--- ray/src/hd/rholo.c 2003/05/13 17:58:33 3.53 +++ ray/src/hd/rholo.c 2003/06/21 14:48:54 3.58 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rholo.c,v 3.53 2003/05/13 17:58:33 greg Exp $"; +static const char RCSid[] = "$Id: rholo.c,v 3.58 2003/06/21 14:48:54 greg Exp $"; #endif /* * Radiance holodeck generation controller @@ -45,7 +45,7 @@ time_t starttime; /* time we got started */ time_t endtime; /* time we should end by */ time_t reporttime; /* time for next report */ -long maxdisk; /* maximum file space (bytes) */ +off_t maxdisk; /* maximum file space (bytes) */ int rtargc = 1; /* rtrace command */ char *rtargv[128] = {"rtrace", NULL}; @@ -152,6 +152,7 @@ userr: } +void onsig(signo) /* fatal signal */ int signo; { @@ -214,7 +215,7 @@ initrholo() /* get our holodeck running */ init_global(); /* record disk space limit */ if (!vdef(DISKSPACE)) - maxdisk = (1L<<(sizeof(long)*8-2)) - 1024; + maxdisk = ((off_t)1<<(sizeof(off_t)*8-2)) - 1024; else maxdisk = 1024.*1024.*vflt(DISKSPACE); /* set up memory cache */ @@ -287,7 +288,7 @@ rholo() /* holodeck main loop */ static long nextfragwarn = 100*(1L<<20); static int idle = 0; PACKET *pl = NULL, *plend; - long fsiz; + off_t fsiz; int pksiz; register PACKET *p; time_t t; @@ -412,7 +413,7 @@ creatholo(gp) /* create a holodeck output file */ HDGRID *gp; { extern char VersionID[]; - int4 lastloc, nextloc; + int32 lastloc, nextloc; int n; int fd; FILE *fp; @@ -430,7 +431,7 @@ HDGRID *gp; putw(HOLOMAGIC, fp); /* put magic number */ fd = dup(fileno(fp)); fclose(fp); /* flush and close stdio stream */ - lastloc = lseek(fd, (off_t)0L, 2); + lastloc = lseek(fd, (off_t)0, 2); for (n = vdef(SECTION); n--; gp++) { /* initialize each section */ nextloc = 0L; write(fd, (char *)&nextloc, sizeof(nextloc)); @@ -475,11 +476,10 @@ char *s; loadholo() /* start loading a holodeck from fname */ { - extern long ftell(); FILE *fp; int fd; int n; - int4 nextloc; + int32 nextloc; if (ncprocs > 0 & force >= 0) fp = fopen(hdkfile, "r+"); @@ -608,7 +608,7 @@ int ec; if (nprocs > 0) status = done_rtrace(); /* calls hdsync() */ if (ncprocs > 0 & force >= 0 && vdef(REPORT)) { - long fsiz, fuse; + off_t fsiz, fuse; fsiz = hdfilen(hdlist[0]->fd); fuse = hdfiluse(hdlist[0]->fd, 1); fprintf(stderr,
