--- ray/src/hd/rholo.c 1997/11/19 17:56:47 3.11 +++ ray/src/hd/rholo.c 1997/12/13 10:30:56 3.25 @@ -9,8 +9,10 @@ static char SCCSid[] = "$SunId$ SGI"; */ #include "rholo.h" -#include "paths.h" +#include "random.h" +#include #include +#include /* the following must be consistent with rholo.h */ int NVARS = NRHVARS; /* total number of variables */ @@ -19,16 +21,18 @@ VARIABLE vv[] = RHVINIT; /* variable-value pairs */ char *progname; /* our program name */ char *hdkfile; /* holodeck file name */ -char froot[MAXPATH]; /* root file name */ +char froot[256]; /* root file name */ int nowarn = 0; /* turn warnings off? */ -double expval = 1.; /* global exposure value */ - int ncprocs = 0; /* desired number of compute processes */ char *outdev = NULL; /* output device name */ +int readinp = 0; /* read commands from stdin */ + +int force = 0; /* allow overwrite of holodeck */ + time_t starttime; /* time we got started */ time_t endtime; /* time we should end by */ time_t reporttime; /* time for next report */ @@ -38,11 +42,15 @@ long maxdisk; /* maximum file space (bytes) */ int rtargc = 1; /* rtrace command */ char *rtargv[128] = {"rtrace", NULL}; +int orig_mode = -1; /* original file mode (-1 if unchanged) */ + long nraysdone = 0L; /* number of rays done */ long npacksdone = 0L; /* number of packets done */ PACKET *freepacks; /* available packets */ +char *sigerr[NSIG]; /* signal error messages */ + extern time_t time(); @@ -52,9 +60,9 @@ char *argv[]; { HDGRID hdg; int i; - int force = 0; /* mark start time */ starttime = time(NULL); + initurand(16384); /* initialize urand */ progname = argv[0]; /* get arguments */ for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { @@ -64,6 +72,9 @@ char *argv[]; case 'f': /* force overwrite */ force++; break; + case 'i': /* read input from stdin */ + readinp++; + break; case 'n': /* compute processes */ if (i >= argc-2) goto userr; @@ -95,8 +106,7 @@ char *argv[]; /* check settings */ checkvalues(); /* load RIF if any */ - if (vdef(RIF)) - getradfile(vval(RIF)); + getradfile(); /* set defaults */ setdefaults(&hdg); /* holodeck exists? */ @@ -107,12 +117,16 @@ char *argv[]; creatholo(&hdg); } else { /* else load holodeck */ loadholo(); - if (vdef(RIF)) /* load RIF if any */ - getradfile(vval(RIF)); + /* check settings */ + checkvalues(); + /* load RIF if any */ + getradfile(); + /* set defaults */ + setdefaults(NULL); } /* initialize */ initrholo(); - /* run */ + /* main loop */ while (rholo()) ; /* done */ @@ -125,10 +139,59 @@ userr: } +onsig(signo) /* fatal signal */ +int signo; +{ + static int gotsig = 0; + + if (gotsig++) /* two signals and we're gone! */ + _exit(signo); + + alarm(30); /* allow 30 seconds to clean up */ + signal(SIGALRM, SIG_DFL); /* make certain we do die */ + eputs("signal - "); + eputs(sigerr[signo]); + eputs("\n"); + quit(3); +} + + +sigdie(signo, msg) /* set fatal signal */ +int signo; +char *msg; +{ + if (signal(signo, onsig) == SIG_IGN) + signal(signo, SIG_IGN); + sigerr[signo] = msg; +} + + +int +resfmode(fd, mod) /* restrict open file access mode */ +int fd, mod; +{ + struct stat stbuf; + /* get original mode */ + if (fstat(fd, &stbuf) < 0) + error(SYSTEM, "cannot stat open holodeck file"); + mod &= stbuf.st_mode; /* always more restrictive */ + if (mod == stbuf.st_mode) + return(-1); /* already set */ + /* else change it */ + if (fchmod(fd, mod) < 0) { + error(WARNING, "cannot change holodeck file access mode"); + return(-1); + } + return(stbuf.st_mode); /* return original mode */ +} + + initrholo() /* get our holodeck running */ { extern int global_packet(); register int i; + /* close holodeck on exec() */ + fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC); if (outdev != NULL) /* open output device */ disp_open(outdev); @@ -143,7 +206,7 @@ initrholo() /* get our holodeck running */ if (!vdef(TIME) || vflt(TIME) <= FTINY) endtime = 0; else - endtime = starttime + vflt(TIME)*3600.; + endtime = starttime + vflt(TIME)*3600. + .5; /* set up memory cache */ if (outdev == NULL) hdcachesize = 0; /* manual flushing */ @@ -159,7 +222,7 @@ initrholo() /* get our holodeck running */ if (ncprocs > 0) { i = start_rtrace(); if (i < 1) - error(USER, "cannot start rtrace process"); + error(USER, "cannot start rtrace process(es)"); if (vdef(REPORT)) { /* make first report */ printargs(rtargc, rtargv, stderr); report(0); @@ -170,7 +233,7 @@ initrholo() /* get our holodeck running */ goto memerr; freepacks[--i].nr = 0; freepacks[i].next = NULL; - if (!vbool(OBSTRUCTIONS)) { + if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) { freepacks[i].offset = (float *)bmalloc( RPACKSIZ*sizeof(float)*(i+1) ); if (freepacks[i].offset == NULL) @@ -184,6 +247,18 @@ initrholo() /* get our holodeck running */ freepacks[i].next = &freepacks[i+1]; } } + /* set up signal handling */ + sigdie(SIGINT, "Interrupt"); + sigdie(SIGHUP, "Hangup"); + sigdie(SIGTERM, "Terminate"); + sigdie(SIGPIPE, "Broken pipe"); + sigdie(SIGALRM, "Alarm clock"); +#ifdef SIGXCPU + sigdie(SIGXCPU, "CPU limit exceeded"); + sigdie(SIGXFSZ, "File size exceeded"); +#endif + /* protect holodeck file */ + orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444); return; memerr: error(SYSTEM, "out of memory in initrholo"); @@ -202,19 +277,23 @@ rholo() /* holodeck main loop */ if (!disp_check(idle)) return(0); /* display only? */ - if (ncprocs <= 0) - return(1); + if (nprocs <= 0) + return(outdev != NULL); /* check file size */ if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { error(WARNING, "file limit exceeded"); - return(0); + done_rtrace(); + idle = 1; + return(1); /* comes back */ } /* check time */ if (endtime > 0 || reporttime > 0) t = time(NULL); if (endtime > 0 && t >= endtime) { error(WARNING, "time limit exceeded"); - return(0); + done_rtrace(); + idle = 1; + return(1); /* comes back */ } if (reporttime > 0 && t >= reporttime) report(t); @@ -223,35 +302,19 @@ rholo() /* holodeck main loop */ p = freepacks; freepacks = p->next; p->next = NULL; if (!next_packet(p)) { p->next = freepacks; freepacks = p; + idle = 1; break; } if (pl == NULL) pl = p; else plend->next = p; plend = p; } - idle = pl == NULL && freepacks != NULL; - /* are we out of stuff to do? */ - if (idle && outdev == NULL) - return(0); - /* else process packets */ + /* process packets */ done_packets(do_packets(pl)); return(1); /* and continue */ } -report(t) /* report progress so far */ -time_t t; -{ - if (t == 0) - t = time(NULL); - fprintf(stderr, "%s: %ld packets (%ld rays) done after %.2f hours\n", - progname, npacksdone, nraysdone, (t-starttime)/3600.); - fflush(stderr); - if (vdef(REPORT)) - reporttime = t + (time_t)(vflt(REPORT)*60.+.5); -} - - setdefaults(gp) /* set default values */ register HDGRID *gp; { @@ -268,12 +331,35 @@ register HDGRID *gp; sprintf(errmsg, "ignoring all but first %s", vnam(SECTION)); error(WARNING, errmsg); } + if (!vdef(OCTREE)) { + if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL) + error(SYSTEM, "out of memory"); + sprintf(vval(OCTREE), "%s.oct", froot); + vdef(OCTREE)++; + } + if (!vdef(VDIST)) { + vval(VDIST) = "F"; + vdef(VDIST)++; + } + if (!vdef(OCCUPANCY)) { + vval(OCCUPANCY) = "U"; + vdef(OCCUPANCY)++; + } + /* append rendering options */ + if (vdef(RENDER)) + rtargc += wordstring(rtargv+rtargc, vval(RENDER)); + + if (gp == NULL) /* already initialized? */ + return; + /* set grid parameters */ + gp->grid[0] = gp->grid[1] = gp->grid[2] = 0; if (sscanf(vval(SECTION), - "%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf", + "%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd", &gp->orig[0], &gp->orig[1], &gp->orig[2], &gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2], &gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2], - &gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2]) != 12) + &gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2], + &gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12) badvalue(SECTION); maxlen = 0.; for (i = 0; i < 3; i++) @@ -287,36 +373,15 @@ register HDGRID *gp; if ((d = vflt(GRID)) <= FTINY) badvalue(GRID); for (i = 0; i < 3; i++) - gp->grid[i] = len[i]/d + (1.-FTINY); - if (!vdef(EXPOSURE)) { - sprintf(errmsg, "%s must be defined", vnam(EXPOSURE)); - error(USER, errmsg); - } - expval = vval(EXPOSURE)[0] == '-' || vval(EXPOSURE)[0] == '+' ? - pow(2., vflt(EXPOSURE)) : vflt(EXPOSURE); - if (!vdef(OCTREE)) { - if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL) - error(SYSTEM, "out of memory"); - sprintf(vval(OCTREE), "%s.oct", froot); - vdef(OCTREE)++; - } - if (!vdef(OBSTRUCTIONS)) { - vval(OBSTRUCTIONS) = "T"; - vdef(OBSTRUCTIONS)++; - } - if (!vdef(OCCUPANCY)) { - vval(OCCUPANCY) = "U"; - vdef(OCCUPANCY)++; - } - /* append rendering options */ - if (vdef(RENDER)) - rtargc += wordstring(rtargv+rtargc, vval(RENDER)); + if (gp->grid[i] <= 0) + gp->grid[i] = len[i]/d + (1.-FTINY); } creatholo(gp) /* create a holodeck output file */ HDGRID *gp; { + extern char VersionID[]; long endloc = 0; int fd; FILE *fp; @@ -327,6 +392,7 @@ HDGRID *gp; } /* write information header */ newheader("RADIANCE", fp); + fprintf(fp, "SOFTWARE= %s\n", VersionID); printvars(fp); fputformat(HOLOFMT, fp); fputc('\n', fp); @@ -396,7 +462,7 @@ loadholo() /* start loading a holodeck from fname */ done_packets(pl) /* handle finished packets */ PACKET *pl; { - static int nunflushed = 0; + static int n2flush = 0; register PACKET *p; while (pl != NULL) { @@ -407,8 +473,8 @@ PACKET *pl; p->nr*sizeof(RAYVAL)); if (outdev != NULL) /* display it */ disp_packet((PACKHEAD *)p); - else - nunflushed += p->nr; + if (hdcachesize <= 0) /* manual flushing */ + n2flush += p->nr; nraysdone += p->nr; npacksdone++; } @@ -416,67 +482,20 @@ PACKET *pl; p->next = freepacks; freepacks = p; } - if (nunflushed >= 256*RPACKSIZ) { + if (n2flush > 512*RPACKSIZ*nprocs) { hdflush(NULL); /* flush holodeck buffers */ - nunflushed = 0; + n2flush = 0; } } -getradfile(rfargs) /* run rad and get needed variables */ -char *rfargs; -{ - static short mvar[] = {OCTREE,EXPOSURE,-1}; - static char tf1[] = TEMPLATE; - char tf2[64]; - char combuf[256]; - char *pippt; - register int i; - register char *cp; - /* create rad command */ - mktemp(tf1); - sprintf(tf2, "%s.rif", tf1); - sprintf(combuf, - "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH", - rfargs, tf1); - cp = combuf; - while (*cp){ - if (*cp == '|') pippt = cp; - cp++; - } /* match unset variables */ - for (i = 0; mvar[i] >= 0; i++) - if (!vdef(mvar[i])) { - *cp++ = '|'; - strcpy(cp, vnam(mvar[i])); - while (*cp) cp++; - pippt = NULL; - } - if (pippt != NULL) - strcpy(pippt, "> /dev/null"); /* nothing to match */ - else - sprintf(cp, ")[ \t]*=' > %s", tf2); - if (system(combuf)) { - error(SYSTEM, "cannot execute rad command"); - unlink(tf2); /* clean up */ - unlink(tf1); - quit(1); - } - if (pippt == NULL) { - loadvars(tf2); /* load variables */ - unlink(tf2); - } - rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */ - unlink(tf1); /* clean up */ -} - - rootname(rn, fn) /* remove tail from end of fn */ register char *rn, *fn; { char *tp, *dp; for (tp = NULL, dp = rn; *rn = *fn++; rn++) - if (ISDIRSEP(*rn)) + if (*rn == '/') dp = rn; else if (*rn == '.') tp = rn; @@ -525,24 +544,21 @@ int ec; { int status = 0; - if (hdlist[0] != NULL) { /* flush holodeck */ - if (ncprocs > 0) { - done_packets(flush_queue()); - status = end_rtrace(); /* close rtrace */ - hdflush(NULL); - if (vdef(REPORT)) { - long fsiz, fuse; - report(0); - fsiz = hdfilen(hdlist[0]->fd); - fuse = hdfiluse(hdlist[0]->fd, 1); - fprintf(stderr, + if (hdlist[0] != NULL) { /* close holodeck */ + if (nprocs > 0) + status = done_rtrace(); /* calls hdsync() */ + if (ncprocs > 0 && vdef(REPORT)) { + long fsiz, fuse; + fsiz = hdfilen(hdlist[0]->fd); + fuse = hdfiluse(hdlist[0]->fd, 1); + fprintf(stderr, "%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n", - hdkfile, fsiz/(1024.*1024.), - 100.*(fsiz-fuse)/fsiz); - } - } else - hdflush(NULL); + hdkfile, fsiz/(1024.*1024.), + 100.*(fsiz-fuse)/fsiz); + } } + if (orig_mode >= 0) /* reset holodeck access mode */ + fchmod(hdlist[0]->fd, orig_mode); if (outdev != NULL) /* close display */ disp_close(); exit(ec ? ec : status); /* exit */
