--- ray/src/hd/rholo.c 1998/01/10 16:37:10 3.36 +++ ray/src/hd/rholo.c 2005/12/21 07:26:29 3.72 @@ -1,22 +1,36 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo.c,v 3.72 2005/12/21 07:26:29 greg Exp $"; #endif - /* * Radiance holodeck generation controller */ -#include "rholo.h" -#include "random.h" +#include +#include #include -#include #include +#include +#include "platform.h" +#include "rterror.h" +#include "resolu.h" +#include "rholo.h" +#include "random.h" + +#ifndef FRAGWARN +#define FRAGWARN 20 /* fragmentation for warning (%) */ +#endif #ifndef MAXQTIME #define MAXQTIME 5 /* target maximum seconds in queue */ #endif + /* manual cache flushing frequency */ +#ifndef RTFLUSH +#if MAXQTIME +#define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */ +#else +#define RTFLUSH (50*totqlen) /* just guess */ +#endif +#endif /* the following must be consistent with rholo.h */ int NVARS = NRHVARS; /* total number of variables */ @@ -26,21 +40,19 @@ char *progname; /* our program name */ char *hdkfile; /* holodeck file name */ char froot[256]; /* root file name */ -int nowarn = 0; /* turn warnings off? */ - int ncprocs = 0; /* desired number of compute processes */ char *outdev = NULL; /* output device name */ int readinp = 0; /* read commands from stdin */ -int force = 0; /* allow overwrite of holodeck */ +int force = 0; /* allow overwrite of holodeck (-1 == read-only) */ time_t starttime; /* time we got started */ time_t endtime; /* time we should end by */ time_t reporttime; /* time for next report */ -long maxdisk; /* maximum file space (bytes) */ +off_t maxdisk; /* maximum file space (bytes) */ int rtargc = 1; /* rtrace command */ char *rtargv[128] = {"rtrace", NULL}; @@ -51,20 +63,33 @@ long nraysdone = 0L; /* number of rays done */ long npacksdone = 0L; /* number of packets done */ PACKET *freepacks; /* available packets */ -int avgqlen; /* average queue length when full */ +int totqlen; /* maximum queue length (number of packets) */ char *sigerr[NSIG]; /* signal error messages */ -extern time_t time(); +extern int nowarn; /* turn warnings off? */ +static void onsig(int signo); +static void sigdie(int signo, char *msg); +static int resfmode(int fd, int mod); +static void initrholo(void); +static int rholo(void); +static void setdefaults(HDGRID *gp); +static void creatholo(HDGRID *gp); +static gethfunc headline; +static void loadholo(void); +static void rootname(char *rn, char *fn); +static void badvalue(int vc); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { int i; - initurand(16384); /* initialize urand */ progname = argv[0]; /* get arguments */ for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { @@ -72,8 +97,11 @@ char *argv[]; nowarn++; break; case 'f': /* force overwrite */ - force++; + force = 1; break; + case 'r': /* read-only mode */ + force = -1; + break; case 'i': /* read input from stdin */ readinp++; break; @@ -116,6 +144,9 @@ char *argv[]; HDGRID hdg[HDMAX]; /* set defaults */ setdefaults(hdg); + /* check read-only */ + if (force < 0) + error(USER, "cannot create read-only holodeck"); /* holodeck exists? */ if (!force && access(hdkfile, R_OK|W_OK) == 0) error(USER, @@ -133,22 +164,27 @@ char *argv[]; quit(0); userr: fprintf(stderr, -"Usage: %s [-n nprocs][-o disp][-w][-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", +"Usage: %s [-n nprocs][-o disp][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", progname); quit(1); + return 1; /* pro forma return */ } -onsig(signo) /* fatal signal */ -int signo; +static void +onsig( /* fatal signal */ + int signo +) { static int gotsig = 0; - if (gotsig++) /* two signals and we're gone! */ + if (gotsig > 1) /* we're going as fast as we can! */ + return; + if (gotsig++) { /* two signals and we split */ + hdsync(NULL, 0); /* don't leave w/o saying goodbye */ _exit(signo); - - alarm(60); /* allow 60 seconds to clean up */ - signal(SIGALRM, SIG_DFL); /* make certain we do die */ + } + alarm(300); /* allow 5 minutes to clean up */ eputs("signal - "); eputs(sigerr[signo]); eputs("\n"); @@ -156,9 +192,11 @@ int signo; } -sigdie(signo, msg) /* set fatal signal */ -int signo; -char *msg; +static void +sigdie( /* set fatal signal */ + int signo, + char *msg +) { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); @@ -166,9 +204,11 @@ char *msg; } -int -resfmode(fd, mod) /* restrict open file access mode */ -int fd, mod; +static int +resfmode( /* restrict open file access mode */ + int fd, + int mod +) { struct stat stbuf; /* get original mode */ @@ -186,7 +226,8 @@ int fd, mod; } -initrholo() /* get our holodeck running */ +static void +initrholo(void) /* get our holodeck running */ { extern int global_packet(); register int i; @@ -199,12 +240,12 @@ initrholo() /* get our holodeck running */ init_global(); /* record disk space limit */ if (!vdef(DISKSPACE)) - maxdisk = 0; + maxdisk = ((off_t)1<<(sizeof(off_t)*8-2)) - 1024; else maxdisk = 1024.*1024.*vflt(DISKSPACE); /* set up memory cache */ if (outdev == NULL) - hdcachesize = 0; /* manual flushing */ + hdcachesize = 0; /* manual flushing */ else if (vdef(CACHE)) hdcachesize = 1024.*1024.*vflt(CACHE); /* open report file */ @@ -222,7 +263,7 @@ initrholo() /* get our holodeck running */ endtime = starttime + vflt(TIME)*3600. + .5; /* start rtrace */ if (ncprocs > 0) { - i = start_rtrace(); + totqlen = i = start_rtrace(); if (i < 1) error(USER, "cannot start rtrace process(es)"); if (vdef(REPORT)) { /* make first report */ @@ -233,8 +274,6 @@ initrholo() /* get our holodeck running */ freepacks = (PACKET *)bmalloc(i*sizeof(PACKET)); if (freepacks == NULL) goto memerr; - if (!(avgqlen = i/nprocs)) /* record mean queue length */ - avgqlen = 1; freepacks[--i].nr = 0; freepacks[i].next = NULL; if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) { @@ -253,26 +292,37 @@ initrholo() /* get our holodeck running */ } /* set up signal handling */ sigdie(SIGINT, "Interrupt"); - sigdie(SIGHUP, "Hangup"); sigdie(SIGTERM, "Terminate"); +#ifdef SIGHUP + sigdie(SIGHUP, "Hangup"); +#endif +#ifdef SIGPIPE sigdie(SIGPIPE, "Broken pipe"); +#endif +#ifdef SIGALRM sigdie(SIGALRM, "Alarm clock"); +#endif #ifdef SIGXCPU sigdie(SIGXCPU, "CPU limit exceeded"); +#endif +#ifdef SIGXFSZ sigdie(SIGXFSZ, "File size exceeded"); #endif - /* protect holodeck file */ - orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444); + /* protect holodeck file */ + orig_mode = resfmode(hdlist[0]->fd, (ncprocs>0) & (force>=0) ? 0 : 0444); return; memerr: error(SYSTEM, "out of memory in initrholo"); } -rholo() /* holodeck main loop */ +static int +rholo(void) /* holodeck main loop */ { + static off_t nextfragwarn = 100L<<20; static int idle = 0; PACKET *pl = NULL, *plend; + off_t fsiz; int pksiz; register PACKET *p; time_t t; @@ -286,28 +336,41 @@ rholo() /* holodeck main loop */ return(1); } else if (idle) return(0); /* all done */ - /* check file size */ - if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { - error(WARNING, "file limit exceeded"); + fsiz = hdfilen(hdlist[0]->fd); /* check file size */ + if (maxdisk > 0 && fsiz >= maxdisk) { + error(USER, "file limit exceeded"); done_rtrace(); return(1); /* comes back */ } +#if FRAGWARN + if (fsiz >= nextfragwarn) { + double pctfrag = 100.*(fsiz-hdfiluse(hdlist[0]->fd))/fsiz; + if (pctfrag >= (double)FRAGWARN) { + sprintf(errmsg, "holodeck file fragmentation is %.0f%%", + pctfrag); + error(WARNING, errmsg); + nextfragwarn = fsiz + (fsiz>>2); + } else + nextfragwarn = fsiz + (10L<<20); + } +#endif t = time(NULL); /* check time */ if (endtime > 0 && t >= endtime) { - error(WARNING, "time limit exceeded"); + error(USER, "time limit exceeded"); done_rtrace(); return(1); /* comes back */ } if (reporttime > 0 && t >= reporttime) report(t); /* figure out good packet size */ + pksiz = RPACKSIZ; #if MAXQTIME - pksiz = nraysdone*MAXQTIME/(avgqlen*(t - starttime + 1L)); - if (pksiz < 1) - pksiz = 1; - else if (pksiz > RPACKSIZ) + if (!chunkycmp) { + pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L)); + if (pksiz < 1) pksiz = 1; + else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ; + } #endif - pksiz = RPACKSIZ; idle = 0; /* get packets to process */ while (freepacks != NULL) { p = freepacks; freepacks = p->next; p->next = NULL; @@ -326,14 +389,15 @@ rholo() /* holodeck main loop */ } -setdefaults(gp) /* set default values */ -register HDGRID *gp; +static void +setdefaults( /* set default values */ + register HDGRID *gp +) { extern char *atos(); register int i; int n; - double len[3], maxlen, d; - char buf[64]; + double len[3], d; if (!vdef(SECTION)) { sprintf(errmsg, "%s must be defined", vnam(SECTION)); @@ -366,13 +430,15 @@ register HDGRID *gp; &gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2], &gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12) badvalue(SECTION); - maxlen = 0.; for (i = 0; i < 3; i++) - if ((len[i] = VLEN(gp->xv[i])) > maxlen) - maxlen = len[i]; - if (!vdef(GRID)) - d = 0.125*maxlen; - else if ((d = vflt(GRID)) <= FTINY) + len[i] = VLEN(gp->xv[i]); + if (!vdef(GRID)) { + d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] + + len[2]*len[2] + 4*len[1]*len[2]) + + len[1]*len[1]*len[2]*(len[2] + 4*len[0]) + + 4*len[0]*len[1]*len[2]*len[2] ); + d = sqrt(sqrt(d)); + } else if ((d = vflt(GRID)) <= FTINY) badvalue(GRID); for (i = 0; i < 3; i++) if (gp->grid[i] <= 0) @@ -381,11 +447,13 @@ register HDGRID *gp; } -creatholo(gp) /* create a holodeck output file */ -HDGRID *gp; +static void +creatholo( /* create a holodeck output file */ + HDGRID *gp +) { extern char VersionID[]; - int4 lastloc, nextloc; + int32 lastloc, nextloc; int n; int fd; FILE *fp; @@ -403,7 +471,7 @@ HDGRID *gp; putw(HOLOMAGIC, fp); /* put magic number */ fd = dup(fileno(fp)); fclose(fp); /* flush and close stdio stream */ - lastloc = lseek(fd, 0L, 2); + lastloc = lseek(fd, (off_t)0, SEEK_END); for (n = vdef(SECTION); n--; gp++) { /* initialize each section */ nextloc = 0L; write(fd, (char *)&nextloc, sizeof(nextloc)); @@ -411,17 +479,20 @@ HDGRID *gp; if (!n) break; nextloc = hdfilen(fd); /* write section pointer */ - if (lseek(fd, (long)lastloc, 0) < 0) + if (lseek(fd, (off_t)lastloc, SEEK_SET) < 0) error(SYSTEM, "cannot seek on holodeck file in creatholo"); write(fd, (char *)&nextloc, sizeof(nextloc)); - lseek(fd, (long)(lastloc=nextloc), 0); + lseek(fd, (off_t)(lastloc=nextloc), SEEK_SET); } } -headline(s) /* process information header line */ -char *s; +static int +headline( /* process information header line */ + char *s, + void *p +) { extern char FMTSTR[]; register char *cp; @@ -433,7 +504,7 @@ char *s; HOLOFMT, hdkfile, FMTSTR, fmt); error(USER, errmsg); } - return; + return(0); } for (cp = s; *cp; cp++) /* take off any comments */ if (*cp == '#') { @@ -441,21 +512,35 @@ char *s; break; } setvariable(s, matchvar); /* don't flag errors */ + return(0); } -loadholo() /* start loading a holodeck from fname */ +static void +loadholo(void) /* start loading a holodeck from fname */ { - extern long ftell(); FILE *fp; int fd; int n; - int4 nextloc; - /* open holodeck file */ - if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) { - sprintf(errmsg, "cannot open \"%s\" for %s", hdkfile, - ncprocs>0 ? "appending" : "reading"); - error(SYSTEM, errmsg); + int32 nextloc; + + if ((ncprocs > 0) & (force >= 0)) + fp = fopen(hdkfile, "r+"); + else + fp = NULL; + if (fp == NULL) { + if ((fp = fopen(hdkfile, "r")) == NULL) { + sprintf(errmsg, "cannot open \"%s\"", hdkfile); + error(SYSTEM, errmsg); + } + if (ncprocs > 0) { + sprintf(errmsg, "\"%s\" is read-only", hdkfile); + if (outdev == NULL) + error(USER, errmsg); + strcat(errmsg, "; new rays will be discarded"); + error(WARNING, errmsg); + force = -1; + } } /* load variables from header */ getheader(fp, headline, NULL); @@ -469,7 +554,7 @@ loadholo() /* start loading a holodeck from fname */ fd = dup(fileno(fp)); fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, (long)nextloc, 0); + lseek(fd, (off_t)nextloc, SEEK_SET); read(fd, (char *)&nextloc, sizeof(nextloc)); hdinit(fd, NULL); } @@ -481,8 +566,10 @@ loadholo() /* start loading a holodeck from fname */ } -done_packets(pl) /* handle finished packets */ -PACKET *pl; +extern void +done_packets( /* handle finished packets */ + PACKET *pl +) { static int n2flush = 0; register PACKET *p; @@ -490,12 +577,12 @@ PACKET *pl; while (pl != NULL) { p = pl; pl = p->next; p->next = NULL; if (p->nr > 0) { /* add to holodeck */ - bcopy((char *)p->ra, - (char *)hdnewrays(hdlist[p->hd],p->bi,p->nr), + memcpy( (void *)hdnewrays(hdlist[p->hd],p->bi,p->nr), + (void *)p->ra, p->nr*sizeof(RAYVAL)); if (outdev != NULL) /* display it */ disp_packet((PACKHEAD *)p); - if (hdcachesize <= 0) /* manual flushing */ + if (hdcachesize <= 0) n2flush++; nraysdone += p->nr; npacksdone++; @@ -504,36 +591,46 @@ PACKET *pl; p->next = freepacks; /* push onto free list */ freepacks = p; } - if (n2flush > 300/MAXQTIME*avgqlen*nprocs) { - hdflush(NULL); /* flush holodeck buffers */ + if (n2flush >= RTFLUSH) { + if (outdev != NULL) + hdsync(NULL, 1); + else + hdflush(NULL); n2flush = 0; } } -rootname(rn, fn) /* remove tail from end of fn */ -register char *rn, *fn; +static void +rootname( /* remove tail from end of fn */ + register char *rn, + register char *fn +) { char *tp, *dp; - for (tp = NULL, dp = rn; *rn = *fn++; rn++) + for (tp = NULL, dp = rn; (*rn = *fn++); rn++) { if (*rn == '/') dp = rn; else if (*rn == '.') tp = rn; + } if (tp != NULL && tp > dp) *tp = '\0'; } -badvalue(vc) /* report bad variable value and exit */ -int vc; +static void +badvalue( /* report bad variable value and exit */ + int vc +) { sprintf(errmsg, "bad value for variable '%s'", vnam(vc)); error(USER, errmsg); } +void eputs(s) /* put error message to stderr */ register char *s; { @@ -553,14 +650,7 @@ register char *s; } -wputs(s) /* put warning string to stderr */ -char *s; -{ - if (!nowarn) - eputs(s); -} - - +void quit(ec) /* exit program gracefully */ int ec; { @@ -569,10 +659,10 @@ int ec; if (hdlist[0] != NULL) { /* close holodeck */ if (nprocs > 0) status = done_rtrace(); /* calls hdsync() */ - if (ncprocs > 0 && vdef(REPORT)) { - long fsiz, fuse; + if ((ncprocs > 0) & (force >= 0) && vdef(REPORT)) { + off_t fsiz, fuse; fsiz = hdfilen(hdlist[0]->fd); - fuse = hdfiluse(hdlist[0]->fd, 1); + fuse = hdfiluse(hdlist[0]->fd); fprintf(stderr, "%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n", hdkfile, fsiz/(1024.*1024.),
