--- ray/src/hd/rholo.c 1997/12/16 15:45:55 3.29 +++ ray/src/hd/rholo.c 1997/12/31 20:45:31 3.33 @@ -14,6 +14,9 @@ static char SCCSid[] = "$SunId$ SGI"; #include #include +#ifndef MAXQTIME +#define MAXQTIME 5 /* target maximum seconds in queue */ +#endif /* the following must be consistent with rholo.h */ int NVARS = NRHVARS; /* total number of variables */ @@ -48,6 +51,7 @@ long nraysdone = 0L; /* number of rays done */ long npacksdone = 0L; /* number of packets done */ PACKET *freepacks; /* available packets */ +int avgqlen; /* average queue length when full */ char *sigerr[NSIG]; /* signal error messages */ @@ -59,8 +63,7 @@ int argc; char *argv[]; { int i; - /* mark start time */ - starttime = time(NULL); + initurand(16384); /* initialize urand */ progname = argv[0]; /* get arguments */ for (i = 1; i < argc && argv[i][0] == '-'; i++) @@ -88,6 +91,8 @@ char *argv[]; goto userr; } /* get root file name */ + if (i >= argc) + goto userr; rootname(froot, hdkfile=argv[i++]); /* load variables? */ if (i < argc) @@ -197,11 +202,6 @@ initrholo() /* get our holodeck running */ maxdisk = 0; else maxdisk = 1024.*1024.*vflt(DISKSPACE); - /* record end time */ - if (!vdef(TIME) || vflt(TIME) <= FTINY) - endtime = 0; - else - endtime = starttime + vflt(TIME)*3600. + .5; /* set up memory cache */ if (outdev == NULL) hdcachesize = 0; /* manual flushing */ @@ -213,6 +213,13 @@ initrholo() /* get our holodeck running */ if (*s && freopen(s, "a", stderr) == NULL) quit(2); } + /* mark the starting time */ + starttime = time(NULL); + /* compute end time */ + if (!vdef(TIME) || vflt(TIME) <= FTINY) + endtime = 0; + else + endtime = starttime + vflt(TIME)*3600. + .5; /* start rtrace */ if (ncprocs > 0) { i = start_rtrace(); @@ -226,6 +233,8 @@ initrholo() /* get our holodeck running */ freepacks = (PACKET *)bmalloc(i*sizeof(PACKET)); if (freepacks == NULL) goto memerr; + if (!(avgqlen = i/nprocs)) /* record mean queue length */ + avgqlen = 1; freepacks[--i].nr = 0; freepacks[i].next = NULL; if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) { @@ -262,29 +271,28 @@ memerr: rholo() /* holodeck main loop */ { - static int idle = 1; + static int idle = 0; PACKET *pl = NULL, *plend; + int pksiz; register PACKET *p; time_t t; - long l; - - if (outdev != NULL) /* check display */ - if (!disp_check(idle)) - return(0); - /* display only? */ - if (nprocs <= 0) { + /* check display */ + if (nprocs <= 0) idle = 1; - return(outdev != NULL); - } + if (outdev != NULL) { + if (!disp_check(idle)) + return(0); /* quit request */ + if (nprocs <= 0) + return(1); + } else if (idle) + return(0); /* all done */ /* check file size */ if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { error(WARNING, "file limit exceeded"); done_rtrace(); return(1); /* comes back */ } - /* check time */ - if (endtime > 0 || reporttime > 0) - t = time(NULL); + t = time(NULL); /* check time */ if (endtime > 0 && t >= endtime) { error(WARNING, "time limit exceeded"); done_rtrace(); @@ -292,10 +300,18 @@ rholo() /* holodeck main loop */ } if (reporttime > 0 && t >= reporttime) report(t); + /* figure out good packet size */ +#if MAXQTIME + pksiz = nraysdone*MAXQTIME/(avgqlen*(t - starttime + 1L)); + if (pksiz < 1) + pksiz = 1; + else if (pksiz > RPACKSIZ) +#endif + pksiz = RPACKSIZ; idle = 0; /* get packets to process */ while (freepacks != NULL) { p = freepacks; freepacks = p->next; p->next = NULL; - if (!next_packet(p)) { + if (!next_packet(p, pksiz)) { p->next = freepacks; freepacks = p; idle = 1; break; @@ -480,15 +496,15 @@ PACKET *pl; if (outdev != NULL) /* display it */ disp_packet((PACKHEAD *)p); if (hdcachesize <= 0) /* manual flushing */ - n2flush += p->nr; + n2flush++; nraysdone += p->nr; npacksdone++; + p->nr = 0; } - p->nr = 0; /* push onto free list */ - p->next = freepacks; + p->next = freepacks; /* push onto free list */ freepacks = p; } - if (n2flush > 512*RPACKSIZ*nprocs) { + if (n2flush > 300/MAXQTIME*avgqlen*nprocs) { hdflush(NULL); /* flush holodeck buffers */ n2flush = 0; }
