--- ray/src/hd/rholo.c 1998/10/08 14:52:26 3.41 +++ ray/src/hd/rholo.c 1999/08/05 19:20:10 3.51 @@ -1,4 +1,4 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ +/* Copyright (c) 1999 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ SGI"; @@ -11,12 +11,22 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rholo.h" #include "random.h" #include -#include #include +#ifndef FRAGWARN +#define FRAGWARN 20 /* fragmentation for warning (%) */ +#endif #ifndef MAXQTIME #define MAXQTIME 5 /* target maximum seconds in queue */ #endif + /* manual cache flushing frequency */ +#ifndef RTFLUSH +#if MAXQTIME +#define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */ +#else +#define RTFLUSH (50*totqlen) /* just guess */ +#endif +#endif /* the following must be consistent with rholo.h */ int NVARS = NRHVARS; /* total number of variables */ @@ -32,7 +42,7 @@ char *outdev = NULL; /* output device name */ int readinp = 0; /* read commands from stdin */ -int force = 0; /* allow overwrite of holodeck */ +int force = 0; /* allow overwrite of holodeck (-1 == read-only) */ time_t starttime; /* time we got started */ time_t endtime; /* time we should end by */ @@ -49,7 +59,7 @@ long nraysdone = 0L; /* number of rays done */ long npacksdone = 0L; /* number of packets done */ PACKET *freepacks; /* available packets */ -int totqlen; /* maximum queue length when full */ +int totqlen; /* maximum queue length (number of packets) */ char *sigerr[NSIG]; /* signal error messages */ @@ -72,8 +82,11 @@ char *argv[]; nowarn++; break; case 'f': /* force overwrite */ - force++; + force = 1; break; + case 'r': /* read-only mode */ + force = -1; + break; case 'i': /* read input from stdin */ readinp++; break; @@ -116,6 +129,9 @@ char *argv[]; HDGRID hdg[HDMAX]; /* set defaults */ setdefaults(hdg); + /* check read-only */ + if (force < 0) + error(USER, "cannot create read-only holodeck"); /* holodeck exists? */ if (!force && access(hdkfile, R_OK|W_OK) == 0) error(USER, @@ -133,7 +149,7 @@ char *argv[]; quit(0); userr: fprintf(stderr, -"Usage: %s [-n nprocs][-o disp][-w][-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", +"Usage: %s [-n nprocs][-o disp][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", progname); quit(1); } @@ -144,11 +160,13 @@ int signo; { static int gotsig = 0; - if (gotsig++) /* two signals and we're gone! */ + if (gotsig > 1) /* we're going as fast as we can! */ + return; + if (gotsig++) { /* two signals and we split */ + hdsync(NULL, 0); /* don't leave w/o saying goodbye */ _exit(signo); - - alarm(60); /* allow 60 seconds to clean up */ - signal(SIGALRM, SIG_DFL); /* make certain we do die */ + } + alarm(300); /* allow 5 minutes to clean up */ eputs("signal - "); eputs(sigerr[signo]); eputs("\n"); @@ -204,7 +222,7 @@ initrholo() /* get our holodeck running */ maxdisk = 1024.*1024.*vflt(DISKSPACE); /* set up memory cache */ if (outdev == NULL) - hdcachesize = 0; /* manual flushing */ + hdcachesize = 0; /* manual flushing */ else if (vdef(CACHE)) hdcachesize = 1024.*1024.*vflt(CACHE); /* open report file */ @@ -259,7 +277,7 @@ initrholo() /* get our holodeck running */ sigdie(SIGXCPU, "CPU limit exceeded"); sigdie(SIGXFSZ, "File size exceeded"); #endif - /* protect holodeck file */ + /* protect holodeck file */ orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444); return; memerr: @@ -269,8 +287,10 @@ memerr: rholo() /* holodeck main loop */ { + static long nextfragwarn = 100*(1L<<20); static int idle = 0; PACKET *pl = NULL, *plend; + long fsiz; int pksiz; register PACKET *p; time_t t; @@ -284,12 +304,21 @@ rholo() /* holodeck main loop */ return(1); } else if (idle) return(0); /* all done */ - /* check file size */ - if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { + fsiz = hdfilen(hdlist[0]->fd); /* check file size */ + if (maxdisk > 0 && fsiz >= maxdisk) { error(WARNING, "file limit exceeded"); done_rtrace(); return(1); /* comes back */ } +#if FRAGWARN + if (fsiz >= nextfragwarn && + (fsiz-hdfiluse(hdlist[0]->fd,0))/(fsiz/100) > FRAGWARN) { + sprintf(errmsg, "holodeck file fragmentation is %.0f%%", + 100.*(fsiz-hdfiluse(hdlist[0]->fd,1))/fsiz); + error(WARNING, errmsg); + nextfragwarn = fsiz + (fsiz>>2); /* decent interval */ + } +#endif t = time(NULL); /* check time */ if (endtime > 0 && t >= endtime) { error(WARNING, "time limit exceeded"); @@ -299,13 +328,14 @@ rholo() /* holodeck main loop */ if (reporttime > 0 && t >= reporttime) report(t); /* figure out good packet size */ + pksiz = RPACKSIZ; #if MAXQTIME - pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L)); - if (pksiz < 1) - pksiz = 1; - else if (pksiz > RPACKSIZ) + if (!chunkycmp) { + pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L)); + if (pksiz < 1) pksiz = 1; + else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ; + } #endif - pksiz = RPACKSIZ; idle = 0; /* get packets to process */ while (freepacks != NULL) { p = freepacks; freepacks = p->next; p->next = NULL; @@ -367,7 +397,7 @@ register HDGRID *gp; for (i = 0; i < 3; i++) len[i] = VLEN(gp->xv[i]); if (!vdef(GRID)) { - d = 2/5e5*( len[0]*len[0]*(len[1]*len[1] + + d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] + len[2]*len[2] + 4*len[1]*len[2]) + len[1]*len[1]*len[2]*(len[2] + 4*len[0]) + 4*len[0]*len[1]*len[2]*len[2] ); @@ -420,6 +450,7 @@ HDGRID *gp; } +int headline(s) /* process information header line */ char *s; { @@ -433,7 +464,7 @@ char *s; HOLOFMT, hdkfile, FMTSTR, fmt); error(USER, errmsg); } - return; + return(0); } for (cp = s; *cp; cp++) /* take off any comments */ if (*cp == '#') { @@ -441,6 +472,7 @@ char *s; break; } setvariable(s, matchvar); /* don't flag errors */ + return(0); } @@ -451,11 +483,23 @@ loadholo() /* start loading a holodeck from fname */ int fd; int n; int4 nextloc; - /* open holodeck file */ - if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) { - sprintf(errmsg, "cannot %s \"%s\"", - ncprocs>0 ? "append" : "read", hdkfile); - error(SYSTEM, errmsg); + + if (ncprocs > 0 & force >= 0) + fp = fopen(hdkfile, "r+"); + else + fp = NULL; + if (fp == NULL) { + if ((fp = fopen(hdkfile, "r")) == NULL) { + sprintf(errmsg, "cannot open \"%s\"", hdkfile); + error(SYSTEM, errmsg); + } + if (ncprocs > 0) { + sprintf(errmsg, + "\"%s\" opened read-only; new rays will be discarded", + hdkfile); + error(WARNING, errmsg); + force = -1; + } } /* load variables from header */ getheader(fp, headline, NULL); @@ -495,7 +539,7 @@ PACKET *pl; p->nr*sizeof(RAYVAL)); if (outdev != NULL) /* display it */ disp_packet((PACKHEAD *)p); - if (hdcachesize <= 0) /* manual flushing */ + if (hdcachesize <= 0) n2flush++; nraysdone += p->nr; npacksdone++; @@ -504,15 +548,11 @@ PACKET *pl; p->next = freepacks; /* push onto free list */ freepacks = p; } -#if MAXQTIME - if (n2flush > 300/MAXQTIME*totqlen) { -#else - if (n2flush > 50*totqlen) { -#endif - if (outdev == NULL) - hdflush(NULL); /* flush holodeck buffers */ + if (n2flush >= RTFLUSH) { + if (outdev != NULL) + hdsync(NULL, 1); else - hdsync(NULL, 1); /* sync holodeck file */ + hdflush(NULL); n2flush = 0; } } @@ -568,7 +608,7 @@ int ec; if (hdlist[0] != NULL) { /* close holodeck */ if (nprocs > 0) status = done_rtrace(); /* calls hdsync() */ - if (ncprocs > 0 && vdef(REPORT)) { + if (ncprocs > 0 & force >= 0 && vdef(REPORT)) { long fsiz, fuse; fsiz = hdfilen(hdlist[0]->fd); fuse = hdfiluse(hdlist[0]->fd, 1);
