--- ray/src/hd/rholo.c 1997/11/11 11:31:54 3.9 +++ ray/src/hd/rholo.c 1997/12/01 16:34:21 3.14 @@ -9,8 +9,11 @@ static char SCCSid[] = "$SunId$ SGI"; */ #include "rholo.h" +#include "random.h" #include "paths.h" +#include #include +#include /* the following must be consistent with rholo.h */ int NVARS = NRHVARS; /* total number of variables */ @@ -38,11 +41,15 @@ long maxdisk; /* maximum file space (bytes) */ int rtargc = 1; /* rtrace command */ char *rtargv[128] = {"rtrace", NULL}; +int orig_mode = -1; /* original file mode (-1 if unchanged) */ + long nraysdone = 0L; /* number of rays done */ long npacksdone = 0L; /* number of packets done */ PACKET *freepacks; /* available packets */ +char *sigerr[NSIG]; /* signal error messages */ + extern time_t time(); @@ -55,6 +62,7 @@ char *argv[]; int force = 0; /* mark start time */ starttime = time(NULL); + initurand(10240); /* initialize urand */ progname = argv[0]; /* get arguments */ for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { @@ -125,6 +133,53 @@ userr: } +onsig(signo) /* fatal signal */ +int signo; +{ + static int gotsig = 0; + + if (gotsig++) /* two signals and we're gone! */ + _exit(signo); + + alarm(30); /* allow 30 seconds to clean up */ + signal(SIGALRM, SIG_DFL); /* make certain we do die */ + eputs("signal - "); + eputs(sigerr[signo]); + eputs("\n"); + quit(3); +} + + +sigdie(signo, msg) /* set fatal signal */ +int signo; +char *msg; +{ + if (signal(signo, onsig) == SIG_IGN) + signal(signo, SIG_IGN); + sigerr[signo] = msg; +} + + +int +resfmode(fd, mod) /* restrict open file access mode */ +int fd, mod; +{ + struct stat stbuf; + /* get original mode */ + if (fstat(fd, &stbuf) < 0) + error(SYSTEM, "cannot stat open holodeck file"); + mod &= stbuf.st_mode; /* always more restrictive */ + if (mod == stbuf.st_mode) + return(-1); /* already set */ + /* else change it */ + if (fchmod(fd, mod) < 0) { + error(WARNING, "cannot change holodeck file access mode"); + return(-1); + } + return(stbuf.st_mode); /* return original mode */ +} + + initrholo() /* get our holodeck running */ { extern int global_packet(); @@ -184,6 +239,18 @@ initrholo() /* get our holodeck running */ freepacks[i].next = &freepacks[i+1]; } } + /* set up signal handling */ + sigdie(SIGINT, "Interrupt"); + sigdie(SIGHUP, "Hangup"); + sigdie(SIGTERM, "Terminate"); + sigdie(SIGPIPE, "Broken pipe"); + sigdie(SIGALRM, "Alarm clock"); +#ifdef SIGXCPU + sigdie(SIGXCPU, "CPU limit exceeded"); + sigdie(SIGXFSZ, "File size exceeded"); +#endif + /* protect holodeck file */ + orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444); return; memerr: error(SYSTEM, "out of memory in initrholo"); @@ -304,6 +371,10 @@ register HDGRID *gp; vval(OBSTRUCTIONS) = "T"; vdef(OBSTRUCTIONS)++; } + if (!vdef(VDIST)) { + vval(VDIST) = "F"; + vdef(VDIST)++; + } if (!vdef(OCCUPANCY)) { vval(OCCUPANCY) = "U"; vdef(OCCUPANCY)++; @@ -317,7 +388,9 @@ register HDGRID *gp; creatholo(gp) /* create a holodeck output file */ HDGRID *gp; { + extern char VersionID[]; long endloc = 0; + int fd; FILE *fp; /* open & truncate file */ if ((fp = fopen(hdkfile, "w+")) == NULL) { @@ -326,14 +399,15 @@ HDGRID *gp; } /* write information header */ newheader("RADIANCE", fp); + fprintf(fp, "SOFTWARE= %s\n", VersionID); printvars(fp); fputformat(HOLOFMT, fp); fputc('\n', fp); putw(HOLOMAGIC, fp); /* put magic number & terminus */ fwrite(&endloc, sizeof(long), 1, fp); - fflush(fp); /* flush buffer */ - hdinit(fileno(fp), gp); /* allocate and initialize index */ - /* we're dropping fp here.... */ + fd = dup(fileno(fp)); + fclose(fp); /* flush and close stdio stream */ + hdinit(fd, gp); /* allocate and initialize index */ } @@ -363,8 +437,10 @@ char *s; loadholo() /* start loading a holodeck from fname */ { + extern long ftell(); FILE *fp; - long endloc; + int fd; + long fpos; /* open holodeck file */ if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) { sprintf(errmsg, "cannot open \"%s\" for %s", hdkfile, @@ -379,19 +455,21 @@ loadholo() /* start loading a holodeck from fname */ hdkfile); error(USER, errmsg); } - fread(&endloc, sizeof(long), 1, fp); - if (endloc != 0) + fread(&fpos, sizeof(long), 1, fp); + if (fpos != 0) error(WARNING, "ignoring multiple sections in holodeck file"); - fseek(fp, 0L, 1); /* align system file pointer */ - hdinit(fileno(fp), NULL); /* allocate and load index */ - /* we're dropping fp here.... */ + fpos = ftell(fp); /* get stdio position */ + fd = dup(fileno(fp)); + fclose(fp); /* done with stdio */ + lseek(fd, fpos, 0); /* align system file pointer */ + hdinit(fd, NULL); /* allocate and load index */ } done_packets(pl) /* handle finished packets */ PACKET *pl; { - static int nunflushed = 0; + static int n2flush = 0; register PACKET *p; while (pl != NULL) { @@ -402,8 +480,8 @@ PACKET *pl; p->nr*sizeof(RAYVAL)); if (outdev != NULL) /* display it */ disp_packet((PACKHEAD *)p); - else - nunflushed += p->nr; + if (hdcachesize <= 0) /* manual flushing */ + n2flush += p->nr; nraysdone += p->nr; npacksdone++; } @@ -411,9 +489,9 @@ PACKET *pl; p->next = freepacks; freepacks = p; } - if (nunflushed >= 256*RPACKSIZ) { + if (n2flush > 512*RPACKSIZ*ncprocs) { hdflush(NULL); /* flush holodeck buffers */ - nunflushed = 0; + n2flush = 0; } } @@ -520,8 +598,6 @@ int ec; { int status = 0; - if (outdev != NULL) /* close display */ - disp_close(); if (hdlist[0] != NULL) { /* flush holodeck */ if (ncprocs > 0) { done_packets(flush_queue()); @@ -540,5 +616,9 @@ int ec; } else hdflush(NULL); } + if (orig_mode >= 0) /* reset holodeck access mode */ + fchmod(hdlist[0]->fd, orig_mode); + if (outdev != NULL) /* close display */ + disp_close(); exit(ec ? ec : status); /* exit */ }
