress so far */
| 243 |
time_t t;
| 244 |
| 245 |
if (t == 0)
| 246 |
t = time(NULL);
| 247 |
fprintf(stderr, "%s: %ld packets (%ld rays) done after %.2f hours\n",
| 248 |
progname, npacksdone, nraysdone, (t-starttime)/3600.);
| 249 |
fflush(stderr);
| 250 |
if (vdef(REPORT))
| 251 |
reporttime = t + (time_t)(vflt(REPORT)*60.+.5);
| 252 |
| 253 |
| 254 |
| 255 |
setdefaults(gp) /* set default values */
| 256 |
register HDGRID *gp;
| 257 |
| 258 |
extern char *atos();
| 259 |
register int i;
| 260 |
double len[3], maxlen, d;
| 261 |
char buf[64];
| 262 |
| 263 |
if (!vdef(SECTION)) {
| 264 |
sprintf(errmsg, "%s must be defined", vnam(SECTION));
| 265 |
| 266 |
| 267 |
if (vdef(SECTION) > 1) {
| 268 |
sprintf(errmsg, "ignoring all but first %s", vnam(SECTION));
| 269 |
error(WARNING, errmsg);
| 270 |
| 271 |
if (sscanf(vval(SECTION),
| 272 |
"%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf",
| 273 |
&gp->orig[0], &gp->orig[1], &gp->orig[2],
| 274 |
&gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
| 275 |
&gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
| 276 |
&gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2]) != 12)
| 277 |
badvalue(SECTION);
| 278 |
maxlen = 0.;
| 279 |
for (i = 0; i < 3; i++)
| 280 |
if ((len[i] = VLEN(gp->xv[i])) > maxlen)
| 281 |
maxlen = len[i];
| 282 |
if (!vdef(GRID)) {
| 283 |
sprintf(buf, "%.4f", maxlen/8.);
| 284 |
vval(GRID) = savqstr(buf);
| 285 |
vdef(GRID)++;
| 286 |
| 287 |
if ((d = vflt(GRID)) <= FTINY)
| 288 |
badvalue(GRID);
| 289 |
| 290 |
gp->grid[i] = len[i]/d + (1.-FTINY);
| 291 |
if (!vdef(EXPOSURE)) {
| 292 |
sprintf(errmsg, "%s must be defined", vnam(EXPOSURE));
| 293 |
| 294 |
| 295 |
expval = vval(EXPOSURE)[0] == '-' || vval(EXPOSURE)[0] == '+' ?
| 296 |
pow(2., vflt(EXPOSURE)) : vflt(EXPOSURE);
| 297 |
if (!vdef(OCTREE)) {
| 298 |
if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
| 299 |
error(SYSTEM, "out of memory");
| 300 |
sprintf(vval(OCTREE), "%s.oct", froot);
| 301 |
vdef(OCTREE)++;
| 302 |
| 303 |
if (!vdef(OBSTRUCTIONS)) {
| 304 |
vval(OBSTRUCTIONS) = "T";
| 305 |
vdef(OBSTRUCTIONS)++;
| 306 |
| 307 |
if (!vdef(OCCUPANCY)) {
| 308 |
vval(OCCUPANCY) = "U";
| 309 |
vdef(OCCUPANCY)++;
| 310 |
| 311 |
/* append rendering options */
| 312 |
if (vdef(RENDER))
| 313 |
rtargc += wordstring(rtargv+rtargc, vval(RENDER));
| 314 |
| 315 |
| 316 |
| 317 |
creatholo(gp) /* create a holodeck output file */
| 318 |
HDGRID *gp;
| 319 |
| 320 |
long endloc = 0;
| 321 |
int fd;
| 322 |
FILE *fp;
| 323 |
/* open & truncate file */
| 324 |
if ((fp = fopen(hdkfile, "w+")) == NULL) {
| 325 |
sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
| 326 |
error(SYSTEM, errmsg);
| 327 |
| 328 |
/* write information header */
| 329 |
newheader("RADIANCE", fp);
| 330 |
printvars(fp);
| 331 |
fputformat(HOLOFMT, fp);
| 332 |
fputc('\n', fp);
| 333 |
putw(HOLOMAGIC, fp); /* put magic number & terminus */
| 334 |
fwrite(&endloc, sizeof(long), 1, fp);
| 335 |
fd = dup(fileno(fp));
| 336 |
fclose(fp); /* flush and close stdio stream */
| 337 |
hdinit(fd, gp); /* allocate and initialize index */
| 338 |
| 339 |
| 340 |
| 341 |
headline(s) /* process information header line */
| 342 |
char *s;
| 343 |
| 344 |
extern char FMTSTR[];
| 345 |
register char *cp;
| 346 |
char fmt[32];
| 347 |
| 348 |
if (formatval(fmt, s)) {
| 349 |
if (strcmp(fmt, HOLOFMT)) {
| 350 |
sprintf(errmsg, "%s file \"%s\" has %s%s",
| 351 |
HOLOFMT, hdkfile, FMTSTR, fmt);
| 352 |
| 353 |
| 354 |
return;
| 355 |
| 356 |
for (cp = s; *cp; cp++) /* take off any comments */
| 357 |
if (*cp == '#') {
| 358 |
*cp = '\0';
| 359 |
break;
| 360 |
| 361 |
setvariable(s, matchvar); /* don't flag errors */
| 362 |
| 363 |
| 364 |
| 365 |
loadholo() /* start loading a holodeck from fname */
| 366 |
| 367 |
extern long ftell();
| 368 |
FILE *fp;
| 369 |
int fd;
| 370 |
long fpos;
| 371 |
/* open holodeck file */
| 372 |
if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) {
| 373 |
sprintf(errmsg, "cannot open \"%s\" for %s", hdkfile,
| 374 |
ncprocs>0 ? "appending" : "reading");
| 375 |
| 376 |
| 377 |
/* load variables from header */
| 378 |
getheader(fp, headline, NULL);
| 379 |
/* check magic number */
| 380 |
if (getw(fp) != HOLOMAGIC) {
| 381 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
| 382 |
hdkfile);
| 383 |
| 384 |
| 385 |
fread(&fpos, sizeof(long), 1, fp);
| 386 |
if (fpos != 0)
| 387 |
error(WARNING, "ignoring multiple sections in holodeck file");
| 388 |
fpos = ftell(fp); /* get stdio position */
| 389 |
| 390 |
fclose(fp); /* done with stdio */
| 391 |
lseek(fd, fpos, 0); /* align system file pointer */
| 392 |
hdinit(fd, NULL); /* allocate and load index */
| 393 |
| 394 |
| 395 |
| 396 |
done_packets(pl) /* handle finished packets */
| 397 |
PACKET *pl;
| 398 |
| 399 |
static int nunflushed = 0;
| 400 |
register PACKET *p;
| 401 |
| 402 |
while (pl != NULL) {
| 403 |
p = pl; pl = p->next; p->next = NULL;
| 404 |
if (p->nr > 0) { /* add to holodeck */
| 405 |
bcopy((char *)p->ra,
| 406 |
(char *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
| 407 |
p->nr*sizeof(RAYVAL));
| 408 |
if (outdev != NULL) /* display it */
| 409 |
disp_packet((PACKHEAD *)p);
| 410 |
else
| 411 |
nunflushed += p->nr;
| 412 |
nraysdone += p->nr;
| 413 |
npacksdone++;
| 414 |
| 415 |
p->nr = 0; /* push onto free list */
| 416 |
| 417 |
freepacks = p;
| 418 |
| 419 |
if (nunflushed >= 256*RPACKSIZ) {
| 420 |
hdflush(NULL); /* flush holodeck buffers */
| 421 |
nunflushed = 0;
| 422 |
| 423 |
| 424 |
| 425 |
| 426 |
getradfile(rfargs) /* run rad and get needed variables */
| 427 |
char *rfargs;
| 428 |
| 429 |
static short mvar[] = {OCTREE,EXPOSURE,-1};
| 430 |
static char tf1[] = TEMPLATE;
| 431 |
char tf2[64];
| 432 |
char combuf[256];
| 433 |
char *pippt;
| 434 |
register int i;
| 435 |
register char *cp;
| 436 |
/* create rad command */
| 437 |
mktemp(tf1);
| 438 |
sprintf(tf2, "%s.rif", tf1);
| 439 |
sprintf(combuf,
| 440 |
"rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
| 441 |
rfargs, tf1);
| 442 |
cp = combuf;
| 443 |
while (*cp){
| 444 |
if (*cp == '|') pippt = cp;
| 445 |
cp++;
| 446 |
} /* match unset variables */
| 447 |
for (i = 0; mvar[i] >= 0; i++)
| 448 |
if (!vdef(mvar[i])) {
| 449 |
*cp++ = '|';
| 450 |
strcpy(cp, vnam(mvar[i]));
| 451 |
while (*cp) cp++;
| 452 |
pippt = NULL;
| 453 |
| 454 |
if (pippt != NULL)
| 455 |
strcpy(pippt, "> /dev/null"); /* nothing to match */
| 456 |
else
| 457 |
sprintf(cp, ")[ \t]*=' > %s", tf2);
| 458 |
if (system(combuf)) {
| 459 |
error(SYSTEM, "cannot execute rad command");
| 460 |
unlink(tf2); /* clean up */
| 461 |
unlink(tf1);
| 462 |
quit(1);
| 463 |
| 464 |
if (pippt == NULL) {
| 465 |
loadvars(tf2); /* load variables */
| 466 |
unlink(tf2);
| 467 |
| 468 |
rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */
| 469 |
unlink(tf1); /* clean up */
| 470 |
| 471 |
| 472 |
| 473 |
rootname(rn, fn) /* remove tail from end of fn */
| 474 |
register char *rn, *fn;
| 475 |
| 476 |
char *tp, *dp;
| 477 |
| 478 |
for (tp = NULL, dp = rn; *rn = *fn++; rn++)
| 479 |
if (ISDIRSEP(*rn))
| 480 |
dp = rn;
| 481 |
else if (*rn == '.')
| 482 |
tp = rn;
| 483 |
if (tp != NULL && tp > dp)
| 484 |
*tp = '\0';
| 485 |
| 486 |
| 487 |
| 488 |
badvalue(vc) /* report bad variable value and exit */
| 489 |
int vc;
| 490 |
| 491 |
sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
| 492 |
| 493 |
| 494 |
| 495 |
| 496 |
eputs(s) /* put error message to stderr */
| 497 |
register char *s;
| 498 |
| 499 |
static int midline = 0;
| 500 |
| 501 |
if (!*s)
| 502 |
return;
| 503 |
if (!midline++) { /* prepend line with program name */
| 504 |
fputs(progname, stderr);
| 505 |
fputs(": ", stderr);
| 506 |
| 507 |
fputs(s, stderr);
| 508 |
if (s[strlen(s)-1] == '\n') {
| 509 |
fflush(stderr);
| 510 |
midline = 0;
| 511 |
| 512 |
| 513 |
| 514 |
| 515 |
wputs(s) /* put warning string to stderr */
| 516 |
char *s;
| 517 |
| 518 |
if (!nowarn)
| 519 |
eputs(s);
| 520 |
| 521 |
| 522 |
| 523 |
quit(ec) /* exit program gracefully */
| 524 |
int ec;
| 525 |
| 526 |
int status = 0;
| 527 |
| 528 |
if (hdlist[0] != NULL) { /* flush holodeck */
| 529 |
if (ncprocs > 0) {
| 530 |
done_packets(flush_queue());
| 531 |
status = end_rtrace(); /* close rtrace */
| 532 |
hdflush(NULL);
| 533 |
if (vdef(REPORT)) {
| 534 |
long fsiz, fuse;
| 535 |
report(0);
| 536 |
fsiz = hdfilen(hdlist[0]->fd);
| 537 |
fuse = hdfiluse(hdlist[0]->fd, 1);
| 538 |
fprintf(stderr,
| 539 |
"%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
| 540 |
hdkfile, fsiz/(1024.*1024.),
| 541 |
100.*(fsiz-fuse)/fsiz);
| 542 |
| 543 |
} else
| 544 |
hdflush(NULL);
| 545 |
| 546 |
if (outdev != NULL) /* close display */
| 547 |
disp_close();
| 548 |
exit(ec ? ec : status); /* exit */
| 549 |
